Page 8 of 8 FirstFirst ... 45678
Results 351 to 363 of 363
  1. #351
    May 2010
    Quote Originally Posted by pulsepro View Post
    Can you tell me if the crown on the Magnum clears the Krampus downtube?
    Yeah it clears it on my frame (small).
  2. #352
    Oct 2014
    Interesting thread. Thanks for the info so far.
    Has anybody tried the Fox 34 (2016) with the Chupacabra or the Knard on a Stan's Hugo or WTB Scraper rim (about 50 mm)? Heard that although the DW is 3.0 it turns out to be a little smaller than a Chupa or Knard.
    Getting a steel 29+ bike (custom frame/Krampus style). Frame will be designed around 120 mm. suspension. Was thinking about the Magnum but a Fox would be even better.
  3. #353
    Oct 2014
  4. #354
    Sep 2015
    Where did you put chase the Manitou Magnum?
    And is that 1 1/8 steer tube?
  5. #355
    wanna ride bikes?
    Oct 2013
    why is this not in 29+?
    Rigid SS 29er
    Fat Lefty
    29+
    SS cyclocross
    all steel
    "Fully rigid" isn't a thing.
  6. #356
    May 2010
    Quote Originally Posted by *OneSpeed* View Post
    Probably because the subcategory didn't exist when the thread was created.
  7. #357
    Feb 2016
    bigger is better
  8. #358
    Reputation: ak greeff's Avatar
    Hello, what size is the Dirt Wizard? Is it the 29plus version? Im wondering if a knard 29plus will fit in this fork. It looks like the Knard casing may be wider. Thanks!
    litespeed's break
  9. #359
    Jun 2013
    Quote Originally Posted by the old fart View Post
    I'm also curious about this. Anyone use a non-boosted fork with a Chupa?
  10. #360
    Mar 2012
    Current list 29+ Krampus reasonable?
    15mm 100
    Fox 34 non boost DW fits 120
    Lefty's 100/120
    Bluto 80/100/120
    Carver 120
    MRP Stage 120
    RS1 100/120
    Boost 15mm 110:
    Fox 34 27.5+ 110(custom only)/120/130
    Manitou Magnum Pro 100/110(stache OEM)/120
    Manitou Machete 120
    Pike 27.5+ 120
    Yari 27.5+ 120
    Reba 27.5+ 100/120
    SID 27.5? 100
    Lauf AC 485 60 2.8?
    Wren Sports 120
  11. #361
    Mar 2012
    I am a Clydesdale I ride a L. Mix of all Mt. and XC. Riding a 2011 Fox 32 Talas. Need something stronger. I am an beg-intermediate rider. Do you think I am a match for the Yari or do you think I need/want the Magnum/34/Pike?
  12. #362
    Oct 2011
    Yari has 35mm stantions, so stiffness should be ok. It does not have as sophisticated of a damping system, so that might make you want to spend more.
  13. #363
    Mar 2012
    Yeah but what are we really talking about here? I mean how will a 2016 Yari compare to my 2011 fox 32 which seems significantly over tasked with my riding. Plus it seems like the Yari is actually stiffer then a Pike and you can upgrade the internals to a Pike or better.
    If someone could help me understand if the difference between a Yari and Magnum Pro is significant. Seems like the Yari is stronger.
