Results 1 to 8 of 8
    Dec 2009
    Karate Monkey with 120 mm fork = Allmountain Hardtail?
    29" allmountain hardtails/trailbikes are very popular here in germany this time.
    So I compared the geometry of a few allmountain 29" Hardtails and took the calculator…
    Karate Monkeys geometry is suspension corrected for 80 mm forks.
    So what happens to the geo, if I take a 120 mm fork?
    Front is coming 40 mm higher -> good for descents
    Steering angle goes down from 72 deg to 70 deg -> more stable going downhill. OK, not the angle of a real AM/Trailbike (about 68-69 deg) but you should feel the difference.
    Seat angle goes down from 73 deg to 72 deg -> not so good for uphill, but if you use a setback seattube, you can compensate this with a non-setback one
    BB drop goes down from 68 mm to 59 mm -> some AM hardtails (e.g. Kona Honzo) have such values and so it should be OK.
    Has anyone tried a Karate Monkey with a 120mm fork and can write about it?
    MTB B'dos
    Reputation: LyNx's Avatar
    Nope, no one.
    I think you mis-calculated the height of the BB, AFAIR it went up a lot more than 11mm, but I liked the tall BB, less pedal strikes. I liked it, but since the frame wasn't designed for it by 40mm I decided to not ride it like that for safety reasons, although it most likely wouldn't do it anything.
    Reputation: Jstews's Avatar
    Oct 2011
    Interesting. Come spring, I'm planning to split the difference and put a 100mm Reba on my KM. I figured that the slight slackening/BB raising might do the Karate Monkey some favors.
    I have a 100mm travel reba on mine. Works great. With a little sag, it comes out just right.
    Always Learning
    Reputation: BruceBrown's Avatar
    Quote Originally Posted by Jstews View Post
    Mine resembles those remarks.
    <a href="http://www.flickr.com/photos/7166535@N05/8285454455/" title="P1010002 by BBcamerata, on Flickr"><img src="http://farm9.staticflickr.com/8062/8285454455_7f8bfc86ef_z.jpg" width="640" height="469" alt="P1010002"></a>
    And for the OP - I'm typing this post on my way back from Germany to the US (was in Schorndorf near Stuttgart the past 8 days).
    Reputation: bikeuphill9's Avatar
    100 seems to be perfect for my KM. It is not quite as spirited on the climbs, but screams on the way down.
    "Don't take life too serious. You'll never get out alive."
    MTB B'dos
    I actually think a travel adjust 90-120mm fork might be the ticket if you're really wanting to use the KM as such, not sure though still if I'd trust the HT.
    Mar 2013
    i have a buddy with a KM on a 120... i will see if i can get some pics. he loves the ride, i have pedaled it a bit and it feels a bit strange to me
  1. Replies: 6
    Last Post: 03-15-2013, 10:58 AM
  2. Karate Monkey fork on Paragon?
    By JonathanGennick in forum 29er Bikes
    Last Post: 05-20-2012, 08:37 AM
  3. 120 mm Fork on a Karate Monkey??
    By neilether in forum Surly
    Last Post: 04-23-2011, 07:55 AM
  4. G2 fork on Karate Monkey?
    By lucero in forum 29er Bikes
    Last Post: 04-21-2011, 11:08 AM
  5. Karate Monkey Sus Fork Recommendations
    By terrysol in forum 29er Bikes
    Last Post: 03-10-2011, 01:19 PM
