Page 2 of 2 FirstFirst 12
Results 51 to 88 of 88
  1. #51
    meh... whatever
    Reputation: monogod's Avatar
    Feb 2006
    Quote Originally Posted by jkidd_39 View Post
    Pics please?!
    A man willing to customize a frame with a hacksaw is someone that needs to be taking lots of pics..
    I like your style sir!
    wish granted!
    pretty much just pulled it out of the box and cut it before i even unwrapped it.
    before the mod:
    about to cut:
    the cut:
    finished product:
    more info and pics here and here.
    "Knowledge is good." ~ Emil Faber
  2. #52
    Pixie Dust Addict
    Quote Originally Posted by FoShizzle View Post
    why? just like carbon...and 29er wheel size...and 650b....and suspension.....and hydraulic brakes....absolutely no reason whatsoever other than MARKETING and thank goodness for companies that retardation runs rampant in the MTB community.
    there is nothing better about any of the aforementioned dynamics, to include belt drives, other than to pose a little better at the trailhead to compensate for your insecurities.
    the only radical improvement in the entire MTB market that is tangible is a gravity dropper post.
    I have to say that my single speed cred on our weekly club rides went through the roof when I rolled up on my belt drive Ventana. I really enjoy it when the belt is clean and my bike is silent when I'm pedaling. I've never had a problem with the belt breaking or derailing, even when my 200+ pounds are mashing the pedals as hard as I can to make it up a climb. With Industry Nine hubs, the connection from my feet to the rear wheel feels more direct than any other bike I've owned. The only downside I've experienced is when I ride in dusty conditions much, the belt will start making noise and I need to clean it with soap and water and put some silicone spray lube on it to quiet it back down.
    If I was going to do it again, I would definitely keep my options open and get a frame that was belt-capable.
  3. #53
    Rogue Exterminator
    Reputation: kjlued's Avatar
    Quote Originally Posted by PoisonDartFrog View Post
    So, to summarize:
    Cons:
    Limited to single speed No, you can get internal geared hubs
    Need a special frame Yes
    Non-repairable if it breaks, must be entirely replaced Yes
    Pros:
    Slightly more efficient than a chain (debatable) I would say the opposite and not debatable since it is on Gates own website
    Slightly less maintenance than a chain I would say a lot less since other than hosing it off I have done nothing to maintain mine in almost 1000 miles
    Novelty factor I guess. It does strike up a lot of conversations but I like chatting with people.
    Just stick it in granny and start grinding.
  4. #54
    psycho cyclo addict
    Reputation: edubfromktown's Avatar
    So, to summarize:
    Cons:
    Pros:
    Novelty factor
    I'll add:
    According to long time local guru who was a huge proponent until ~6 months ago:
    Better chance for success for a belt implementation on a road/cross frame where there aren't so many rocks, logs, etc.
    Best use case of all is on commuter bike.
    I'm sticking with ring/cog and Whipperman White Star 108 mondo beefy chain on my latest rigid 29er creation.
    【ツ】 eDub 【ツ】
  5. #55
    meh... whatever
    Feb 2006
    i'll add that neither a belt nor a chain are designed or suited for constantly bashing rocks and logs and NEITHER will hold up well doing so. thus, for someone who's constantly bashing logs and rocks with their chainring a belt wouldn't be a good choice and they should go with a standard chain setup with a beefy bash guard. or learn how to properly clear obstacles.
    sounds like your "guru" was using parts for applications they weren't designed for, has poor riding skills (or both) yet then wants to bad mouth the equipment.
    weak sauce...
  6. #56
    psycho cyclo addict
    Sure- neither belt or chain are designed for contact with rocks or logs however, particularly the latter happens on trails at times for me and I imagine others too (some logs are too large for my aging/sagging bones to get all air over).
    I've run all my single speeds with no bash guard and they've left an imprint on many logs with no ill effects on chain or ring. I had run cheapy Nashbar 8-speed chains on my SS and now have gone to beefier Whipperman's that are reminiscent of a smaller version of a moto chain.
    The big rings on my geared bikes have also left plenty of bite marks in wood and haven't ended up worse for wear either (occasionally a rock hit has bent or snapped a tooth- like 1 out of 40 which is no biggie over 3-4 years of hammering on it).
    The gent I speak of has mucho MTB skills of long duration- gravity stuff too (freeride, pump track, ...) that I no longer mess with. He had also ridden a belt drive for years.
    He launches off TTFs such as this for example:
    【ツ】 eDub 【ツ】
  7. #57
    Rogue Exterminator
    The funny thing is, most the belt hatters have never had one.
    The majority of those who have had one and don't like them, were 1st gen belt owners.
    There is a very small percentage of people that have had the new system and don't like it.
    Is it perfect? No but neither is a chain. So if you haven't had one or hadn't had experience with one then maybe you really shouldn't comment on it no matter what guru or who's friend's uncle's brother's coworker's bike mechanic said.
    Mine goes through some of the worst conditions possible 50+ miles a week for 6 months now with zero issues. Not one squeak, slip, etc. My trails are always wet, muddy sandy, rocky, etc and I have hit a few rocks and logs with it too. Anyone who has ridden Pisgah or anywhere else in Western NC can vouch for that. So far, it gives me a lot less grief than my chained bike.
    Also, Monogod has been around a while and has way more experience with Belts than me. I don't think he would have cut the frame of his Surly if the belt was purely a novelty.
    I still guess I probably should eventually buy a spare belt to have on hand for when this one does eventually break so I don't have any down time but I doubt I will carry it around with me.
  8. #58
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    Quote Originally Posted by yourdaguy View Post
    Zero maintenance for 10,000 miles.
    Quote Originally Posted by Max24 View Post
    That's a pretty good reason over there.
    It's also complete BS... like about 95% of what he posts, unfortunately.
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
  9. #59
    Quote Originally Posted by jomissa View Post
    Why?
    Just because... something different, new and cool to play with and push the envelope.
    There's a reason you don't see belts on dirt bikes.
  10. #60
    meh... whatever
    Feb 2006
    Less efficient than a chain especially the newest incarnation. And not really debatable, since Gates admits this.
    from their website:
    At the core of the drive is the CenterTrack belt. Custom made, this 11-mm pitch, carbon-fiber belt is stronger than and as efficient as a traditional bike chain.
  11. #61
    4 Niners
    Dec 2008
    That is from marketing, they rounded up. I read an interview with the engineer (a woman by the way) who admits it is less efficient.
    Full rigid SS, Hardtail SS, Hardtail Geared, Full Suspension Geared.
  12. #62
    where?
    Quote Originally Posted by monogod View Post
    from their website:
    He just makes things up. I think some call it pathological.
    Nice avatar, btw.
  13. #63
    Do all the Harley Davidson riders carry an extra belt?
    Is there a single off-road motorcycle that uses a belt drive?
  14. #64
    meh... whatever
    Feb 2006
    produce it.
    more propaganda from gates' website of lies:
    Repeated testing has found new belt drives equally efficient to new chain drives, including a third party test evaluating the Carbon Drive system on a bicycle.
  15. #65
    Reputation: jkidd_39's Avatar
    Sep 2012
    Monogod, thanks for the pics. Great idea to use that spot to cut.
    And to this huge sh!tshow of a thread.. a Harley or any cruiser belt drive system vs. a Gates system is a gigantic apples vs. oranges comparison. And if you don't see that then please do not post in this thread.. cuz your retarded..
    Those systems have a tensioning system that could crush your hand.. ohh and it's a floating system so it will grow and move.. The Gates system is nothing of the sort.
    I think we have already established that the gates system is pretty much a niche type system that will reward someone with mechanical know how or at least will invest the time to screw with it enough to get it right..
    Does the efficiency of the gates vs. traditional chain really make or break the one guy on this thread looking to get one? Nope.. they will buy it or they won't.. but no one will be swayed by 4%. and If they are they are prob a jackass anyways.
    If you wanted to compare a belt drive system prevalent in the market then you would look at the clutch drive system the RZRs use. And the reason they use them is you can shred the belt instead of eating clutches.. This is still an apples to oranges comparo but it's closer than a motorcycle system.. The main advantages of the belt drive on motorcycles is the reduction in noise and smoothness of a belt system.. added plus of not chain growth.. which is pretty much a non issue on 99% of crusiers cuz most guys put almost no miles on either system.. if your stretching chains on a moto your prob at a track eating miles like no other or you are being some sort of tool and abusing the bike..
    That 1% I spoke of prob eat serious highway but to stretch a moto chain takes a long time..
    and besides crusiers are for the homosexuals or mid-life crisis folks..
    let the games begin...
  16. #66
    Reputation: theMeat's Avatar
    If they could engineer/figure a way to make a clutch like this (cvt) work imo it would be freakin awesome. This type clutch puts the load where the max rpm/output is automatically/by design which is an obviously good thing. But the output of an engine is constant/predictable, where a riders energy varies. And the weights and springs take energy to work, and that energy would only be coming from the rider. As well as the sheaths of the clutch contact the sides of the belt for contact, unlike the groves and gears on the bicycle systems of topic, which makes dirt/dust/slippage much more of an issue too.
    Round and round we go
  17. #67
    snatched from the misplaced response that polluted the tubeless brew thread:
    Ok, so JH found that chain drive was 98.6 percent efficient. So instead of me saying that a chain drive is 98% efficient, I should now round that to 99 % efficient? I will update my spiel.
    What you claimed as the efficiency of the chain is not the issue.
    I'm curious why you ignored the fact that measured efficiency ranged from 81% to 98.6%, only referenced the highest value recorded, and now present that as if all chain drives are that efficient.
    Typical error from someone that has never ridden a bike and is a researcher.
    Error? By your judgement? lol
    It's actually a pretty typical selection from someone actually employing the scientific method to try and control variables so that their results mean something. Jason Smith uses the same methodology, not surprisingly.
    Your "butt dyno" is meaningless.
    Oh, and Spicer rides bikes.
    btw: here's Smith's set-up:
    and here is Spicer's:
    It is ridiculous to attack the research that you disagree with by saying it is not real-world and then turn around and cite bench tests from someone else who uses a nearly identical set-up.
    So the CyclingNews experiment that is about a year old with the current technology says that a chain with no tension is almost 100% efficient (maybe they meant 98.6) and a 15 year old study (the JH study was done in 1999) that was done before cellphones were invented with all new parts and probably eliminated bearing efficiency says that increasing tension is more efficient.
    Cell phones are definitely relevant.
    Smith's results do not show what you claim (surprise).
    I realize that pointing out the pervasive and blatant disregard for facts in your posts is like pissing in the wind, so I'm not going to engage that.
    Also, you site a study that says that increasing tension is more efficient for chains and the question is whether more tension is more efficient for belts.
    I just pointed out that the Cycling News article contradicted some peer-reviewed scientific work on a similar topic... you're the one who delved into the article in an attempt to confuse the issue evade the question about where your "Gates admits 93%, it's not debatable" came from.
    I'll point out that the scientist you like reported a 1W difference between a typical chain and the Gates drive.
    At the constant 250W loads he uses that's an efficiency difference of 0.4%.
    That is not the point of this thread.
    I know it's not. You took it there.
    I complimented you for contributing, but you are again resorting to your normal obfuscation/confusion/BS/take them off the topic spiel.
    lol
    pot, meet kettle.
    you somehow come here to dominate not just me, but many of the posters.
    I come here to learn and contribute like most people. When posters like you spew blatant misinformation it is detrimental to the community. People might actually believe some of the stuff you say.
    If someone posts something that is not in conjunction with what you know, instead of telling the internet that they are an idiot (in so many words); just post what you think is the correct information
    That's mainly what I do.
    You are probably the most prolific repeat poster of misinformation I've seen across an incredible range of topics and you post a lot in the forums I read, which is why we cross paths.
  18. #68
    Apr 2005
    Quote Originally Posted by theMeat View Post
    I think that it would be tough to make it work right at the very low RPM of a cyclist. The gear ratios are determined by the centrifugal force on the pulleys. Moreover, even if you could make it work, you'd be losing a lot of efficiency in friction between the sides of the belt and pulley.
    That said, it would be probably be quite marketable just because of the sheer awesomeness.
    '12 Santa Cruz Superlight 29 | '12 Santa Cruz Butcher | '06 Specialized Allez Comp | '81 Schwinn Converted Fixie
  19. #69
    meh... whatever
    Feb 2006
    a cvt for bicycles has been available since 2007 (nuvinci) and gates makes a cog for them. the new n360 is a vast improvement on the original, just as the cdx is over the cdc.
  20. #70
    Call it what you want but that's nothing like the clutch Jkid, Ghost and I were referring to, but it looks promising.
  21. #71
    meh... whatever
    Feb 2006
    in over your head again, meat, as i said nothing of the sort. although they are both continuously variable transmissions at no time did i state, imply, nor could anyone with even moderate reading comprehension infer that i was drawing a similarity between the functional design of either the operation or "shifting" of the two CVTs.
    what i said is simply that a CVT has been available for bicycles since 2007 (nuvinci) and that gates made a cog for it. in other words, a belt-driven CVT has been available on bicycles for quite a while and both components were superior to their predecessors. nothing more, nothing less.
    so in your haste to be argumentative and confrontational you errantly inferred that which was neither said nor implied.
  22. #72
    Say what? I even said it looks promising and I'm hastefully confrontational?
    When it comes to the cvt that was being discussed i'm not in over my head with many, and i'm also not ashamed to admit i don't know something (hint). Like I don't know squat about bicycle belt drives, except for the fact that everyone i know that's tried it has gone back to a chain. Albiet none of them were as smart as you think you are lol. As well i think it's cool that people try to experiment with new tech, whether it's an attempt to be a show stopper or not. And i also think it's cool of you to share your experience with this, whether or not it's another look at how smart and cool I am attempt on your part. It's not surprising that you're the expert and absolute authority on everyfreakinthing that comes up, no matter how unrelated, and that you buddy around with everyone who bows to or agrees with you, and turn righteous troll psycho on everyone who doesn't. Except of coarse the mods which you kiss up to. Sorry if it's surprising to you that people can figure this out.
    Wish you could stay OT for once but go ahead, say whatever you want, it changes nothing, that's the way it is with you. If it makes you feel better to let you think you're one up on me by having the last word on any thread we're on that's fine. Even if the truth is I let you have the last word because i know you must and I just want you to stfu. Now, to leave this on a positive note, like i thought i did with the previous post, it's appropriate to say that many find you entertaining, and your grammar is excellent.
  23. #73
    meh... whatever
    Feb 2006
    wow.
  24. #74
    Saving lives with knives.
    Reputation: frank daleview's Avatar
    It would seem to me that of all the "problem" places to attack on current bike design, the chain is a pretty poor place start. The chain can easily be repaired or modified to suit the needs of it's user, it is efficient enough that any gains would be irrelevant, and it is not particularly heavy.
    Now, since these are used on single speeds... I would be very interested in chain tensioner that worked without creaking or requiring constant adjustment...
    Formerly known as iceaxe
  25. #75
    meh... whatever
    Feb 2006
    Quote Originally Posted by frank daleview View Post
    curious about a couple things... where'd you get the impression the impetus of the belt was to attack the "problem" of the chain? have you ever ridden a belt drive?
    discounting the below, what do you see as problem places of current bike design and which would you rectify first?
    wish granted!
    just a few:
    • niner biocentric 2
    • spot's kobe sliders
    • carver's sliders
    • carver's delron wedge ebb
    • philcentric ebb
    • WI eno eccentric hub
    • good old fashioned track ends
  26. #76
    Actually, I have ridden a belt drive, it's quiet, and smooth. There seemed to be an awful lot of tension on the belt. Other than that I really didn't perceive any other differences, granted I never took these on a trail or rode it very hard. I imagine they won't stain your fancy linen pants or while riding--I would get one for a city cruiser.
    I think it is a very reasonable assumption that the impetus for belt drive development was to overcome some of the shortcomings of chain drive for certain applications... or are you suggesting it was designed purely as a novelty?
    With respect chain tensioning:
    I am currently on my second air 9 carbon frame utilizing the Biocentric 2 and thus far I am unimpressed, yes it stays put, unlike my friends Gary fisher with sliders that constantly slip, however it constantly creaks and pops. Unfortunately the ENO is not recommended for most carbon frames. The others I have not had the opportunity to try. I am very interested in the system on the new Ibis 29er.
  27. #77
    I ran belt drive for about year and a half. Worked fine I ran a bashquard with the belt drive so I didn't have a belt problems.
    One thing I didn't like is the amount a tension required for the belt drive. I think it affects bearing wear in the rear and in the bottom bracket bearings. Also it would squeak in the right dry dusty conditions. Believe there is a little more resistance then a chain also. Anyway I went back to chain, easier to switch ratios, and cheaper.
  28. #78
    meh... whatever
    Feb 2006
    Quote Originally Posted by quicksilverta View Post
    the original CDC system required a lot of tension to operate properly, and was detrimental to both bb and hub bearings. the current CDX system requires MUCH less tension, and is superior to the original CDC in many other ways as well - including being as efficient as a chain (which the CDC system was not).
  29. #79
    Yep I have the new CDX system. I disagree, I used the iphone app to set the tension to gates recommended tension. Set it around 75 Hz. Checked with a iphone5 and a iphone4s.
  30. #80
    meh... whatever
    Feb 2006
    that's the problem. setting the belt with the iphone compared to the gate's krikit has routinely resulted in much higher tension, sometimes as much as 40 lbs too much.
  31. #81
    Looks like it works fine....
  32. #82
    meh... whatever
    Feb 2006
    fwiw, i wasn't sharing his experience or commenting on an interweb vid clip, i was sharing my experience using both back to back in nearly a score of instances. in every case using the app resulted in both higher and inconsistent tension vs the krikit. we also tried using a straight frequency analyzer on an android with similar results.
    imho everyone running a belt drive should own a krikit just as everyone running a chain drive should own a chain tool.
  33. #83
    Thanks for the info, sounds like gates should pull the app and stop telling people to use it.
  34. #84
    Rogue Exterminator
    I fail to see how anyone would think an app on a cell phone would have any value in properly setting the belt tension. I would much rather use the German method of gutenuf.
  35. #85
    meh... whatever
    Feb 2006
    no, i was suggesting that despite being room for improvement in certain applications that the chain is not an intrinsic problem area lagging behind in development that needed to be addressed. i would also suggest there is a difference in refining a final drive system verses it inherently being one of the ""problem" places to attack on current bike design". all other areas of the bike from suspension, ders/shifters, component materials, and even shift cables are constantly being refined - INCLUDING chains. look at the new 10 and 11 speed stuff.
    it would also seem, as another poster pointed out, that most of the people railing against it haven't actually ridden it for any length of time either on or off road. your admission being case in point. and i'm not sure which system you used, CDC or CDX, or if it was properly set up but a properly set up CDX system doesn't require excessive tension.
    i will wholeheartedly agree with you that one application where a belt drive really shines is in urban commuter scenarios - particularly when riding in mucky weather. but since my fancy linen pants are black it really doesn't matter if they happen to get a little grease on them or not.
    Quote Originally Posted by daleview
    i was just sharing tension methods that i have personally found to be both solid and squeak free. ENO eccentric can be used on a carbon frame provided it doesn't have a carbon dropout. i ran one on a first-gen superfly for a while. and notice i was very specific in which sliders i referenced. despite being of similar design it's odd that some mfg's sliders grip and are quiet while some are not.
    the tranny's tensioning system is intriguing indeed, and i'm keeping my eye on it too. would like to get one in my hands to fiddle with.
  36. #86
    Reputation: Zerort's Avatar
    Jan 2013
    To revive a dead thread - the tension system on the IBIS Tranny doesn't even need to be used if you run certain ratios and belt length.
    For instance, I am currently running a 42 x 24 with a 113T belt and the chain stays are in their shortest setting against the frame. This is also true with a 46 x 24 with a 115T belt if I recall correctly but that did have a bit more tension on the belt that I was comfortable with and the gearing was wrong for what I ride.
    One other thing I like about the belt is that it is a bit lighter.
    by Silentfoe
    I'm satisfied knowing that what I wear during my "day" job makes me more of a man than you'll ever be.
  37. #87
    Jun 2015
    Quote Originally Posted by Zerort View Post
    What mountains are you riding that you can pull a 42/24 or a 46/24?
    I don't IBIS anymore but that must be a city bike. And maybe for city bikes this 'advancement' may be appropriate.
    I have only known two people in my life with a belt drive. One reverted to a chain and the other sold that belted bike.
    Now we have an internet debate, an iphone app for belt tension, a kit that supposedly works better to set tension, etc etc. All for a belt drive that, at best, is equal to the efficiency of a chain and at worst is a few degrees less efficient, but requires less maintenance, but a different sort of frame, the addition of some sort of tensioner, and is not field repairable nor is it easy to change gear ratios.
    Not to mention I can walk to any one of the 4 bikes shops in town here and buy a SRAM, Shimano, and in one of them, a Campagnolo chain.
  38. #88
    Jan 2013
    Quote Originally Posted by Schlug View Post
    Mountains? I live in Michigan.
    Not a commuter bike.
    by Silentfoe
  1. belt drive
    By JUNGLEKID5 in forum Singlespeed
    Last Post: 04-14-2013, 05:30 PM
  2. Belt drive?
    By slopok in forum Singlespeed
    Last Post: 04-08-2013, 08:46 PM
  3. Belt Drive
    By Graham77 in forum Fat bikes
    Last Post: 03-06-2013, 08:21 AM
  4. MTB Belt Drive CVT..........Please?
    By NEPMTBA in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-05-2012, 01:28 PM
  5. I'm DONE with Belt Drive!
    By drMP in forum Singlespeed
    Last Post: 04-30-2011, 11:29 PM
