Results 1 to 21 of 21
Thread: Is that joke?
    Nov 2008
    Is that joke?
    i just order and received two 29er frame from on-one uk,
    once i open it and found one of the frame was cracked at headset area,
    then more interesting things coming,
    the dice side dropout they gave me didn't match the frame at all,
    also each frame needed 4 bolts, they only just gave me 4 bolts, then what about the other frame?
    umm.... what can i say, never has that horrible experience in online shopping,
    Sent from my GT-N7105 using Tapatalk
    Attached Thumbnails Attached Thumbnails Is that joke?-uploadfromtaptalk1406534685986.jpg
    May 2012
    That HT is from shipping damage, not really their fault. Perhaps some of the packaging was misplaced.
    Quote Originally Posted by meltingfeather View Post
    If I told you I saw a unicorn ****ing a leprechaun trail side, you'd probably be suspicious.
    Nov 2008
    回覆: Is that joke?
    no
    the packing was so nice inside the box, must be hit by someone before packing
    Attached Thumbnails Attached Thumbnails Is that joke?-uploadfromtaptalk1406557062422.jpg
    Pirate!!!
    Reputation: Captain Cobb's Avatar
    Did you contact OnOne about this yet? Don't be "that" guy. The one who likes to raise cane about a problem before giving the supplier the opportunity to make good. Last I checked we are all human, and we make mistakes from time to time. If they fail to make good on this, then flame on!
    aka "SirLurkAlot"
    I've dealt with them since '03. I have always found their customer service to be top notch. Things can and may have changed but I would contact them before going any further. Per Captain Cobb, don't be "that" guy.
    Reputation: DeeZee's Avatar
    Jan 2005
    Quote Originally Posted by bbbbking View Post
    How many threads are you going to start on this issue?
    box open and found the frame was cracked
    ballbuster
    Reputation: pimpbot's Avatar
    Least you can do is contact the manufacturer, and then report back here about how awesome their customer service was when you get your issue handled... and how much you believe that mistakes happen and are willing to forgive.
    Reputation: Gasp4Air's Avatar
    These are all good responses. OnOne may just surprise you if you give them a chance. Of course, the alternative is to keep it and harbor a grudge all the way to your grave.
    Use it, use it, use it while you still have it.
    Crash Dummy In Training
    Reputation: PauLCa916's Avatar
    Jun 2013
    Quote Originally Posted by Captain Cobb View Post
    Amen it's not like it's their fault there was damage during shipping.
    All shipping companies have damage.
    As for the wrong part's I would bet they have no problem replacing them.
    2015 Flyxii / ENVE /Chris King Carbon 29'er H.T.
    SRAM XX1
    2012 Stump Jumper Comp 29'er H.T. SRAM XX1
    1997 Rock Hopper / Rock Shox Recon Silver / 1 x 10 SRAM X9 XO Mix XT V Brake system
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Maybe if you complain more they will hack the mtbr database and then hire a private detective to get your contact info. Just sayin, it's an option...
    Reputation: Fix the Spade's Avatar
    Quote Originally Posted by PeopleForScience View Post
    Inadequate packaging is always the sellers fault, if you're running a mail order business there's no excuse for not knowing that shipping companies are staffed by angry gorillas.
    Also, I had this exact problem with an On One Whippet four years ago and asked them to pad the head tube on the replacement, which they did not and apparently still don't.
    Jan 2005
    After further investigation it was determined that bbbbking dropped the frame after unpacking causing the damage.....to be continued..
    Actually the On-One guys are very much in touch with mtbr.
    Also, the brake mounts inside the triangle on most of the On-Ones...that dropout gets flipped over.
    Jun 2013
    The headtube's metal "base" (I forgot the exact word I wanted to say) was most likely bend before packing the frame.They didn't even care to check, or just abandon that frame.I doubt it that they didn't notice it.
    Send them an email, don't dispute on paypal or anything.Wait for their response, accidents like these happen.If they are not eager to refund you/Send you a new frame then you can continue with a dispute.
    Quote Originally Posted by MOJO K View Post
    Even if that's the case (have seen some on-one feedback from years ago, but nothing recent in the fatbike forum), "hoping" someone will contact you because you made a post on a website and didn't take the time to call or contact the company is the real "joke".
    I was more pointing out that if the OP ends up being "That Guy," and was to blow up on this, On-One would probably be aware.
    I don't think it would change how they handle things on their end...they're very good.
    Lone Wolf
    Reputation: Osco's Avatar
    Apr 2013
    Trolls,,,pfft.
    Reputation: shiggy's Avatar
    Dec 1998
    Re: Is that joke?
    There are both types of Swapouts (for vertical dropouts), inside brake mount and outside brake mount (as the OP has). The real issue here is unless the Lurcher frame has been modified in the last 18 months the outside brake Swap out does not fit. You need the inside version.
    mtbtires.com
    And THAT is why you're the super-moderator!!
    Not sure if I ever said it, but Shiggy, thank you for being so helpful to everyone here. You're the man.
    Dec 1998
    Re: Is that joke?
    Nothing to do with being a SMod. I did work for On-One for two years and dealt with the Lurcher daily.
    mtbtires.com
    Oct 2016
    A satisfied customer MAY tell one person. A dissatisfied customer WILL tell ten. Just sayin'
    Yes, a Necro thread But thinking of building another bike. This company still good with customer service?
    DAMN THE MUD, FULL SPEED AHEAD!!
  1. Fox forks are a joke...
    By Thimk in forum Shocks and Suspension
    Last Post: 02-20-2014, 03:21 PM
  2. What a joke...
    By luckybastard in forum Arizona
    Last Post: 02-14-2014, 01:05 PM
  3. I thought this was a joke...
    By Uncle Six Pack in forum Downhill - Freeride
    Last Post: 01-07-2013, 12:27 PM
  4. is it a joke?
    By car bone in forum Where are the Best Deals?
    Last Post: 07-09-2012, 10:21 AM
  5. OT : Beaver joke
    By David C in forum General Discussion
    Last Post: 12-07-2011, 03:50 PM
