Results 1 to 6 of 6
    HOV
    HOV is offline
    Reputation: HOV's Avatar
    Jabberwocky frame prep?
    Hello all
    I'm replacing my current frame with a Vassago Jabberwocky. Would like to know:
    1. Does Vassago face the BB shell & headtube from the factory?
    2. Does it matter if there's a little paint in the BB shell threads?
    3. If the frame has been faced, does it matter if there's paint on the faced area, or should that be scraped off prior to (Ext. Bearing) BB installation?
    I've searched the subject but only came up with a few mentions, I want to be sure on the facing issue before I continue on with the build.
    Muchas gracias amigos!
    Reputation: Captain_America1976's Avatar
    Mar 2005
    They claim to do that. My current Jabberwocky came faced and chased. If you are asking about paint in the faced area and paint in the BB threads it doesn't sound like it was done. If it was it wasn't done very well.
    You should also treat your frame with Frame Saver of Boeshield T-9 to prevent rust prior to completing the build.
    Reputation: Gasp4Air's Avatar
    Quote Originally Posted by Captain_America1976 View Post
    If in doubt, you can take the frame to a shop - facing the head tube and bottom bracket is not a big deal.
    BTW, in case it's not obvious, the frame treatment (Boeshield, etc) is for the INSIDE of the frame to protect rust prone steel from corrosion.
    Use it, use it, use it while you still have it.
    HOV
    HOV is offline
    Yes, I have a can of frame saver that I plan to apply tonight. On the inside. LOL, it never hurts to be clear!
    I've had other frames chased and faced at my LBS, but if the frame was faced from the factory I don't want to do it again. Chasing I don't care so much about, but facing a frame twice, no thanks.
    Captain America - was there paint on the leading edge of your BB shell when you got your frame?
    Mar 2005
    Quote Originally Posted by HOV View Post
    I don't remember. Sorry
    May 2005
    Claimed to be done at the factory. I have owned at least 5 Vassago's and have not needed to do it again. Frame saver, and build has been fine with mine.
  1. 456 Carbon Frame Prep?
    By dslfoolish in forum On One
    Last Post: 07-16-2012, 03:24 PM
  2. Frame prep....need a shop
    By dormad in forum California - Socal
    Last Post: 04-28-2012, 10:01 PM
  3. Chilcotin frame prep...
    By TSC in forum Knolly
    Last Post: 04-27-2012, 11:58 PM
  4. Surly Frame Prep ... just DIY
    By estabro in forum Surly
    Last Post: 03-06-2012, 12:35 PM
  5. New frame, headset prep??
    By anesthesia-matt in forum Bike and Frame discussion
    Last Post: 08-21-2011, 06:51 PM
