Do it already!!! Massive improvement over my 2013 Fox 34 Float 140mm. This fork is superbly supple, almost coil like. Also unlike my Fox 34, you can use all the travel on this fork. I moved the slider indicator all the up to the top of the stanchion on some bigger drops and jumps. With the Fox 34 I could never use all the exposed stanchion although I don't think you can on this particular fork even without air in it.
The stanchion length is pretty identical on the Pike vs. Fox 34, but the crown/steerer junction is much taller on the Fox and that makes up the difference in A-C length between the two.
Also for you people on the fence about going with the 140 or 150, compared to my Fox 34 140mm Float...
The Pike 150mm 51mm offset is approximately 7mm shorter than the Fox 34 in terms of Axle to Crown measurements. So it is like 10mm free travel, especially if you are already running a Fox 34 140mm.
Also the Pike 150mm weighs 4.3 lbs with full length uncut steerer, crown race and axle vs. 4.57 lbs for the Fox 34 with trimmed steerer, crown race and axle.
So take my advice, get it and while you're at it get the 150mm too.
I also have a Pike in 140mm 51mm offset that I plan on using on my Ripley when it comes in. I'll have to compare it versus the Fox 34 and 140mm Revelation that I have when I start the build.
Also, what's a thread about new gear without pics? Useless.
