Results 1 to 5 of 5
    Oct 2017
    I9 Enduro S 29er
    I am buying some Industry 9 Enduro S wheelsleets. Internal width = 30.5mm/Outer Width = 34.1 mm. Website says these are rated for 2.3" - 2.8" tire sizes. They obviously don't make 2.8" 29er tires, so will this wheelset be sufficient for 29er 3.0. Let's say WTB Ranger 3.0s?
    You can run them, but you'll have to use higher pressure than if you use a wider rim. Cuts somewhat the value of the wider tire's potentially larger footprint for traction.
    WTB makes 29 2.8's
    Feb 2018
    Ibis 942's might be better for you
    Oct 2017
    I am trying to stay under 1K for pricing. I did look into your Ibis recommendation and saw that they have an aluminum wheel set that 38 mm OW/ 34 mm IW. The 942s have an IW of 35 mm. With that difference being 1 mm (hopefully negligible) would the Ibis 938 be ok to run 3.0s on?
  1. Replies: 4
    Last Post: 08-19-2015, 01:27 PM
  2. Specialized Enduro 650b vs Enduro 29er
    By dk13 in forum All Mountain
    Last Post: 12-18-2014, 04:48 PM
  3. Replies: 11
    Last Post: 10-24-2013, 09:19 PM
  4. Specialized Enduro 29er? Why? Isnít this misplaced for a 29er?
    By weekendthrasher in forum All Mountain
    Last Post: 03-25-2013, 08:29 PM
  5. Replies: 3
    Last Post: 10-20-2011, 05:33 PM
Members who have read this thread: 52
