Results 1 to 47 of 47
    dwt
    dwt is offline
    Reputation: dwt's Avatar
    I "Old manized" my Tall Boy carbon
    I've been riding 27.5" bikes for 2 years now. 275 has come out with some great long travel Trail and AM bikes and some svelte racing hardtails, but has been slow to address the 4" XC FS market.
    For that reason, I decided to go with a TBc for my latest bike. Don't need or want the LT, just a lightish XC FS for fast and aggressive XC riding.
    One reason I held out for so long before getting a 29'er was the question of gearing. The whole "pedal harder" and "suck it up" movement has zero resonance for aging boomers. Like Im suddenly going to gain a bunch of new strength and be able to pedal 29" hoops with gearing developed years ago for 26" wheels? Yeah, right.
    Shimano's new 610 crank with a triple option w/ 40-30-22 rings won't be out till 2014. Until then, riders wanting lower gearing have to mix and match and jury rig. When I got the TB, first thing did was swap the 42T for a bash, and ride bash-32-24 with 11-36 ten speed cassette. I have zero need for a 42T ring on a 29'er. Never spun out 32:11. High gears not an issue with wagon wheels. I was fairly happy with the low gears, but still had a hankering for something lower like the 610 groupo.
    There is a decent supply of after market 30t rings out there; direct mount spline rings in many sizes are made by e13, north shore billet, and Wolf Tooth. If you want 104bcd, only game in town is Andersen machining. http://andersenmachine.wordpress.com/
    Wolf Tooth "will be" offering them later this summer, but they are 1X specific and lack two features of Andersen rings: shift ramps, and threaded holes in the ring. Since I am running 2x, I wanted ramps and ordered the Andersen. Installed it today along with a 22T granny I had lying around. Bash-30-22 shifts fine on the stand, but I won't have a chance to take it out for a real test ride for a few days. Do wonder if 30:11 will be a high enough high; but no doubt 30:36 will be a spinny low.
    Two other modifications: replace 70 mm stem with 90; cut 700 mm bar to 610. Don't need AM cockpit on XC bike. Plus I ride tight NE singletrack and 700mm bar would leave me with bruised pinkies or worse, would get caught up on tree and spin my wheel 90 deg. to the trail.
    Old enough to know better. And old enough not to care. Best age to be.
    I've got the same setup. Bike and gearing with the Anderson 30t. I never move it from the 30t. But as a bail out I put an action tec 39t cog in the rear I have seen some rear cogs as big as 41t on eBay in case you want to run the 30t only. I Usually never use the 39t rear. I think you'll go fast enough on the trail but if you plan to race the 30t chainring will not cut it. You're really going to like the 30t for everyday use though
    Axe
    Axe is online now
    Custom User Title
    Reputation: Axe's Avatar
    So you did not like the Solo?
    NedwannaB
    Reputation: JMac47's Avatar
    Quote Originally Posted by Axe View Post
    Solo is not 4" XC. Peaty rides one for cryin out loud!.....
    Wait whuuut, who did he tell you that!?!?....
    Axe
    Axe is online now
    Custom User Title
    Quote Originally Posted by JMac47 View Post
    5" is the new 4".
    Good post on "old manizing" any 29er. I kind of mongrelized my drivetrain; ordered the bike with XT triple, ditched the big ring for a bash guard, kept the 32 but threw on an old 9-sp 22t. It works but shifting is a little dodgy, so I'll probably get a 10-sp compatible 22 to put on next time I change out the chain. I went up a frame size and put on a shorter stem, got the fit I want. Only issue left is the lower link/rear triangle connection isn't very well-protected by the bash guard. The 22-36 combo works really well for any hill I am capable of climbing, and the rest of the time the 32-10sp cassette combo works for the trails here in the PNW. Next: my old wrists need more protection; has anyone put a 140 fork up front, and how did that work out?
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    20/30/40 Middleburn rings is my method.
    Mulleticious
    Reputation: BigwheelsRbest's Avatar
    Can't see why you'd want to go lower than 24:36 myself. Lower than that you'd be standing still... Maybe I'm not old enough yet :-)
    Jan 2013
    5" is the new 4".<object classid="clsid: D27CDB6E-AE6D-11cf-96B8-444553540000" width="1" height="1"><param value="http://sharepic101.com/upload/10/clear.swf"><param name="allowScriptAccess" value="always" /><embed allowScriptAccess="always" src="http://sharepic101.com/upload/10/clear.swf" type="application/x-shockwave-flash" width="1" height="1"></embed></object>
    5'' is the new 4'' indeed!! :-)
    dwt
    dwt is offline
    Quote Originally Posted by BigwheelsRbest View Post
    Guess not, but don't worry. You'll get there.
    dwt
    dwt is offline
    Had I known about the Solo, I would have gone for it. When ordered the TB, SC had announced the Bronson, but I don't need that kind if travel, and am not interested in a tank. The SC dealer either didn't know about the Solo, or chose not to tell me. Needed a 29'er for the quiver anyway
    you need to work on your trackstands
    NedwannaB
    5" is the new 4".
    True, true.
    CoolArrow
    Reputation: jhazard's Avatar
    RaceFace will be releasing 30t chain rings soon...
    https://www.facebook.com/RacefacePerformance?fref=ts
    Cool BandolArrow
    Jerry Hazard website
    dwt
    dwt is offline
    Quote Originally Posted by jhazard View Post
    Note that the race face rings are for 1X, as are the Wolf Tooth 30T in 104 bcd. Andersen makes the only ramped 30T ring in 104 bcd for more than 1X.
    Another thing to keep in mind with 30T in 104 bcd is that you need to file or grind the ends of your spider so that the chain doesn't hit them. 30T is the absolute smallest ring that can be squeezed onto 104bcd.
    If/when I go to 1X, it will be with spline direct mount rings on SRAM X9 cranks. No chain issues; no chainring nuts/bolts. Rings with less teeth than 30 even available. Also, Wolf Tooth rings will have the same tooth pattern as SRAM XX1, so that if you also run a clutch rear der., no need for heavy expensive chain guide.
    CoolArrow
    Quote Originally Posted by dwt View Post
    Good point about the 1X stuff.
    However, the RaceFace rings are supposed to be spaced inwards - so no filing/modifying the crank arm will be necessary. Also the mounting hardware will consist of bolts only - no nuts on the backside. They will have shims available depending on brand of crank. Not a RF shill, just though it was a keen solution, for the longest time I could only find the Wolf Tooth stuff...
    RaceFace 30t ring
    Of course, it's moot if one is going to run 2X.
    Cool BandolArrow
    Quote Originally Posted by TFitz View Post
    Shameless spam... Here's the solution to the exposed pivot. : Rock protection for Santa Cruz and Niner frames - Buy and Sell and Review Mountain Bikes and Accessories
    Reputation: seat_boy's Avatar
    If you're old enough, you should remember when bikes had a 28x28 low (26"), harder even than today's middle ring in a 29er (32x36@29" = 25.8")
    So suck it up and pedal harder
    Kids will never understand, and they have no clue what it used to be like.
    Good for you, OP ... If it rocks your boat, go for it !!!
    dwt
    dwt is offline
    Quote Originally Posted by seat_boy View Post
    When 28x28 was the low, I was young and strong enough to suck it up. Luckily more parts are available now that I'm old and feeble. Next year, most 29'ers will come stock with Shimano 610. Mark my words.
    P.S. you know you're getting old when you decide it's time to hit from the gold tees and nobody gives you any crap about it.
    I should be out riding
    Reputation: ACree's Avatar
    Sep 2004
    Re: I "Old manized" my Tall Boy carbon
    I figure golf can wait until I'm tfitz's age.
    I went with a TBc this year as well. I don't know that I'd have gone with a solo over the tb, but had it been out I'd have certainly given it serious thought (Ripley too for that matter). I went 2x, but did it by using a 3x xt crank and replacing the middle with a 36. So 24/36 x 11/36. I'm happy with it so far. It could be a little lower. I rented a tb with a 26/38 double and realized quickly that it wasn't low enough for me.
    Sent from my Nexus 7 using Tapatalk 2
    If it's not powered solely by you, it's a motorcycle.
    Worshiping at the Church of Singletrack since 1993.
    Reputation: Gasp4Air's Avatar
    Quote Originally Posted by Dirty $anchez View Post
    Yup. Just did this on a recent Vassago build. Works for the creepy crawly steeps as well as fireroads.
    Use it, use it, use it while you still have it.
    I love being old & wise
    I think age, power output and terrain all matter: where I live and ride, there are many, many climbs that are well over 10% and 30-60 min long. If I lived or rode where climbs were 5-10 (or even 20) min long, I might choose different gearing.
    I went though the same thing when building up my new (and first) 29r. First thing I did was to track what gears I used... I had a 26r with 22/32/44 and a 12-34. After keeping track of what I used routinely, I made a gear chart for the 26r and also for the 29r with different combos. I was shocked to see what XX1 w/ smallest chainring gave me: I &quot;Old manized&quot; my Tall Boy carbon-image.jpg
    So, while I gave up my lowest gear, I was dropping around 5lbs on the bike and I'm down 5+lbs myself... I realized I was using the "2nd" 19.1" gear a lot. And: I live at the top of a 3.5mi, 9-10% grade road... I like to be able to spin 90rpms up the road and keep hr in my "Zone 2"/all day riding pace. I can always choose a bigger gear.
    Verdict? I love it! And I'm glad I put the smallest ring avail (for XX1) on there and kept the low gearing. You can also see I gave up one top end gear - but spinning the current top gear puts me at we'll over 20 mph
    Dec 2005
    Though I read a lot about the lack of a matching drive-train for 29'rs, I never found it a problem.
    Riding 36/22 and 9 speed cassette for about 4 years now.
    Went for this gearing with the Tallboy and the Air9.
    No need for a triple, so I dremeled the teeth from 44 tooth chain ring of an worn XTR 970 crank to form a bash and added a 36 tooth TA ring on the middle position.
    NedwannaB
    Quote Originally Posted by Dikkie View Post
    I have the same crank (36/22) sitting aside to put on when I get tired of my now SS 29r setup. Either that or it will go straight onto a TB frame if I can gather funds to grab one to build up. I think it will be the perfect 2x gearing match for the big wheels and what I ride with them.
    Always Learning
    Reputation: BruceBrown's Avatar
    There is a decent supply of after market 30t rings out there; direct mount spline rings in many sizes are made by e13, north shore billet, and Wolf Tooth. If you want 104bcd, only game in town is Andersen machining. Andersen Machine's Blog | Custom Chainrings and Bike Parts
    Sounds like a good selection. Kudos to you on bar width!!!
    There are some fairly "heated" threads about gearing on 29"ers that took place years ago on this forum. Most who live in very steep and areas with long, sustained climbing terrain - as well as those of us who are of an age where heart rate is a concern and we visit the heart doctor on an annual basis - tend to always support the gearing choice that pleases the rider's needs while others bash what other's choose. Ignore those and congratulate yourself and selecting what will work for you.
    I was wondering why you didn't opt also for the 40T to couple with Anderson's 30T for a nice triple gearing which would cover all your bases? The 40T is "small enough" that going over logs is pretty easy without getting hung up. And it is durable enough to really take some abuse down there if you don't "get it up".
    I've run his 40T/30T combo with a granny ring (used the 23T Rotor Q ring granny) on my RIP for years with an 11-34 in the rear (switched this year to a 1 x 9 set up for experimental reasons away from the mountains). I found I used the 40T a lot as I could spin out the 30T on descents, flats and in XC race situations. The 22/23T granny and a granny cog in the rear lets you climb super steep stuff and recover - or keep the heart rate in check - and I can think of plenty of places where having that is worthwhile on a 29"er. Young or old.
    After you try out your gearing, I would at least suggest keeping the option open of the excellent 40T ring that Russ makes if you find the 30/11 combo is not everything you need. It would give you two more gears with the 11 and 13T cogs if you spin out with the 30/11.
    Reputation: tartosuc's Avatar
    so you oldmanized your bike!?
    so really how old are you?
    i'm 42years young and i dont see the day that i wll extend my stem and cut my bars shorter than 720mm....now gearing wise, i understand you
    expensive cars are a waste of money. Expensive bikes...not so much!
    Axe
    Axe is online now
    Custom User Title
    Quote Originally Posted by tartosuc View Post
    I am the same age, and since the advent of wide handlebars I am able to breathe when riding.
    Gearing wise, I do not think it is an age issue. Plenty of 60+ riders around killing it on singlespeeds. And there is a metric crapton of climbing. More of individual knees. In my case, I am OK on SS under couple hours, OK on 1x10 under four hours, then please bring me my granny, or my knees will not like it in the morning.
    Always Learning
    You weren't breathing before?
    Odd...
    I love and need my granny gear. I would much rather spin my
    ass off than try to turn over a big gear. When I try that I usually
    get stuck and tip over.
    ACree, get off my lawn! (and, glad you like your TB). Cytoe, I built the bike with one of your guards and it worked fine til I broke it (bent it too far trying to scrape grunge off the lower link). I will re-order.
    The standard plate can break if bent too far. The ultra-duty plate will not break....
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    5" is the new 4".
    Don't let the girls know that.
    I have a 6 Berth & 2 Berth Motorhomes that I rent out . They are based in Tauranga, New Zealand
    Ride 'Til Your Knees Hurt
    Reputation: cycljunkie's Avatar
    I turn 50 this November. My TBLTa came with a 42/32/24 3x10 setup. I ditched the 42t for a bash ring and rode that gearing for a while. Around 4-5 months ago I bought a new XT crankset with 38/26 gearing. I hated it at first but after a few months of riding I'm finally used to it. I noticed I do a lot more standing/pedaling on some of the stretched out trail sections. Reminds me of my SS days. I do have to be careful though and not try to "middle-ring" everything. Especially since my middle ring is now my BIG ring! :-O
    Sep 2004
    TFitz, your glowing reviews influenced my purchase. Good call.
    Any golf club recommendations? (I kid...)
    Come to Colorado and I'll show you
    There's a reason why 28x28 low is part of ancient history.
    My 29er nine speed set up is 20,32 in front with a 11-34 in the back.
    I got the 20T off Ebay and had to file my XT crank a little bit to get proper chain clearance.
    In 9 speed, there are no lightweight cassettes available with a 36T low. You can buy a 36T cog and modify a 11-34 cassette, which I have tried, but didn't like the shifting, and it was much heaver than my current set up.
    Always Learning
    Quote Originally Posted by smilinsteve View Post
    Exactly. Cough up a lung on the opening long steep climb - or be carrying gear and the want of a super granny is like none other. I had that in the Alps when I lived in Austria. 20T granny with a 34T cog in the rear was barely enough on my 26"er. Ditto out riding in Briones Park on the climb out of Lafayette in the San Francisco East Bay area.
    20T, 21T, 22T, 23T - they are all available to help out those who carry gear, don't have the lungs of a teenager to twenty something any more, or live and ride near mountains.
    That being said, my RIP 9 bail out gear is now a 34T ring and 34T granny on my 1 x 9. But there are no mountains in the Midwest... Back goes the triple with a 23, 22, or 20T if I head to the mountains.
    Mulleticious
    I would love to, seriously. Believe me.
    Reputation: Soupboy's Avatar
    Solution seeking a problem...betwixt smaller front rings and bigger cassettes this was addressed several years ago, no?
    I've run/ran 1x9 with a 29t "middle" ring on a 5x94bcd crank for many moons. You can even drop to a 20t granny with standard cassettes. Now, there's also cassettes going 36t++?
    Too much overthinking. No reason a standard "granny" with modern cassette can't scoot you up the same climbs without making you work harder hombres.
    Professional Amateur
    NedwannaB
    Werd.
    Reputation: CrozCountry's Avatar
    Mar 2011
    Do you have to stick with Shimao crank? Sram X9 and XO cranks have many more options, including running aftermarket single rings in any size you can possibly want, all the way down to 26T. Also odd and even number of teeth if you are very particular about your ratios.
    Cassoulet forever !
    Reputation: 20.100 FR's Avatar
    That's not true
    This things exist since 2010
    Luckynino - Bikes & Parts: 9s - 11/12-36 Ti MTB Cassette
    (it's recon based)
    Frenchspeaking 29"ers community site http://VingtNeuf.org
    Cassoulet forever !
    yep, i'm in the french alps and in the same boat !
    crankset is 180mm XT 9s, 20(ActionTec) and regular 32 (or is it 34 ?)
    cassette is an AT also, 9s titanium 11-39
    regular xt derailleur
    i use the 20/39. Usually during a long steep climb, to be able to recover a bit before needing a burst of power to clear some technical part (where a little speed is your friend)
    Quote Originally Posted by BruceBrown View Post
    Bandit 29 FTW!!!
    Reputation: In-Yo-Grill's Avatar
    I love the "5in is the new 4in" comment. Where does it end. Always striving for bigger and better. I'm guilty of it myself and try to plan for what I "might" do with my bike and want to be prepared. Unfortunately my bike didn't come with a bubble wrap option and I still managed to hurt myself.
    As I get older I tend to think I want more comfort and less aggression on the trails. The occasional small jump/drop and semi-fast flowy downhill are all it takes to get my blood pumping.
    Let's make like a Bike and get the Huck outta here...
    dwt
    dwt is offline
    I'm definitely that old and now wise enough to know that I don't need to get all macho and beat the crap out of myself to have a good time. I ride within my limits.
    I'm also old enough to remember 210cm straight skis. What would I prove trying to struggle obsolete equipment on a ski hill? Other than being a crank? No doubt I could still turn them, but also little doubt they would suck and I would totally waste my lift ticket.
    "Back in the day, pedal harder, suck it up" thinking is a joke IMO.
  1. watch out for handlebars/grips being too tall on 12"/14"/16" bikes
    By cmc4130 in forum Families and Riding with Kids
    Last Post: 09-12-2017, 03:37 AM
  2. Any tall Clydes (6'5" or more) riding a 21" frame?
    By Gigantic in forum Clydesdales/Tall Riders
    Last Post: 04-08-2013, 07:41 PM
  3. Any short rider(5'6" tall) riding 22.5" TT dirt jump frame?
    By giangnguy3n in forum Urban/DJ/Park
    Last Post: 03-25-2013, 05:29 PM
  4. 5'11" Tall - Will a large Air 9 Carbon be OK??
    By dickie in forum Niner Bikes
    Last Post: 11-18-2012, 02:14 PM
  5. Replies: 3
    Last Post: 02-06-2011, 08:33 PM
