• 03-05-2013
    RedRiver
    I ask you Banshee Prime or Yeti SB95?
    Well this comparison has been made before in other threads, but I am hoping to consolidate opinions and get whatever insight people may bring to this duo. I'll be upgrading bikes from a steel 29er HT this year and don't want to make a hasty decision. I have ridden the Yeti on the street and thought the geometry felt great. I have not been able to track down a Banshee, but they seem to share some similarities. Other bikes I've ridden include the RIP 9 and Tallboy LTC. I think the slack HA and short CS of the Yeti are what set it apart.
    My riding consists mostly of pedal up/ride down with some XC riding. Examples of rides I do frequently include Cold Creek Washington, Sandy Ridge Oregon, and Oakridge Oregon. I am 6'2" 230lbs and ride fairly aggressive. I tend to be hard on things so durability is a must. I would like a bike that pedals well and that is my biggest question of with the Prime at the moment. So what do you think? Has anyone ridden both? It seems like they can be had for roughly the same price. Thanks for the insight.
  • 03-05-2013
    Colin+M
    I owned a SB95 and now have a Prime. Two different design intentions with those bikes IMO. The Yeti for me pedaled better, but I actually prefer the Prime in terms of descending ability as well as overall stiffness of the frame. The prime begs to be pushed hard and fast. I prefer the suspension feel of the Prime as with the Yeti it felt not so plush and more stiff which makes it feel like it betters better, but I usually used all the travel on rides. So if you are looking for an XC bike that can dabble in all mountain then you would be better suited with the Yeti. If you want to shred, Prime. They both could probably be built to close to the same weight as the frame weights aren't far off. As I bigger guy myself I would vote Prime (and I did). I don't think the Yeti pedals miles ahead of the Prime, marginally at best.
  • 03-05-2013
    bholwell
    Well, the Yeti and the Banshee have nearly identical heat tube angles and chainstay lengths (when the Prime is in the slack setting). But with the Prime's adjustable geometry, you can steepen the HA by 0.5 degrees or a full degree, which you might prefer.
    I haven't ridden the Yeti, but I feel like my Prime pedals extremely well for a 130mm travel bike. And it definitely likes to be ridden aggressively!
    Good luck with your decision.
  • 03-05-2013
    XJaredX
    The Yeti can't fit a very big tire in the back, if that matters. That was partially what made me go with a Bandit 29 last year.
  • 03-05-2013
    RedRiver
    Thanks for the feedback guys. Colin what really sets the two apart for you? On paper they look pretty similar in terms of geo and both seem stout, but I'm not that knowledgeable when it comes to the numbers. The rear tire clearance on the yeti is a bit concerning to me. If the prime can climb and pedal with aplomb I would probably go that route, but I haven't found one in my area to test. Knowing that I'll have to pedal up roughly 3-6mi had me wondering if the prime will wear me out at a quicker rate than the yeti.
  • 03-05-2013
    smithrider
    I rode the 95 and it is one fine riding bike. The unique geometry (at the time it was developed) really sets it apart. I also rode the LTC and RIP9 shortly after the 95 and neither could hold a candle to it. They both rode more like you expect a 29er to handle.
    Having never riddent the Prime, I cannot offer you an opinion there but I can say the Yeti is great handling trail bike you won't be dissapointed with.
  • 03-05-2013
    Colin+M
    For me the Prime just checked all the boxes. Adjustable geo, mini-link suspension, gobs of tire clearance, 150mm rear axle spacing, stiff as hell and overall will just plow through rough terrain. Since you are a bigger fella, I would recommend the Prime. The gains in stiffness will more than likely make up for perceived pedaling efficiency since more energy will be going to the wheels instead of frame flex especially if you are a masher.
    As stated above, I wasn't a fan of the Yeti suspension which probably was due having to run a higher PSI to achieve proper sag. It was too XCish (similar to a Pivot 429), I prefer more supple suspension feel.
  • 03-05-2013
    Colin+M
    Our Spider Comps are better than the Yeti :)
  • 03-05-2013
    smithrider
    I didn't want to taint his decision given he was going back and forth between two bikes, but yes, I am loving the Spider. I will be hitting Moab with it here in a couple of weeks.
    Sorry for the off topic post!
  • 03-05-2013
    Colin+M
    I hope you have a blast. I wish I had that type of terrain around here.
    I think it is only a matter of time before the Spider gets some well deserved love. I personally think its what the Tallboy LTc should have been even though that is a great bike as well.
    I would be interested in the trying SB95c if it actually eventually exist.
  • 03-05-2013
    wfo922
    I have a yeti sb 95 stand 6'2" weigh 200lbs and ride fairly aggresive. I've hit sandy ridge a few times and felt the bike never held me back. Rode black rock last weekend and although I never hit any of the huge gaps there were plenty of drops and natural dirt jumps that were hit. The build I bought is mostly xt with a fox 34 fork. The stk wheels were a little weak and a 2.3 tire would not fit without rubbing the seat tube when bottomed. Bummer!
    I must say the prime is one sweet looking ride. Custom building it would give you the ability to make it perfect.
  • 03-05-2013
    evasive
    With the caveat that what I'm presenting are just my opinions, I'll add to the mix.
    I own a (preproduction) Prime, have previously owned a WFO9, and have ridden (at Outerbike) a SB95 and TBLTc. Actually, I rode a buttload of bikes at OB, including the Spider (which I dug) but that's beside the point.
    I agree with Colin+M. I don't have any experience with the production Prime, but when it comes to stiffness and overall burliness, the Prime is in a different category. To slip into jargon, the SB95 is a trailbike, whereas the Prime is an all-mountain bike. The frame is a lot stiffer, and the 150mm rear makes a difference, too. At Outerbike, I actually took the SB95 out at the same time my buddy took a TBLTc. We're about the same size, so we swapped. Both bikes had the same drivetrain, brakes and wheels. I cautioned him against saying anything until we were back at the demo area, and we independently came to the same conclusion. I went into it expecting to have a 'meh' feeling about the TBLTc and to really like the SB95, which I was thinking was a leading candidate for a quiver killer. Despite the numbers and the way they look on paper (and I can geek out on that like anyone else here), we both preferred the ride of the TBLTc. But I wouldn't trade any of them for the Prime for my big mountain all-day rides. For my local short rides where it might be nice to have less bike, honestly I'd just as soon have a JET9 RDO or a Spider, but not if that meant giving up the bigger bike. For what it's worth, I also rode a coil-sprung SB66 and was really impressed with it.
    Does that mean the SB95 is a bad bike? Of course not. It means I didn't like it. I didn't like the Mojo HD either, and I seem to be in the minority there. So after describing my experience and impressions, what I can give you with confidence is that the Prime is stiffer and stouter, and that I do all-day big mountain rides on mine with no problem. It'll be up to you to sort through opinions and figure out what's useful to you. Hope that's some help. Good luck-
  • 03-06-2013
    pbrgdmkj
  • 03-06-2013
    bear
    Adding in my 2c, because, well, this is the interwebs.
    I own an SB95 (XT, but I have replace the rims with Stan's Flow), have had it since last June and have about 1500 miles on it, north-east PA rocky stuff mostly. Some buff trail (like Kingdom Trails in VT), some moderate light-DH (at Burke Mtn in VT, near KT). I'm about 205-210 ready to ride.
    No question, rear tires 2.3+ can rub the seat tube on bottom-out/deep compression.
    No question, with a front-d, rear tires 2.3+ can make for not leaving a lot of room for mud/crap there.
    But if I didn't have a front-d I'd run up to an Ardent 2.4, or a Panaracer 2.35 there and deal with the infrequent seat tube rub (think helicopter tape patch)
    Sure, it's a minor pita, but I don't consider it a show stopper.
    I've played around quite a bit with suspensions setup, shock setup, internal shims, etc., and have found that if I run 20-25% rear sag the bike feels snappy-xc-crisp, and if I run 25-30% sag then it feels notably more AM-plush. I do NOT know how the feel compares to the Prime as like others there is no way for me to test.
    I have ridden the 'cruz bikes (briefly) here locally and do find that I like the feel of the Switch more than the VPP from CA. I think that's mostly a personal "taste" preference than anything else. I also like that the moving bits on the Switch are well protected, and the bike drains crap/mud/leaves more easily than the 'cruz bikes. Again, no personal experience on the Prime but it LOOKS to me like it'd also "drain well" as it were.
    The Prime was also on my short list last year, but when I had to make a decision (early January '12) it was not yet an option in reality. I know that changed quickly, but not quickly enough. Would I have chosen the Prime if it WAS available? I don't know. Conceptually it was close, and while I had prior experience 1st and 2nd hand with Yeti and their staff and bikes I had zero with Banshee. There is also a LBS for Yeti but none for Banshee for me. That is a factor.
    I think the world well of my Yeti, I have never even come close to buyers remorse in any way. I've spent the winter prepping it for spring season and going nuts fine-tuning it to my desires. I think it's a very solid bike, having ridden a bunch of FS bikes in various styles and builders over the last 10 years I feel like I can say it's in the upper 5 or 10% of "solid" across the board, maybe higher.
    BUT
    For a stated Clydesdale who wants big mileage, and hard mileage, I think that the Prime may have a few design points that tip the scales in it's favor. The overall build is supposedly Just More Durable (restating what others have said). The 150mm rear axle is a plus there, maybe. I've read of people using a coil shock on the Prime which I think would be a better fit for someone significantly over 200# in riding weight. Being able to adjust the bike geometry is a nice selling point, but I believe that after about a month you'd probably never change it, having tuned it to your desire.
    BUT
    The Prime is not proven hugely more stout. I'd not consider it a light-freeride machine (as some people do when they think "All Mountain" these days), so I'd keep that in mind.
    AND
    I'd whole-heartedly agree that you need to notice that Banshee is selling the Prime as an All Mountain bike, and Yeti the SB95 as a Trail bike. In the end I think you need to decide which of those design targets really map to your intended usage and buy accordingly.
  • 03-06-2013
    RedRiver
    Again thanks for the feedback. Bear I've really appreciated all the insight you've provided into the Yeti here and elsewhere on this forum. I never thought this was going to be an easy decision.Smithrider and Colins concerns about bringing the Spider Comp into the mix are appreciated :cool:
    To clarify my riding probably doesn't qualify as free ride/ all mountain (these terms always confuse me). I enjoy riding flow with jumps, taking on 2-4ft drops, and going over roots and rocks when possible. WFO what would you classify Sandy Ridge as? Here in Oregon we get a lot of mud, so tire clearance could potentially be more of an issue.
    The differences between suspension designs on the trail is something I will probably never have the fortune to compare directly. For me the geometry of the Yeti really set it apart from the LTC and Rip, but having only ridden it on the road and through a park/off some stairs I cannot speak to the function of the switch technology on the trail. The Banshee grabbed my attention because it shares many characteristics with the Yeti, but seems to be stiffer, has more tire clearance, and can run a big boy shock. It sounds like it the Banshee can climb/pedal with close to the efficiency of the Yeti making a test ride or at least in person viewing necessary.
    The more I talk about it and learn the more I am leaning Prime. Now I just need to throw my legs over one to confirm my suspicions. An added bonus with the Prime is I can configure the set up to my liking for the same price and if a year or two down the road I want to change it up I'll have all the components I want on hand. I am probably over analyzing and should just get a bike and ride it.
  • 03-06-2013
    Colin+M
    You're on the right track my friend. Don't think of the Prime as overkill, think of it as capable:)
  • 03-06-2013
    29erchico
    RR:
    If you can get some time on a Transition Bandit 29 you would discover that it's geo and the SB95 are very similar. That is if we are looking at a 2013 B29 with a 130mm fork & 120mm rear squish or a 2012 B29 with a 140mm fork and 130mm rear. Very playful ride, makes you seek out trail features to pop off of. It pedals up and bombs down with equal aplomb. Gobs of tire clearance. The simpler suspension makes it less expensive to buy than the two bikes that you are focusing on.
    Even though I now have a Covert 29 (150mm F34 front and 140mm of coil sprung rear action) for gravity days and a Trans AM 29 hardtail on the way, both also from Transition, there is no way that I am going to part with my 2012 B29. Way too much fun.
  • 03-06-2013
    LyNx
    RedRiver, I guess I'll state upfront I'm most likely biased since I too have a pre-production Prime I love. As someone who loves to climb, the more technical the better, the Prime just excels at this and when you point it down, well if you've got the nads it will take you through/over almost anything - I think I could torw my Prime off a cliff and have to replace every part EXCEPT for the frame it's that damn burly :D
    Also as you mention your need tyre clearance, the Prime has loads of this, you can easily run a 2.5" tyre with room for mud, which for me is very important down here where our clay content is extremely high and we have a long rainy season and if you waited for that to end you'd not ride for 6+ months of the year.
    The versatility of the Prime with it's adjustable Geo and the option to switch axle configuration make it a very versatile frame - you could very easily set it up with 2 wheelsets, 1-150x12 with big meaty, aggressive rubber and 1-135x10 with lighter, faster, less aggressive rubber and then to differentiate it even more you can adjust the geo to the steepest setting on the "XC" wheelset and to the Slackest setting on the AM/Trail set, could even throw in 2 different shocks if you really wanted, 1 coil w/ piggyback and 1 air.
    Gratuitous shot of my Prime and of the clearance in the stays - note production Prime's clearance isn't as huge, they're about 6mm narrower AFAIR - I can fit a Surly Knard in there going by measurements people have given for that 3.0" tyre and still have room on either side.
  • 03-06-2013
    wfo922
    I would say sandy ridge is all mountain'ish. I put the ish in there because it has nothing all that steep and everything can pretty much be nailed on the first run. The prime would be a killer ride there.
  • 03-06-2013
    RedRiver
    WFO that is kind of what I was thinking Sandy Ridge would be classified as. Since I can scare myself on my XC hardtail there I am sure my new wheels whatever they may be will have me gripped :thumbsup:.
    Lynx thanks for the eye candy. That is one fine looking and from the sounds of things riding steed. Your point about the adjustable geometry is noted, and the fact that you love to climb and the Prime does it well is just the kind of input I was looking for.
    29erchico I've also ridden the Bandit 29 and liked it a lot, but the suspension didn't feel nearly as efficient as the Yeti (all street based). I am sure it is a inspiring and playful ride though.
    Looks like I'm going to have to deal with some serious first world problems in the near future.
  • 03-16-2013
    bholwell
    4 Attachment(s)
    My Prime
    Recently upgraded some parts: 2x10 with type 2 derailleur, carbon bars, spare front wheel with DHF 29x2.5 Exo...
  • 03-16-2013
    RedRiver
    Well, I got the chance to ride a Prime yesterday and I am sold. The suspension was very similar to the Yeti on my opinion, but it had a stouter feel to it. I didn't get to really grind on any hills, so I am still lacking that comparison. Anyways I think the deal is pretty much sealed for the Prime. Now just to try and find the best place to order from and work on the build specs.
    bholwell Thanks for the pictures. That is a great looking rig. How did you get the black float? I am hesistant to go white, but don't want to shell out the extra coin for the black Talas.
  • 03-16-2013
    bholwell
    Thanks, man! Mine is a pre-production model bought directly from Banshee as a frame & fork package. Just got lucky in that regard.
  • 03-16-2013
    Fluidworks
    Not trying to hijack, but since the people who know are here, but Banshee Prime or Transition Covert? Both seem to be very similar in spec and purpose. I've never ridden either brand and neither are in my LBS.
  • 03-16-2013
    LyNx
    Yeah, the pre-production guys were lucky as Banshee got black versions of the normal Float for us :D As to the build, I'm a form over fashion type guy (although I think XT looks damn good to me) and $$ are always tight, so I stick to XT for anything of mine, love the new stuff and it always functions. Right now after a year on the Prime it is now full XT - brakes, shifters, derailleurs and wheels are Pro2s laced to Flow/Crest ATM and replaced the DHXA I couldn't seem to find to my liking with an X-Fusion 02 RLZ which is an OEM 02 RL made for Cdale for the Rize and I like it a lot. Attached a pic I took this evening just for more incentive ;)
    Attachment 781512
  • 03-16-2013
    evasive
    Yeah, they do. Do you know if you prefer a mini link or a single pivot suspension? If not, I'd say pick the one that looks the nicest to you. Sizing is a little different between brands. IIRC, my L Prime is almost exactly the same reach/stack as a XL Covert.
  • 03-16-2013
    Fluidworks
    I'm looking for a true all mountain bike that can pedal uphill about as well as a 30 lbs FS can, I enjoy climbs because I enjoy the descents. I know single pivots have been improved, but it still seems like the mini-link is the way to go, if only in that regard.
    Honestly I like the looks of the Banshee more. Comparing the two monetarily, it seems like it would be the more expensive of the two, as well.
  • 03-16-2013
    evasive
    Mine climbs well. Despite the weight, I prefer it to my Yelli Screamy unless it's a moderate grade or smooth. I've done quite a few multi 1K climbs with it, and although it requires a diesel gear for the burly build I chose, it just goes. Obviously I like my bike, and I don't want to do the MTBR "My bike is the best!" thing, but I think Banshee have done a great job with this frame for that purpose. But I don't see any of the Covert owners complaining, either.
  • 03-16-2013
    dv8xin
    I've seen Sandy Ridge in vids and always wanted to ride it. I think they're both sort of overkill. Kind of built too heavy, in my eyes.
    I've ridden the SB95 and I've talked with a guy who owns a WFO9 with a Dorado, who demo'd the SB95, and wound up getting a Prime (I think to replace the WFO9, which was too beefy/heavy for the trails we rode). He's under 6' and not a lightweight, and he thought the Prime was more suited for him. He gave me the impression that he thought the SB95 wasn't beefy enough for him.
    While the SB95's geo, ride feel, looks and suspension dynamics are top tier, it's not too hammer friendly and is heavy at 29 lbs without pedals for the XT build. I think it has a very sensitive and relatively linear suspension feel, better for ultimate traction and control, so good that it makes things easier to ride. The only effort you even need to think about is just keeping the pedals turning and keeping the front wheels pointed where you want to go. It's a like technical cheater bike. Seeing how you're coming off a steel HT, which I consider are fairly stiff and solid feeling, I'm assuming you like to get out of the saddle, since that's something that's naturally done when on a HT. The Intense Spider 29 Comp has the almost the same geo with a 0.5" longer ETT than the SB95, but their VPP2 is a bit more hammer friendly, and the carbon tech is supposedly good. Since it's lighter, I figure you'd be wanting to go with a more aggressive trail build with it, rather than AM.
    I'm thinking the Pivot Mach 429 (and carbon version) and RIP9 RDO are good alternatives too. If the SB95 carbon version ever comes out, I'd be interested in checking that out, personally. Don't have to go heavy for durability, I would like to think, but I'm a short and light Asian fellow and recommending frames and parts are somewhat out of my scope of knowledge/expertise. Honestly, the only times I really broke stuff was on my old heavy Kona with Deore level parts--I think lighter higher end parts are made both strong and light (not cheap though).
  • 03-17-2013
    dv8xin
    Actually, would a 29er FS even really make sense for such flowy trails? I fear a 29er FS might just want to roll over all the rollers, whereas a 26" would find opportunity for some sweet air. I'm trying to imagine how much a Santa Cruz Blur TRc would rock on those trails, but then again, I don't know clydes too well.
  • 03-17-2013
    RedRiver
    Lynx - I was thinking 2x10 XT group with either e thirteens or I9's on Flow EX rims. I am on the fence about getting the CCDBA. I kind of think the climb feature on the RP23 could be nice for my purposes.
    dv8xin - I'd agree that the Prime and other long travel 29ers might be a bit over kill for Sandy. For the last two years I have been riding my hardtail there without losing a smile. That said I think at bike like the Prime or SB95 will open up lines and inspire hits that weren't feasible for me before. I should note that as a clyde I flex the hell out of my steel Salsa and Sandy and pretty much everywhere else.
    When investigating Sandy Ridge I think you might have seen a video of Hide & Seek which is more flow than some of the upper trails like 338 and rock drop IMO. The other aspect is that I also ride place like Cold Creek/Thrillium, Black Rock, etc. A bike like we're discussing fits in nicely there.
  • 03-17-2013
    Miker J
    Great thread.
    The Prime looks like a great AM machine. I always thought the weak link of the 29er was the dished (Oopps... I meant dished, not dishless...) rear wheel. If I had the cash and and need for a full-bore AM 29er it would likely be the Prime with a King/Flow EX rear wheel build. The downsides would be a weighty bike that might be over kill for most trails. The other would be there is still probably not a fork to match that sort of rear. Maybe when a RS makes a 29er Lyric.
    On the other hand if I were a clyde, I might go the Prime route even for a trail bike. At my weight, for routine trail duties I'm looking at a lighter weight LTc.
    Without trying to incite a stir, I do think that AM will likely end up being owned by the 275.
  • 03-17-2013
    bholwell
    Originally Posted by Miker J View Post
    Great thread.
    The Prime looks like a great AM machine. I always thought the weak link of the 29er was the dishless rear wheel. If I had the cash and and need for a full-bore AM 29er it would likely be the Prime with a King/Flow EX rear wheel build. The downsides would be a weighty bike that might be over kill for most trails. The other would be there is still probably not a fork to match that sort of rear. Maybe when a RS makes a 29er Lyric.
    With a 150mm rear hub, the dish of my rear wheel is pretty nice. Not all 150mm hubs are created equal, though.
    You know, I'm riding my Prime much more than I thought I would. At 165 lbs, I'm no clyde, but since I've moved to an area with more chunk, it's just a more fun ride. I built my bike up fairly light, and granted at 31 lbs it'll win no awards for weight, but on rides where I'm just having fun I don't mind the additional 6 lbs over my Jet 9. It's a very efficient bike, which is more important than weight imo.
  • 03-18-2013
    LyNx
    Red, can't go wrong with the new XT, great bang for your $$ and most definitely in the brake dept. Since I got my XT 785 brakes what I will attempt now has changed, as I just have more control of my speed and the ability to bring the bike back in check if i go off line and need to correct.
    As to if to get the CCDB, if you're a clyde, that's a no brainer, most definitely get it, lots more adjustment than any non piggyback Fox. As to the fact that you're a clyde, then the Prime makes even more sense, since as you say you flex stuff and I'll find it hard to think you can flex the Prime :D Like you say, it WILL open up your thought process on what you can ride and in looking at the trail differently and where you might have gone around before, just go straight through/over with the Prime.
    IMHO the F34 is about the best out there right now, well, the old Float version with FIT, not sure about the newer ones with CTD, but in a few months the Trace from X-Fusion should start showing up and that most definitely has my attention and I think that it will compare comparably to the F34, but for a good bit less $$. I've just received two of their Velvet's (straight and tapered)and the quality is top notch, and also their 02 RL shocks for myself and a friend and also very nicely constructed and working nice. In the future I'll be looking to get their Vector AIR shock for the Prime.
    FYI, like Bholwell, I'm a light weight at only 170lbs nekked and 6'2", but the Prime is just so fun that I take the weight penalty (34lbs for my XL, with XT and Pro2/Flows) because it just makes the fun stuff funner :D PLUS, it's fun to out hammer the guys on the 23-24 S-Works and Ultimates that cost about twice as much.
  • 03-18-2013
    Miker J
    I meant to say the weak link is a dished, not dishless, 29"wheel on an AM bike.
    My bad.
  • 03-18-2013
    bholwell
    My bad.
    That's what I thought you meant to say. You'll have a dished wheel on every rear hub except a SS hub- not a 29er issue.
  • 03-18-2013
    jjcools
    Let us know how you like your choice. I have been scaling back my FS needs and am just down to my Paradox but this new crop of 29ers are making me want one bad.
  • 03-27-2013
    RedRiver
    The Prime has been ordered and the build will start this week. Once complete I'll snap some photos and give my initial impressions of the ride. Thanks to you all for the insight and discussion.
  • 04-08-2013
    nasd90
    Finally on the road last week... Incredible bike, I still can't believe it. The things I am able to do on this bike for someone who is 40 is ridiculous. couple foot drops, jumps with freakin' ease (just like the BikeMag video guys stated... it lifts!)
    switching out things slowly... WTB Silverado is incredible, even for 230-ish 6-2 me, top heavy. I may have gone for the XL believe it or not, but I think the longer Thompson stem coming should do it, I just need a little.
    Had to get a Cane Creek 110 as the Banshee headset wasn't available... and the PointOne Podiums are tits.
    I agree with one of the forum members, not sure if it's even this post about the white Manitou fork... It's ok, but I don't like the white. it's like they do this on purpose so you go for the black. Had one shop tell me to take it to a automotive bodyshop and get it painted...with a serious face! haha. I'll probably go the Fox route, but I did see WhiteBros have a sharp black offering in the 29er shock black category, 'round 800 I think.
  • 04-08-2013
    dv8xin
    You like the Silverado? After 2.5+ hours on that thing, my sit bones are on fire. To be fair, 2.5+ hours on a Rocket V, my ass feels sore, but not in a pin point area like the sit bones. My overall riding is much more dynamic (another way of saying, out of the saddle) with it on my bike though. I have no urge to change it out; I'm more or less interested in hearing opinions from others on it, as I didn't think it was a popular model compared to the Rocket V and others. I actually tried to get another one, but it turned out to be a turd "Test Ride" version, with steel rails and crappy padding (not the nice DNA padding) and cover.
  • 04-08-2013
    nasd90
    I couldn't believe I took to the silverado either... I think it's all about sitbone placement in your skeleton as opposed to it leaning more towards actual weight. but, to each his own. I want the Pure V, but the Rocket is more race I think... The Silverado has really helped me to relax with all of these small seat offerings. And I'm not up to 2.5+ hours on the Prime yet, but soon. :-)
  • 04-08-2013
    LyNx
    Nad, nice looking Prime. Don't think the white fork looks bad, not optimal, but not bad. As to the suggestion by your shop, don't laugh at them, it's actually a great suggestion. I painted the lowers on my Minute dark blue to go with my old bike, looks a bit weird to some maybe on my silver/orange Paradox, but the finish has held up and I could easily change the colour and this was a rattlecan job, proper automotive paint would be more durable.
    Have to agree, love WTB saddles, but no the silverado, was glad someone else liked it enough to offer me some cash for it. My fav 3 WTB saddles - PureV, LaserV, RocketV, PureV being my fav - and most anyone who rides my bikes tend to agree that they're just comfortable, even if they're accustomed to other brand saddles.
  • 04-08-2013
    dv8xin
    All this bike saddle talk got me to check out the Specialized saddles. As much as people criticize Mike Sinyard's business tactics, including bashing other brands with dealer e-mails, the saddles are surprisingly well received. Too expensive for me though. I'd rather toughen up my ass than pay $80+ for a new saddle.
  • 04-13-2013
    RedRiver
    She's here
    Well my Prime got hear yesterday. After a brief issue with the headset she's up and running. Our first romp in the dirt is tomorrow. If my initial impressions hold true I'm in for a wild ride :thumbsup:. Here are the build specs.
    Frame: large raw
    Fork: fox float 34mm 140mm
    Rear shock: fox ctd
    Components: shimano xt 2x10
    Crank: race face atlas 175mm 26x38
    Wheels: Stan's flow ex
    Hubs: industry 9 torch
    Stem: race face atlas 50mm
    Bars: race face atlas 785mm (probably going to cut these down a bit)
    Seat post: reverb
    Pedals: black spire
    Weight: just shy of 32lbs:D
    More insights to follow.
  • 04-13-2013
    LyNx
    Looks pretty good, can't see if you managed to get the matching purple ano hubs, looks like a see a hint there in the 2nd pic, but hard to tell. Very brave BTW, can't remember the last time I saw someone with purple ano bits recently :D So how come you went with the CTD Fox over the CCDB air?
  • 04-13-2013
    RedRiver
    The hubs are matching. I know I went out on a limb with the purple, but it is my favorite color. Personally, I think it looks dope and is definitely a break from the old red and blue.
    I went with the CTD for a couple reasons including cost, weight, and lock out capability. It was a tough call though. It gives me something to upgrade in the future should I find the CTD underwhelming.
  • 04-14-2013
    bholwell
    Very nice!
    I initially went with a 50mm stem, then settled on a 60mm.
    Looking forward to hearing your ride report!
  • 04-14-2013
    Just J
    Very nice indeed! I too am considering these two bikes at the moment. Looking good. :)
  • 04-14-2013
    LyNx
    Dude, if you like it, then that's all that matters :D Problem with the likes of the Ano Purple is you don't find stock parts coming with it to fit in nicely, so going with blue/red just makes it easy to incorporate them. I have seen one guy remove such things as fork controls etc and had them anodized to match the other ano parts he'd chosen - think orange or some such. Had my Prime now for over a year and toying again with the idea of stripping it to have it refinished in a nice warm yellow PC or maybe a candy yellow that will go well with my blue ano parts - local colours are blue, yellow/gold and black.
  • 04-14-2013
    RedRiver
    Yeah the wife ribbed me a bit about the purple, so I am a little sensitive. That would be pretty sweet to get a custom powder coat and match everything up. Maybe you could even get a trident graphic.
  • 04-19-2013
    aalbanezjr
    Sweet ride. I'm stoked on my Prime, I'm just not sure if I'm gonna stay with the Fox CTD. I can't seem to get the adjustment quite right. I was thinking of maybe replacing it with a DHX. I'm having issues with the front forks also, they don't return all the way up. I still have between 10-12 mm sag no matter how much or how little air is in the forks with me off of the bike. Other than that the bike handles, climbs and descends great.
