    Jan 2011
    HT MB Phantom Pro 29er to a Voodoo Canzo 29er frame?
    Hey guys,
    Please be patient with me regarding this, as I am not nearly as knowledgable about these things as most of you are.
    My current bike is a Motobecane Phantom 29er Pro:
    http://www.bikesdirect.com/products/...om29pro_08.htm
    However, I have been wanting to go to FS for a bit and have been looking at this frame:
    http://www.airbomb.com/itemMatrix.as...trixType=1&Av=
    Anyone have an idea what sort of difficulties or problems I will encounter trying to make this a straight swap?
    poser Administrator
    Reputation: rockcrusher's Avatar
    Aug 2003
    I just made a similar comment here: FS 29er bikes from BD: The Story so far...
    Generally besides the obvious items (seatpost and front derailleur due to differing seat tube diameters but not always), swapping from a HT to a FS frame usually requires new shifter cables and housing and possibly longer rear brake housing (which if it is a hydro can be a pain if you are not capable of doing it yourself) due to differing cable run routing and cable stop locations.
    Otherwise i suspect everything would swap in easily (also depending on your mechanical prowess).
    Try this: HTFU
    Terror of Sidewalls
    Just taking a quick look, the seatpost diameter is smaller on your current bike so you'll need a new one of those. The front derailleur may have to be changed to a high clamp one because of how the shock is mounted. You'll also need to convert the fork to 100 mm if you haven't already.
    MTB B'dos
    Reputation: LyNx's Avatar
    Good info from RC, if you want more info on the Canzo best bet is to check out the big thread here in the 29er forum. Voodoo Canzo 29er: So what do you get for $750
