Page 6 of 9 FirstFirst ... 2 3 4 5 6 7 8 9 LastLast
Results 126 to 150 of 213
  1. #126
    Reputation: leesrt's Avatar
    Quote Originally Posted by chris5107 View Post
    Trek Cobia started out at 29.5 Lbs on my scale. Dropped 2.7 Lbs so far for a final weight of 26.8.
    The biggest shocker was the rear cassette. This thing was a brick at 452 g. An SRAM 990 brought that down to 303 g for a 0.33 Lb drop on just the cassette.
    Good info. I'd like to change out my crank set and cassette in the future. Lot of weight with that solid crank as well.
    My weight of 30 included my cyclometer, underseat tool pouch with spare tube, multi, and co2, and bottle cage.
    Sent via mental telepathy.
  2. #127
    Reputation: jearl's Avatar
    [QUOTE=Dirtydogg;9582759]It says Bomber on it. Tells me it's a Marzocchi Bomber...not a RS ;-)
    My Talon on page 4 post #90 is what he was refering to, it has RS and not the stock Suntour
  3. #128
    I like bikes.
    Reputation: Dirtydogg's Avatar
    [QUOTE=jearl;9583106]
    Quote Originally Posted by Dirtydogg View Post
    Ohh, well he quoted a picture of a bike with a Bomber but now iI see it was a differnt part of his post.
    No sweat. Was wondering what he was thinkin...lol
    Thanks for the clarification.
  4. #129
    Formerly of Kent
    Reputation: Le Duke's Avatar
    Just over 20lbs at the moment. Should be well under 20 when the new stem, seatpost and tires arrive.
    Attached Thumbnails Attached Thumbnails How much does your 29er hard tail weigh?-img_0658.jpg
  5. #130
    29lbs of course!
    With my steel frame, I've gotten my SS up to 29lbs. (Isn't that what a 29er should weigh anyway?!) jk,jk...
  6. #131
    2011 Trek Cobia 21 inch
    OK, I had a table on here as an image but it did not show up. I will try again with text. Also, I ended up taking my bike to the LBS and they weighed it for me so now I hopefully have a more accurate weight.
    My Cobia weighs in at 30.93 Lbs at the Local Bike Store on a digital bike scale (this replaces my bathroom scale measurement of 29.5)
    The weight of 30.93 includes a wireless Trek Speedometer and one bottle cage installed. I swapped out some parts and brought the weight down to 28.14 (this is higher than the 26.8 I noted above because of the bathroom scale error).
    Here are the changes I made. (weights in grams from good scale)
    New Part weight weight of old cobia part
    RXL seat and RXL seat post 414 736
    Frnt RL Rim 905 1078
    Front Quick Release 36 82
    Front XT Brake setup (all parts) 290 334
    Grips (Ergon with extender) 251 93 (going up here)
    Rear RL Rim 1129 1309
    Rear Quick Release 38 88
    SRAM 990 Cassette 303 452
    Rear Avid Rotor and Bolts 138 144
    Pedals (Kona LG) 543 415 (going up again)
    XT 760 Crank w/3 rings 763 952
    Hollowtech II bottom bracket 89 289
    Frnt XT derailer 166 150
    rear XT derailer 224 252
    rear XT Brake setup (all parts) 301 340
    Race XXX lite carbon handlebar 184 269
    FSA stem 120mm 6 deg 162 192
    XT shifter set R/L 250 254
    Front Avid G3 rotor and bolts 115 142
    Total difference in Lbs is 2.79 for a final weight of 28.14 Lbs.
    Changing my pedals and hand grips back would help bring this under 27.5.
    Hope this helps anyone looking to upgrade for weight purposes. I upgraded because I had the parts on a 26 inch mountain bike and just swapped them over because I had them.
  7. #132
    SSolo, on your left!
    Quote Originally Posted by tjwil9488 View Post
    My 29er hard tail weights 31lbs. Just curious to see what everyone elseís weighs.
    Should also ask to post rider weights, super lightweight stuff is cool, but not for heavy and/or strong riders. Light weight is good to a point.
    Get off the couch and ride!
  8. #133
    Reputation: VanillaEps's Avatar
    Aug 2010
    Approximately 23 lbs.
    Stumpy HT Carbon
    1x10
    Sun Ringle Black Flag Pro wheelset
    Niner Carbon handlebar
    Niner RDO seat post
    XT clipless
    Fox 32 F29 100mm RLC
    I weigh between 170-175 lbs.
  9. #134
    I like turtles
    Reputation: TiGeo's Avatar
    15.5" 2012 Stumpy Evo HT 29er; 23.5 pounds. Upgrades/changes over stock include Roval Control 29 wheels and Renegade Control/S-Works Fast Trak tires, Shimano 520 pedals, and Alligator Serration rotors. I weighed 164 this morning, naked, after I took a leak and a dump...hey, every gram counts right?
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2012 Specialized Stumpy EVO 29 HT
  10. #135
    Moto Ti 29er weight
    Out of the box w/Shimano clips added, it weighed out a 23.5 lbs. Just changed out the Kenda Small Block 8's for Geax Gato front and Sagaro rear, so I'm guessing I'm closer to 24 lbs now.
  11. #136
    Reputation: AaronJobe's Avatar
    Niner Sir 9 SS Rigid 20 lbs 1 oz
  12. #137
    Reputation: zx1421's Avatar
    2012 Carve med. frame 27.8lbs
  13. #138
    Ghost poster
    Lynskey Pro 29 sl. w/ ti seat post
    full 2x10 xtr race
    niner carbon fork, ec90 stem, soma bars
    ea90 xc wheel set
    candy 11 pedals
    maxxis tubeless
    21 lbs 6 oz. w/carbon niner fork, 23 lbs 9 oz. w/rs sid xx
    I'm 165-170 lbs.
    Lynskey Pro 29 SL brushed etched.
  14. #139
    19" Bikesdirect/Motobecane Fantom 29 Titanium, 25lbs even.
  15. #140
    Reputation: hey_poolboy's Avatar
    2012 Kona splice
    Swapped out the stock crank for a Shimano Deore (holotech ii)
    Swapped pedals
    I haven't really done anything with weight in mind.
    29# even.
    Sent from my DROID RAZR using Tapatalk 2
  16. #141
    Rod
    Rod is offline
    Reputation: Rod's Avatar
    Oct 2007
    Giant XTC
    alum frame
    Stans Crest
    1x9
    No super light parts, alum bars, heavy Giant seatpost
    23 pounds even with Crank Brothers Candy Pedals installed
    I weigh 159.
    There is not much choice between rotten apples.
  17. #142
    Reputation: kevocastro's Avatar
    Niner EMD 2011
    Large
    2x10
    Sun Ringle Black Flag Expert
    Tubeless
    Shimano M540 pedals
    25.5 lb
    Some carbon fiber goodies in the mail, might shave half a pound more
  18. #143
    Reputation: kingdom's Avatar
    My Yelli Screamy comes in at a touch under 27lbs. I think the bike could really do with a reverb and maybe some longer fork (120/130mm) so it'll probably be closer to 28lbs. Solid build though and can certainly handle some abuse.
  19. #144
    Reputation: eclipse24's Avatar
    My 2011 EMD9 comes in at 27lbs with no carbon parts. Reba fork, Flow EX w/ Hope hubs, Tubeless Conti TK's, SLX brakes and Sram X9 drive train.
  20. #145
    US Army Vet-Airborne 11B
    Reputation: longhaultrucker's Avatar
    Pair of Vassagos
    When I still had it it was a hair over 25 pounds (via the bathroom scale,which proved to be fairly accurate over a 2 year period).
    Just under 28 pounds (same method as above).
    '11 Origin 8 700CX
    '14 Surly Troll
  21. #146
    Reputation: dwnhlldav's Avatar
    Feb 2006
    Trek Stache 8ish. It's similar in build to the 8, but with some burlier parts in key places. 31.5 pounds and its perfect. I've got no plans to reduce that. I weigh 265 pounds and like technical aggressive riding, if I build my bikes much lighter I start breaking stuff.
    Attached Thumbnails Attached Thumbnails How much does your 29er hard tail weigh?-643948_10151043314857742_262241787_n.jpg
    Last edited by dwnhlldav; 11-04-2012 at 04:36 PM. Reason: Spelling, punctuation and capitalization
    Disclaimer: I no longer fix bikes for a living.
    National Ski Patroller to feed my winter habit.
  22. #147
    Formerly of Kent
    Eh, you could drop plenty of weight with some Enve wheels, bar, and stem, but probably not worth it to you.
    Definitely sturdier than the current set up, though.
    Death from Below.
    RLTW!
  23. #148
    The perfessor
    Reputation: mr_chrome's Avatar
    Jan 2005
    My bike weighs 25 lbs. even, but I am about to add shifters / derailleurs.......add to that my body weight of 178 lbs. and it comes out a cool 203 before season optional clothing (doesn't everyone ride naked!?).......lol............
    Attached Thumbnails Attached Thumbnails How much does your 29er hard tail weigh?-moto-ss.jpg
    29er Ti SS Rigid / 29er SC Tallboy AL
  24. #149
    Feb 2006
    Quote Originally Posted by Le Duke View Post
    I know carbon is pretty bomb proof, but when I was buying the bar and stem I talked to a couple of my sales reps and got the same answer, unless I planned to replace the bar every time I crashed that I should stick with aluminum.
  25. #150
    18 pounds
    Attached Thumbnails Attached Thumbnails How much does your 29er hard tail weigh?-68018_541141392566266_478327639_n%5B1%5D.jpg
  1. Hard tail 29er
    By jimmyj in forum Arizona
    Last Post: 10-01-2010, 09:06 AM
  2. 29er hard tail vs. f/s?
    By jclarkhall12 in forum 29er Bikes
    Last Post: 04-12-2010, 09:19 PM
  3. FS or hard tail for 1st 29er?
    By Bobonli in forum 29er Bikes
    Last Post: 04-01-2008, 04:45 PM
  4. 29er Hard tail
    By bubbleblower in forum Ellsworth
    Last Post: 11-11-2006, 04:07 AM
  5. which 29er hard tail is the best
    By joerazlifts in forum 29er Bikes
    Last Post: 01-02-2006, 08:11 AM
