Results 1 to 6 of 6
    How to install disc brakes on a rigid fork?
    I'm swapping out the Suntour xcr on my HT for a White Bros rigid fork. I thought I was good to go until I saw the mounts for the hydraulic brakes are different, 90 degrees different and the White Bros mount is not threaded. Is there an adapter plate that I need? I'm using Skelatal brakes if that makes a difference. I've looked at both the Skelatal and White Bros sites to see and couldn't find a lick of info.
    Reputation: bryan_d's Avatar
    Adapter based on your Brand and disc size.
    Just keep pedaling, don't stop pedaling.
    Sources? I saw that Skelatal brakes are made in England. Who would carry an adapter here in the U.S.?
    hispanic mechanic
    Reputation: sslos's Avatar
    The WB fork is post mount (74mm,) as opposed to your other fork that I'm assuming isa 51mm International Standard. As Bryan said, the specific adapter will depend on rotor size, but shouldn't be brand specific.
    Los
    Whiskey is my yoga.
    dongerparty.com
    Aug 2010
    according to clarks website they skeletal brakes can be installed on forks with post mounts. the brakes you have might already have the adapter however in your case you wouldn't need it since the fork has post mounts on it.
    I just mentioned the brand because I assumed things like Avid's CPS system would dictate different mounts even with same sized rotors. Could be wrong though.
  1. How to install Avid BB7 disc brakes
    By dog.gone in forum Brake Time
    Last Post: 01-31-2014, 05:18 PM
  2. how do i install disc brakes???
    By vqdriver in forum Brake Time
    Last Post: 05-23-2009, 12:01 PM
  3. install new fork and disc brakes, how to do it???
    By evil monkey in forum Beginner's Corner
    Last Post: 07-22-2007, 10:05 PM
  4. What shop to install XTR disc brakes
    By xbiker in forum Brake Time
    Last Post: 06-29-2007, 03:31 PM
  5. Replies: 0
    Last Post: 06-22-2005, 10:52 AM
