• 12-12-2012
    John.K
    How hard is bikesdirect's bike assembly?
    So after stopping biking for roughly 10 years, I am ready to jump back into the sport for leisure. Been lurking the forums a lot for the pass few weeks and have decided to purchase a Motobecane Fantom 29er Elite and have couple of questions if I may please get some assistance. :)
    1) How difficult is the assembly for someone who hasn't build many things? I have absolutely no problem assembling furnitures and computers etc but never anything with moving parts.
    2) Would you recommend me paying a bike service center $150+ to assemble a bike?
    3) Does a brand new bike require tuning etc? If I do decide to assemble myself, would I still have to drop it off at a LBS for tuning?
    ** I would post the link to the bike but I'm not allow to post links.
  • 12-12-2012
    ftajiri
    Pay a pizza to a friend :D unless do you to bleed the brakes you can assembly in home
    Send from Tapatalk via GalaxyTab
  • 12-12-2012
    John.K
    Wish the had a friend that's into mountain biking =(
    Is it required to bleed the brakes on a brand new bike?
  • 12-12-2012
    TiGeo
    Its not hard. BUT, assembling a bike correctly is more than just slapping on the front wheel and straightening the stem - to do it right there are lots of small things that should be done. Honestly, based on your description, pay ~$75 and have a shop do it. $150 sounds way high. We typically charged the price of a tune-up at the shop I worked at to assemble a bike.
  • 12-12-2012
    mitzikatzi
    This site might help.
    Shop Talk
    If you have to start paying for assembly help and/or tuning it might end up being cheaper to buy a bike from a local shop. They come assembled and tuned and often with a period of free servicing.
  • 12-12-2012
    ftajiri
    Omg... In Brazik this service cost less 20bucks.... I go to USA to assembly bikes :D
  • 12-12-2012
    John.K
    Oh wow, I've call around a few shops and all have quoted me $100+. R.e.i wanted close to $200 :eek:
    On a side note- Does anyone around the Atlanta area know of a reputable bike shop that will do it for a reasonable price?
    Excellent! Thanks so much for the link. Too bad I can't reverse the purchase now, it has already been shipped.
  • 12-12-2012
    eb1888
    This stuff is more time than technical challenge.
    The time it takes to finish the assembly and do the initial tune is going to be well spent. LBS techs don't offer trail side assistance. What you learn is what you'll need on the trail.
  • 12-12-2012
    mitzikatzi
    This
    Buy a "cheap" tool kit or a few select tools.
    Plenty of info around on how to work on bikes. Parktool site is good. Lots of you tube videos, ask here. Learn to do it yourself. take your time you will be OK. Enjoy your new bike.
  • 12-12-2012
    TiGeo
    I think some shops dislike people who buy online so they jack up their assembly costs..terrible. Yes, doing it yourself is great and will teach you a lot. Just keep in mind the bike has not been adjusted beyond the quick work done at the factory. The derailleurs and brakes will likely need tweaking. The disc brakes should not need bleeding. The wheels should be straight but often they can require minor truing. All bolts should be checked. All bearings that are adjustable (not so many of these anymore) should be checked for proper tension. You should grease the threads of any bolts you work on. Finally...it's an important one..check the rear derailleur limit screws so your derailleur doesn't end up in your spokes!
  • 12-12-2012
    duncaterro
  • 12-12-2012
    PrincipalRider
    Would you consider yourself mechanically inclined? If so, bikes are simple. I bought a Mercier road bike a long time ago and it was pretty easy to put it together. I learned how to do all of my own adjustments because I was tired of paying for a shop to keep my bikes for a week at time. Its basically just nuts, bolts, and cables.
    I bought a book called Mountain Bike Maintenance and it pretty much taught everything about bikes except suspension. I even built wheels by following the directions in that book and they always stayed true. I still shop at the LBS, but only when I need parts or tools. Never for service.
    BTW, suspension is easily learned by watching videos on youtube.
  • 12-12-2012
    De La Pena
    An experienced bike builder will take it from box to sales floor in 15 minutes.
    An inexperienced, but reasonably mechanically inclined person will assemble it in 30-45 minutes and then take an additional 10-30 minutes to tune it.
    One word of caution. Make sure every nut/bolt is tight, especially those the factory has already put in place, and use a torque wrench for those bolts that have prescribed settings according to the manual as to not over tighten key areas.
  • 12-12-2012
    mattnmtns
    Do it yourself. Its really not hard. If you have no experience with the different components do your research ahead of time. I assembled my wife's BD bike in about an hour. That included adjusting the derailleur, aligning the brakes, and double checking everything.
    Lots of good advice so far.
    As already stated, even if you are a total noob you will come out of it knowing more about your bike and how it functions. That can and will pay off down the road.
  • 12-12-2012
    Blister Butt
    As has been said, a good shop will charge you the price of a tune-up to assemble the bike, because that's really what's required to ensure that the bike is properly set up. A second-rate shop will tell you they can assemble it in a half an hour and charge you whatever the hourly rate comes out to.
    As also has been said, if you are for some reason afraid to pay a shop what it's worth to properly assemble your bike, then you should think very hard about purchasing a bike from your local bike shop. This is a great time of year to do just that as most shops are closing out the previous year's models.
    The bike shop you choose to purchase your bike from should be the one that wants to charge you the cost of a full tune-up to assemble your bike, not the shop that wants to charge you a half hour or 45 minutes worth of the standard labor rate.
    I hope your experience turns out well!
    Best regards,
    --Jim
  • 12-12-2012
    mitzikatzi
    Best regards,
    --Jim
    A nearby shop charges $80 per hour. To me that seems like a "'fair" hourly rate.
    I like an hourly rate YMMV
  • 12-12-2012
    wmac
    You might find this place helpful: Open Shop Hours Sopo Bicycle Cooperative
  • 12-12-2012
    sauprankul
    I have a 3 car garage that was converted to one car.
    I had recently moved, so the one car garage was packed with boxes and crap.
    I assembled mine there in around 1/2 hour I think. Plenty of cussing and knocking things over.
    And it never occurred to me that I could use my backyard the size of a basketball court! :madman:
    Now I look back at it, and I think to myself...
    WTH was I thinking? It really isn't very hard at all.
    Then you get to the adjusting. It really sucks because you have to check everything. You don't know if you went over everything. I have some form of OCD, as some (many) mtbrs have noticed and everything HAD to be adjusted perfectly. The brakes and front derailer were PITAs. My chain rings weren't true.
    For some reason, my derailer cables are contracting gradually. I kid you not. Now my front barrel adjuster is screwed in all the way, and the thing will barely shift down. It kills me. :madman:
    Or maybe I'm delusional.
    /rant
    Don't let the assembly get between you and an internet bike. If you're a real man, then putting it together will come to you naturally when you touch your tools. Like when Buddha achieved Nirvana by sitting under a tree. :p ;) lol jk haha /joke. Yeesh! Not trying to be sexist or bring up religion or w/e.
    Sorry guys. Too much chocolate. And both us jolly fellows at mtbr and YouTube got your bike. I mean back.
  • 12-12-2012
    wmac
    Sau: shift to your small chainring and big cassette cog, detatch the f. Der. Cable from f der. Adjust barrel adjuster to middle of adjustment range. Adjust low screw limiter of f der until the inside of der is just barely not touching chain. Re-attach cable to f. Der.
    Shift to big chain ring and little cassette cog. If you cannot shift to big ring, adjust high limiter screw out until you can. Adjust High limiter screw until the outside of f der is just barely not touching chain.
    Shift to middle ring, little cog. F der should not touch chain. If it does, adjust with barrel until it just barely does not touch.
    Shift to big cog. F der should not touch chain. If it does, adjust with barrel until it just barely does not touch.
    Now, shift to little cog - it should not touch. Shift to big cog, it should not touch. Shift to little ring. It should not touch. Shift to third smallest cog. It should not touch
    Shift to big ring. It should not touch. Shift to third biggest cog. It should not touch.
    All done.
  • 12-12-2012
    sauprankul
    Small small and no chain rub? :confused:
    Sorry about the derailer rant. I know how to adjust my front derailer. But the cable seems to be contracting over time. I'll get to it later, but I'm just tired of screwing with it.
    Not to mention the barrel adjusters on my EF 51s are crap. I think the barrel adjusters are slipping somehow. The ferrule/housing is moving within the shifter. Just crap.
  • 12-13-2012
    wmac
    Not sure I wrote small/small. You shouldn't be in small/small or big/big. Cables can shrink with low temps. This procedure is routine and takes about ten minutes.
  • 12-13-2012
    TiGeo
    Really? Wow, I think you are way off. 15 minutes isn't enough time to properly put a bike together.
  • 12-13-2012
    CB2
    If you brought a bike, un-assembled in a the box to the shop I work at we'd charge you more than the price of a tune-up; probably double. Now bring that same bike unpacked with the wheels on and you're looking at the price of tune up.
    It's rare that we have to cut brake lines down and bleed brakes on a new bike.
    The quickest anyone assembles a boxed bike where I work is a little over an hour, and that's if it comes out of the box with the bearings well adjusted, and the wheels true.
  • 12-13-2012
    ftajiri
    Wacth some videos... Parktool has a lot of diy on youtube and... Sram also hava a channel videos on yt
  • 12-13-2012
    Lenny7
    Bikesdirect bikes come more than 90% assembled. If you know what you are doing it won't very long.
    OP, learn to do it yourself. You can learn pretty much everything from youtube.
  • 12-13-2012
    Fleas
    Do it. It's fun!
    Most experienced bike builders have a method or sequence that makes it faster and more orderly so they don't forget any steps, but it is not hard.
    Be thorough. Check that every part was installed correctly (i.e. nothing loose, nothing too tight). I find myself actually loosening some stuff and re-tightening it just to make sure it is torqued properly when I'm done.
    Use the right tools.
    Getting your wheels true and tensioned before you ride will pay off big time later on. I got a really tweaked set from an internet bike purchase once that took a long time to make right.
    New hydro brakes should be all ready to just bolt on and go.
    In the worst case, you slap it together and drop it off at your LBS for a tune-up. Just make sure all the parts are there.
    My pet peeve is that I HATE starting a build and then getting interrupted and having to come back to it later. Don't be in a hurry.
    Have fun!
    -F
  • 12-13-2012
    TiGeo
    Amen brother...15 minutes...I ain't buying a bike at the shop ;)
  • 12-13-2012
    AZ
    At Walmart?
  • 12-13-2012
    Glide the Clyde
    @6bobby9:
    15 minutes from box to floor? To unpack, basic assembly and torque check all fasteners, check wheel true and tension, adjust calipers/pads/cables, adjust drive train, air up tires, put a for sale sign on it?
    Real time video or I call total BS.
  • 12-13-2012
    roadie scum
    1 hour + or - depending on the wheels and if they need to be trued up. Now wallyworld is probably far less than that, being all about quality and all that.
  • 12-13-2012
    jochribs
    A fifteen minute bike build is one where the mechanic simply opens the box, throws the seatpost in, clamps it in the stand, straightens the bars, throws in the front wheel, attaches the front brake and throws it through the gears to see if it generally shifts. Might adjust at the barrel adjuster.
    The bike is not ready to be sold. Period. It's a half-assed way of doing it, to simply get it out on the floor, so it's there and can be seen. Issue with this approach is that the bike still needs to be gone over a bit more thoroughly at the time of a test ride (and then hopefully sale) so you haven't saved anymore time in the long run. You've actually added it to the ass-end of the process when the customer (and you) want a smooth efficient process/sale. Having the bike go out on a test ride without spending this time (which doesn't have to be a full hour... it depends on the bike level really...but definitely not 15 minutes) is that it can leave a bad taste in the customers mouth because being "speedy" AKA half-assed, was the priority.
    There are a lot of small details to assembling a bike that are all important, and generally aren't going to be thought of or looked for by the first time builder. Derailleurs are often crooked, and or set too high, cables are often clamped in positions that aren't optimal...ie, the barrels are halfway out already and the derailleur is still not shifting properly. At that point, you've got to expose even more barrel to adjust cable, which is just fundamentally wrong. Set screws are off. Brake pads are contacting rim terribly, or calipers are uncentered etc. Both of which will cause accelerated wear, as well as poor performance. Wheels can be out of true, out of dish, you name it. rear hangers can be bent, out of alignment. Etc. etc. etc.
    When manufacturers box bikes, they box them with the mindset that close enough is good enough to get it in the box and to you. Some are better than others, but you always make sure. You don't just build on "robot mode".
    I've worked as a mechanic since '97 and this is true of all brands and quality levels. Building a bike in fifteen minutes and calling it done, is doing nothing to separate the 'bike shop' from the 'department store'. And that's what the customer is coming there for in the first place...reliabilty and quality.
    To the OP, yes you probably can assemble the bike yourself. It ain't rocket science. But, are you going to miss stuff that an experienced mechanic wouldn't? It is most likely. That's not an insult, it's just to be expected...you haven't done this before. My recommendation is to find a shop that you can talk with, and aren't utter snoots...ask them if they would be willing to build the bike for you and run you through the process at the same time. I never had a problem with giving advice to people...I actually appreciated their interest, and they appreciated my being happy to help them. You make good customers that way.
    And don't necessarily balk at the labor charge. It is the way the shop makes money. Don't get hosed, but don't be a stingey scrooge either. $75 to have your bike dialed isn't a bad price. Even 10% more than that ain't bad.
    For what it's worth...
    Good luck
  • 12-13-2012
    TiGeo
    Good luck
    You hit the nail on the head...nice post.
  • 12-13-2012
    jochribs
    Thanks man. I just feel that in the long run, he'll benefit from this the most.
  • 12-13-2012
    TiGeo
    ^^^ Yep. Even with a $75 build, he is going to be ahead in terms of price. I built a lot of bikes in the 4 years I was a wrench and I just don't think folks that buy these online bikes realize what actually goes into putting one together properly. With that being said, there are plenty of shops that do the 15 minute build as well and you don't want to pay $75 for that. One of the selling points of the last shop I worked at vs. our competitors was that we did a top-notch assembly of the bikes.
  • 12-13-2012
    De La Pena
    I worked at my LBS for a few years while in school and have assembled a few hundred bikes. The bikes are 80% assembled out of the box. It would take me 10-15 minutes per bike followed by a short test ride on our little test track out back. It's so simple it gets boring. If you don't believe it IDFC, :rolleyes: this shop is a regular winner for bike shop of the year in my city so we/they must be doing something right.
  • 12-13-2012
    coot271
    My friend, its easy. My Outcast was a simple build. There weren't any gears/ders to speak of, so assembly was a snap. I have since upgraded it to gears and have replaced almost everything else on it myself. Im the process, I have learned a great deal about bike building/adjustments----it just goes with the territory:D. If there is something that is beyond your technical skill, then try your LBS. If you want to try and do it all, then use some good references....many adjustment/repair tutorials can be found on youtube. Have fun:thumbsup:
  • 12-13-2012
    kjlued
    Bikes direct is a good online retailer but there is a lot to be said about supporting a business in your community.
    Sure, you can learn to do it all yourself through youtube (it is what I try and do and have been successful so far) but it is nice to start off with a professionally set up bike so you know what right feels like.
    A LBS will help you find the right size, set it up, tune it and have you ready to ride.
    Often they offer free tune ups (some even offer free life time tune ups).
  • 12-13-2012
    Axe
    Took me about half an hour to get my Fly Ti assembled (attach bars and wheels pretty much), double check all bolts, adjust air pressure, adjust calipers, put on pedals, ride around the block and adjust shifting. But then I usually do know what I am doing with a bike.
    It was very well tuned out of the box. Wheels had been true and stayed true. But that was their high end titanium model, so maybe whoever packs it in Taiwan pays a bit more attention.
    I would not recommend an online purchase to anybody who does not know how to perform basic adjustments. But it ain't rocket science, and do not let LBS employees browbeat you out of a sensible purchase.
  • 12-13-2012
    ghettocop
    To the OP..... Do it! It is fun and rewarding to work on and build your own stuff.
    I work at an LBS and would never "browbeat" anyone out of working on their own stuff. That's how I started, and I'm sure every other tech out there started by working on their own things.
    To 6bobby9.......... I call ******** on this 15 minute thing. It takes me 15 minutes just to cut all the packing tape and protective wrap on the frames and install the reflectors.
  • 12-13-2012
    De La Pena
    Then you're slow. Really slow. You just might be the guy I was hired to replace. We would have laughed and made fun of you. Whats not to understand? When you build these things day in and day out it's second nature.
    1. Open box. (5 seconds)
    2. attach seatpost and pull bike out of box and clamp on to stand. (30 seconds)
    3. tear off packing (20 seconds)
    4. attached bars and tighten levers and shifters. (60 seconds)
    5. mount front wheel and adjust front brake (60 seconds)
    6. adjust back wheel and brakes (60 seconds)
    7. Pump front and rear shock. (60 seconds)
    8. Air up tires with shop compressor (30 seconds)
    9. Attach pedals (30 seconds)
    10. Adjust front and rear derailleurs (90 seconds)
    11. Take a drink of favorite beverage (60 seconds)
    12. Check wheel tru (30 seconds)
    13. Secure and torque all bolts. (180 seconds)
    14. mount reflectors (60 seconds).
    15. Record serial number and affix price tag to owners manual (60 seconds)
    16. Remove bike from stand and make any final saddle adjustments. 60 Seconds
    17. Test Ride.
    If I am not mistaken, that's around 14 minutes there.:eek::eekster:
    WIN. :thumbsup:
  • 12-13-2012
    AZ
    Walmart build.
  • 12-13-2012
    De La Pena
    Originally Posted by AZ.MTNS View Post
    Walmart build.
    Is that where you got your bike? uhhh. ok. lol.
  • 12-13-2012
    AZ
    What a brilliant retort.
  • 12-13-2012
    De La Pena
    Yup. Took me less than 15 minutes to come up with that one too. I am genuis.:cool:
  • 12-13-2012
    roadie scum
    17. Test Ride.
    WIN. :thumbsup:
    Do you know what the difference is between a trained monkey and a bike tech? Yep, about 45 mins.
  • 12-13-2012
    De La Pena
    If you put down the pipe you might have a future.
  • 12-13-2012
    roadie scum
    Dude, there is no shame in your employment at walmart. Keep trying, they might even bump you up to assembling grills. Fly the flag proudly.
  • 12-13-2012
    Glide the Clyde
    I say we neg rep bob69by back to something rivaling DC. Make him our boy.
  • 12-13-2012
    TiGeo
    Do you use air tools when you build your bikes?
  • 12-13-2012
    sxshep
    I'm getting my Fantom29 X7 tomorrow, but probably won't "build" it until I'm off work Monday. Tomorrow morning I plan to piece together a DIY PVC stand and clean out some space around the workbench. I picked up a pedal wrench, tire pump and a few other tools today from my LBS and should be good to go. Just need to keep reading (hydraulic brake adjustments, wheel truing, etc) and I'll be good to go. It's cold out and I'm a pretty patient person when I'm doing something I don't want to screw up, so I will probably drag out the assembly process to 18-21 minutes... tops.
  • 12-14-2012
    TiGeo
    I can see this post has degraded....goodbye.
  • 12-14-2012
    De La Pena
    Hate all you want. I have way more positive than negative rep in this thread. And no. I did not rep anyone positive or negative. The rep thing is actually kind of dumb now since the give me rep thread started..:rolleyes: Rep is meaningless here, rep on the mountain is where it matters.:thumbsup:
  • 12-15-2012
    sxshep
    Went together fairly easy (I've never done it)... I took my time, probably over two hours or so. Everything is done except the grips/minor adjustment to the handlebar, and the rear derailleur needs adjusted. Overall, the whole bike is pretty well assembled (no loose nuts, rattles, etc). I'll probably order a new stem and a Garmin Edge 200 in the coming weeks.
  • 12-15-2012
    ghettocop
    Congrats on your build man. Here is a tip to take the mystery out of rear der adjustment/indexing.
    Set your high and low limit screws. To set the high, disconnect the cable. The der will automatically spring out to your highest cog. Visually align the upper jockey wheel to just on the outer edge of the smallest cog using your high limit screw. Now pull the derailleur by hand up to the lowest (biggest cog) and adjust your low limit screw so the upper jockey wheel is just to the outside of the largest cog, but will not go past that point even by forcing it with your hand.
    Now, run your barrell adjuster clockwise all the way in until it stops. Then back it out counter clockwise one full turn. Attach your cable, making sure your shifter is in the highest gear. Pedal the bike and shift down one gear. (it probably wont shift). While pedaling, turn the barrell adjuster counter-clockwise until it shifts. Done. It's indexed and should be fine.
  • 12-22-2012
    TiGeo
    The new rep system has you showing up as the neg repper. At least be honest and don't lie about leaving it
  • 12-22-2012
    jochribs
    Run for office...
    "I build in 15 to 20 minutes also and I AM a tech." ....Your words verbatim, and the reason you gave me negative rep.
    Seriously man? That was the reason you negative repped me? Unless you have doubts about your build quality in that amount of time, I can't see the psycology in feeling the need to negative rep someone because they simply said that a solid build in the majority of cases is not going to be accomplished in that amount of time.
    No need to get vindictive because another members opinion on a matter differs from your own.
    ...and I still won't neg rep you...it's pathetic.
  • 12-22-2012
    jochribs
    and hey, to the OP...Good work man! I'll eat my words.:thumbsup:
    *edit* sxshep isn't the OP, woops!
  • 12-22-2012
    Fred Smedley
    17. Test Ride.
    WIN. :thumbsup:
    So this is why I don't want a cheap bike from any manufacturer set up at your shop. A cheap bike will most likely have the axle cones to loose or two tight. 150 miles down the road the cheap wheels are now toast. The cheap wheels will most likely have insufficient spoke tension, how about Headset tension, again a hand full of rides and guess what, do you see where this is going?
    To the OP , check CL , there are qualified mechanics working at home who moonlight or are out of work and are quite willing to spend a hour or two at $ 25.00 a hour to take the time to set up your bike correctly and will then make a free cable tension adjustment after a few hours of saddle time while showing you how to do it yourself.
    I bought a 2012 Trek Wahoo for my wife so she could try the 29er thing. It was a smoking used deal from CL from a collage girl whose Daddy had bought here a mountain bike because he was into it . She wasn't so I got a essentially new Trek with all the maladies I described above plus a squealing front brake which is the reason the girl dumped it for half of new. This bike was set up by a Trek dealer doing the 15 minute set up.
