Results 1 to 59 of 59
    Superflying on Haven
    Reputation: Menzo's Avatar
    Nov 2007
    How to : Extend a 400mm seatpost
    I have a short torso with long legs. When I need a bike, I'm in between two frame size. I need a medium frame (usually with a 80mm stem) for my torso but I would need a large frame (19 inches seat tube) for my legs. Most people always told me to get a large frame but I don't like the handling. Here is my solution that I share so that it may help other people who have the same problem and need an extension on a 400mm seatpost. This is for a seatpost with a 30.9 diameter.
    You need to "sacrifice" an old 30.9 seatpost and a 27.2. Cut a 27.2 seatpost (the lenght you need) and insert it inside the tube of the 30.9. Then cut another 30.9 and use it as a shim over the 27.2. It is supposed to fit very very tightly but maybe a bit of sanding will be necessary. Use some JB cold weld if necessary. As you can see on the pictures, it will extend your seatpost enough to avoid a cracked frame. My seatpost went from 400mm to 485mm (I know, I know... the Ritchey seapost has a particular shape at the bottom) . I used this trick for few years and I never had a problem.
    I hope this may help someone
    Attached Thumbnails Attached Thumbnails How to : Extend a 400mm seatpost-ext-1.jpg
    How to : Extend a 400mm seatpost-ext-2.jpg
    How to : Extend a 400mm seatpost-ext-4.jpg
    How to : Extend a 400mm seatpost-131-3172_img.jpg
    How to : Extend a 400mm seatpost-131-3171_img.jpg
    I would take to a local machine shop and have it welded rather than JB weld. Good thinking!
    Holy Long Seatposts Batman!
    Nice job and ingenuity. How about a picture of you riding it? I'd like to see what that looks like. Is that a weird request?
    I think you need some riser bars, maybe a set from an old Schwinn Sting Ray.
    Plays with tools
    Reputation: customfab's Avatar
    I would prefer it to be welded together but then it would need to be heat treated ideally.
    I did a similar job on the fork for my cruiser, steer tube was to short so I found another steel steerer and added it on.
    Mar 2005
    I did the same thing a few years ago on my fisher 292. I used hysol 9430 epoxy, which is 10 times stronger than welding. I would never weld the seatpost in this situation. JB weld is also a very good product, I've repaired lots of aluminum products with it and it has never failed.
    Would that not put a sketchy amount of leverage (= flex) onto your frame?
    Thats one of the worst examples of forcing a frame to fit I've ever seen. Congratulations. Your extending a seatpost and commenting on the 'handling' of a larger (one size, no differences other than slightly longer TT and more seat I'd bet) frame are mad. I hope your medical insurance covers you for the accident.
    Reputation: tmccrohon's Avatar
    Good god man. You need the next size up frame! Your seat is way too high. You would be better off changing cockpit (stem big sweep bars, saddle forward) then monkeying around with the seatpost. Your seat is WAY too high. your center of gravity is compromised. Be careful!
    29ers are more fun!
    Reputation: seat_boy's Avatar
    Changing frame sizes won't change his center of gravity at all. That's based on how far he sits from the bottom bracket, which is independent of his frame size (assuming he gets his targeted leg extension on both sizes)
    Quote Originally Posted by tmccrohon
    Reputation: brant's Avatar
    OP :: Seeing as you're using an inline post with the saddle centred on the rails, I'd think a "next size up" with an inline post would be OK for you. But YMMV.
    memento mori
    I'd guess Seven,Moots,or even Thompson can and would make a custom post for ya.
    TR
    TR is offline
    Angry bunny
    Reputation: TR's Avatar
    I would love to know some body dimensions that needed that "fix".
    You're right. I was thinking in terms of leverage. Moving the saddle (work) away from the fulcrum would make the bike top heavy. maybe mythbusters can tackle this one..lol
    29ers are more fun!
    Nov 2007
    It's always funny to read the comments of people who don't know me, never see me and are not inside me, telling me what and how I should setup my bike. You guys should make kids so that you can teach them all your knowledge... They'll worship you
    Have you ever heard of a guy named RYAN TREBON. Believe me, my situation is ten times better than him
    bike tester
    Reputation: syl3's Avatar
    Clearly you're not manly enough to ride gnarcore stuff, otherwise that seatpost for the price of 3 would have failed a long time ago.
    Currently in Exile
    Reputation: Frozenspokes's Avatar
    Menzo, what exactly are your dimensions? I have relatively long legs and short torsos also. My inseam is 32" and I'm 5'6" tall. I always choose frames based on top tube length and normally end up on a med/17"/18" frame.
    Have you looked into custom builders?
    "There are those who would say there's something pathological about the need to ride, and they're probably on to something. I'd wager though that most of the society-approved compulsions leave deeper scars in the psyche than a need to go and ride a bicycle on a mountain." Cam McRea
    Reputation: Team Fubar Rider's Avatar
    Sep 2003
    I would second the idea of getting a custom frame. Any builder can easily make a frame for you that accommodates your unique issues.
    Ingenious job making your seatpost work, but I'd worry about having something like that put together in the region by my sack!
    bonked
    Reputation: IF52's Avatar
    Or how about a woman specific frame. I'm not joking or trying to be a smart a$$, but women typically have longer legs and shorter torso, so frames designed specifically for women typically have shorter top tubes than 'typical' frames. And you could always put a decal over the model name if it's called something like the princess or the butterfly.
    Quote Originally Posted by banks
    That is one big f'n dude!
    Yes I am!
    Waiting for Godot
    Reputation: OilcanRacer's Avatar
    50mm stem and the next size up frame would be a better idea.
    Out riding, leave a message
    nice fix.
    now to more pressing questions. Where the hell do you buy pants?
    TR
    TR is offline
    Angry bunny
    Quote Originally Posted by singer
    nice fix.
    At a pants party???
    Nov 2007
    Menzo, what exactly are your dimensions? I have relatively long legs and short torsos also. My inseam is 32" and I'm 5'6" tall. I always choose frames based on top tube length and normally end up on a med/17"/18" frame. Have you looked into custom builders?
    I'm 5'10" with a 35" inseam. I'm right on the fence of Medium/large. I tried a large frame with a very short stem (60mm) and it felt like I was riding a Jesse James chopper bike. The wheelbase is too long, the handling awful.
    Plays with tools
    Quote Originally Posted by Menzo
    except Ryan is lucky enough to have custom FSA seat posts. He runs more drop on his mtb than most pros run on their time trial bike, wow. really is pretty oddly proportioned. The townie bike I built for him has a head tube that's almost a foot long
    don't bother listing to unsolicited fit advice, the internet breads experts and idiots faster than anyone can imagine. Although your solution is unorthodox to say the least I think it's pretty sound considering you almost have enough seat post in the frame without your extension, your just buying your self a little insurance.
    27mm difference in the wheelbase between Med & Large and therefore the wheelbase is 'too long' and the handling 'awful'? Ah - OK - right - I see.
    I'm always amazed how people find ways to ride (too) small frames.
    i feel your pain, i have to ride a med niner air9 with a 410 thomson at the max with a 70mm stem. although i dont get bad handling issues. pretty much all my mtbs follow the same formula as well.
    Feb 2010
    Quote Originally Posted by TooTallUK
    Exactly my thoughts too and with a remark like "I hope this might help someone"...well yah it might just help someone being seriously injured or even worse.With all the good parts out there im shure one can find a better soultion (as said bigger frame,shorter stem,sweepback bars,ect.).I have no issues with inovation but to what cost?
    Reputation: boomn's Avatar
    i would guess that it has more to do with the 40mm shorter stem and not being used to feeling so far behind the wheel instead of over it. That difference can definitely be noticeable and can make the wheelbase feel "longer". Combine that with an actual 27mm difference in wheelbase and you certainly have a difference in handling
    Funny, you moan about the handling of a slightly longer bike, yet you run Furious Freds.
    Quote Originally Posted by monolith
    yeah he is obviously only riding in straight lines since he doesn't have real tires. Once he puts on some nice big DH tires he can comment on the handling of his xc race bike
    locked - time out
    It's not only about the insertion, but the leverage. Way to void the frame warranty. I'm sure Spec is going to be scrutinizing over any of these they get back for failure.
    locked - time out
    Pics saved for later LOL usage.
    Nov 2007
    Yep your are right
    I don't make any assumptions, unlike many comments here, I say assertions based on my experiences. I don't ride a medium just for the sake of riding a medium but because after I tried several sizes and several setup that is the one I feel good.
    Few numbers (for those who understand maths and logic) : The medium Epic has 590mm effective top tube vs 615mm for a large. The wheel base is 1109mm vs 1136. Both have the same seat tube angle 74 deg and chainstay length 448mm. Which mean going to a large extend the seat tube (ok that's good) BUT it also extend the front of the bike of a full inch. Those who say stupid things like "it makes no difference" are making assumptions. Back in the days when there was no sloping top tube geometry with freakin short seat tube I had no problem ;-)
    I think the pictures give the impression the seatpost is more extended than it is for real or maybe that it because my stem is at the lowest although the saddle and bars are almost even heiight. I don't really understand why people are raging... oops this comment will bring more rage
    I hear there are other bike manufacturers out there who have different geometry. That might just be a rumour. There will always be people totally dedicated to getting a certain bike to fit despite all evidence that another brand might be better for them.
    locked - time out
    I <3 confused mtbr bikes.
    Always Learning
    Reputation: BruceBrown's Avatar
    Quote Originally Posted by customfab
    I think that's the route I would go if I needed a really long post. Custom usually allows you to go up to 500mm long. And for a weight weenie, I am assuming it would weigh less.
    Menzo - your bike looks sweet and fast. Nice work on the seatpost work around.
    BB
    Nov 2007
    The only long seatpost available on the market is the Syntace P6 Carbon (480mm) but not in size 30.9. No custom builders where I live, I had to use my brain but the result is solid although there is a penalty of 70 grams because of the double layers.
    change is good
    Sep 2004
    You're on the wrong size bike.
    I hear that alot. 5'11" with over a 35in inseam. I feel the OPs pain. You should see the length of the head tube on my custom Lynskey road bike. The solution - custom Ti Rockstar. I'm more than willing to spend your money.
    The Serotta Tech with years of experience that fitted me told me he only had one other customer with such atypical proportions. Some people are just on the end of the bell curve.
    Nov 2007
    I think that JHK's seatpost is way too high and its frame undergoes too much leverage and might break...
    Attached Thumbnails Attached Thumbnails How to : Extend a 400mm seatpost-jhkscustomsf100.jpg
    Reputation: laffeaux's Avatar
    It's funny how a group of people who actively encourage 5'2" rider to buy 29er also talk about how a rider using a 80mm stem on an XC bike needs the next size up. One size MUST fit all!!
    Nice looking bike. Good job making it work better for you.
    Each bicycle owned exponentially increases the probability that none is working correctly.
    The White Jeff W
    Reputation: jeffw-13's Avatar
    Quote Originally Posted by laffeaux
    ..and how the standard mantra around here is 'go to the lbs and buy the bike that feels best' but when this fella says the bigger bikes don't ride well for him he's doing it wrong.
    No moss...
    Clever solution by the op. Part of the problem is the radical slope on the top tube. Other brands of medium bikes would probably fit him without so much seat post needed.
    bike tester
    Quote Originally Posted by jeffw-13
    my main problem with this is that i doubt the OP tested other bikes/sizes for long enough to get over the "it feels wrong because it's not what i'm used to".
    a parking lot ride definitely won't do it.
    Reputation: Minimalist's Avatar
    Quote Originally Posted by syl3
    Let me get this straight, you insult somebody based on an assumption that this person didn't buy a bike according to your standards without knowing anything (or not much) why this person purchased the bike under what circumstances?
    Quote Originally Posted by Minimalist
    You call that an insult? Dry your eyes, princess and a hug will make it all better.
    Reputation: sanjuro's Avatar
    Sep 2004
    Welcome to the Internet!
    Quote Originally Posted by sanjuro
    I know, but sometimes I wish that the dull tools would just shut up. Guess I am a dreamer.
    Sep 2004
    Btw, based on the stem length and the assumption the rider does fit this bike correctly, I just wonder how the frame will hold up with a longer seatpost. Time will tell.
    Personally, I would save my pennies for a custom frame.
    Looking back on the OP, he says that he "used this trick for a few years". So, whether you like it or not, it seems he has proven this as a reliable solution for himself.
    Being a short legged guy, I never have a whole lot of seatpost sticking out and it does look like there would be a lot of stress on it, but how much stress is too much? They make 400 mm seatposts, and that seems like a lot, but they work, so why can't 485? Apparently, it does work for the OP.
    M_S
    M_S is offline
    Nov 2007
    Going out on a limb here, but the OP also may well not be as fat as the average mtbr user, and it sure seems like leverage on the frame is also going to be determined by the weight on the seat, hm?
    While not as extreme, I have similar issues sometimes with fit (longish legs to torso) so I can understand the issue. I am a little bit taller though, and usually end up on large frames. Not always.
    But no matter, the mtbr types will just go on riding their rigid singlespeeds with weird looking handlebars and flat pedals around the upper midwest, complaints and criticisms drifting on the breeze.
    Nov 2007
    I started this thread to share my positive experience, to say "here is something that has been working very well for me, maybe it could work for you too". Bottom line.
    If you don't like the idea, I agree that you say it but there is no need to tell me that I'm an idiot unless that spitting you disdain makes you feel good inside. Why this need to be so negative ?
    Nov 2007
    I uploaded new shots but it still look worst on the pictures than it is. Maybe it's like being on TV that makes you look like taller or fatter than you really are.
    What about this guy's bike? Most would say he's on the wrong size bike too. But the owner seems to be fast enough on it.
    <img src="http://cdn.mos.bikeradar.com/images/news/2008/12/23/1230026320789-106b6cagp071t-500-90-500-70.jpg" height="330" width="500">
    Reputation: schnee's Avatar
    hey now
    The White Jeff W
    Agreed. I expect this sort of nonsense in the middle of winter when no one can ride and everybody is *****y.
    I'm kind of a freak show myself, all arms & legs, so I dig your ingenuity. If you saw the things I have to go through to make a pair of hockey skates fit.....
    No moss...
    Blanco
    Personally, I would have bought a seatpost shim. But perhaps I'm misunderstanding the problem...?
    Actually, Menzo's riding position isn't all that bizarre...the bars aren't that far under the seat. It's the fact that he's on such a small frame because he likes the shorter top tube that makes it look weird.
    My back and neck are hurting just looking at that picture.
    Reputation: jetraid's Avatar
    I've in front of me a 500 mm Shannon headtube (made in Germany by vanBokhoven) seat post...
    Reputation: jetta_mike's Avatar
    Feb 2007
    I feel your pain Menzo. I'm 5'8" and am the proud owner of a 33" inseam. On my HT I run 400mm seat post extanded about 10mm past the "danger line" on my medium frame. A large fit my lower half perfectly but was just too far a stretch. What the MTBRetards aren't understanding is that if your inseam is 3" longer than a "normal" individual, then your torso is 3" below average. That means going to the next size up would make it waaaaay to big.
    Nice solution to a not so common problem.
    Here's my rig.....with the seat not all the way up :P
