Results 1 to 10 of 10
    Help- Removing Stuck Tire from Wheel
    I'm trying to remove a stuck worn tire from a 29" wheel. I can break the bead on the one side but the other side is stuck/glued and won't budge. Tubeless setup with Stans. I've tried prying with tire levers but can't get the lever under the bead. I've also tries grabbing the tire with vise-grips and pulling with no luck. Even had an LBS shop try and they couldn't budge it either. Short of cutting it off, any ideas?
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Tire pliers.
    Have you tried some heat from a heat gun, I would not recommend a propane torch with AL. Might have bigger problems.
    Might Call Stans and see if they have a solution.
    Todd
    Northern Aggressor
    ready to ride
    Reputation: mattnmtns's Avatar
    I would try boiling some water and pouring it on a section and see if it loosens it up.
    If that doesn't work you could try something like this
    Silicone Latex Caulk and Foam Sealant Remover : TAP Plastics
    Sent via my heady vibes from the heart of Pisgahstan
    No Clue Crew
    Apr 2005
    Geax tire with TNT casing? A good shop, particularly one that works with DHers, should have a few moto-style big metal tire levers/spoons. They'll do the trick.
    Specialized Captain tire. I'll try hot water or a heat gun and see if that does the trick. Thanks for your suggestions.
    Reputation: Stopbreakindown's Avatar
    Have your husband remove it for you.
    Look on the bright side, it probably never burped, did it?
    No Clue Crew
    Apr 2005
    Quote Originally Posted by Stopbreakindown View Post
    Now that's good comedy.
  1. Ideas for removing stuck dampners from legs
    By Dan Zulu in forum Shocks and Suspension
    Last Post: 11-05-2012, 11:03 AM
  2. Removing stuck zerk fitting
    By dropadrop in forum Intense
    Last Post: 05-14-2012, 12:02 PM
  3. Removing a "stuck" wheel from a Lefty?
    By grnamin in forum Cannondale
    Last Post: 10-18-2011, 10:31 PM
  4. removing a tire off of wheel, why so difficult???
    By jojotherider in forum Wheels and Tires
    Last Post: 09-24-2011, 11:30 AM
  5. removing/ lacing hub with FW stuck on
    By mack_turtle in forum Singlespeed
    Last Post: 05-02-2011, 01:00 PM
