Results 1 to 38 of 38
    Feb 2013
    Hayes dyno sport brake question! (Trek mamba)
    Howdy, im just starting to get into mtb. I got a trek mamba a few weeks ago, however I'm not happy with the brakes at all. I cant lock the front wheel, infact i can barely stop using the front brake. I spoke to the bike rep who kept telling me that all bikes after different, but from all the other bikes ive ridden with hydraulic brakes, they stop the bike quickly.
    Just wondering if anyone can comment on the stopping power of the hayes dyno sport hydraulic brakes? Ive ridden a mates bike with shimano's on them, just an entry level one, and it was amazing compared to. Just wndering what the hayes brakes are meant to be like and if the pads or something are contaminated/air in the brake lines?
    Feb 2013
    Also, i realised ive put this in the wrong section but dont know how to shift it... any help? lol
    ready to ride
    Reputation: mattnmtns's Avatar
    No personal experience with that specific brake but it sounds like the brake needs to be bled. Any brake hydro or mechanical should apply enough force where if applied improperly should about send you over the bars. At the very least it should give you good stopping power.
    That said all brakes aren't equal. I gave up on Avids after having them continually go soft after multiple bleeds. I got them replaced under warranty which SRAM upped the model but after that experience I had no confidence in them. Dropped some coin on some shimanos and couldn't be happier.
    That said I would go back to your LBS and get them to bleed the brake in question.
    Sent via my heady vibes from the heart of Pisgahstan
    Feb 2013
    Thanks mattnmtns. Given the bike is only a fortnight or so old ill just hassle the LBS until im happy.
    Reputation: BoomerBrian's Avatar
    I have these brakes on my trek and I am very disappointed. I bled them a few weeks ago hoping that would help but it didn't help much. I would like to hear what others say but imo these brakes suck. Wonder if new pads would help?
    Feb 2013
    Yea.. thats what i wasnt hoping to hear lol. The back brake isnt too bad, but i cant lock the front.. It doesnt matter how much pressure i try to apply i can still ride, just with alot more resistance.. Ill see what the bike shop says, but worse case, shimano brakes are looking pretty good..
    They couldn't send me over the bars if I squeezed them as hard as humanly possibly.
    I rode my buddies bike a while back and I almost went over the bars because I was use to the crappy Hayes and he had good brakes with stopping power and I squeezed way too hard.
    Post up when you find something out at your lbs.
    Feel Good About Hood
    Reputation: Pedal/Paddle's Avatar
    My buddy just got the same bike and has the same issue. I did some searching for him and there is a service bulletin on the hayes site Excessive lever throw service Look under "Documents" on the lower right of the website. He took his bike to the shop and asked them to do it. They apparently had no idea what he was talking about and told him "That is just the way hydros are, you'll get used to it" This is his first new bike in a really long time so he wasn't sure if this was true. I told him to print out the sheet and make them fix it. This thread also discusses the issue and people report good results after the service is done. Hope this helps.
    I saw that service bulletin. Bleeding them should have fixed it as well but they still have no stopping power. Fortunately the trails in Oklahoma aren't very hilly so I can live with them for now.
    Feb 2013
    Took it to the bike store. They reckon that my front pads had glazed over. Apparently hayes have brought out a new bleeding kit thing too that the shop are yet to get, but the front feels firmer.. I need to wait until the pads bed in to see if its fix. Ill be taking it back when the new kit comes in to get them redone, hopefully that will fix it otherwise i think ill splash out some money and get some shimano's.
    Quote Originally Posted by Nathax View Post
    Please report back your findings.
    Feb 2013
    Initial comments, no better. Took it for a sizable ride today, the brakes are screaming now, and i can pretty much pull the lever of both the front and back into the handle bars. Im feeling like this is a fluid bleeding issue again? Really not happy with these brakes so far.. Hopefully this new kit they get in will fix it...
    Mar 2011
    I have not had good experiences with cheap disc brakes. You can set them up to be usable, but you will not get actual stopping power until you get to the high-end stuff. If you are going to buy a new set, I would recommend Shimano XT.
    Reputation: Cenzobear's Avatar
    Oct 2012
    You say the brakes are screaming? As in they're rubbing? If so, you may have been the victim of an overheated system. When hydros overheat, all kinds of bad stuff happens. Squishy lever, no modulation, squealing noises... It seems like they might need a bleed. I'm not sure of the exact design but I know a lot of cheaper hydros succumb to sticky calipers too, when one piston sticks in the caliper and therefore half the force is lost. The only experience I have with cheaper hydros is my set of tektro dracos on my rockhopper, but even those can flip me forward if I wanted to...
    Feb 2013
    I have a mamba as well and the brakes are the same for me as well. I was comparing to a mates 26" with Shimano deore brakes and they are miles ahead of me. You need to remember that both had 160mm rotors, except there is a 11.5% increase in wheel size on the 29 over the 26. To get a similar braking experience you need a 180mm rotor on a 29er to have the same braking leverage on a 26" wheel.
    I got rid of my Hayes, and put some shimano deore and a 180mm rotor on the front. I can now wheel stand with one finger. Even my heavy arse at 250lb (110kg)
    Feb 2013
    They cant be over heating, cause they squeal even cold. I think they need a proper bleed, ill wait and see what the shop will do with a different bleeding kit before i decide.
    Ports, how much did that set you back? Ive riden a mates with shimanos and they feel so much nicer. Im toying with just replacing them if they dont after the next bleed.
    Oct 2012
    A good set of shimanos would be a world of difference, I did it for the reliability and power. My set of xt's set me back about 250 from my LBS. worth 100% of the money. No squeals, rattles, fades, squishyness... And super easy to maintain because the simply dont need much besides a pad change every blue moon. Ps- on that cold squealing: that could be the rotor vibrating from a dozen and a half other problems like a bad set of pads etc. the bleed might fix it so like you said just wait and see. I know a lot of people with higher end avids had that problem and it was never really fully resolved. They even made a solid rotor for them to try and combat it...
    2013 Rockhopper 29- The hot rod fun bike
    2013 Stumpy HT Comp 29- The racin' machine
    Bigger rotor may help but shouldn't be needed. These brakes just suck.
    Oct 2012
    +1 on that. Cheap hydros will never out perform (or even outlast) mechanicals at the same price point.
    Feb 2013
    Quote Originally Posted by BoomerBrian View Post
    I kind of disagree, in comparison of a 26 - 29 wheel when both are using a 160mm rotor, the 29" wheel has the increased wheel leverage, but the brakes have stayed the same.
    I said before there is a 11.5% size increase in the wheel, and to get the same brake increase it puts the rotor in the 180mm size range (180mm = 12.5% increase)
    I certainly DO agree that the brakes are pretty ordinary, and its probably best just to swap them out. I spoke to a Trek dealer and he mentioned that Hayes have brought out this lower end model to target the budget market. He even said they are fairly ordinary....
    Nathax, I bought just regular Shimano Deore brakes from CRC. Im in Australia so I'm not sure how much they are for you. I paid $110 for front and rear together, but i also grabbed a larger rotor and bracket to mount the calliper. I still have the old hayes brakes, if you're curious, i will chuck the hayes back on the front with the 180mm rotor and see if just the size increase has made a satisfactory improvement.
    Quote Originally Posted by Ports View Post
    My comment comes from riding 29ers with 160mm that would send me over the bars with a gentle squeeze. My Hayes couldn't do it if squeezed the handle as hard as I could.
    I am not saying it wouldn't help. I am only saying it shouldn't be needed.
    I would love to see your comments after trying them on the 180. It could be a cheap fix. I really don't want to buy new brakes.
    Oct 2012
    You have a very good point. Not to mention factoring in the extra rotational mass and momentum incurred by a size increase.(Math which is way over my head) I believe that's why many 29ers come standard with 180mm+ brake rotors.
    But once again bottom line is these brakes just don't stop as well as something only marginally more expensive.
    Feb 2013
    Awesome, im in australia too so hopefully i can get them for a similar price. Whats CRC? If its easy enough itd be interesting to see how the hayes go with the 180mm rotor on them. I daresay ill end up just getting the shimanos though, its an awesome bike... aside from the braking issues.
    Feb 2013
    CRC, chain reaction cycles? Good old google.
    Mar 2011
    I live in Australia and I use chain reaction cycles for my parts.
    Just in case you were interested
    Oct 2012
    They have great service, I just saw Shimano M445s on there yesterday for $35(American dollars) a pop, can't beat that!
    Feb 2013
    Ah cool, well i paid $147 Australian for front and rear Shimano deore brakes (levers and callipers) a 180mm ice tech rotor and a bracket for the larger disc size. For the mamba, make sure you get post to post (the rear is IS to post) for the mounting bracket.
    I'll be swap out the brakes tomorrow and get back to you. Im in Wollongong, where a bouts are you?
    Feb 2013
    Awesome, ill probably end up getting those. What model deore? Looks like there are a few.
    Funnily enough I live in kiama but work up in Wollongong haha. Small world
    Feb 2013
    Ok, i put the hayes back on with the 180mm front rotor.
    After 3-4 runs up and down the drive to see if there is any difference as it heats up. The larger rotor does help a little bit, for me the bike when i jumped on the brakes it didnt stop with any sort of urgency, now with the larger rotor, you can feel the weight transition onto the front wheels a lot more but it certainly wont lift the rear wheel. Thats having to pull the lever all the way to the bars. So not the greatest improvement, by going with a larger rotor the 11% improvement at first thought sounded like it wasnt very much. Id agree that it feels like only a 11% increse.
    To say where the most improvement comes from is certainly the brakes. The Shimanos feel a lot better, and thats where i would put my money first. Find some brakes you like, and deal with the smaller rotor later.
    Feb 2013
    I took the bike back for one last attempt, they got a new bleeding kit, but ive pretty much lined up what brakes and stuff ill be getting, im not holding my breath of this getting fixed.
    Ports, they mentioned a dude had taken his back after a bleed and got some shimano deore brakes put on, plus bigger rotors, Im guessing that would have been you. Simple cycles in wollongong?
    Feb 2013
    Yeah, Simple cycles.... pretty decent shop, Friendly as too. The brakes the came with the bike, they do as they should, It stops the bike. I was just expecting it to lock the front wheel and throw me over. Probably the same thoughts as you? I figured the larger rotor cant hurt, and the brakes from shimano, even though are bottom end, are miles ahead of the hayes. Im all for supporting the shop and buy whatever i can from there, and my next bike will be from there again.
    What did you think of the place?
    Feb 2013
    Yea, I was expecting that they would grab instantly and have heaps of feel given they are hydraulic, but just no. Got it back today after its final bleed and its just as bad, I cant stop it with the front brake, so its shimano time. Im getting deore M596 i think they were. All up its $130 including brakes, adaptors and shipping. How long did yours take to turn up?
    The dudes at simple cycle are heaps friendly. The guy thats there all the time has been heaps helpful, I cant remember his name though. Other than the brakes too the bike has been awesome, so I wouldnt hesitate with another trek. Just something that doesnt have hayes brakes lol
    Reputation: riotactor10's Avatar
    I'm running a 2012 Mamba and have had the same issues reported by the OP. had them bled and they still were mushy and ended up getting new brake pads...still think they could be better...will be avoiding Hayes in the future.
    Jul 2013
    I just got a Trek Mamba too and am having similar doubts. They were crap at first, but after "braking" them in they worked much better. You've probably broken them in by now though. Anyways, I am finding that not locking the front wheel is a good thing--especially going steep and loose!
    I purchased a Trek Mamba with Hayes Dyno Sport hydraulic disc brakes and they let me lock up the tires very easily! So far, I haven't had a problem with them.
    Sep 2012
    Problem I found on my Mambe when I had it was the rotors machined surface was machined to rough, my wifes Marlin was the same way. Once I sanded the surface down and got it smoother the brakes started to work better, but in the end the hayes were junk even compaired to the Shimano SLX brakes I put on her bike. Stops on a dime now.
    Apr 2014
    I have the 13 Mamba with Hayes and I was really close to buying new brakes until I took it down a really steep trail where I live and during the first section I thought I was going to die. But after they heated up real good (to the point that I could smell them) and then they cooled a little bit, they worked great. I couldn't dream of doing an endo stall on my front wheel before this and now I can with no problem. So if you have these brakes maybe warm them up first real good and them see if they work any better. Keep in mind I had rode almost 300 miles on the road with them and "used" them frequently but I guess that's not "breaking them in" until you really "brake" them in.
    Aug 2013
    make sure your pads or rotors arent contaminated with oil, that can sometimes happen when lubing up a bike. try cleaning then with rubbing alcohol and see if that helps.
