Results 1 to 3 of 3
    Jul 2014
    Handlebar riser issues
    I just bought a Cannondale Trail 7 and after the first ride, I wanted the handlebars to be a little taller. I'm new at the whole mountain bike thing and this is my first bike since I was a kid. I noticed that the riser and had more of downward angle and thought that I could just flip the riser and get more of an upward angle. I was correct, but now I can't get the riser to tighten down enough on the stem. Any ideas? Thanks
    Short-Change-Hero
    Reputation: gregnash's Avatar
    Little confused but think you are saying that you want more rise out of your handlebars. You found that the stem was flipped with a negative rise so you flipped it over to give you more rise but now you cant tighten it down properly?
    Jul 2014
    Correct. I figured out that the bolts were not in correctly. Stupid mistake on my end but I have found a few that were a little strange from the shop. Seat bolt came loose on first ride and had to adjust a few other simple things
  1. Thomson Carbon Riser vs Enve Riser Handlebar?
    By Krause in forum All Mountain
    Last Post: 07-29-2014, 06:48 PM
  2. Flat handlebar vs riser handlebar
    By RidgeRunner in forum General Discussion
    Last Post: 05-16-2014, 07:49 AM
  3. Handlebar riser stem?
    By Jeremiah Luoma in forum Specialized
    Last Post: 03-29-2014, 05:10 PM
  4. Handlebar: Riser With Less Backsweep?
    By JRS73 in forum 29er Components
    Last Post: 08-31-2013, 12:57 PM
  5. Crank Bros Iodine 11 Riser Handlebar
    By rth009 in forum 29er Components
    Last Post: 07-17-2012, 09:14 AM
