Good tubeless patch kit?
Printable View
  • 07-09-2008
    Miker J
    I put a 3/8" slice in a Dry X. Any hopes of salvaging it with a tubeless patch kit? If so which brand?
    I've never patched a tubeless tire.
    Thanks.
  • 07-09-2008
    BruceBrown
    Thanks.
    Hutchinson and a couple of others make a "tubeless patch kit" specific one. It's like patching a tube, but the patches in these "special" kits have some fiber in them. You could also try a regular glue on patch on the inside to see if it will hold. I did my Racing Ralph like that with a 3/8"+ tear and it has been holding up just fine thus far. Since then, I've purchased the tubeless patches with fiber in them in case that one gives up the ghost.
    Instructions here (scroll down the left hand margin to tubeless w sealant):
    http://www.utahmountainbiking.com/
    BB
  • 07-09-2008
    bank5
    Edit: I just deleted my previous post because I thought the OP was asking something else.
  • 07-10-2008
    readingracing
    Tubeless plug kit from any auto store,no wheel pull or tire removal,been using it for several years,work mint in most cases.
  • 07-10-2008
    CDB
    I have repaired a couple tires using superglue in the cut, then simply using a standard glue on patch on the inside of the tire casing.
  • 07-11-2008
    Miker J
    Thanks....
    To those who've patched bigger slices, bigger than a 1/4" or so, do find the tire remains reliable?
  • 07-11-2008
    ionsmuse
    Only if I took the time to stitch it with dental floss. You get hardcore points for cutting a Dry X; not an easy thing to do.
  • 07-11-2008
    Miker J
    My fault...
    I attribute the tear to probably running just a bit too much pressure.
