Results 1 to 10 of 10
    Good News/Bad News Stumpy HT Lacking Instant Gratification
    Had the local shop order a spankin' new Stumpjumper Comp 29er. Fit is outstanding, they swapped tires to the Captain S works (I'm a biggie who wanted more traction), out for the first test ride out back. Stomped on the cranks - BIG chain suck/gear slip. DOH.
    Fortunately a mechanic was out testing a bike too and I assured him I wasn't on the gear lever at the time - I SWEAR.
    He was able to recreate it. Every time.
    Long story short - big problems getting the chain alignment where it needs to be - they tried different crank combo, different chain. Calls to Specialized and SRAM...
    SRAM is sending them a new set of better X9 cranks and trimmings. I'm concerned that might not fix it.
    The owner (very likeable guy) told me the next best option would be to go to a double up front. Are there any pros with that approach? I mean, I bought a 30 speed bike, don't take 10 away from me! Yes, I'm aware that I'd lose a couple of the lowest gears and a little off the top end. My gut says don't do it...
    Anybody heard of such a travesty with a Stumpy?
    I want my bike,
    LAX
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    X9 will probably fix it. Give it a shot.
    You may be surprised at how little you miss the gears. I have a 1x10 setup with 32 up front and 11-36 in the rear. Big range and all I need. I am by no means a super strong rider, but I can mash when needed. Part of the reason for my setup was to make myself survive without the granny. I can say I am very happy I did it.
    Just a thought, but you may be cutting yourself short in thinking you need those extras (weather your dumping the big or small ring).
    Reputation: reydin's Avatar
    Feb 2007
    If your bike shop has a bike set up 2X10 in stock, give it a try and see for your self. That's what I did and I haven't looked back since.
    If I had a black light this place would look like a Jackson Pollock painting.
    A REAL RIDER
    Reputation: Rearwheelslider's Avatar
    X9 will fit! I bet you.
    Just Ride!
    Reputation: kustomz's Avatar
    I have not experienced chain suck in about 10 years. Went single speed for that very reason and don't miss it a bit.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by laxpatrick View Post
    I want my bike,
    LAX
    Slipping gear and chain suck at the same time? How is that even possible. One is when the chain moves too much and the other when it locks up.
    Good that the mechanic was there it see it.
    mtbtires.com
    Thanks for the supporting words. They said I could take it home for the weekend since the parts are going to get replaced - but I think that I want to hold off on possession - it hasn't left the shop, just paid for it...
    Oh, the humanity.
    On the bright side, I got a really good deal on a Thule T2 - VERY impressed with that. Only haven't had a bike on it - YET.
    Reputation: Eric Z's Avatar
    if there's an issue aligning the chain with the stock cranks that worked well on other comps, how will a new crank fix it? i hope it does for you but wonder if it's a different issue.
    if you have to go to 2x10, you probably wouldn't notice much. i have it on my el mar and haven't missed any gears.
    good luck! i hope things work out for you. there's nothing like having an issue with a brand new bike.
    ez
    - 1995 Giant ATX 870
    - 2011 Salsa El Mariachi XL
    - 2011 Kona Unit (singlespeed) XL
    Update: Good shops do good things... They talked to SRAM and they delivered and installed a set of X9 cranks. Took it for a decent test ride, all is GOOOOOOD.
    Nice upgrade, too!
    Need to take it out for some abuse tomorrow.
    LAXPatrick
  1. Good news/bad news for beer-drinking mtb'ers
    By Finch Platte in forum Beer Forum
    Last Post: 01-27-2007, 10:21 PM
  2. White Bros BW 1.0 Good news / Bad news
    By tat2niner in forum 29er Bikes
    Last Post: 10-28-2006, 08:37 AM
  3. News on 2006 Boxxers: Good news that is!
    By Robot Chicken in forum Downhill - Freeride
    Last Post: 07-01-2005, 10:52 PM
  4. Good News, Bad News and *rt*'s Stalker Update
    By Ken in KC in forum Passion
    Last Post: 04-01-2005, 09:31 AM
  5. bike lights good news, bad news... x-post
    By fc in forum Lights DIY - Do It Yourself
    Last Post: 01-20-2005, 03:53 PM
