Results 1 to 16 of 16
Thread: Ghost 29er
    Apr 2013
    New question here. Ghost 29er
    hi guys ive got myself a ghost se2930 29er and its fantastic but had a couple of punctures and tubes are expensive,can I use a 700c or even a 26''??
    Reputation: ElDuderino2412's Avatar
    Oct 2012
    convert the wheels to tubeless, and you will be much happier in life
    Not really sure what you are asking. You want to use 26" tubes on a 29er wheel? the answer is no if so.
    2012 Pivot Mach 429
    2010 Cervelo R3 SL
    Mar 2013
    How about this ?
    Apr 2013
    I read on another forum that u could use a 26" tube but glad i asked before i tried,thanks
    How will tubeless help me?
    Mar 2013
    Tubeless will help you since you don't need to worry about tubes and punctures anymore.
    But it is quite expensive to upgrade.
    You need special tyres.
    But I wouldn't recommend to try 26 tubes for 29er.
    Before I had tubless wheels I used a puncture repair kit to fix the problem.
    It is cheap and you don't need a new tube.
    Oct 2012
    Quote Originally Posted by gregalezswfc5 View Post
    Tubeless tires have sealant in them, which almost eliminates flats from small punctures and pinch flats. Look up stan's no tubes conversion kit, they are the easiest and most popular to use. You can also do a search on here for ghetto tubeless, which is a homemade kit.
    Or you can just do what rotor suggested and repair your flats.
    2012 Pivot Mach 429
    2010 Cervelo R3 SL
    max_29
    Reputation: max_29's Avatar
    Oct 2007
    I've been using 26" tubes on 29er wheels for years without any problems.
    Oct 2012
    Quote Originally Posted by max_29 View Post
    well i stand corrected. I wouldn't think they would stretch that much. It's almost a foot difference in circumference.
    2012 Pivot Mach 429
    2010 Cervelo R3 SL
    Reputation: zyzbot's Avatar
    You can use 26 " tubes. I've done it a number of times before. You may have to work a bit depending on the tube but they will work.
    turtles make me hot
    Reputation: NYrr496's Avatar
    26er tubes absolutely work in 29er wheels. Go tubeless.
    I like turtles
    Mar 2013
    As two useres had no issues with 26" tubes you could give it a try.
    But I still don't think that this is a good idea.
    Especially with super light tubes I would definetly advise you against this.
    Moderator Moderator
    Reputation: driver bob's Avatar
    26er's work, 700c wont.
    But tubeless is the way to go.
    Reputation: Zaratustra's Avatar
    Jan 2009
    If tubeless conversion seems expensive, you can try normal tubes with removable valve cores + you can add sealant easily.
    Or,I think that they sell ready made tubes with sealant inside.
    A tubeless conversion would be even better though ..
    Moderator Moderator
    Best Tubeless Brew?
    A huge wealth of info in this thread on going tubeless. I run the V2 mixture with Stans rim strips and regular tires without an issue.
    Sep 2012
    go tubeless... Make sure your tires are tubeless ready---use 1" gorilla tape to seal spoke holes on rim-- install stans valve onto rim(get the stans syringe and valve tool-- this makes replacing sealant much easier)--put tire on--inflate(i use a co2 cartridge to seal the tire-- then let the air out and pull the valve tip---and use the syringe to fill the sealant and the insert the valve end and refill with regular air-- this helps prevent buggers).. boom-- now your running tubeless... Like anything it will take a little bit to learn the first time-- but then youll have it.. Thorns-- pinch flats and rock holes will be a thing of the past... Plus you can run lower psi rates giving you more cush and grip then you would get with a tube..
    Video
    Jun 2012
    I have to say the same but use stans tape, I did a project where I did one tire ghetto one stans and the stans held air way better than the goriila tape.Just my 2 cents.
    Giant XTC 2 29er
    KHS Flagstaff 29er FS
    Neon Bow Trials Bike
    Norco Fluid 9.2 29er FS
    Norco BIGFOOT FATTY
  1. Ghost shifting
    By pat656 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-08-2013, 09:26 PM
  2. One Ghost Industries Ronin 29er Carbon HT
    By Agledhill in forum 29er Bikes
    Last Post: 12-27-2012, 10:25 AM
  3. MEC and Ghost brands
    By BrandNewDaddy in forum Beginner's Corner
    Last Post: 08-14-2012, 10:05 AM
  4. Sog Bot Ghost Riders
    By rio in forum Alaska
    Last Post: 07-30-2012, 02:10 PM
  5. Ghost Bikes
    By rookie nick in forum All Mountain
    Last Post: 03-04-2012, 09:25 AM
