Results 1 to 8 of 8
    Reputation: DylanGalaty's Avatar
    Gazza Extreme 294
    I just picked up a pair of studded tires and wanted to know if people had successfully set them up tubeless? I currently run all of my bikes tubeless on flow rims. Thanks for any input.
    "Even 100 years ago, adults didn't ride 26-inch wheels, only little children did." - Wes Williams
    I've heard reports that people have managed to run these tubeless, but I tried and failed. Couldn't get the tire to seal up to the rim.
    I just set up a pair on Bontrager Duster's with the Bont strip...it was painless.
    I asked the same question a few weeks ago and basic reply was no problem
    http://forums.mtbr.com/showthread.ph...66826#poststop
    Thanks Mayor. I should have done a search.
    Quote Originally Posted by -LightOn-
    What rim are you using?
    Quote Originally Posted by DylanGalaty
    Consider it your X-mas present
    I was going to put the Nokians on a Arch with yellow tape...it aired up fine...but I like it better on the wider Bontrager which is about the same size as the Flow
    Set-up was a snap. Now to take them for a spin.
    Quote Originally Posted by the mayor
    Dt x470 which aren't tubeless or ust rims. I tried the gorilla tape method with no success. Maybe it would have worked with either a stan's rim strip or the inner tube ghetto method.
