Results 1 to 16 of 16
    aka: SpeedyChix
    Apr 2005
    Which full-suspension XC-type bike will clear 2.4-2.5 tires?
    Going at this a bit backwards. Have a set of wheels looking for a bike to put on em.
    120 travel would be ideal, more of a XC orientation than enduro. This makes the hunt for a suitable light frame that fits wider tires a bit harder.
    What's out there? Haven't shopped full-suspension bikes for quite awhile.
    Thanks.
    Nov 2016
    2018 Ibis Ripley LS comes with 29x2.6 Nobby Nics from the factory, so there's an option.
    aka: SpeedyChix
    Apr 2005
    Quote Originally Posted by matt.s67 View Post
    Been looking at that and would like to add a couple others to the "look at/test ride" list. Intense Primer?
    Formerly of Kent
    Reputation: Le Duke's Avatar
    Intense Sniper.
    Death from Below.
    aka: SpeedyChix
    Apr 2005
    Feb 2005
    Norco Optic would easily pass 2.5s
    Mar 2015
    I currently have 2.35 Ikons on 36mm wheels on my bike with plenty of room on a top fuel 9.8
    The front has a 2.35 HD in a 32 Stepcast of all things and it has a ton of space despite what Fox says. When I put a fox 34 SC up there, it will have room for 2.6 NoNi if I wish.
    I post my configuration because It is an XC bike and it does clear with lots of room. for dry conditions.
    aka: SpeedyChix
    Apr 2005
    If Ikon 2.35s are happy on a 36 internal, that opens up a number of options. Also looking at Yeti SB 4.5. SHOULD sell wheel set but....
    Quote Originally Posted by FJSnoozer View Post
    tmb
    tmb is offline
    When in doubt- turn left
    2018 Rocky Mountain Element. I'm currently running a Panaracer Fat B Nimble 29x3 on a Fox 34 front and a Kenda Sabre Pro 29x2.6 rear, both on 35mm O.D. rims with Boost spacing.
    Granted, both of these tires run small for their stated size but it gives you an idea of what is possible.
    Mar 2015
    Quote Originally Posted by SpeedyChix View Post
    Sorry, they are 36 outer.
    I just measured last night, The Ikons are 61.5mm on the 30 internal 36 outer. Knobs are at 61,
    Knobs have 7mm clearance on either side at the tightest spot, I wouldnt want to ride this in deep mud, but we dont ride muddy trails here.
    Surprisingly, the Hans Dampf 2.35 side knobs have about 1 cm tire clearance inside the Step cast sc 32 fork.
    aka: SpeedyChix
    Apr 2005
    Wow, RM Element fitting those is impressive. Should easily take a 2.4 xc tire. Thanks!
    Is that with the carbon frame?
    Quote Originally Posted by tmb View Post
    tmb
    tmb is offline
    Element C-50, carbon front and alloy rear.
    Reputation: RubenAlonzo's Avatar
    Apr 2018
    Scott Spark or Genius should fit those no problems
    aka: SpeedyChix
    Apr 2005
    Quote Originally Posted by RubenAlonzo View Post
    The 2017 27.5 Spark wouldn't take a 2.5. The 900 series might.
    I'd go for a Genius but looking for a bike for the husband and he's after less travel than that.
    Apr 2018
    Thank you for the correction.
    aka: SpeedyChix
    Apr 2005
    2018s may have more clearance than the 2017. Thought I recall reading that.
    Adrenaline junkie.
    2x "big c" and enjoying life.
  1. Replies: 3
    Last Post: 08-30-2017, 04:23 PM
  2. Replies: 28
    Last Post: 08-29-2016, 04:39 AM
  3. Replies: 12
    Last Post: 07-28-2016, 08:22 PM
  4. Replies: 2
    Last Post: 07-11-2015, 03:19 PM
Members who have read this thread: 144
