Results 1 to 23 of 23
    Sep 2013
    Full Suspension 29er Frames with Most Rear Tire Clearance
    Is there a list of full suspension 29er frames that will fit some of the newer high-volume, non-plus 29in tires (like the Nobby Nic 29x2.6)?
    Seems like the following all will:
    17 Fuel EX
    Hightower
    Deadwood
    Ibis Ripley V3
    Tallboy 3
    What else?
    Mr. Buck E. Fikes
    Reputation: Oh My Sack!'s Avatar
    I think my new Stumpjumper 29/6Fattie fits in that category. I'm running 27.5x3.0 now but originally ran a Schwalbe 2.35 on the i35 hoop that profiles at 2.5" and there was lots more room.
    Here, diagonally!
    Reputation: JACKL's Avatar
    Banshee Prime easily takes a 2.6 Nic (that's what I'm running now). With the long dropouts can easily take 2.8s (if they ever make any). I ran a 3.0 with the long dropouts for a while, but did get some tire rub.
    Banshee Prime
    Feb 2017
    Quote Originally Posted by JACKL View Post
    With the success stories trickling out about 29x2.6 it's only a matter of time before we start to see 29x2.8. I think this may be an awesome tire size to rear a 29x3.0 front which many 29r forks these days seem to be able to fit.
    Turns right to go left
    Reputation: 410sprint's Avatar
    Oct 2012
    The Canfield Riot will easily fit a 2.5 and probably a 2.6 without any issues
    Reputation: Zerort's Avatar
    Jan 2013
    Full Suspension 29er Frames with Most Rear Tire Clearance-20170427_114931b.jpg
    How's this for clearance?
    by Silentfoe
    I'm satisfied knowing that what I wear during my "day" job makes me more of a man than you'll ever be.
    Alt-132
    Feb 2005
    Is this sold as a frame only?
    [COLOR="Black"]HARDMTNBIKER on Instagram
    Seven Sola SLX ENVE MTN SS
    Sir9 Carbon Niner SS
    #1gearallyear #Iridemtn
    Alt-132
    Quote Originally Posted by hardmtnbiker View Post
    Yes
    Trail Pistol Custom Build & Frameset - Choose Your Components
    Feb 2005
    that's good, I hate when bikes are only sold complete.
    Reputation: Switchback Bikes's Avatar
    Dec 2013
    Trail Pistol Mixer
    Quote Originally Posted by mtg7aa View Post
    Do you know of anyone running the Trail Pistol in a Mixer set up?
    130mm travel rear
    27.5 x 2.6 - 2.8 rear
    140mm travel front
    29 x 2.6
    Alt-132
    Quote Originally Posted by Switchback Bikes View Post
    130mm travel rear
    140mm travel front
    29 x 2.6
    I don't know of anybody running a mixer setup off hand on a Trail Pistol, but we've talked about it, and called it the full moto configuration.
    If you were to do that, I'd go 27.5x2.8 rear, 29x2.5-2.6 front, and use Plush Mode. To run 27.5x2.6 rear, the Megatrail SS would be a better choice.
    Dec 2013
    Excellent...thanks for the reply
    Yeah was thinking Plush Mode would be the way to go for Full Moto.....
    Sep 2013
    Anyone know for sure if the 17 Fuel EX will fit a 29x2.6?
    Dec 2015
    Quote Originally Posted by brogo View Post
    I've got a 29x2.4 XR3 in the rear on my 17 Fuel EX 9 and there is still a ton of room. I'm pretty confident a 2.6 would fit.
    Sent from my Pixel using Tapatalk
    Reputation: chomxxo's Avatar
    Yes it will definitely fit. I ride 29x2.6 Nobby Nics on my 2017 Fuel EX8 and there's still plenty of clearance.
    Sep 2013
    Reviving this thread. Anyone know of any other frames that will for sure fit a 29 x 2.6? Seems like a lot more of these tires are on the way:
    – Schwalbe Nobby Nic 29 x 2.6-inch (available)
    – Teravail Kennebec 29 x 2.6-inch (announced)
    – Maxis Rekon 29 x 2.6-inch (announced)
    – Vee Flow Snap 29 x 2.6-inch (announced)
    – Kenda Saber 29 x 2.6-inch (announced)
    I've also read that Ibis has said their new Ripley will fit the 29 x 2.6 Nobby Nic but not the upcoming Maxxis Rekon 29 x 2.6...
    Jan 2009
    I rode the new NN 29 x 2.6 tires on the Ibis Ripley 3. Liked the tires (Bend OR) but the Ripley just wasn't for me.
    Niner Jet 9 RDO.
    Any bike that is Boost-compatible (will fit 27.5+ wheels and tires) will, by definition, fit 29x2.6 wheels and tires with plenty of clearance.
    Sep 2013
    Quote Originally Posted by chomxxo View Post
    Niner Jet 9 RDO.
    I don't think that's 100% true... For example, the old Ripley LS was boost, but couldn't fit a 29x2.6 tire.
    How about this: If the Boost frame supports 27.5+ wheels and tires, it is 100% compatible with 29x2.6.
    Not at all true.
    My Specialized alloy Fuse barely fits (2mm @ chainstays) the Terravail Cumberland 2.6 on Specialized Traverse SL 30mm internal rims, and they will rub several times each ride. The carbon version of the fuse won't fit at all (you have to compress the tire quite a bit against the seat tube to get in the thru axle and the wheel will obviously not turn). Nor will that tire/wheel combo fit in a Santa Cruz Tallboy. Putting the wheel in the Santa Cruz Chameleon with the dropouts moved all the way out gets you more clearance (4mm at CS) but definitely not enough to be legal (CPSC requires a 6mm rod to be able to clear all the way around the tire for a company to spec or claim a tire size to fit).
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    I've been riding a Lenz Behemoth 29+ for the past few months. 135mm front travel, 125mm rear. Maxxis Minions in 29 x 3.0" on both ends.
    Attached Thumbnails Attached Thumbnails Full Suspension 29er Frames with Most Rear Tire Clearance-8a3a7965.jpg
  1. Lightest full suspension 29er carbon frames?
    By aliikane in forum 29er Bikes
    Last Post: 05-07-2014, 04:39 PM
  2. Replies: 11
    Last Post: 01-27-2013, 06:29 PM
  3. Any 29er Full Suspension Frames under 500?
    By Baldrick843 in forum 29er Bikes
    Last Post: 08-22-2011, 10:18 AM
  4. ti 29er rear tire clearance
    By GlazedHam in forum 29er Bikes
    Last Post: 02-02-2011, 07:36 PM
Members who have read this thread: 69
