Results 1 to 22 of 22
    Front wheel slipping
    Hello,
    My front wheel axle on the Karate Monkey sometimes slips and the wheel comes out of alignment causing the disc brakes to drag. The last time I was out I had to stop and re-adjust it 3 times, and I have the quick release pretty tight. I know this topic has been covered before but I couldn't find the right search words to find it. Has this problem been solved? The guy at the lbs was puzzled.
    Thanks.
    Bored
    Reputation: bigwheelboy_490's Avatar
    Jan 2003
    See the discussion about the fork drop out design in this thread.
    XXX Porn (Wily content)
    I imagine a good quality QR like a shimano would probably help you here.
    WAWE
    What BW490 said... and...
    a) Make sure you're dropouts are properly aligned... LBS should have a tool for this.
    b) Try a different skewer.
    jl
    jl is offline
    climb
    Reputation: jl's Avatar
    Quote Originally Posted by aosty
    I had to 'face' the dropouts on the fork, and I'm using salsa flip-offs, so far no more problems ...
    Ride On!
    Quote Originally Posted by jl
    How do you face dropouts?
    drev-il, not Dr. Evil!
    Reputation: Drevil's Avatar
    Quote Originally Posted by chris the monikerless
    Maybe he meant this:
    http://www.parktool.com/repair_help/FFG.shtml
    "Keep your burgers lean and your tires fat." -h.d. | bikecentric | ssoft
    jl
    jl is offline
    climb
    Ride On!
    Sep 2004
    Maybe I'm blind, but I couldn't find a tool that faces dropouts in the link you provided. The only facing tool I found is one that faces disk brake tabs. Does it also work to face dropouts as well, or am I totally missing it?
    jl
    jl is offline
    climb
    Drevil,
    My mistake... I did NOT mean 'dropouts' in my original post, I meant the disk brake tabs. One word, one big misinterpretation ... I faced the disk brake tabs and used am using a salsa skewer. whewww...
    Sorry for that, now back to the regularly scheduled program.
    Ride On!
    I really wasn't trying to bust your balls. I just never heard of such a tool, and was curious why someone would want to remove material from the dropout (unless the faces on each side of a dropout weren't parallel to each other).
    jl
    jl is offline
    climb
    No, you weren't busting my balls and I didn't take it that way. I just latched on to the previous thread (aostys dropout comment) and didn't realize I wasn't talking about dropouts ... No worries, hopefully chris can ride safely (soon)...
    Ride On!
    Reputation: Soupboy's Avatar
    How much...
    ...was the Hope tab facing tool? Did you order it directly from them?
    I have all my tabs faced - nary a chime running my Minis. I always have my LBS do this though because the Maggie Nanomat is prohibitively expensive.
    Sean
    Professional Amateur. Disagree? Submit your grievances here.
    WAWE
    Quote Originally Posted by Drevil
    I was referring to this - to align the axle dropouts.
    Jl was referring to facing the disc brake tabs.
    Two different things.
    Sep 2004
    Do you really need to face your disc tabs to make the brake work? I thought they came with shims for alignment.
    Back to the OP's problem, what does disc tab facing have to do with front wheel slippage?
    Edit: Never mind...I see it's dropout alignment. Just the same, as flexible as the fork and skewer are I wouldn't expect any benefit from a few degrees of alignment perfection. That looks like a tool for repairing crash damage or cold setting a frame.
    Dude needs a knurled steel faced skewer like a Shimano at least, and I wouldn't be happy without horizontal dropouts or V brakes to boot.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by bigwheelboy_490
    I use only Shimano skewers because of possible axle slippage. I have had Salsas move.
    mtbtires.com
    I have Shimano skewers but they're used. Do they ever wear out and need replacement?
    Dec 1998
    The cams can wear and reduce clamping force.
    Did you file off the fork's lawyer tabs? Keeping them is a good idea with disc brakes.
    mtbtires.com
    Quote Originally Posted by shiggy
    What are "lawyer tabs"? I haven't done anything to the fork but I got the bike used and I don't know if the previous owner did anything.
    Dec 1998
    The raised lip on the dropout that make you have to unscrew your QR to release the wheel.
    mtbtires.com
    Steel and teeth.
    Reputation: b1umb0y's Avatar
    Feb 2005
    Quote Originally Posted by Soupboy
    Sean
    $140.
    b1umb0y
    That looks fine. I have to unscrew to take the wheel off.
  1. Welcome, here's your 29er FAQ thread!
    By ncj01 in forum 29er Bikes
    Last Post: 06-20-2012, 01:56 PM
  2. 29er front race wheel
    By lithiapark in forum 29er Bikes
    Last Post: 05-05-2005, 09:06 PM
  3. Crossmax XL (non-dsic) front wheel
    By Poster Nutbag in forum Wheels and Tires
    Last Post: 03-09-2005, 09:06 AM
  4. Aaaaagh..front wheel fell out!!
    By kevsurf2003 in forum General Discussion
    Last Post: 06-17-2004, 02:35 PM
  5. I just drove over my front wheel....
    By Monte in forum Passion
    Last Post: 05-27-2004, 05:45 PM
Hot Deals
Contests
Latest Mountain Bike Articles
