Results 1 to 7 of 7
    Mar 2013
    Which Frame should I buy... Dillinger or Orbea Hydro Alma S30 ?
    My first post ever... general information for a better idea of where I'm coming from.
    Weight - 230 lbs. fully equipped
    Frame size medium
    Terrain - XC circuit - very flat buy very windy. Loose over hard pack and hard pack
    Will run the bike as an SS fully rigid with a Niner carbon fork
    Want something that turns on a dime tp help on the windy sections but is fast in the longer straightaways.
    Easton Bars and Seatpost
    Will run tubeless
    I do not race or jump
    Any ideas of which frame to choose between the Dillinger from Soul Cycles or the Orbea Alma S30?
    AOK
    AOK is offline
    Reputation: AOK's Avatar
    If you are planning to run SS, I would think you want the Dillinger simply because it has an EBB. The Alma doesn't have sliding drops or an EBB so you would have to run a tensioner.
    I have a carbon Alma and it is a great handling frame, fwiw.
    Are you set on aluminum? For a rigid singlespeed, I'd consider steel frames. I'd take a look at the new Canfield Nimble 9, especially for a big guy like yourself.
    having ridden a dilinger for a few yrs, I think there are better frame options out there in the $500 range now.
    Nimble 9
    Kona Unit
    Kona Honzo
    Spesh Carve/ Stumpy SS
    Niner bikes on clearance
    Mar 2013
    I have a Mary Haro Steel frame and a Niner steel frame as well. I'm looking to try aluminum.
    I run either of these frames with a hanger and a tensioner from it. I have never experienced chain suck thus far.
    The EBB is an interesting propositions I have never fiddled with one.
    You should try to get one of the Niner One9's on clearance. I'm not fond of the set screw type EBB like on the Dillinger. I much prefer either Bushnell or Niner. I've had no issues with either.
    I've also got both aluminum/scandium and steel bikes. Both have their pros and cons, and I like them both.
    Jun 2012
    If you're wanting an aluminum frame and are good with running a tensioner I'd check out the Canfield Yelli Screamy. They're supposed to handle well because of the shortened chain stays.
  1. Orbea Alma Hydro Build thread
    By ghettocop in forum 29er Bikes
    Last Post: 02-15-2013, 06:14 PM
  2. Orbea Alma Hydro 29er Frame $199
    By CYCLEJCE in forum Where are the Best Deals?
    Last Post: 01-19-2013, 12:13 AM
  3. Replies: 0
    Last Post: 12-27-2011, 01:13 PM
  4. Replies: 2
    Last Post: 03-10-2011, 01:24 PM
  5. 2008 Orbea Alma frame help
    By Mr. IROC-Z in forum Custom Builders & Other Manufacturers
    Last Post: 02-24-2011, 10:36 AM
