I got a response back from Trek Support
I believe Fox has a repair solution to prevent your splitter from breaking in the same fashion again. You will want to contact them directly and ask about this particular repair. I believe it is simply sending out a revised part to work with your current lockout splitter.
I have a part that is supposed to arrive today. if it is any different from stock I will post pics. if not, I will call Fox and inquire about the "repair solution"
I'll post back more when I know someting
got the new part in and it LOOKS identical.
I called Fox and was told that they found a manufacturing issue in the plastics used to make the splitter. they changed the process and all new splitters and end caps are now made in the new manner.
So, I'm holding my breath and installing the new one tonight
Thanks for sharing, and posting pics.
Had the same experience a couple of weeks ago. The splitter split! Hahahaha! That plastic part is a weak point. Maybe they should've used aluminum?
I agree, suggested the same thing and was told it was extensively tested before release but something changed in manufacturing process to make them bad on mass production. assured the plastic will be fine.
Also as a side note, I was looking for another end cap for the cables after I installed the new splitter assembly, and came across a ziplock bag that had been given to me when I picked up the new bike. inside that bag was a mixture of small rubber items and the brake bleeding block. But also inside that bag was another small bag that had two new splitter end-caps!!!
I'm guessing Trek included them on bikes that had already been partially assembled by the time they discovered the issue. I figure LBS just thought they were EXTRA and didn't replace them.
well, now I have extras if this one should break too!!
Same issue here. Ride #3 and snap. No questions asked FOX replaced and made sure I got in time for Southern Utah trip. Nice to see a company that follows through on a warranty without donating your first born. Thank you for putting this out here saved me tons of time!!
Gladly. Nice to be able to give back to such an awesome community.
Sent from my SCH-I535 using Tapatalk
Re: Fox ctd remote-ISSUE
I guess the CTD remote is intended for FS setup, right?
The CTD dial on the fork is very reachable while in riding position, which makes the benefit of a CTD remote insignificant on a hardtail setup.
What works for me may not work for you. What's best for you depends on many factors. We are different from each other.
For a HT I wouldn't see much benefit although, I almost never changed my shock setting on my front prior to the remote. If I knew I had a big climb or a long descent coming AND I was for some reason stopped, I would change the setting, but I rarely had the time (or the control) to reach over the bars and fiddle with a lever.
It is possible and I managed to do it, once or twice just to see if I could, but I often felt the effort outweighed the benefit. So for me, I typically left the shock in trail front/rear and just dealt with it. Now, I switch 1-2x per ride on average, or more if trail or my fitness dictates.
That's just me. I personally thought it was silly but now I really like it. it's a tool that compensates for my lack or desire or skill to change the settings on the fly. so now I use the shock to its full designed potential.
RIDE TO LIVE
Thanks for posting this info. While I haven't broken mine yet, I prefer to keep spares handy during race season to avoid any potential delays. So I called up Fox and explained my situation and they said no problem, we will send one out right away. Great service!
Cassoulet forever !
what is the weight added by this handlebar control ?
Well through all my trials and tribulations I actually have an almost complete set sitting on my workbench so I can try and give you an approximation, it's two cables, the housing, the remote switch, and the splitter box. I have everything in duplicate except the remote switch. So I can give you a rough approximation but it'll be later this afternoon. The front and rear shock are slightly different as well so some of the added weight may be offset by not having levers and adjustments on the shock.
Again when I first got it I thought it was kind of silly but I have really come to like it and I'll tell you on technical climbs especially very tough climbing switchbacks it is worth whatever small weight penalty it carries.
Including the actual remote switch I'm guessing ~100g or less
I have 2014 fox 120mm ctd remote fork on my 2013 Rocky Mountain Element 999 RSL, FS 29er. I'm using the older 2013 Fox remote lever. I use the lever on the L/S of bar on the downside, 1x10 set-up. It works perfect, with the cable and remote tucked low and out of harms way!!
I was riding and did a end-over "rock garden" and ripped the front CTD cable off. Since I had the 2014 Fox CTD remote that came with the fork, I decided to install the new Remote and see how I liked it.
Went for a ride, I hate it!! Took it all apart and reinstalled the older better lighter more reliable 2013 remote. It is bigger but mounted on the down side of bar the bigger lever has more leverage and much easier to operate.
That junction box on the 2014 remote is crap, the cable sticks up way to high, the position and action on the remote button sucks. If you have 1x set-up get the 2013 remote you will love it!!
Correction on the weight, the 2013 remote is total 19grams heavier than 2014 remote.
By J0hnnie in forum Shocks and Suspension
Last Post: 09-02-2013, 07:06 AM
By jos3ph4ever in forum 29er Components
Last Post: 03-12-2013, 12:41 PM
By millertj1 in forum 29er Bikes
Last Post: 01-04-2013, 09:34 AM
By richulr in forum Shocks and Suspension
Last Post: 10-29-2012, 12:48 PM
By NCSS07 in forum Shocks and Suspension
Last Post: 07-28-2011, 11:05 AM
- You may not post replies
- You may not edit your posts
Forum Rules
