Results 1 to 16 of 16
    Jun 2013
    Fork for new 29r build
    So I'm new to bike building and I'm going to put together a 29r ( with my friends help ). Wanted to ask something here first. How do I determine if the Marzocchi fork I'm looking at will fit my frame? This might be a dumb question, but I thought I'd ask before I go spending the $$ !! Do all 29r forks fit all 29r frames ??
    Reputation: ghettocop's Avatar
    Axle to crown wise all 29er forks will fit 29er frames. You need to match the forks steerer tube with your head tube. Is your head tube 1 1/8th. 1.5, or tapered.....1.5 at bottom 1 1/8th at top?
    Jun 2013
    Frame has a FSA Orbit C-40 Headset. Looked it up and it says it's 1-1/8 x 1.5 tapered. No idea what this means...lol, but I'm a quick learner. Help !
    Jun 2013
    more detailed view...
    FSA Orbit C-40 1-1/8" x 1.5 Headset: 1-1/8" 45/45 ACB upper - 42mm ID. 1.5" 36/45 ACB lower - 52mm ID. Compatible with carbon or alloy head tubes. For 1-1/8" to 1.5" tapered steerers. 16.3mm stack height. 81.2 grams.
    Jun 2013
    Here's the fork....
    Marzocchi Corsa SL RC 29 Fork 2012 Marzocchi Corsa SL RC 29 Fork Specifications: Travel:100mm 80-120mm (with spacers) Spring:Air Steerer:Tapered 1 1/8th to 1.5 Axle:QR 15mm Bolt Thru Weight:1858 grams.
    If I'm not mistaken I think it will work. Right?
    Jan 2013
    I'm a noob too, so would wait on someone else who is more experienced, but I believe that will work with your frame
    MTBR Member
    Reputation: ncfisherman's Avatar
    Yes -- you have a tapered headtube.
    Make sure your front hub will work with the QR15 thru-axle on the fork.
    Jun 2013
    What does that mean and how do I check that?
    MTBR Member
    Quote Originally Posted by Luis M. View Post
    The fork you mentioned has a QR15 axle
    Like this...
    As opposed to the standard quick-release, like this...
    You'll need to make sure your hub has the ability to accept a QR15 axle, if you want to run that fork.
    Jun 2013
    Got it. Thanks for all your responses.
    is the fork that you are looking at new or used? If it is used then you need to measure the steerer tube length. Installed forks usually have the steerer tube cut down to fit, so if this is used then you need to measure the length v. The combined height of the head tube, headset cups, stem and at least one small spacer.
    Jun 2013
    It's brand new.
    It's brand new.
    You may want to ride it a bit at full steerer tube length before having it cut down, just to see what height is the best fit for you. You do this by placing spacers both below and above the stem. Or if the height doesn't matter then just have it cut down and leave yourself some room for spacers. the height and amount of spacers are preference but you need at least one spacer. But once you cut the tube that's it--if you have cut it too short...
    Jun 2013
    Thanks cjsb. I really appreciate the help. I'm 6'-2" . I don't think I'll cut it unless it's really high.I think it would be much easier to sell if I want something different. I like my position slightly higher. My 26r has 3 spacers on the bottom an 2 on top. It works well at this height and leaves me the option of raising it further if its needed.
    Jun 2013
    Anyone have any experience with this wheelset?....Name:  79495-1.jpg
    Kore Durox II 29er Wheelset - White 2012
    Specifications:
    UST Tubeless Compatible
    26" Or 29" Welded High Strength AL6061-T6 Rim
    32 Hole with Eyelets
    Rim Width 24.4mm, Height 19mm
    KORE Stainless Butted Black Spokes With Brass Nipples
    110 Front And 135 or 142 Rear Sealed Bearing ISO 6 Bolt Disc Hubs
    Cr-Mo Sealed Bearing Cassette
    Annodized Black Or White Powder Coated With HRT Graphics
    KORE Chastity Belt Rim Tapes Included
    Weight - 26" 898g Front / 1087g Rear - 29" 930g Front / 1134g Rear
    They're a bit on the heavy side and wanted some opinions. Perhaps there's better options, at a higher cost I'm sure.
    Jun 2013
    Decided to X this wheelset and go for the real deal. Got some Mavic SLRs. Got a nice carbon frame with a nice fork to boot. Why cheap out on the wheels !!
  1. Homebrew Fat Fork Build
    By woodi2259 in forum Fat bikes
    Last Post: 01-23-2014, 06:24 PM
  2. AM hub, fork, and wheel build?
    By TrailNut in forum Shocks and Suspension
    Last Post: 10-26-2012, 12:47 PM
  3. Replies: 20
    Last Post: 11-11-2011, 12:34 PM
  4. Which fork for my AM build?
    By mtbks in forum Shocks and Suspension
    Last Post: 08-31-2011, 01:37 AM
  5. Which Fork for my build?
    By Chase1996 in forum Beginner's Corner
    Last Post: 05-22-2011, 01:22 PM
