Page 2 of 4 FirstFirst 1234 LastLast
Results 101 to 200 of 304
  1. #101
    JB
    Reputation: Nevada 29er's Avatar
    Nov 2007
    For a made in USA option, there's also the GG Smash 140mm 29er. It seems to tick the same boxes, except it has short stays, 429mm. Not sure how that affects the overall handling.
  2. #102
    For those in the US that have bought Poles, did you pay any customs duties and how much?
    Googling, I am struggling to find a definitive answer whether duty is due and the rate. I'm ready to place an order but want to know ahead of time what my final cost is going to be.
  3. #103
    Reputation: Zerort's Avatar
    Jan 2013
    No duty.
    What frame and size are you buying?
  4. #104
    Thanks. No duty sounds good. Hopefully that is the norm and not just a one off you got lucky situation.
    I'm ordering a large 140 Evolink.
  5. #105
    JB
    Nov 2007
    Kind of a long shot, but has anyone ridden both an Evolink and Geometron/Nicolai? The geometries are very similar, but not sure on suspension characteristics, etc.
    Kind of weird no XL in the Evolink 140, considering its available on the 130 and 150. Its supposed to be coming but not likely until next year.
  6. #106
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Quote Originally Posted by trail-blazer View Post
    Linkage Design: Pole Bikes
    Nicolai ION-G13 29'' 2017 - Linkage Design
    There is information out there. As far as pedaling efficiency, the Nicolais are horst links that are moving towards higher and flatter anti-squat profiles. Older horst links with severe falling curves starting out at lower values were pretty poor climbers and some manufacturers(not many!), like nicolai, have been shifting towards higher and flatter curves, as seen above. A much bigger trend is to generally have around 100% AS throughout a significant portion of travel, for consistent pedaling effects. Significantly more, like 120%+, starts to interfere with the suspension, with old high-pivot bikes sometimes approaching 200%. The Pole on the other hand replicates an older horst-link profile, with about 80% anti-squat at the sag point and a steep falling curve after that, which is going to be fairly poor for efficiency. There's really nothing about the Pole linkage that would lend it towards good efficiency.
    As far as the shape of the leverage curve, the Pole appears to be optimized for an air shock, and the nicolai seems to be optimized for a coil (despite them putting an air shock on it, but there's at least one thread in the nicolai forum where a guy is trying to figure out why he can't use all his travel with an air shock, it gets too progressive). Efficient doesn't mean the manufacturer has nailed the bump-absorption characteristics or matched the shock tune, so there are variables that will affect how the bike rides, besides the anti-squat profile.
  7. #107
    Any Pole 140 owners try a fork with a smaller offset than 51mm? Chris Porter at Mojo swears by smaller offsets for 29ers being better. Transition now with their new range are going on about the smaller offset fork too.
    I wondering what and if there will be any real noticeable difference between at fork with 51mm or 44mm offset on the Pole Evolink 140.
  8. #108
    Sep 2014
    I have Evolink 150 with Öhlins RXF34, which has the 46 mm offset. I have used 2 other forks with the bike, DVO Diamond 27,5 and MRP Stage 34 29. MRP had offset 51 and DVO was with 44 mm offset. With smaller offset it is little bit easier to weight the front, but the differense is quite small.
    And by the way it pedals really well with either air or coil shock. It hardly bobs at all even I am currently running it with Öhlins coil shock.
    It is my trail bike and it is perfect for that kind of riding.
  9. #109
    Jan 2013
    My 2018 Specialized Epic has a 42mm offset. The thing just wants to wash out all the time in slower type turns.
    My Evolink has a 51mm Fox and it handles great. Leo from Pole recommends this offset.
  10. #110
    Apr 2015
    Most probably you forget a minor detail. That there is absolutely no similarity between an Epic and an Evolink! I would suggest reading a little about trail and how it is affected by the head angle, the offset etc.
    Having said that I have a 44 fork in a Mondraker Crafty and one of my friends has the same exact bike (even the size) with 51. I have ridden both and the 44 offset makes the bike more stable while the 51 is a little more twitchy.
    Here are both bikes. You can easily see the difference in the offsets.
    And another one with the same tires to eliminate this factor also. We even have the same height, weight etc.
    Pole most probably suggests a 51 offset to make the steering quicker due to the really slack head angle, wheel size and overall length of the bike.
    Chris Porter on the other side has a different opinion and the same applies to the Transition guys but at the end it is a matter of personal preference and experience.
  11. #111
    Jan 2013
    Quote Originally Posted by gpgalanis View Post
    No need to read. I own both bikes so I am well aware of the difference.
    The example was given as a reference how offset affects handling.
    Not sure why you need to slow down the steering anymore when you already have a head angle of 64.5 degrees.
    But if it works for you - go for it.
    by Silentfoe
    I'm satisfied knowing that what I wear during my "day" job makes me more of a man than you'll ever be.
  12. #112
    Not having ridden anything as slack or long as the Pole, I have no reference of how slow or quick the steering is going to be.
    I know from reading Chris Porter's views and reading the comments in the geometron thread that short offset seems to be the way to go for their geometry which is similar to the Pole but with even kslacker HA.
    I don't think I'd mind slower steering as it allows you to thread the bars between trees on tight trails but how slow would it be? Is there likely to be a huge difference?
    I know tat which ever I go for would feel weird because I'm also adapting to the Pole's geometry but I'd prefer to get it right first time if I can.
  13. #113
    Jan 2013
    I would stick with what the owner of Pole recommends. 51mm
    I'm sure Leo has tried various offset forks during his testing.
    You could even read some Facebook threads in the Pole riders group or ask the question there.
    Those people are building and riding Poles. Relying on what Cris Porter says seems silly IMO. He's discussing a completely different bike.
  14. #114
    How long did it take to receive your Pole after it was shipped? The tracking says it was processed through the Helsinki facility on Wednesday and is on it's to the destination country but no update since then. It was sent via EMS which use USPS as their agent in the US. USPS tracking doesn't show any updates either so was wondering if this was normal.
  15. #115
    Jan 2013
    Mine took forever. I know it was over a month, and I want to say it was close to 2, but I can't recall exactly.
    I actually thought it was lost somewhere but it did show up eventually.
    They need to choose a different shipping method.
    Hang in there, it will show up.
    by Silentfoe
  16. #116
    What? That's crazy. Was yours sent by the same method? EMS mail service using Posti on the Finnsh side and USPS on the US side.
    I wish I knew that before they shipped. I would have paid to have it sent by another method.
  17. #117
    Jan 2013
    Yes, same method. It was very aggravating.
    And Pole became a little unresponsive too which made it even more difficult.
    But, like I said, it did turn up.
    by Silentfoe
  18. #118
    Reputation: Gvus2001's Avatar
    Jul 2016
    It looks like the 2018 Evolinks (as well as the new full CNC frames) should be out soon, Pole has been teasing them a lot. Sounds like the Evolink frames will stay about the same, and the CNC frames will be the exact same geo and suspension kinematics as the current frames.
    Personally I think the CNC frames aren't nearly as pretty as the "normal" frames, but I guess I'll have to wait and see how the finished frames look. I'm planning on getting an Evolink 140 sometime this winter so I'm excited to see the new stuff!
  19. #119
    Apr 2015
    The 140 is great but I would like to see a 160 in 29er format.
  20. #120
    Jul 2016
    Pole did mention in their teaser post of the new CNC'd frames that the first bike in that line is going to be a "superenduro" bike. Not sure if that really means anything but it could be something with a bit more travel. I know they have been playing around a lot with putting 29er wheels on the 150 so I wouldn't be surprised.
  21. #121
    Apr 2015
    I have also asked them a couple of months ago and they said that something good is coming. I guess we will have to wait and see!
  22. #122
    JB
    Nov 2007
    You can run the 150 with 29 wheels, raises the BB, but some might prefer that in chunky terrain. They're saying the 2018s will be out in Feb.
  23. #123
    Jul 2016
    Well the new frames have been announced, looks like and ETA of March. Still no geo charts yet but they are on the Pole Store site. The new 158 29er looks like it could be really cool, gonna be hard for me to decide between the 140 and the 158, will have to wait to see the geo of the 158. Preorder deals are really good too, around $1900 for a frame is great.
  24. #124
    Apr 2015
    I was looking their 158 on the site and not only there is no geo chart but also the description is from the 150!
  25. #125
    Looks like the new evolinks come with rear mud guards. They mention new cable routing and more space for a bottle. I don't think there will be any geo changes to the evolinks. The 158 is stating a 42mm fork offset for a 29er. I'm not sure if that is a type or not. Based on my discussions with Leo, he was still of the opinion that 51mm offset was right for the 29er and his frame geo.
    Perhaps the new machined frames may have slight geo changes but I don't think that they'll be much different from the evolink. The main thing about the machine frame is that it's lighter and compete with carbon. Not sure how much stiffer if at all it will be than the evolink frames.
    I was on the fence about waiting for the new frames or ordering a 140 now but when they told me it would be Mar for the new frames and that would be for a more aggressive model initially, I decided to pull the trigger on the 140. I also wanted to see what the production version of the frame looked like and what the feedback was first.
  26. #126
    Apr 2015
    I am really curious about the CNC bikes. The 500 euros discount if you preorder is a great incentive but I would most probably wait and see all the details first.
  27. #127
    JB
    Nov 2007
    I'm in!! Just preordered a 140 XL. Was also considering a G15/16 Geometron and GG Smash, but the price is significantly higher for the Geometron and wasn't sure about the short stays on the Smash. I figure if I'm going to try the new school geo I go all in.
    Price came out just over $2,000 for the frame which includes shipping, not too bad. Can't wait to give it a go. Thinking of a 150 DVO Diamond fork to pair with it.
  28. #128
    How tall are you Nevada? Did you get any figures for the reach of the XL? I too was considering the Geometron / Nicolai but the cost was too high for me at this time.
    I've been flipping back and forth on a MRP Ribbon or Lyrik with Luftkappe for my 140. Haven't really considered the DVO as I heard mixed opinion on how easy it was to get dialed.
    BTW, when it comes time to shipping, I would suggest you look into having it shipped via UPS/Fedex or equivalent. For some reason the frames get stuck in US customs (we assume) for ages when shipped by EMS, their current shipper. Been waiting over two weeks for my frame since it left Finland. Have an open case with USPS to find out where it has got to. They seem to think it's in customs. I think Fedex would have it cleared much quicker.
  29. #129
    JB
    Nov 2007
    I'm 6'6". No numbers published for the XL yet, but both the 130 and 150 XLs have a reach of 535, so I assume it will be right in that neighborhood.
    Good to know on the shipping, I'll have to look into that when the time comes. I've always heard USPS was best for international shipping, but maybe UPS is an option.
  30. #130
    Quote Originally Posted by Nevada 29er View Post
    I think there is something weird going on with customs. My stuff from Germany has also just vanished off the radar. Last was it left from Frankfurt airport over 10 days ago. That was sent DHL which use USPS as their local delivery agent. I don't know if USPS are slow to get things cleared through customs or that it's stuck in some corner in a customs warehouse and hasn't even been handed over to USPS yet. But this has been the worse and slowest experience I've had with importing things from Europe. Normally my stuff is at my door within 6-7 days when ordering from the German sites or Chain Reaction.
    Back on topic. Anyone tried internal routing for their dropper? Does the cable exiting from the bottom of the seat tube interfere with the shock? It looks like it's going to be really close unless you put quite a sharp kink in the cable. Not many options with external routed droppers. The Fox Transfer looks the best but I don't like that it's not user serviceable. Had too many problems with KS droppers so don't want to go there.
  31. #131
    JB
    Nov 2007
    Yeah, I don't know. It literally took like 2 months to get my Works headset from England. I guess the hamsters that power the boats are overworked and under fed..
    Kinda bums me out when I can't find certain parts (or frames) from US based companies.
  32. #132
    Sep 2017
    Just placed the order for the 2018 Evolink 140 TR in XL. Will be a loooong wait to March
  33. #133
    Reputation: Sid Duffman's Avatar
    Oct 2015
    question for you Pole owners: how difficult is it to fold it up and re-assemble. Do you often put it in the trunk to drive to the trailhead, or is it too much of a pain to fold/unfold for every trip?
  34. #134
    Haven't received my frame yet but judging from the videos it looks fairly simple and quick. Also depends on whether you need to remove the wheels too to get it in your car.
    I know from experience that I soon got tired of having to remove the front wheel to get my bike into the back of my car and went and got a rack instead.
  35. #135
    Oct 2012
    In case people haven't seen it yet, the geo for the 158 is up in the Pole store (scroll down to the bottom of the page).
    https://polebicycles.com/polestore/p...r-29-pre-sale/
    The XL looks huge, 535mm reach at a stack height if 652mm, shorter riders might have an issue with this height, it's the same across all sizes.
  36. #136
    JB
    Nov 2007
    I'm wondering why the ST is so short on the XL. Considering the people on this bike will be 6'3" plus, why put a 19" ST on it? Standover is never an issue on any modern bike. I will have to get a 175mm dropper to have a chance of getting the seat out of the way at the height it will need to be for seated climbing. 500mm should be min for an XL frame, which the other manufacturers seem to have figured out.
  37. #137
    Oct 2012
    Warning: there are many double entendre in this post.
    Depending on the dropper you are using and it's minimum insertion requirements the relatively short seatpost insertion figure on the XL of 250mm (I'm taking this to be the max insertion) somewhat compounds this issue (short seat tube with the shock running through it limits the amount of post you can get into it).
    I was looking at getting a 9point8 200mm dropper; however, with a total length of 560mm it will probably be too long. A 175mm LS Lev with a length of 490mm should go close (not sure what the minimum insertion for this post is).
    Other than the seat tube length / insertion issue it looks pretty good.
    Interestingly the geo table seems to be based off a 170mm fork (581mm atc) but the kit mentions a 160mm.
  38. #138
    Dec 2012
    Thinking about ordering a 158 29er frame this weekend. Worried about warranty issues since I broke 2 mondraker foxy rear ends in less than a year. I want it to replace my Mondraker Summum Pro dh bike that I ordered (the frame) and built here in Canada.
  39. #139
    Jan 2013
    You should look up Peter Taylor on the Pole FB page. I think you would have a hard time breaking that bike.
  40. #140
    Jul 2016
    First pic of the CNC frame built up is out
    Everyone wants to ride my Pole-22802672_499122500475170_7550375523650633728_n.jpg
    Personally I really respect the innovation behind it and think it's a sick idea, but I'm just not a fan of the looks at all. I love the angular look of the normal Evolink frames, kinda wish they just kept those lines for the CNC frame.
  41. #141
    That looks pretty slick. I like it.
  42. #142
    Jul 2016
    I really want to like it, but something about the curvy seatstays and top tube just looks off to me. The close ups on all that machined goodness look amazing though, that I can get behind.
  43. #143
    Haven't seen any machined goodness up close. Why the external dropper? /:
  44. #144
    Oct 2015
    Quote Originally Posted by Gvus2001 View Post
    My first reaction when I saw that pic was "ugh, that's ugly." But I gotta admit, it's kinda growing on me. Where is that pic from?
    Also, I'm trying to figure out the longest dropper post I could get into the frame and something seems off on the geometry chart online. For the Evolink 158, if you look at the where the 'bottom' of the seat tube is by taking the seat-tube length and subtract the seat tube insert length, it is highest for the small frame (280mm above the bottom bracket). Compared to 240mm for the M, and 220mm for the large. That trend seem backwards to me.
  45. #145
    Jul 2016
    Pic is from Pole's Instagram. And for droppers that's something I'm trying to figure out too, Leo runs a 150mm fox transfer and it sounds like that can just barely be slammed in a large frame. I'd really like to run a 170mm+ post when I eventually get one of these. I'm leaning towards the 185mm bikeyoke revive, as it's insert length is not much longer than that of a 150mm transfer. The 170mm e13 dropper might work too as it's insert length isn't too long.
  46. #146
    Finally received my Evolink 140 frame. I was pleasantly surprised at how nice it was. Lokks much nicer in the flesh than the photos. Now just waiting for the parts to arrive so I can start building. Still got to make a decision on the fork. Flipping between the MRP Ribbon, Lyrik and as an outsider the DVO Diamond.
    On the topic of the new machined frame. When I first saw that photo of the built up bike my initial thought was that someone had broken its back lol. The way the top tube swoops down into that parabolic curve and the way the seat tube and head tube seem to converge above it just looks like the bike was crushed from above.
    After seeing the photo a few more times it's starting to grow on me though. Will need to see a few more angles.
  47. #147
    Feb 2017
    I have the bikeyoke 185 on my large Evolink 140 and totally love it. Fits really well, and is super smooth and easy to install. I am 192cm tall with a 93cm inseam. The internal routing works fine, I use cable ties to ensure the cable housing doesn’t touch the shock.
  48. #148
    Quote Originally Posted by soebauer View Post
    That's good to know as I am considering the Bikeyoke dropper too. I'm 188cm. How much of the post do you have sticking out above the top of the seat tube? I'm on a large frame too.
  49. #149
    Sep 2017
    Great to hear that you can fit the 185 mm dropper in the size L frame. I´m 193cm and have just ordered the “new” Evolink 140 in XL and have changed the dropper for the 185 mm. I did some fast calculations and came to the conclusion that it should work so it reassuring to read that it fits perfect for you.
    Is that 27,5+ wheels? How does the Evolink feel in that configuration?
  50. #150
    Oct 2015
    Put in a pre-order for a M 158 frame, so stoked, but it's gonna be a looooong 5-6 month wait. Oh well, it'll give me ample time to sell the wife on the need for another bike.
    The dropper post issue is tricky on this frame. I seem to limited to a 125mm post on a M or L frame. This article has some useful measurements of many different droppers: Vital MTB Face Off: The Best Dropper Seatposts - Mountain Bikes Feature Stories - Vital MTB
    9point8 is another to check out if you're struggling with dropper fit.
  51. #151
    Feb 2017
    Sticks out some 6-7cm
  52. #152
    Feb 2017
    Quote Originally Posted by rikhal View Post
    Those are 29” wheels. Newmen 35mm inner width aluminium rims with 2.6” Nobby Nics APEX. Works pretty well, at least for the local trails in Singapore.
  53. #153
    Quote Originally Posted by Sid Duffman View Post
    The FallLine posts are internally adjustable for travel length. I put a 170mm in my Longer G16 frame and the post is barely above the collar.
  54. #154
    JB
    Nov 2007
    ^^ The G16 has a straight ST, no? It should fit in that frame fine.
  55. #155
    Dec 2012
    Talked to Lauri,
    that and the other Instagram picture is actually their new super enduro frame 180 bike that will have pre sale launched at the end of November.
  56. #156
    Yes. But I'm ~175cm and ~82cm inseam. 165mm cranks.
    It's easier to subtract 10mm from the 170mm 9point8 than it would be to add 10mm to the 150mm post.
  57. #157
    JB
    Nov 2007
    T-B, can you give us a ride report?
  58. #158
    Will do but it won't be until late December now as I couldn't finish the build before leaving for business trip and then vacation.
  59. #159
    Dec 2012
    Pulled the trigger today on the 158 29er in blue size large. Now just waiting 5 months to get it.
  60. #160
    Oct 2012
    Geo is up for the new 180 / 160 Machine 29er.
    https://polebicycles.com/machine-geometry/
    Shorter CS at 445, and a longer seat tube on the Large and XL, when compared to the Evolinks.
    EDIT: the shorter CS could be a typo on the website. The change in wheelbase between the Machine and the 158 suggests that the CS is not materially shorter than the 158.
  61. #161
    Nov 2012
    Hi There! Is there anybody here from Canada who own a Evolink or G16? If so, have you paid duties/taxes? And for people who bought a Pole bike from oustide Finland did you get the Finland tax off the price?
  62. #162
    Jul 2016
    Quote Originally Posted by Welric View Post
    I've heard from some people in the U.S. that shipping from Pole is $50 and there are no taxes, or import fees, so I imagine it would be similar for Canada. I'd like to hear what shipping/ taxes is for Nicholai, the G15 looks interesting to me.
  63. #163
    Dec 2012
    I have ordered 3 mondraker frames over the last few years, never got bagged for anything. I am hoping it will be the same with my Pole. Canada Customs seems to pick and choose what gets hit or not.
  64. #164
    Reputation: rollertoaster's Avatar
    I've been riding an evolink 140 for a couple months. This bike is what I've been looking for in a bike. Before I got it i was fed up with the geometry on "normal" bikes and was about to give up and buy a dirt bike. I love slack bikes but slack seat angles and cramped cockpits have been bothering me for years.
    I just pre-ordered a Machine frameset on Friday...
    Sent from my SM-G955U using Tapatalk
    Team _________
  65. #165
    Nov 2012
    Lots of good feedback on the 140. What about the evolink 158? Same bike, more travel?
  66. #166
    Oct 2015
    158 hasn’t been released into the wild yet. Expected delivery in April 2018 (I preordered one; gonna be a loooong wait!)
    But yeah, other than the slightly slacker head tube angle and slightly longer wheelbase, the geometry looks almost identical to the 140. So I would expect, as you said, same bike with more travel.
    No info (that I could find) on the website about if the kinematics are different between the two bikes.
  67. #167
    I would expect the kinematics to be similar to the 150, which according to the leverage charts Leo has posted on fb yesterday, are optimized for an air shock. Compared to the machine, the 150 the machine has less of a hook at the end of the travel. That hook is to help squeeze the last little bit of travel out of an air can.
    This is purely speculation that the leverage curve will match the 150. It's possible that the kinematics are modeled after the machine.
    Team _________
  68. #168
    SISSIF
    Reputation: TheCanary's Avatar
    May 2014
    Quote Originally Posted by rollertoaster View Post
    The Machine looks amazing! Curious if you would share your dimensions and the frame size you ordered?
    The Geo is out there enough to make it difficult to compare to my current ride.
    Thanks.
    Big Wheels and Fat Skis keep me young.
  69. #169
    Quote Originally Posted by TheCanary View Post
    Thanks.
    6'2" 188lbs 35" cycling inseam. No idea how long my arms are. I ordered a large and I'm currently on a large evolink 140 with a 160 fork and 50mm stem.
    Team _________
  70. #170
    SISSIF
    May 2014
    Great. Thanks.
    5' 11" with 34" inseam. Thinking medium with a long dropper would be spot on.
  71. #171
    Great. Thanks.
    Don't be affraid to step out of your comfort zone. My teammate is about the same size as you (maybe slightly shorter legs), he's looking to get a large
    Team _________
  72. #172
    SISSIF
    May 2014
    Yeah, tough call. Down sizing on the Wreckoning because it was such a 'Big' bike was a mistake. The Machine is another big bump up, 5' 11"(180cm) puts me right on the line between sizes.
    Looking for accurate numbers, I've seen chainstay lengths from 445 to 456 and wondering if there is different lengths for different sizes.
  73. #173
    Sep 2013
    Leo is on a m+ size don’t know when that is released but I’ll wait for that
  74. #174
    SISSIF
    May 2014
    What are Leo's dimensions?
  75. #175
    Aug 2013
    I'm 178cm and was thinking about going for the large frame 158 as I usually ride a large in everything else. I asked Pole what they would recommend, and both Leo (179cm) and Juhani Kettunen (Pole ambassador, height 180cm) prefer the medium over the large frame. Also the Pole homepage recommends sizing down when between sizes. So I took their advice and ordered a medium 158.
  76. #176
    SISSIF
    May 2014
    Yep. Hemmed and hawed, feel pretty good going for the medium Machine.
  77. #177
    Reputation: Toube's Avatar
    May 2017
    Hi,
    I'm a owner an Evolink 150 L size frame. I'm 183 cm tall and I got the bikeyoke 125 installed on it. Pole recommended me the Link size frame.
    Br,
    Toube
  78. #178
    Dec 2012
    Ordered a 158 to replace my Mondraker Summum DH bike. Got a SC Tallboy 3 this summer and I see the future with 29 wheels.
    Going to use it at my local bike park. It comes with a Monarch Plus RC3 but I am thinking about going to a Fox DHX air. Anyone upgrade their frame with Pole?
  79. #179
    Nov 2016
    any thoughts about the stack height on the 158 being too high? it is 13mm higher than the 140 which is already high
  80. #180
    Aug 2013
    It's measured with a longer fork than the 140. It is probably totally ok. If you like a low front end you can always use a negative rise stem and/or a flat bar. Usually I put all the spacers under the stem anyways, and most other riders i meet on the trail do the same. I think a higher stack is not a problem unless you are fairly short.
  81. #181
    Nov 2016
    Thanks, if I am understanding you correctly you are still raising the stem? How does this effect flat corners?
  82. #182
    Aug 2013
    Yes and no. I do raise the stem on my bikes, but I don't have a Pole. I have ordered a 158 , and it will possibly arrive in early spring. There are a lot of bikes with high stacks, and I have never heard owners complaint about it. Stumpjumper, camber, guerilla gravity, all have high stacks. Evil Wreckoning is one of the most hyped and highly praised LT bikes, and it has a similar stack to the 140-158, and I have never heard anybody complaint about the stack. You can always to a degree remedy a too high stack. I do not think it will be a problem on the Pole either unless you are short or you just hate high stack bikes.
  83. #183
    JB
    Nov 2007
    Any updates on the anticipated delivery dates for the 140 XLs? I preordered back in November.
  84. #184
    Oct 2015
    You probably have already seen this, but the Pole website says approx delivery date in April 2018. I'm guessing that means May, best case scenario, for those of us in the US.
    I pre-ordered a 158 in November and the waiting is killing me!
  85. #185
    SISSIF
    May 2014
    Delivery of The Machine
    Yep. The Machine delivery has been steadily pushed back. Not unexpected with the design and production being so unique. The big descents don't open around here till July, hoping to have it ready by then.
  86. #186
    Sep 2017
    I preprdered my 140 XL in the end of October. And then the delivery date was set to March. I have asked Pole about the delivery and they told me that the first preorder bunch will be shipped during the last week in March.
  87. #187
    Dec 2012
    Just got the email, March became April and it has become May.
  88. #188
    Apr 2015
    This is disappointing.
  89. #189
    Dec 2012
    yep,
    It is going to be my bike park ride so the hill here does not open until the end of may. If it was to be my only ride, I would not be very happy at all.
    dave
  90. #190
    Oct 2015
    I pre-ordered a 158, but the repeated delays made me wonder if it was ever going to come. So I decided to get a refund and ordered a transition Sentinel. Bummed because i’m sure the Pole would’ve been sweet, but also really excited for the Sentinel!
  91. #191
    Aug 2013
    I'll stick with my order for the 158 for now. A delay seems to be the norm for bike preorders. Many companies won't even give you a date for preorders since they don't know when they can deliver. Let's just hope that there will not be any more delays from now on. I bet the Sentinel is a sweet ride. Was considering it but wanted to go the extra mile with a long travel two niner.
  92. #192
    Dec 2012
    I am sticking with my 158 order as well. The only other frame I thought of getting was the RAAW Madonna but they did not ship to Canada.
  93. #193
    Dec 2012
    Another delay, this time until May 25th.
  94. #194
    Aug 2013
    Yeah that sux. Not really a problem for me yet since there is still a meter or more of snow on the trails. But it is getting seriously close to the date I have set where I need to find a new bike and cancel my Pole. For ppl living South of the arctic circle I can understand they are getting frustrated.
  95. #195
    Here, diagonally!
    Reputation: JACKL's Avatar
    I don't think I've ever seen a new bike product release on time. Whatever the expected remaining wait time is, just double it.
    I'm looking for an XXL bike and 158 sure does look interesting. Checks most of the boxes, but not a fan of a falling AS curve, at least based on FSR bikes I've ridden. May end up being a non-issue with the Evolink, but buying one without being able to demo would be quite the leap of faith.
  96. #196
    SS in CO
    Reputation: Jayson44's Avatar
    Aug 2005
    two questions:
    1.) does anyone have an Evo 130 yet? if so, what do you think about it? same sort of positive reviews as the 140?
    2.) anyone in Colorado have an Evolink yet? I'd love to see/sit/ride one in person at some point.
    J.
    are you a bike shop owner? or a custom builder? I want to talk to you about your website
  97. #197
    Dec 2012
    Anyone get a new email saying their frames have shipped?
  98. #198
    SISSIF
    May 2014
    Hoping to have a Machine in CO this summer.
    Being patient...
  99. #199
    Sep 2014
    They seem to have some demo days in US. Check from their web-site where and when. At least one location was in Colorado and another one in Utah.
  100. #200
    Aug 2013
    Quote Originally Posted by depeche4 View Post
    According to Pole. The first evolink 140 v1,3 was shipped to customer last week. They have pics of the 158 on their facebook. So some of the bikes seem to have arrived in Finland. I got an email where they say they will probably have an update on delivery on thursday this week.
    As i understand it the first batch was shipped by air to Finland.
  1. What would you do? Pole
    By Finch Platte in forum Off Camber (off topic)
    Last Post: 11-18-2015, 09:26 PM
  2. Saturday's Ride ... Bobcats fighting on Power Pole / Limekiln
    By ancient rascal in forum California - Norcal
    Last Post: 06-15-2014, 01:25 PM
  3. An Antartic bike ride unassisted to the South Pole
    By coastkid71 in forum Fat bikes
    Last Post: 06-02-2014, 09:09 PM
  4. Christini 2wd Fat Bike for South Pole ride
    By shanesbw in forum Fat bikes
    Last Post: 04-12-2013, 01:28 PM
  5. Pole Hill
    By dutchman59 in forum Colorado - Front Range
    Last Post: 10-10-2011, 10:42 PM
Members who have read this thread: 620
