Page 4 of 31 FirstFirst 1234567814 ... LastLast
Results 76 to 100 of 757
  1. #76
    Reputation: Loonytik's Avatar
    Quote Originally Posted by nbwallace View Post
    The frame weighs 2040g.....Here are some photos:
    The layup looks good on the last pic. Build her up!
  2. #77
    Oct 2007
    I will post build pics as we go.
    Normally this wouldn't take too long, but the lack of shock hardware has me stymied. We could drop $62 on RWC needle bearings I guess.
  3. #78
    Plays with tools
    Reputation: customfab's Avatar
    Quote Originally Posted by AZ.MTNS View Post
    Seat stays at the pivot look suspect IMHO, would like to see a bit more material there.
    Did you run the FEA based of the photo?
    http://www.abbeybiketools.com/
    --- industry disclaimer ---
  4. #79
    Reputation: two-one's Avatar
    The frame arrived yesterday shipped last Tuesday. The finish is top notch it is beautiful. Sadly it arrived without any shock mount hardware. I think I can get some somewhere, the upper and lower are 8mm with 22mm spacing. I suspect I should email janice to see if we were supposed to get hardware.
    The frame weighs 2040g and none of the pivots were greased out of the box.
    Do you have a close-up of the front derailleur mount?
  5. #80
    Reputation: vizsladog's Avatar
    frame looks nice. cant wait for a build pic and ride report
  6. #81
    The mounting hardware is supplied by SRAM and sold separately from the shock since it has to be sized to the frame. Do a search for "rockshox monarch hardware kit" and you should find what you need. Below is the link to BTI's page. Your LBS should be able to order what you need. Universal also sells these if you prefer that route. You'll need to source a high grade bolt too, as I believe these kits are just the spacers.
    BTI | Forks & Rear Shocks from Rock Shox (page 10)
  7. #82
    Mar 2011
    monarch shock
    Will a monarch shock fit this frame? Thanks!
  8. #83
    AKA AZ.MTNS
    Reputation: Dirty $anchez's Avatar
    Quote Originally Posted by customfab View Post
    Did they?
  9. #84
    Depends which Monarch. If it's the correctly sized Monarch, then it will fit. I'm pretty sure the shock dimensions are earlier in the thread.
  10. #85
    Mar 2011
    Thanks car nut. I'll check it out.
  11. #86
    Yes , I am slow
    Reputation: floydlippencott's Avatar
    Let me guess, you did.
    Originally posted by AZ.MTNS
    "Massive trail closures in Sedona will be Trail Doc's legacy."
  12. #87
    Oct 2007
    Thanks for the links to the shock mount kit
    In the end we ordered two need bearing kits from RWC. Probably spent $25 more than we needed to. As far as the bolts go. I have been running a regular M8 in the linkage of my spider for a while with no problems. I may just run to home depot and get some 40mm m8 bolts and lock nuts. I guess I could call my local fastenal and get SS m8x50 bolts.
    I think at some point I will put together a shopping list for those wishing to build up this frame.
    Also there is no front derailleur mount. We'll be using an e-type. From the tubing profile I think that is the only solution. I'll know more when I get the crank on. There might be a place for a high mount clamp. it looks like bottom pull is required as well.
    This frame is not exactly a good practice run for first time builders.
  13. #88
    AKA AZ.MTNS
    Awesome idea to help out with build ups.
  14. #89
    Needle bearings, eh? Going all fancy like!
    I suppose it doesn't matter for a XC bike what kind of bolt you use. I just have a general disdain for Home Depot grade bolts as they're soft as clay. It doesn't need to be stainless, just something that's harder than butter.
    I think I (and others) assumed the gold metal piece above the BB was a hard mount for an E-type derailleur. It looks like it has some threaded bosses on it, but it's' hard to say. I think that's the area they were requesting better photos of.
  15. #90
    Also interested in seeing a shopping list.
    2013 Epic Expert Carbon Evo R
    2012 Specialized Stumpjumper FSR Expert Carbon 29r
    2012 Ventana El Rey
  16. #91
    Plays with tools
    Quote Originally Posted by floydlippencott View Post
    Nope, don't know how either. It just seamed odd to me that a member that usually posts level headed advice made an assumption about the structural integrity based off a picture.
  17. #92
    Quote Originally Posted by Stryder75 View Post
    Wow, that looks a lot like the new Scott spark 29er frame. I mean a lot. If it is under 1K, may be worth a purchase and build up.
    I agree it does
  18. #93
    AKA AZ.MTNS
    I'm going to take that as a compliment, in a friendly beat down kinda way. You are absolutely correct, it was a huge assumption.
  19. #94
    Plays with tools
    correctly taken. That comment was about is well placed as when you suggested somebody read threads about saddle preferences.
  20. #95
    Jan 2011
    First impression: AWESOME!
    I can't wait arriving to me..
    About front derailleur I think it fits a mech direct mount bottom pull. Pay attention to the gap between the centres of the two mounting holes.
  21. #96
    Quote Originally Posted by LoAl View Post
    I would also figure it can be mounted like this, thats why i asked for a close-up:
  22. #97
    Oct 2007
    Yeah that looks like the front derailleur mount
    We have an e-type for the build it will be nice to just bolt it on. My question is how long will they keep making e-type derailleurs.
    We're gonna start building tomorrow night. I'll try to document as much as I can. I think that we might be able to get pretty far without another trip to the bike shop. But my guess is that the lower shock mount is going to need a shock bolt kit from another frame. I will try to post a photo of what I'm talking about, but let's put it this way there's no room for a lock nut to hold the M8 bolt, we're gonna need some special kind of M8 nut on the end of a 50-60mm M8 bolt.
  23. #98
    Oct 2007
    Building the AC-036 Chinese carbon 29er fully
    The frame arrived without shock as expected we also needed shock hardware and
    bolts as well, you'll also need an e-type front derailleur (more on that later)
    Shopping list:
    Shock - Rockshox RT3 high tune 6.5"
    Mounting hardware - Rockshox sells a 22.2mm by 8mm bolt setup. You'll need two
    Or you can go to RWC and get needle bearing kits for 22.2mm spacing
    Shock bolts m8x40mm with a lock nut and and m8x50mm (some kind of specialty nut) I'm MacGivering
    somthing up out of brass
    E-type front derailleur we used XT
    If you want to use a non-tapered shock you'll need a baseplate from cane creek
    You'll need to take apart all the pivots and grease them. There are bearings in the lower
    and upper main pivots. Everything else has bolts that act as bushings. I fear for
    the longevity of the pivots. When it came out of the box you could not cycle the suspension with
    your hands.
    The bike went together without too much hassle the internal cables allow the cable outers to
    route through the frame. Everything routes under the bottom bracket including the rear brake line.
    See the photos.
    The rally killer is the front der. There is no access to the cable bolt in the
    inner ring position. So you need to do some serious trial and error to get cable
    tension right. The largest issue was the alignment. Without some shims the
    front derailleur sits with the rear toed out. The solution is to put two washers
    under the derauilleur mounting plate (see photo below) once that was addressed the
    front shifted like butter.
    The assembled bike:
    1) it's light. Built up with X9/XT an old Reba Race an XTR-M960 crank and Stan's
    Arches on 3.30 hubs it came in at 26.4 LBS that includes a rather heavy carbon
    wrapped seatpost from ICAN. For reference that's a bit lighter
    than my Spider 29 with a lefty and X0.
    2) The suspension feels quite nice with the RT-3 at 30% sag. It wa a nice balaced ride with the
    Reba. I'm waiting for Eric to ride and give me the full report. He was overjoyed
    with how the bike came out.
    I'll conclude by saying the finish of the bike is really nice. Now that I've built
    one up I think I could go start to finish in a few hours. Cabling this bike is
    pretty easy once you understand the whole front derailleur issue. With having to buy
    a shock and hardware, it's hardly a super cheap build. It really is in the
    neighborhood of a spearfish and a decent build puts it in Giant Anthem territory.
    But none of those bikes will build this light. I am favorably inclined towards this
    frame. I expect the price to come down and with some opportunistic shopping one could
    put together a very light build for about $2K.
    Attached Thumbnails Attached Thumbnails Dual Suspension Chinese Carbon  29er-p1000171.jpg
  24. #99
    a personal favourite
    Reputation: emu26's Avatar
    Damn that bike is so light it's gravity defying. Pity I can't link your last attached pic before you put it the right way up
  25. #100
    Reputation: nathanbal's Avatar
    great write up!
  1. Chinese Carbon 29er
    By crashplayer19 in forum 29er Bikes
    Last Post: 5 Hours Ago, 12:33 PM
  2. Chinese carbon 29er frames?
    By Scott O in forum 29er Bikes
    Last Post: 07-26-2011, 11:05 AM
  3. Chinese Carbon 29er from 2011 Hardrock
    By Pininfarina599 in forum 29er Bikes
    Last Post: 07-23-2011, 07:21 PM
  4. Saw a chinese carbon 29er yesterday, nice...
    By madsedan in forum 29er Bikes
    Last Post: 06-09-2011, 04:53 AM
  5. Chinese Carbon 29er - buy it or not?
    By mountaincycle in forum 29er Bikes
    Last Post: 05-21-2011, 04:57 AM
Hot Deals
Contests
Latest Mountain Bike Articles
