Page 22 of 24 FirstFirst ... 1218192021222324 LastLast
Results 2,101 to 2,200 of 2319
  1. #2101
    May 2013
    This frame looks interesting too.Dual Suspension Chinese Carbon  29er-imust-29er.jpg
  2. #2102
    Formerly PaintPeelinPbody
    Reputation: PHeller's Avatar
    Dec 2012
    Link or model name?
    GIS/GPS Pro using ArcFM for Utility Mapping - Always willing to connect with other MTBers in the industry.
  3. #2103
    May 2013
    I saw it on Ebay. Direct sales bikes.
    EBay search - 222602331908 29ER bike frame
    EBay search - 132107206145 27.5 plus bike frame accepts 29" wheels
  4. #2104
    Reputation: R_Pierce's Avatar
    May 2017
    Ican P8 build finally to where I think Im content (suspension wise and all)
    Attached Thumbnails Attached Thumbnails Dual Suspension Chinese Carbon  29er-img_20170826_092612.jpg
  5. #2105
    May 2013
    Quote Originally Posted by R_Pierce View Post
    Looks great. What do you think of the frame? Are you happy with the quality? Do you like the geometry? That frame claims to have a 68 degree hta. Does this feel at all steep? The seller claims this can be built as a 29er also. Is there room in the back for a 29" wheel?
  6. #2106
    May 2017
    There is room for a 29" wheel. I'm running 27.5 x 2.8 (plus tire)
    The quality is amazing! It is as good or better than my US made Framed Marquette Carbon bike.
    It's stiff. It's rigid. And not at all flexy. There is a little lateral flex in the rear triangle if you grab the top and bottom of the wheel, but it's not noticeable when you are riding. Absolutely love the bike!
    My only complain is the BB height. It's only 324mm static, so gets pretty low when sagged. But that is the new trend so....
    Sent from my ONEPLUS A3000 using Tapatalk
  7. #2107
    May 2017
    And no. It actually feels quite slack. I just measured mine with the 140mm fork and it's right at 67* head angle.
  8. #2108
    May 2013
    Thanks for the great feedback. This frame might even handle a 150mm fork. Raise the bb and slacken the hta, even if only slightly. I am looking to build a 29er. And this frame along with the other (Imust 29er) frame are contenders. This appears a little burlier than the 29er frame. But you can't tell till you build it up. How is this suspension for smoothing out the trail? And how is it for pedal bob when climbing?
  9. #2109
    May 2017
    Quote Originally Posted by endo_alley View Post
    Send me over your email address. I'll send you the linkage curves I had another forum member draw up for me.
    It doesn't have much antisquat so it does peddle bob a bit. But the correct shock selection with a correct platform takes that right out of the bike. Its awesome at smoothing out the bumps (keep in mind I'm a 295lb rider so I have to run quite a bit of pressure)
    Shoot me over your email on a PM and I'll send the charts.
  10. #2110
    I've got quite much sideways play here on my cs 036. Got new bearings. Anything to do about it?
  11. #2111
    May 2017
    Quote Originally Posted by haakonbs View Post
    Yes, put the rear wheel in and through axle and tighen it down??
  12. #2112
    Still play
  13. #2113
    May 2017
    Still play
    Play in what exactly? In the joint? Does the seat stay physically move inside of the chain stay? We need a little better description here.
  14. #2114
    https://youtu.be/dFuv4kAivKM
  15. #2115
    May 2013
    Appears to be missing a spacer or bushing. Are the bearings properly torqued? Something like 12nm I think. Show this link to Carbon Speed.
  16. #2116
    I've might have used the wrong bearing? 2 spacers. 1 on each side
  17. #2117
    Used 8x19x6
  18. #2118
    May 2013
    How many miles on bike till it needed new bearings?
  19. #2119
    These are brand new
  20. #2120
    May 2013
    These are brand new
    Brand new bike has that much play. Hope there is a guarantee. You might be able to find some brass washers or spacers (maybe stainless steel) at a local hardware store if the seller doesn't warranty this. Probably the washers need to be small enough to catch the inner race of the bearing while not catching the outer race. Or better yet find a wider bearing.
  21. #2121
    May 2017
    That's definitely not right. Why did you replace the bearing in the first place on a new bike? And what size was the one that you took out??
  22. #2122
    The frame is not new. Just the bearings. I changed because of play
  23. #2123
    May 2017
    Ah
  24. #2124
    Land of the 230+
    Reputation: GuitsBoy's Avatar
    Sep 2013
    Did you by chance measure length between shock mounting points at full droop and full compression (when arch hits seat tube)?
    I finally took the caliper to this, and it seems theres almost ZERO room for error on this frame. The fully compressed limit was 4.7 inches or 119.4mm. Thats exactly 45mm travel on a 165mm shock. Also, theres no way to fit a larger shock in there, as the linkage binds up at under 170mm eye to eye.
    Anyway, even if we were to find a trunnion mount shock that fits the FS27, you better be sure you never max out travel or you could potentially be sending the seat stay arch into the seat tube. Just one more reason the practical limit to this frame maxes out at 100mm travel.
    Also, in case anyone needs to know, the mounting tab spacing was 21.7 on the top and 49.6 on the bottom.
  25. #2125
    Reputation: mr_manny's Avatar
    May 2016
    Is there a consensus regarding unified rear triangle vs multi pivot?
    fs27, fm006, fm058 vs ican p8, p9
  26. #2126
    Jan 2015
    Quote Originally Posted by GuitsBoy View Post
    I'm going ahead with my build. After looking at extensive pictures I can see that the Scott version has a little more scooped out of the non drive side mount to make room for the air valve. And after looking at the fox shock compared to my rockshox I can see that the fox trunnion mounts are at least 5mm higher on the shock giving it significant more clearance.
    Here is my plan I will have to remove a little material I think to make the air valve clear. I'll do this with a dremel. I am not concerned with sacrificing strength as the mounts are much burlier then the Scott mounts. Typically over built Chinese style. They would rather over build and add weight then have it break and harm their rep imo.
    I will also have the mount eyelets enlarged from 8mm to 10mm this again ok because there are metal inserts there more then enough material to remove some and still have plenty of insert left.
    Dvo have told me they will make a Scott spark version of the Opal inline air shock I am sure I can get them to take a couple mm of travel out if it is indeed true that it has max 119.
    I personally measured the rear axle travel at 128mm from open to stopped against the seatpost. So we will see.
    It may be December before I can get my hands on an opal though it was just shown at eurobike 2017. DVO Introduces New Single Crown, Dual Crown and Air Shock - Mountain Bikes Feature Stories - Vital MTB
    Edit. Bryson Martin ceo/founder in a personal email told me towards the end of the year for Opal release though one site quoted April one quoted fall and another December. So I may be running a 165/38 for quite awhile.
  27. #2127
    Land of the 230+
    Sep 2013
    Please please please post pics. Would love to see how your modifications work out. I doubt I'm willing to take the same risks at my weight, but I'm very intrigued none the less.
  28. #2128
    Jan 2015
    I will post here and chiner don't worry. I can be a little more brazen about mods at 5'9 130lbs 😋
  29. #2129
    Jun 2015
    Congrats KVD!
    Mr Manny. Ha no way, never! All these suspension layouts are copies of popular designs. The three you named in no order are vpp, single pivot rocker and Horst link. They all have pluses and minuses, which you should be able to learn about with some searching.
  30. #2130
    May 2016
    Thanks PurpleMtnSlayer...will do some research
  31. #2131
    Jan 2015
    So I'm looking at the cc db air inline for my stand in shock for fs027+ till the dvo opal drops.
    After doing some measurements I think it can clear sitting right side up air can on top.
    The things on the bottom that stick out will clear by couple mm and offset bushings will give even more.
    What I want to know does anyone see reason I can't mount it top up instead of inverted?
  32. #2132
    Sep 2013
    I lookes like it is the bering itself that moves, happend to my FM036. I used Loctite 641 on all berings before fitting. Solved the problem.
  33. #2133
    Locktite where?
  34. #2134
    Jan 2017
    I received my enduro P9 (ican), but still waiting on parts to come in to build it up.
    AFAIK - this is the most up to date design from all the China Carbon websites. From my initially measurements of everything:
    1) Rear Triangle will have enough clearance to run 29" & Maxxis Minion DHF 2.5 WT. However with shock fully compressed, and seat dropped all the way down, it will most likely hit your seat. I will fully confirm this once the bike is build up.
    2) There's about 300mm of insertion length on the seat tube on a Large Frame. I am thinking of running a 175mm KS Integra dropper post fully inserted into the frame, but I still need to build it up to measure my height.
    3) There's absolutely no protection of any sort on the frame (downtube, chains stays)
  35. #2135
    Dec 2015
    I'm thinking to move to a FS from HT one and i'm also thinking to get a Chinese one! This is what i think it looks interesting! Any other suggestion?(looking for a Non boost, XC racing 100mm frame)
  36. #2136
    Land of the 230+
    Sep 2013
    Quote Originally Posted by cycloholic View Post
    That looks like the CS FS29, right? I have the 27-plus boost version of that, the FS27, and its been fantastic. Ive never been more comfortable on a bike in my life, and the bike climbs way better than I expected it to. Supposedly there are more efficient FS XC racers out there, but if youre looking for something with a little more trail oriented geometry without the weight or losing efficiency, this is about as good as it gets in, IMO.
  37. #2137
    Dec 2015
    I didnt mention this is not a XC geometry! Actually this is why i posted here! So any other more XC competion frame suggestion?!
  38. #2138
    May 2017
    Actually by today's standards that bike is VERY much XC related geometry....
  39. #2139
    Dec 2015
    This also looks nice!!
  40. #2140
    Land of the 230+
    Sep 2013
    I have to agree here. Its geometry is modeled after a bike with at least two olympic gold medals to its name. XC racing seems to be getting a bit more aggressive and chunky these days. This is a bike that will keep up with that. However if he needs something a with more classic geometry to dodge trees, it may not be the best suited frame.
  41. #2141
    Dec 2015
    Ok, so the geometry is similar to scott's spark!! If it works for nino it probably work for me too LOL.
  42. #2142
    May 2017
    I ride the P8 which currently sits at about a 66.5* head angle with the 140 fork and we have some ridiculously tight and twisty single track full of trees. I have no issues. So this bike SHOULD rip through tech.
  43. #2143
    Dec 2015
    Also i found a 2015 cube ams 100 in a very good price(almost the same as chinese) in bike-discount! Whats your suggestion?!
  44. #2144
    May 2013
    I am still waiting for my Nextie rear wheel before my P8 build is finally done. Looking forward to it.
  45. #2145
    Dec 2015
  46. #2146
    May 2017
    no, but as a general manufacturer Hong Fu seems to have a very good reputation.
  47. #2147
    Dec 2015
    Thanks! Is there a direct link of their products?
  48. #2148
    May 2017
    Shenzhen Hongfu Sports Equipment Co., Ltd.
    website is pretty generic at best. But feel free to contact them.
    I will say from experience that Peter @ XMcarbonspeed is by far the best for communication. If you need that, and tech support its probably best to get a bike from XMcarbonspeed. If you are fairly knowledgeable and dont need tech advise or support then you can venture out a bit.
  49. #2149
    Sep 2013
    Inside the bering cups, you glue the bering inside its cup. Then it will not move under pressure. Loctite 641 is made for this and it is possible to press out the berins again when worn out.
  50. #2150
    May 2013
    Quote Originally Posted by eriklanden View Post
    I find that much of the movement is in the oblong (pear shaped) nuts that the bearing screws fasten to. These should be epoxied in place.
  51. #2151
    Nancy at HongFu has been excellent to work with. Quick reply's and she answered all my questions. I have the FM058 on order. Hoping to receive it in early Oct.
  52. #2152
    May 2017
    Quote Originally Posted by babarnicle View Post
    Very nice!!
  53. #2153
    May 2013
    These frames typically have an integrated headset. Is it best to press in the headset using grease, or using a soft thread locker such as Locktite green?
  54. #2154
    May 2017
    neither. Its a carbon frame so no grease. No locktite needed either. Simply place the race on the fork, place the lower bearing on, install the fork through the headset (lower bearing will center itself in the lower integrated cup) install top bearing, install spacer, install top cap, stem and top cap. Tighten top cap to remove any play in the bearings/headtube then torque down the stem.
  55. #2155
    Ride Fast Take Chances :)
    Reputation: alexbn921's Avatar
    Integrated headsets are loose bearings that sit in the molded cups of the head tube and yes they need grease lots of it.
    Press in cups need grease too but just a light coat. If you press it in dry it will require much more force and be more prone to creaking.
    The only place I have ever used locktight on carbon is press fit BB cups.
  56. #2156
    May 2017
    Quote Originally Posted by alexbn921 View Post
    Im willing to bet that the cup in this carbon bike will not be tight enough to need grease. I dont recommend grease ANYWHERE on a carbon bike that is bare carbon. I almost guarantee you that he can press the bearings in by hand with no issue....
  57. #2157
    If we are talking about an integrated headset, then you don't press anything. The bearing sit in cups molded into the frame. This bearing will move slightly even with a properly torque top cap. You need grease and lots of it or will creak.
  58. #2158
    May 2017
    OK, we will just agree to disagree. This is my second carbon bike and I have yet to have a single headset creak. And I have ZERO play in the headset and/or bearings. None once properly tightened with the top cap.
  59. #2159
    Uh, no.
    Small ring in front makes it easier. Small ring in back makes it harder. That blows my mind.
  60. #2160
  61. #2161
    May 2017
    like I said, personal experience on two different carbon bikes with carbon formed integrated headsets has not provided a single creak for me. Im not greasing them. No need.
    To each their own though....
  62. #2162
    Dec 2015
    Great! What shock are you going to put? 165 and 190mm are both for XC with 100mm travel or am i wrong?
  63. #2163
    May 2013
    I guess I will install the headset without any more grease than what comes on it from the factory. As long as it doesn't creak then all is well. Having never dealt with an integrated headset I don't necessarily trust it to seat firm enough not to creak. But I will hope for the best. If it creaks in the future I will address that problem at the time.
  64. #2164
    May 2017
    if it creaks, it takes all of 10 minutes to disassemble and reassemble with grease if needed.
  65. #2165
    I grease mine. Various reasons. Here is part of discussion from other forum. Do some research and decide for yourself though.
    uote:
    Originally Posted by JonD View Post
    Hi All,
    I'm servicing my 9 month old Ridgeback Flight 02, which has integrated cartridge races top and bottom of the headtube. They had a reasonable coating of grease on them when I took them out, but now I'm refitting them I am not sure whether I should grease everything.
    The headtube doesn't appear to have any cups in it, just a 45 degree chamfer machined into the aluminium wall at the top, and a 45 degree chamfer on top of the steerer.
    Having read this article http://chrisking.com/files/pdfs/Int2...sExplained.pdf
    it reminded me of something similar I had read about the importance of *not* greasing bearing seats in other applications, the theory being that you want the race to be the part that moves, not the shell in its seat. Plus if the shell can move around easily on the grease, it will exacerbate the wear described in the article, especially if the grease picks up dirt etc. The article was rather scary regarding irreparably wearing out the seat!
    But, equally I don't want to find the shell becomes stuck in the headtube the next time I service it.
    So, what's the wisdom on grease/anti-seize for installing bearings (not inside the races themselves, just the fit to the frame/tube)? Grease the seats lightly or not, and should there be any grease on the steerer tube where there bearing touches it?
    Many thanks!
    Jon
    Grease or anti seize, your choice, the outsides of the bearings before inserting them into the seats. I also do the same to the crown race. Done so for 40+ years. Andy- whose headsets don't creak.
    Andrew R Stewart is offline Reply With Quote
    Old 12-30-14, 08:58 PM #6
    +1 I also grease both the exterior of the cartridges and seats of headsets. It prevents both corrosion and noise and the seats have never worn.
    HillRider is offline Reply With Quote
    Old 12-30-14, 09:23 PM #7
    I use a stiff anti-seize grease. This stuff is the consistency of peanut butter and is not suited as a ball bearing grease.
    The grease serves two purposes.
    1- it's a weather barrier and prevents water wicking between the two parts and making mischief.
    2- it acts as a bedding compound, allowing the bearing find it's best place and prevents creaking later on.
    There's plenty of latitude here, and just about anything except a dry fit will work. Even dry fits work, but if they creak, you'll go back to bedding the bearing in something.
    FBinNY is offline Reply With Quote
    Old 12-31-14, 02:58 AM #8
    Thanks for all the great advice guys. I think you've convinced me to stick with some sort of grease/anti-seize. On Andy's point though I would say that 40 year old headsets won't have these cup-less integrated bearing seats which are cut into the actual aluminium tubing. I'm now just paranoid that if I wear the seat in the head tube the frame will be junk
    Just hoping someone can allay my fears!
  66. #2166
    May 2013
    Quote Originally Posted by odtexas View Post
    If the integrated machining of the frame wears out over the years, then I am sure locktite will be the necessary fix.
  67. #2167
    I'll do the 165 shock which is a very common size. Probably monarch xx with the single remote to lock our front and rear at the same time. I'm building this up for an XC and marathon set up.
  68. #2168
    Dec 2015
    From which dealer you bought it?
  69. #2169
    Does anyone know how long it takes to get a frame from China to the states? Shipping time? The carrier is EMS???
  70. #2170
    May 2017
    mine took about 10 days
  71. #2171
    May 2013
    P-8 , 29er completed a few weeks ago.
    Attached Thumbnails Attached Thumbnails Dual Suspension Chinese Carbon  29er-img_0783.jpg
  72. #2172
    SHRED!
    Reputation: shredjesse's Avatar
    Oct 2017
    @endo_alley: That looks pretty interesting! How much did it end up weighing? What components did you go with? What was cost like.
    I'm intrigued by the concept of building my own bike and having it be carbon fiber Seems like you might be able to get a pretty radical bike for cheaper than brand new this way. I suppose having all the parts in advance is perhaps critical, that or sourcing cheap stuff on ebay?
  73. #2173
    May 2017
    nice man!! How are you liking it? What width are the tires?
  74. #2174
    May 2013
    Rims 40mm Nextie on DT Swiss 240 hubs. Sram 1x12 cassette and shifter. Next cranks. Fox dropper post w/ Wolftooth lever. 2.4" Continental Mountain King tires. 780mm carbon bars. 50mm stem. And the last addition done yesterday are offset shock eyelets which probably slacken head angle a little. The bike rides great. 13" bb height. The bike I have been riding is a Pivot Mach 6 which also had a 1 degree angle set to slacken head angle to 66 degrees or even a tad slacker. So this seems a little turnier to me on descents until I get completely used to it. Fairly light bike. Climbs well (even better if with a more powerful motor). Not much pedal bob.
  75. #2175
    May 2013
    Looks like it could handle a 2.6" tire front and rear if I ever wished to do so.
  76. #2176
    Reputation: RS VR6's Avatar
    This one from Workswell looks pretty interesting.
    WCB-M-145-workswellbikes
    It's a 100mm frame with a 68 deg HTA (with a 506mm A to C) and a 428mm reach on a medium. No Boost which would work out for me just fine.
  77. #2177
    May 2013
    I added some offset bushings to slacken the bike a little.
    Attached Thumbnails Attached Thumbnails Dual Suspension Chinese Carbon  29er-img_0784.jpg
  78. #2178
    Oct 2017
    awesome looking bike, I am thinking about building something similar.
    Are you having any issues with pedal strikes? what length cranks are you running?
  79. #2179
    May 2013
    Quote Originally Posted by mercenary View Post
    I am really liking the bike. BB is about 13 inches off ground with 29er wheels. At first, the bike took a little getting used to. I had been riding a Pivot Mach 6 with a 1 degree Aheadset to slacken the head angle to about 65.5 . This is not quite so slack in the head angle. Probably 67-67.5 degree head angle. But now that I am used to it the bike is fine. Cranks on this bike are 170mm. No pedal strikes to speak of.
  80. #2180
    Here is mine beauty, got it couple of weeks ago. Front 120mm, rear 100mm, head tube angle 67°. Best bike for ever (previous were epic s-works, Cube Stereo hpc 120mm). Light, hell fast whatever I ride, uphill or downhil. Perfect xc race machine. Only thing I dislike is quite thin bottom bracket shell and bottle cage thread rivets that are assembled too high. I reported the issues to seller and now i will get the new front triangle which the issues are improved. Not bad.
  81. #2181
    Nice looking bike. What supplier & model is it?
  82. #2182
    Quote Originally Posted by sclyde2 View Post
    Thanks, it is http://www.lightcarbon.com/mtb_suspe...cfs911-lcfs911
    size 17"
    I think this is copy of Scott Spark RC. I haven't had change test Spark, but it should be a something special. Unfortunately Scott is bit pricey..
  83. #2183
    Reputation: RobLyman's Avatar
    Finally getting sround to posting this.
    This is my iCAN. I have about 250 miles on it since October.
    Built up from my single speed Lurcher.
    Arch Ex Wheels
    XT brakes, cranks, derailleur
    Rockshox Monarch, Reba
    Attached Thumbnails Attached Thumbnails Dual Suspension Chinese Carbon  29er-newbikesm.jpg
  84. #2184
    Dec 2017
    Hey ican p8 owners.
    Just ordered P8 frame and would like to know before I order the other parts
    - what mounting hardware should I use to mount the rear shock (planning monarch RT3 or monarch plus rc3) the size of the shock should be 200x21 right? any links to purchase the mounting kit would be much appreciated.
    - since this is a boost frame do you use both boosted front and rear wheels? looking at the yari boosted shock for 29 wheels... but if not regular fork would be Ok i suppose?
    - what is the largest 29 tires can this frame handle? as far as i understood 24 fit nicely?
    Reputation: tskubi's Avatar
    Mar 2011
    Here is my 2018 marathon beast,
    FM058 frame, custom paint & stickers.
    I let you look at the pics, feel free to ask for details.
    Thanks to BIKE AHEAD composites for the RS wheels, Darimo Carbon Fiber for feather light cockpit & seatpost, Gelu carbon creation for the stunning saddle, KA Engineering for titanium ring & Garbaruk Bike Components for the superb 10/50 cassette.
    9,380kg
    Read the full story here
    and more pictures there
    Details,
  86. #2186
    impressive weight. I am a little hesitant with the frame due to the low tyre clearance.
    I had a look at your thread. I struggled a bit with the french.
    About 9 pages in (of 22), you show a few photos of the tyre clearance. Does "RK 2.2" mean race king 2.2? Am i correct to interpret that you had a 57.7mm (measured) width tyre on there, and still had over 6mm clearance on each side? (from the tyre to the chainstays)
    the technical drawing posted in that thread showed much less tyre clearance.
    i see that your latest photos have a maxxis ardent 2.25 on the rear. what is the tyre clearance like with that tyre?
  87. #2187
    May 2013
    Quote Originally Posted by _boo View Post
    Hey ican p8 owners.
    easily handles 2.4 Mountain Kings. Mine are mounted on 40mm outside width carbon rims. Recommended shock is 200x 51. But 200 x 57 works well and adds a little more travel. Why not go boost front and back? But use what ever front wheel and fork you like. I would recommend a 140mm x 29er front fork. Any less will make the front too steep in my opinion.
  88. #2188
    I ride bikes
    Reputation: moefosho's Avatar
    Apr 2013
    Are there any fs 29ers that have around 100-115mm rear travel, that can run a 130mm fork, and 66-67 hta? looking for a replacement for my smuggler frame that I can use for xc races or shredding the gnar.
  89. #2189
    Dec 2017
    what are the bushing sizes for rear shock mount? and what headset are you using?
    regarding the shock not sure if i can find boosted for an affordable price, looked at yari but can't find boosted in 140mm travel, pike would be a bit too much for my budget. also how about 150 mm travel?
  90. #2190
    Formerly of Kent
    Reputation: Le Duke's Avatar
    Quote Originally Posted by moefosho View Post
    Check out the 120mm Chinese version of the Scott Spark (non-RC).
    Sent from my XT1585 using Tapatalk
    Death from Below.
  91. #2191
    I ride bikes
    Apr 2013
    Quote Originally Posted by Le Duke View Post
    Do you have a link?
  92. #2192
    May 2013
    I posted this photo earlier. Almost went with it. I bought the P8 instead. Ican P9 looks cool too. More suspension. 67 degree hta.
  93. #2193
    Land of the 230+
    Sep 2013
    Do you have a link?
    XM Carbonspeed FS27 and FS29.
    I dont know for certain that the FS29 will accommodate the full 120 mm travel, but the FS27 will, assuming you can find a 165x45 trunnion shock that will fit. Unfortunately it has not been easy to find one, so effectively we are all stuck at 100mm travel until someone finds one that fits. That aside, its quite a nice frame, and very light. The FS29 is 12x142 while the FS27 is 12x148. The FS27 will clear a 27.5x2.8 tire or a 29x2.4 (or so I hear).
    Full disclosure, my clydeness did snap the alloy pivot bolt cranking hard out of a turn, but a replacement was shipped to me quickly. I'm planning on press fitting a Ti tube inside the hollow alloy bolt to increase sheer strength. But if youre not close to 230-240 lbs, I wouldn't worry too much.
    CS-FS29 full suspension mtb 29er frame carbon bicycle frame - Xiamen Carbon Speed Sport Goods Co.,Ltd
    CS-FS27 27.5 Plus full suspension mtb bike frame BB92 - Xiamen Carbon Speed Sport Goods Co.,Ltd
  94. #2194
    Formerly of Kent
    I dont know for certain that the FS29 will accommodate the full 120 mm travel, but the FS27 will, assuming you can find a 165x45 trunnion shock that will fit. Unfortunately it has not been easy to find one, so effectively we are all stuck at 100mm travel until someone finds one that fits.[/URL]
    https://www.worldwidecyclery.com/pro...oat-black-body
    Death from Below.
  95. #2195
    Land of the 230+
    Sep 2013
    Has anyone successfully fit this shock in the FS27? There's a lot less room than a Scott Spark. From the looks of it, the fill tube wont clear the mounting tabs. Looks like the same problem as the rockshox 165x42.5. But until someone actually tried, we wont know for sure.
  96. #2196
    Dec 2017
    so are you using 200 x 57 shock with 29er 2.4 tires with no problem? if so i'll go for 200 x 57 as well
  97. #2197
    May 2013
    yes. I even tried some offset shock bushings to slacken the head a little with no problems.
  98. #2198
    Dec 2017
    which size of the rear shock Mounting Hardware did you use?
  99. #2199
    May 2013
    I think it was 22mm x 8mm top and bottom. Ican will confirm this if you email them.
  100. #2200
    Dec 2017
    ok thanks!
  1. Chinese Carbon 29er
    By crashplayer19 in forum 29er Bikes
    Last Post: 9 Hours Ago, 08:05 AM
  2. Chinese carbon 29er frames?
    By Scott O in forum 29er Bikes
    Last Post: 07-26-2011, 11:05 AM
  3. Chinese Carbon 29er from 2011 Hardrock
    By Pininfarina599 in forum 29er Bikes
    Last Post: 07-23-2011, 07:21 PM
  4. Saw a chinese carbon 29er yesterday, nice...
    By madsedan in forum 29er Bikes
    Last Post: 06-09-2011, 04:53 AM
  5. Chinese Carbon 29er - buy it or not?
    By mountaincycle in forum 29er Bikes
    Last Post: 05-21-2011, 04:57 AM
Members who have read this thread: 493
