Page 6 of 6 FirstFirst ... 23456
Results 501 to 591 of 591
  1. #501
    Quote Originally Posted by M0riarty View Post
    This is the 41.15mm kit and no shims are necessary.
    RWC SHOCK EYE NEEDLE BEARING KITS
    Thanks! I just ordered a Monarch RCT3 and will likely try the debonair can on it. I also ordered the RWC kit for the upper hardware. I'm going to use 'normal' hardware for the bottom. On a 2014 carbon, does anyone know what size I need? Also, should I order Fox or Rockshox hardware--anyone have a preference? Thanks!
  2. #502
    Mar 2011
    Quote Originally Posted by llamapoo View Post
    Yes, I believe the owner's manual is the 3 pager. I use that technical paper for nearly everything - a combination of that for part numbers and torque settings and the glossy catalogue for original parts spec (OEM names - I've still had to call Easton to get wheel specs though when I rebuilt them).
    From the sounds of it, you've already found the three pager online. If you need any help with the original catalogue for parts and geometry, let me know and I'll scan the pages and send it to you.
    Any chance you still have that? I'm looking at a carbon frame that has the bolt on axle, not the maxle, and trying to see if it's 135 or 142 spacing, and what diameter that axle is. Thanks
  3. #503
    Quote Originally Posted by B. Rock View Post
    send me pics of what you are trying to measure and I'll email you the OM.
    Barry
    nbadam at cox dot net
  4. #504
    Jan 2016
    I have been hearing some creaking when I put a lot of pressure on the bars or if I'm track standing. So I took apart my head set to check. In your opinion, would this be considered a crack?
    Attached Thumbnails Attached Thumbnails Devinci Atlas Carbon-img_20160524_172421%7E3.jpg
  5. #505
    Apr 2013
    Quote Originally Posted by barryadam View Post
    Barry
    Sorry, I guess I only get weekly updates on this thread. B.Rock and barryadam, just let me know if you need the OM and the specs page from the catalogue and I'll send them.
    tab
  6. #506
    Jun 2016
    Quote Originally Posted by ifly3Dallday View Post
    Best I can tell from picture is that is not a crack. Creaking noise comes from headset. Mine has cane creek 40 headset and I cannot stop the creaking either. Some have recommended over tightening headset but I think best is to upgrade to a cane creek 110 series.
  7. #507
    Dec 2005
    Quote Originally Posted by ccook905 View Post
    Just did that a couple weeks ago after the stock headset bearings pretty much rotted out. So far so good i.e. no creaking. Also threw an RWC needle bearing on the rear shock. Wow, now that was an underrated upgrade. My 2015 Carbon Atlas is it still a head turner on the trail. The shiny carbon/teal blue finish gets a lot of nice comments from folks riding around on matte black clone bikes.
    It's been easy enough to work on and my LBS does excellent work and has all the tools. It seems the market is trying to get closer to this bike just as Devinci went in another direction. Shame. I plan to run this until the carbon is ground to dust.
    My next upgrade will eventually be a set of carbon hoops to replace my SunRingle set.
  8. #508
    Quote Originally Posted by Ken6503 View Post
    Yeah, I scratched my head on Devinci's decision to drop the Atlas.
    As noted all the new 29ers coming out resemble the Atlas.
    Just picked up one of those 100mm reverbs from merlin for mine:0)
  9. #509
    Dec 2005
    Quote Originally Posted by Anthem1 View Post
    I talked with the company about 6 months ago. I had concerns about parts and components even the frame had a lifetime warranty. I didn't want them to force me into a 27.5 in case my frame ever went kaboom. They said they had all the molds and materials to replace any component indefinitely. I hope that remains the case.
  10. #510
    Jan 2016
    Ahh thanks for letting me know. I have a FSA (can't see the model number) headset right now. I wonder how the performance differs. By the way, have any of you guys seen a very small hair line crack coming from the seat tube dot going out in an angle. How big do these need to get till I need to worry. Sorry guys for my paranoia, but I just want to keep on riding it as well instead of taking it to the lbs with a probability of getting blown off. I second the ease of dissambly/reassembly as well as peoples reaction when they try to discover what this bike is haha.
  11. #511
    Norūwegr
    Reputation: Vegard's Avatar
    Resemble, yes; ride the same; no. My 2013 carbon Atlas was a good bike, but saying it rides like a modern trailbike would be wrong, the seattube is way too slack for that among some other differences.
  12. #512
    Dec 2009
    Quote Originally Posted by Vegard View Post
    Hi Vegard, have you been able to compare the Atlas to some more recent bikes? What are your impressions of the differenceso?
    Ted
    Sent from my SM-G930V using Tapatalk
  13. #513
    I have had a chance to ride mine back to back with many of the "new trail bikes"
    The Pivot trail is a sweet bike, maybe a little more efficient climbing due to the rear link, but no where near as fun to throw around due to the longer chain stays.
    Same applies to the first gen Ripley.
  14. #514
    Undercaffienated
    Reputation: hmorsi's Avatar
    I just built up an alloy 2015 Atlas after riding many "modern trail bikes". From Ti aggro hardtails to full on enduro machines. The Atlas is seldom matched on the versatility front, even when compared to the latest crop of trail bikes. The geo could do with a few minor tweaks but honestly I am loving it as it is.
    I am running a 140mm fork, 760mm bars and 170mm cranks with the frame set to the low position. This thing rips.
  15. #515
    [QUOTE=hmorsi;12745392]I just built up an alloy 2015 Atlas after riding many "modern trail bikes". From Ti aggro hardtails to full on enduro machines. The Atlas is seldom matched on the versatility front, even when compared to the latest crop of trail bikes. The geo could do with a few minor tweaks but honestly I am loving it as it is.
    [IMG]http://uploads.tapatalk
    I could not agree more.
    I have ridden most of the new trail 29ers, none of them have compelled me to upgrade my 2015 carbo Atlas.
  16. #516
    Short-Change-Hero
    Reputation: gregnash's Avatar
    Quote Originally Posted by hmorsi View Post
    That's a sexy beast. What manitou fork are you running?
  17. #517
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    I must say, I like this bike. I've looked at the specs and I'm possibly in the market for a racey 29er. Too bad they stopped making it.
  18. #518
    Undercaffienated
    Quote Originally Posted by gregnash View Post
    Thanks! The Atlas is a good looking bike indeed. The fork is a Manitou Minute.
    Here is a shot from my ride yesterday.
  19. #519
    Short-Change-Hero
    Nice... How do you like it? What size and riding style are you? I was very close to grabbing one to replace my busted Revelation but at almost 200lbs kitted up I have read that the older Tower was flexy. I had a 100mm Tower Pro on my old hardtail that I loved but felt that it would get overwhelmed when I would hit seriously rocky stuff. Really wish that Manitou would make a 34mm stanchioned 29er fork other than the Magnum.
  20. #520
    Undercaffienated
    I have about 4 rides on it so far and liking it. It's the 140mm Travel version. Easy to set up, predictable along the travel range and no excessive dive on the slow speed technical manoeuvring on steep sections without having to increase the pressure significantly and thus sacrificing some of that small bump response.
    I have a 120mm Tower Pro on my Ti hardtail and also like it. Slightly flexy but I am thinking the flex might be the wheels on the hardtail since they're a Stans Crest rims lightweight build. The only times I do feel the flex is when pushing hard in corners, the 2.3 tire would slightly buzz the plastic Marsh Guard front fender mounted on the reverse arch.
    I am about 76kg geared up on a medium frame. I'd describe my riding as aggro XC on technical forest and desert trails (I travel frequently so have the opportunity to ride varied terrain) and I do a couple XC/enduro races every year.
    I also wish Manitou made a 34mm mid travel 29er fork, but for my current purposes the Minute seems solid.
  21. #521
    Short-Change-Hero
    Ah ok... yeah I am a bit heavier than you at about 190lbs (87kgs) so that is probably part of the reason I felt more flex and most of the guys that I talked to were in the 200+lbs range (95kgs+). Especially at 140mm travel and the fact that I am more of an aggressive trail/AM rider now than when I had the Tower. Came very close to grabbing the 27.5+ Magnum and throwing a standard sized 29er rim in it but ended up not.
  22. #522
    Reputation: Velorangutan's Avatar
    Coming soon is the replacement to the Atlas. The Django 29.
    Best Source for Ibis, Devinci, and Ventana!
    Velorangutan... the pedal type.
    Motorangutan... the motorized type.
  23. #523
    Reputation: xl_cheese's Avatar
    Here's my new Atlas build. I stuck with the Atlas over the new Django because I like the steeper head angle.
  24. #524
    Jan 2016
    Rear derailleur hanger
    Hey guys, might be another ocd question but, should the rear derailleur hanger be square on to recesses on the rear triangle? I can't get it square unless It is well under the recommended torque, so right now it's a bit angled to the recess.. let me know if it's nothing to worry about. a pic.
    Attached Thumbnails Attached Thumbnails Devinci Atlas Carbon-img_20160804_160543.jpg
  25. #525
    Quote Originally Posted by Velorangutan View Post
    Meh, I think the mid-travel 29er market is just super-saturated, it might be along the lines of what I could use, but I really want something a little racier, 100-115mm, with the pedaling characteristics of the Atlas, around 100% or a little above, anti-squat throughout a good portion of the travel, so it won't be like a wet matress uphill when pedaling and the suspension is activating. Although there are a few bikes out there, Czar, 429, Following, Ripley, I think the shorter-travel aggressive 29 XC bikes (with modern XC geometry, not too stupid-steep) are where the market is lacking. You got the basic stuff from the big manufactures, but they tend to rely more on lockouts and brain type devices, rather than good suspension characteristics. I wish there were a few more short travel bikes on the market like the Atlas, without a crazy falling-anti-squat curve or 200%, etc.
  26. #526
    otb club member
    Reputation: Chris2fur's Avatar
    Just curious, why NOT the Czar? Sounds like what you are looking for. Really love mine. It's more of a do-all bike in a very light package than I expected. I'm just getting started on building up a Following for the more punishing trails and steeper downs. The Czar handles everything else very nicely.
  27. #527
    Quote Originally Posted by Chris2fur View Post
    It's a contender, I especially like the open-triangle design that will lend itself well to custom-bags, for the long-distance races. I want something I can XC race and not get beat up on, as I'm getting more competitive, but I'd like even more choices in the field. It seems there are a million 120-140mm 29ers out there, which is the travel-area I'm least interested in, since 150-160mm bikes are so light these days and climb so well. I can cover the spread better for myself with an XC race/endurance bike at this point I think, rather than a 130mm bike that I wouldn't want to take to the bikepark and that would still be a bit of a bear to XC race.
  28. #528
    otb club member
    I hear you. Already having the Czar, choosing my 2nd bike has been a challenge. Never in my wildest dreams expected to get so fond of the big wheels. The SC 5010 I thought would fill the gap is more plush than the Czar, but it won't handle that much more (greater travel, but less rollover). I hear the Following with 140 up front will handle the rough stuff very well, but was tempted to go more extreme (Wreckoning). We'll see...
  29. #529
    Dec 2005
    Quote Originally Posted by xl_cheese View Post
    That's a sexy drivetrain right there. What's the overall weight?
  30. #530
    Mar 2011
    Bumping this one back up...has anyone done the debonair upgrade on their RT3? Looking at rebuilding the Monarch and debating the upgrade but wasn't sure how it would play with the split pivot's dynamics.
  31. #531
    Norūwegr
    I tweeted DW and asked about that, he said it'd be a good upgrade. I bought a can, but I never got around to using it before I sold the frame and got another Honzo.
    Depending on where you live I could sell the unused can to you for cheap. PM me if so.
  32. #532
    Reputation: In2falling's Avatar
    Jan 2005
    I ditched my RT3 and put a Manitou Mcleod on. Sooooo much better of a shock than the RT3 was on the Atlas.
  33. #533
    Undercaffienated
    Quote Originally Posted by In2falling View Post
    Can you elaborate on what you find better with the McLeod?The RT3 on my medium 2015 alloy Atlas is the one of the few stock shocks I am happy with on my bikes. I weigh 78kg geared up.
  34. #534
    Jan 2005
    To me feels like it has better damping and better small bump compliance/smoother over the little stuff. Also I was getting kind of hard bottom outs with the RT3 which I do not get with the Mcleod. Do have to crank up the rebound on it on the Atlas.
    I have a 2013 and the RT3 was in need of a rebuild so threw the money towards the Mcleod instead of the rebuild. For $250 itís a great little shock that preforms very well.
  35. #535
    Undercaffienated
    I see. Thanks! What do you weigh geared up if I may ask?
  36. #536
    Jan 2005
    About 210LBS geared up and run 195PSI in the Mcleod and also the RT3.
  37. #537
    Mar 2011
    PM'd.
  38. #538
    Which way is steeper for the seat angle wrt the flip chip? Bike is awesome but after riding my fat bike (which I swore I'd not like) I found the steep seat tube able really allowed me to get aggressive on flatter ground and S turns, which is what we have hear in the prairies. Want to make sure my Atlas is steep as can be before I decide to put up for sale. It rules in all conditions except that the seat puts me too far back to push into turns without having to really get over bars.
  39. #539
    Mar 2011
    ^^^Flip chip in the 'hi' position steepens everything.
    Just wrapped up some riding in BC on the Atlas, set up with:
    Reverb dropper
    specialized phenom saddle
    740mm carbon bars
    RF Atlas stem
    i9 23.5mm wheelset
    e*13 TRS+ cassette
    28T oval chain ring
    next sl cranks
    130mm Revelation
    XT brakes
    XT pedals
    XT derailleur + shifter
    2.35 forekaster up front, 2.2 forekaster out back
    25.8 lbs all in.
    Could be a touch slacker for my descending tastes, and yes the saddle could be a pinch more forward - but not enough to warrant changing bikes. Really like the split pivot suspension.
    After an 'adventure ride' with some mud, and the BC riding, I now have a pretty good creak - going to do the debonair can upgrade and throw in the enduro bearings and see what that gets me.
  40. #540
    Reverb dropper
    740mm carbon bars
    RF Atlas stem
    i9 23.5mm wheelset
    e*13 TRS+ cassette
    28T oval chain ring
    next sl cranks
    130mm Revelation
    XT brakes
    XT pedals
    25.8 lbs all in.
    Thanks. I should have been more clear with my question. Which orientaton is it that is the 'hi' setting? I had figured hi was the steeper setting with higher bb. If you have a picture of yours with it in either hpost that would be super helpful.
    Since I am asking qustions I found recently that the bike is a little bit flexy. It is only 10-20 rides old and never ridden in wet as it is a clay sold which is akin to concrete in the wet. There's been alot of talk about bearings, but I feel it is smooth in terms of shock action. Maybe I just never noticed it before or maybe I'm just giving it a little more in the turns. Anyne feel that there's was flexy even with good bearings.
  41. #541
    Mar 2011
    With the 130mm fork, I run it in the low position at all times, since the fork is effectively raising the BB.
    I don't find it flexy, but I also only weigh about 165 lbs. If anything is going to flex, it's going to be the Revelation and/or wheelset. For an XC bike it's pretty stout. Much beefier than any of the other 90-110mm travel frames that I've seen. It's not a trail bike though, if that's what you're comparing it to.
  42. #542
    Aug 2017
    Has anybody else cracked their's? I found a crack where the bb she'll meets the frame on the drive side last night.
    Pretty gutted to be honest, we've been through alot together.
  43. #543
    Those frames were so overbuilt, I didn't think that was possible.
    On a positive note, I bet you get a new Django replacement.
  44. #544
    Aug 2017
    Perhaps but should they decide to warranty it then I'm hoping they have an Atlas in a backroom somewhere as I can't imagine the django can ride as well andone it definitely doesn't look as good.
    Failing that I'll push for a Marshall as I would love the option to run 29+. I've got a surly krampus and it's wicked good fun.
  45. #545
    Undercaffienated
    Quote Originally Posted by slugrider View Post
    That's unfortunate! Can you post a picture of the crack?
  46. #546
    Aug 2017
    Here it is, not great photos as light is bad in my workshop.
    I also spoke to a guy with the same problem on his but on the other side.
    Attached Thumbnails Attached Thumbnails Devinci Atlas Carbon-2017_0518_120358_004.jpg
  47. #547
    Undercaffienated
    That sucks but hopefully you'll get a replacement from Devinci. Going to check mine now! What year is your frame?
  48. #548
    Apr 2016
    I could use some advice..
    I have an opportunity to buy a 2013 Devinci Carbon Atlas frame and rebuilt rear shock for a good price and wonder if it's worth it. Does the 2013 still stand up to the newer frames?
  49. #549
    Jan 2005
    Quote Originally Posted by Babylondown View Post
    Have had mine almost 4 years (4000 miles) and plan on keeping for quite a while longer, its my light trial bike (XC bike on steroids). This is still a great bike/frame and you would not be getting much more with the newer trail bikes that are out there (boost, little slacker HA ect..??).
  50. #550
    "Worth it" depends on the price. I love mine, it's a great XC bike. Frame geometry has continued to evolve a bit past where this frame is, but it's as good today as it was when first released. If I had the opportunity to stretch mine another 20mm in reach and slacken the head angle, I would. Bu I'm still happily riding it and have no thoughts of doing otherwise.
  51. #551
    Thanks for all the help. On the 2014 carbon the flip chip is hidden under the 8mm hex bolt. I just went ahead and loosened it off and changed it over. I guess I am old school because I prefer how it handles now. I think it gives the seattube enough steepness to help cornering on more level ground and the head angle is not too steep. We don't have alot of tech features out here so no need to go to slack on HA. Also, the 'wigglyness' I mentioned previously is the wheel. The stan's flow on hope 2 is good, but I think I was comparing lateral stiffness to the carbon tubular rims I have on my XC bike. Obviously there's a huge difference there. Very happy with the bike for what it is. My blackcat 29er beats it in every way except technical descents, but that is to be expected for a race ready set up in a land with no tech features. With 110mm of rear and 120mm of front I get good, but not great speed and have no issues with the features we do have.
    To 'slugrided', sorry about the crack. That sucks. There are carbon repairers I hear.
    They are really good for customer service I think. Hopefully they do right by you.
  52. #552
    I would probably buy again if the price was right. I hugely lucked out on mine and paid 750$ brand new from someone who didn't need it though. Yeah me. The main thing to watch out for is that they are quite short in the top tube. At 6'1" I am always between a L and XL in past bikes, but I got an XL in this one and I am definitely pushing the envelope between needing an XXL (not that they made those). Basically, they have a short top tube even by 2013 standards. I think slackness and longness has gone too far though. I like steeper seat tube angles and relatively slack head angles, but things are very very slack and perhaps too long now I feel.
  53. #553
    Apr 2016
    Quote Originally Posted by car_nut View Post
    Well I'm in Canada and everything is more expensive here, but it's about $600-650USD. I already have a 2013 Devinci Atlas Aluminum frame with rebuilt rear shock that I bought for about $300USD, but when the carbon frame came up, I was very interested. The more confident I ride, the more I wonder if the Atlas is even "traily" enough for me, but I do believe the carbon is more slack than the aluminum frame and offers a bit more travel.
    Would the aluminum atlas frame work with a 140mm front fork or is that just pushing it?
  54. #554
    I believe the aluminum and carbon have identical geometry. The archive page for Devinci shows them as equal. Same for travel.
    Devinci offered the Atlas with a 140mm fork, so it's OK from there point of view. Personally, the seat tube is too slack at 120 and I wouldn't. That's a somewhat personal decision though.
    I personally wouldn't spend the money just to go from aluminum to carbon given your description. I'd look for a more trail oriented bike and put the money towards that.
  55. #555
    Norūwegr
    Seatangle at 140mm was interesting to say the least, going down it worked just fine but doing climbs and stretches of flat with it was less than stellar.
    Given the choice again I'd look into a different frame if going with more travel than 120mm.
  56. #556
    140mm
    I think that between 2013 and 2014 they did change the geometry slightly. I do not believe itwas a carbon/aluminum distinction, however, as your aluminum is 2013 and I assume that the carbon you are looking it is >=2014 that might be the difference. Assuming I am recalling correctly.
    I am also in Canada. I am just very good at finding deals and driving down to the states to get the stuff (back when I lived nearer the border).
    There is a post from hmorsi higher up in this page that has a post of one with a 140mm fork so perhaps ask him. They did say on their site at the time that 100mm for race, 120mm for trail and 140mm for the gravity oriented. I am happy at 120mm for the most part.
    On a separate and related note I don't know the shock length and stroke. I played with my psi today and it kept the o-ring just at the end of travel, but didn't feel much better. I am tempted to go with a Manitou McLoed as I have seen others posting about, but of course need to get the right dimensions. So far google only brought me here. Anyone know?
  57. #557
    Using these two sites as reference
    The complete guide to mountain bike geometry - MBR
    MTB Frame Geometry Explained - Mountain Biking Australia magazine
    I feel that the effective seattube angle is actually closer to 74. I put an angle finder app on my phone and got 74 or 75 using this method.
    The effective seattube angle goes from a line that intersects the seastpost in a horizontal line from the stem measured to the BB.
    Because it is an interrupted seattube with the seat insertion angle sitting slacker than the downtube it appears very slack, but I honestly don't think it is. So, I am going to put mine back into Lo and see if it still climbs as well which I think it will actually.
    The next thing to do would be to change out the tyres from the maxxis ardent I have to the HansDamf and see if that makes a difference on flat ground in terms of how I accelerate and hold speed.
  58. #558
    Apr 2016
    Does anyone know what minimum steerer fork tube length I need to fit a 2013 Atlas large aluminum frame?
  59. #559
    Undercaffienated
    Quote Originally Posted by osakana View Post
    The shock size is 165x38mm.
    A 140mm fork works perfectly for my purposes on my 2015 aluminium Atlas. I wouldn't want the bottom bracket any lower where I ride. I don't notice it any massive adverse effects on climbing and I go up some steep trails. I've raced it in XC and enduro events, and while it isn't the perfect bike for either discipline, I have it set up for fun, versatility and reliability over perfection in one type of riding, and the appeal of the Atlas is exactly that.
  60. #560
    Aug 2017
    It's a 2015
  61. #561
    Apr 2016
    Anyone?
  62. #562
    Undercaffienated
    Anyone?
    If you're not in a hurry I can measure for you on my 2015 alloy Atlas, but I don't have access to my bike until Wednesday.
  63. #563
    Aug 2017
    Would anybody be interested in buying an atlas carbon frame?
    Whilst waiting for a warranty decision on mine I bought another so shortly I will have two, one medium and black and white, one large Matt black and red/yellow (brand new front triangle/seat stay/chain stay)
    I'm in the UK if anyone is interested?
  64. #564
    May 2013
    Iíve been riding my 2013 Atlas carbon RX with original Easton wheels and 2.2 XC race tires. I still love the bike and donít see any reason to justify dropping 5Gs on a new ride for at least another 5 years.
    Iíll be upgrading it to 1 x 11 and the new i9 Trail 270 wheels 27mm inner / 30 outer.
    I also want to use more aggressive trail tires as the race tires donít always cut it on my local trails, lots of roots, loose over hard terrain not too many rock beds bet enough to slice a tire now and then.
    What max size have you been able to fit? Devinci told me the max is 2.2 but that is incorrect for sure. I know 2.4 works, has anyone tried 2.5 or even 2.6?
  65. #565
    Quote Originally Posted by Geotrouvetout67 View Post
    I habve max is ardent 2.35 front and back. The rims are Stan's and are an older version. Not sure exactly inner width but a newer wider width rim would make a difference to the ballooned out tyre width achievable. Our soil is clay which means moisture = cake batter. In dry I have issues with tyre clearance. In wet it rapidly adds an inch. My guess would be 2.4 max if you get a little bit of muck.
  66. #566
    Jan 2005
    I tested mine out the other day with Maxxis Aggressors 2.5WT front and back from my other bike and they worked without any issues, it was very tight maybe 2/2.5mm clearance on each side and did not hear or feel any rubbing during the ride. This was in dry desert conditions.
    The Aggressors 2.5WT measure out right at 63mm/2.5" on 32mm innner rims. Probably get away with 2.5s on 27mm rims in dry conditions (won't have much mud clearance), 2.6 will be a no go.
  67. #567
    May 2013
    Ok so 2.4 is probably the safest max, I think Iíll give a try to the Maxxis Ardent 2.4, thanks for contributing.
  68. #568
    Norūwegr
    2.35 nobby nic did fit on my '13 with ok clearance
  69. #569
    Apr 2013
    I'm running 2.4" Continental Trail Kings on my '13, mounted onto Stans Arch EX. The little whiskers from the injection process buzz the chainstays and the fork arch. Not a lot of room but no rubbing. Mud will cause a problem for sure. I have spare 2.2" and 2.3" for those days...
  70. #570
    May 2013
    Cool, nice set up
  71. #571
    May 2013
    I see so maybe 2.35 is better than 2.4 then.
  72. #572
    May 2013
    I'll give a shot to the Bontrager XR4 Team 2.3 that should fit no problem and improve grip.
    Edit: ended up opting for the Vittoria Brazo 2.35, should be putting them to test in about 2 weeks.
  73. #573
    Oct 2013
    Hi guys.
    I'm excited to join the Atlas club. Albeit, now in 2018 I bought a used 2014 carbon RC frame that I'm building up now. I'm mostly into XC and maybe some more aggressive XC/trail in southern Ontario so this seems like a good fit.
    Questions:
    1. There was some discussion on the seat angle. I do a bunch of climbing and if I put the chip in high, do people find that they are over the cranks enough to do seating climbing when you want to spin it out?
    2. I've got the large frame, I believe the reach is somewhere like 435mm in the high position. With my 5.11" build, what stem lengh do you think I should run? My previous bike was a 2015 carbon hardtail with reach of 460mm though and I was running 90mm stem. Although that bike was clearly intended for race geo, where the Atlas seems a bit more like trail/relaxed Xc (and I think i like a slightly more upright position).
    Thanks for your help guys! Will post pics once I have it built up.
  74. #574
    May 2013
    The Atlas forum is not super active as you can see, makes sense since the model has been discontinued.
    I think your comment about being XC/trail oriented is correct, especially the RX version with 110/140mm travel, I do have a very upright "relaxed" position on it which I like a lot. I would not do crazy jumps or DH parks with it but it's very capable in technical terrain.
    I have the 2013 carbon RX model, it's such a great bike I am currently converting it to 1x11, replacing the OEM wheels with a set of i9's and just found out the shop was not able to rebuild the Reverb seatpost so I'm replacing that with a new Fox Transfer. I could have bought a medium level new bike for the cost of that upgrade but I will keep that bike for a long time, I still have my previous MTB which is now 29 years old and use it as a hybrid for casual family rides.
    My stem is the original Easton 60 mm and it works great for me but I ride mostly flat technical trails (Massachusetts), very little climbing.
    I am 5'11" as well and I have a medium frame, I never felt I needed anything larger, the bike feels quite large to me.
    Edit: I'm actually 5'8" not 5'11", could not remember, it's wrong on my DL... so you should be fine with the large frame.
    Actually the Reverb that came with the bike was a 125 mm, I'm now going with a 100 mm as the high position was always too high and the low position was always too low.
    I'm also reducing the crank length from 175 original to 170. Where I ride there are tons of rocks and pedal strikes are too common.
    About the seat angle, I'm sure there is some kind of science under it, it's definitively important for roadies. For me the only thing that counts is that my butt does not hurt and that will be the best angle for it.
  75. #575
    Quote Originally Posted by bikerfisher11 View Post
    Hi guys.
    Questions:
    Look foward to pics. I am 6'1+ a bit and ride the XL. I think you should size as big as you can. I find it just right for the seated climbing. Sometimes I feel it is smaller side for desceding. Not sure that that makes sense. I ride 60mm stem because I had it. I recall reading it was designed around a 60-70mm stem, which seems right to me. I live in Sask and I find with the right seat angle (saddle on post, not seat tube) I can climb very well. Obviously not big long climbs, but they do tend to like their steep climbs here (why prairie people like to assert their mtbike prowess with tough climbs is beyond me but there you have it). I ride in the high position with 120mm travel fork. Currently I changed to 100mm travel fork for more xc, but it has a higher axle to crown on it so essentially the same riding position. I just wanted to try the manitou tower which I am really enjoying actually.
    Anyway, good climber in high, no worries about seattube angle. 60-70mm stem all good. I've enjoyed with 100 and 120mm travel forks
  76. #576
    Oct 2013
    Thanks for your feedback on the seattube angle, I believe you have put my fears away on that one.
    As for sizing, I'm looking forward to having the bike built up to give it a go. I don't mind a more upright seated position but as you mentioned, I'll see what it's like descending (I don't do epic descents anyway, but I'm curious to find out how it handles cornering while descending too).
    My current roadblock is to get the right fork for the build. I'm open to suggestion, definitely want to try it with a 120mm fork. I found out my current Reba RL won't extend travel to 120mm so that has stalled the building process temporary. I'm finding it harder to get a non-boost fork than I thought it would be.
    Pics coming soon!
  77. #577
    May 2013
    I hate when the industry is coming up with new stuff and is discontinuing the old so you can't repair your bike. I just put new wheels, my fork is 100 mm, it would drive me crazy if I had to get my front wheel rebuilt and replace the hub when I need to change the fork. Or I could use a spacer kit as well.
    For example I recently found out that SRAM does not make parts anymore for my only 5 years old Reverb seatpost, bastards! I had to buy another one but I bought Fox this time.
    This being said, unless you have wheels already why could you not install a 110 mm wide fork?
  78. #578
    Oct 2013
    Good call on that.
    The main reason for not putting the 110mm fork is that my fork is 100mm currently and would cost about $200 CAD for my shop to replace the air spring to get to 110mm.
    At that price I was thinking to put the money towards a proper 120mm fork (but I suppose worse case I can just run the 100mm).
    How do you find the 100mm fork affects the geo on your bike? I'm planning on running it in the HIGH setting on the flipchip.
    Thanks again.
  79. #579
    May 2013
    My bike came with 100 mm and 140mm of travel from the factory (Revelation fork).
    I have recently flipped the rear setting for the first time to check what happens, honestly I could not tell the difference, some people say it makes a huge difference, really?
    I don't think the impact on the geo is of any significance between 100 and 110, all boost does is adding 10mm width in the fork, you gain lateral rigidity with a 110 mm hub but it's not changing any angle. A 100mm hub will remain centered with two 5mm spacers on each side or no spacers if you use a boost front wheel.
    Now if the bike was designed for 120 mm travel and you install your old 100/110mm fork, it may impact it. Good or bad I have no idea. You may ask Devinci. They are slow to respond by email (2 weeks?) but they respond or better yet just give them a call. Going with the $200 rebuild is still a lot cheaper than a new fork like the Pike RC.
  80. #580
    May 2013
    I just realized that my Industry Nine Torch hubs can be easily converted to boost, yeah...
    I did not know, makes me feel that I made the right choice with i9.
    On the front wheel it just requires replacing the end caps and costs only $30. The rear is more expensive of course but cheaper than a new wheel at $180.
    This is great to know for folks who are thinking about new wheels on their non boost bike, the i9 wheels will be compatible with a boost upgrade down the road, like needing to replace the fork. The rear matters less other than using the old wheels on a new boost frame.
  81. #581
    Oct 2013
    Can you please post a couple pictures of how you were able to access and switch the flip chip from low to high?
    I found where it is but I don't know how to access/manipulate it.
    May 2013
    Here's a video on the Django
    https://youtu.be/p2v_aAUrzl8
    On the Atlas, at least mine, it unscrews normally, not reversed as he says in that video in the case of the Django.
    I found it was easier to not completely unscrew it, doing on side at a time that way was pretty easy.
  83. #583
    https://www.pinkbike.com/buysell/2224399/
    I have a 44 micro Ti which is internally adjustable 100-120-140. Have run it in 100 with no troubles. Have serviced and set to 120 which I think I will love. Will keep in high setting for 120mm I think to avoid too much slackness. Marz told me that they were not a great year fork when I got it used and took it in for a service, howver, that was due to the fact that they need sercvice more often. So, now I actually service my fork instead of just complaining about how it needs service.
  84. #584
    Oct 2013
    Quick update,
    I think I found my fork - a 2017 Rockshox Revelation 120mm with the RTC3 damper installed. Going to pick it up tomorrow and then get to work building it up. Pics later this week I promise!
    Thanks for the vid on the flip chip, I tried yesterday to unscrew the bolts with my park tool multitool but couldn't get the bolt to budge (probably need a proper tool for the job). I might just leave it and let my shop do the adjustment when I get them to swap the parts from my hardtail onto it as well.
    Can't wait to see this frame built up.
  85. #585
    Mar 2011
    Don't be afraid to run it in the low setting with that fork. You're raising the BB with the 120mm fork. I found the trade of the slacker head angle and lower bb was well worth the slacker seat angle. Unless you like real twitchy steering, that's my vote. The shorter chainstays keep it pretty nimble.
    FWIW I was running a 70mm stem, 130mm fork chip in low. Bars were....740? Something like that. Even on some super steep climbs in CO and BC, I was able to scootch forward enough on the seat to stay sitting and climb.
  86. #586
    May 2013
    I used a basic allen key on mine and it worked fine but it was super tight the first time I did it. Plus I was not sure which way since it's reversed on the Django and it turned out it's not on my bike. Hope everything works out.
  87. #587
    Oct 2013
    Good feedback B Rock.
    Thanks.
    Bar width will be something else I have to play with. Right now I'm planning running a 90mm stem with 720mm wide flat bar.
    I think I'd actually prefer a wider bar, like a 740 or 760 and then get away with the 70mm stem.
    I'll try it in both high and low and see how it rides for my type of trails. My main concern is the reach number, but as was already pointed out here, that might be okay seated, just worried about the reach while standing on the pedals and I think the high position may help a bit there?
  88. #588
    Mar 2011
    Valid point on reach, the low setting will increase that. I had a large at 6'0" and have a long torso, so yours may fit differently.
    You can always move the seat forward a bit or decrease the stem length though. This was my xc bike, so keeping the bb low for cornering was a priority for me vs a higher bb on my trail bike for pedal/chainring strikes. I was actually going to knock the fork down to 120 but lost the air spring....so at 130 it stayed.
  89. #589
    Jun 2018
    140mm Offset: 46mm vs 51mm?
    Mine in the wild:
    No issues climbing with a 140mm fork, this is probably the best bike I've ever ridden. It's as good or better than these new fangled hyped 29er trailmachines that's been recently released. (The hype is warranted so don't get your panties in a bunch )
    What offset are you running with 140mm fork?
  90. #590
    Oct 2013
    Finally got mine built up.
    Used the Revelation fork set to 120mm 51deg offset with the RCT3 upgrade.
    Took it on its first ride yesterday and loving the setup.
    My fears of the reach/geo were unfounded as it fit quite well for my 5.11" frame, seated and standing on pedals (but I"m using a 90mm stem and will probably keep that until I get a wider bar, current bar is 720mm).
  91. #591
    Norūwegr
    Quote Originally Posted by clifford213 View Post
    I don't have the bike anymore, but the fork is 51mm
  1. Devinci Atlas RC
    By S:Drive in forum 29er Bikes
    Last Post: 10-26-2014, 07:27 PM
  2. 2013 Devinci Atlas carbon 29er
    By jhardeman in forum 29er Bikes
    Last Post: 02-18-2013, 12:03 PM
  3. Devinci Atlas
    By jenndy in forum 29er Bikes
    Last Post: 01-19-2013, 11:45 PM
  4. Mach 429 vs. Devinci Atlas
    By irishpitbull in forum Pivot Cycles
    Last Post: 03-14-2012, 09:27 AM
  5. Devinci Atlas
    By mtbmitch2 in forum 29er Bikes
    Last Post: 03-07-2012, 09:58 PM
Members who have read this thread: 99
