Results 1 to 18 of 18
Thread: DB Mason Review
    Got Twins?
    Reputation: l84biking's Avatar
    DB Mason Review
    So, Iíve been endurance racing for about 12 years from 26Ē XC bikes to 29Ē hardtails including one speeds. Iíve had 5Ē travel bikes and just sold a full suspension 29er for the DiamondBack Mason. Yeah, I fell hard for it. Granted, I did not demo all of the All Mountain 29Ē hardtails on the market as some were not available. But, researching the AM 29 inch hardtail with short seatstays brought me down to a few that I prefered.
    I received the Mason earlier this year thanks to Tony E. and my friend Jim D. Due to a few things that took time to get to set up my Mason, this review is finally being written. I now read that all the Masons for this year are sold out. Hopefully, youíll see one on the trail near you. I also read that the 2014ís will be even better!
    Overview
    The one item that stuck out in my research of the AM hardtail segment, was the slack head tube angle the Mason sports. 66.5 degree head tube angle is to me super slack. Iíve never ridden a bike with such a slack angle. My DH bike from back in the day was 69 degrees! That was a when DH was just beginning. Considering the stock build, this bike is a pretty good deal for itís sticker price. Yes, the parts are not light (not the aim of this bike) but they do get the job done and will last for years. As youíll see below, I swapped out a bunch of parts from my personal inventory. Mostly as a personal preference and to keep the ability to reassemble the stock bike.
    Drivetrain
    The stock SRAM X-9 1x10 drivetrain is spot on. Iíve been riding this set up on my XC bike and am glad this was the stock spec. Out of the box, it has shifted great with no adjustments. The Race Face Respond cranks in white nicely match the white stem and black Respond bar (740mm). If you wanted a granny gear, the RF cranks can accommodate the lower gearing. The Type 2 rear derailleur has been working as advertised keeping the chain slap to a minimum. Great spec!
    Brakes
    The stock Avid Elixr 5 brakes were quiet and stopped the Mason effectively. On the DB website, 203/180 are noted but the Mason showed up with 180 front and 160 rear. Not a big deal since a 200mm adaptor was included with the bike. Another future upgrade! When I demoíd the Mason at Mountain Bike Oregon, it did have the 203/180 combo and I never did once experience brake fade. The Avidís did perform well, quiet and I would have kept them except I prefer the newer XTR brakes. If you are keeping your bike stock, youíll be good with them and can be upgraded later.
    Cockpit
    This is one area that I have kept mostly stock. One of the items that I wanted to try was the Kind Shock Drop Zone dropper post. A great choice and a must for any AM bike. I like the way the stock grips looked but I prefer a little thicker grab for my hands, so a set of ODI Rogue grips replaced the stock ones. The Race Face Respond bar and stem are just right for this bike. The stem nicely matches the stock cranks for a nice looking kit. Maybe Iím alone on this one, but I donít mind the saddle cover as itís pretty comfy compared to my saddle of preference (Fizik Arione). One awesome touch that DB made was the rubber end pieces the protect any painted surface that your bar my come in contact. These are the BEST bar plugs around. DB should sell these as aftermarket items. Iím rather picky when it comes to the small things on my bike and the bar end pieces rank high on my like list.. Again, DB did a great job specíing the cockpit on the Mason.
    Frame and Fork
    This frame is tough! Made from Weapons Grade Aluminum, this frame is built to take it. My experience with short seatstays is pretty limited. Iíve ridden short stays on my one speed, since they were sliders, but these were way shorter. Yes, this is built for AM. And yes, it will give you some feedback from the trail. Itís a hardtail. The frame can handle a 2.4 rear tire and getting a higher volume tire under you will reduce trail chatter. I am riding a large for my 6"+ frame. I'd suggest going with the sizing of your current bike as a guide. The frame has a long top tube but that is due to it's slack headtube angle.
    What can I say, the Fox 34 CTD TALAS fork is what makes this bike. If you look around, the AM bikes I researched all had the 32mm stanchion forks. This fork will plow through anything you can throw at it. Granted, I probably will never need this much fork, but the confidence it brings is huge. Having the TALAS function really helps on any steep pitches you encounter on your ride. Iíve tried to run the fork in the 110mm mode for all my climbs but for me it wasnít needed. I've read that the fork has a 51mm offset too. I haven't confirmed this yet.
    Riding the Mason
    From my first ride at MBO to my home trails, this bike just wants to ride aggressive and fast downhill. The steeper, the better. With the 66.5 degree headtube angle the Mason handles any decline with ease. I ripped the Mason down a very unfamiliar trail and felt very comfortable the whole time. At the bottom, I couldnít believe how ďeasyĒ the trail was compared to the comments I heard before dropping down it. On my home trails, it has brought my skill level up another notch. Hitting drops or any little side stunt on the trail are way more inviting than my 120mm full suspension 29er that preceded the Mason.
    Climbing on the Mason was a little different than my normal XC bikes. During my time on the demo Mason, I did experience a bunch of steep short climbs with the fork fully extended. There were a few times that the front end wandered about. During these times, you need to concentrate on the front end and keep your weight forward. I dropped the fork and the front end behaved just like my XC bikes. In the 110mm mode, the Mason feels like any other bike with a lower bottom bracket. Going from my XC bike to the Mason (fully extended) made me feel way high in the saddle. This isnít particularly a bad thing, it was different than what I was used to. The added height has given me comfort going over logs and step ups. At first my climbing ďfeltĒ slow but that could have been me more than the bike. Now, I climb pretty well and figure itís was my fitness more than the bike. The stiffness of the frame does have the side benefit of...instant acceleration. Coming from a one speed, one tends to stand and mash, the Mason rewards you with forward motion.
    One side benefit I didnít figure on, the Mason is great at my bike park. Drop the saddle and the bike feels like a BMX bike (sort of). Take the flow line, the pump track or the jump lines, this bike rails it. After this revelation, Itís a constant battle as to which bike to bring to the bike park. Thatís a good thing!
    I would like to see a few things added/modified to the next Mason. Two water bottle cages would be welcomed since I do like to ride without carrying water on my back for those last minute rides. Placement of the water bottle mount could be lower on the downtube so bigger bottles can fit better. And lastly, the cable management under the top tube could be a bit better organized. Out of the box, the dropper cable was routed on the underside top tube while the rear derailleur was routed on the outside of the top tube. This routing didnít play nice with the dropper post. Maybe different mounts could be utilized. Again, this is nit picking on my part. Of course some will want Stealth cable routing too.
    My upgrades to the Mason are as many but the overall character of the bike is still there. I upgraded to XTR Trail brakes (200/160 rotors) since I have been spoiled by these brakes since they have been available. Plus they were taken off my previous ride. I swapped out the stock cranks for a set of E*13 XCX SS cranks/bb since I run 170mm cranks on all my 29erís and wanted something lighter for the Mason. I have the 2x Shiftring if I want to get some lower gearing. Some Industry 9 XC wheelset/Stans Arch rims that came off my F/S bike too. Love the flexibility of the I9ís! Just swapped in the 142 axle ends with no problems! For tires, I wanted more bite than stock. Went with a 2.3 Geax Gato front and Maxxis Ardent 2.2 rear. So far theyíve been awesome. Need more time on them since mounting them last month. I did swap out the grips to some ODI Rouges for my personal preference. Will be going to ESI Chunky soon.
    The upgrades dropped a little over 3 pounds off the bike. The Mason is down to just under 26 lbs. The weight weenie in my rejoiced!
    Conclusion
    If youíre looking for a bike that can do many things and donít need full suspension, then the DiamondBack Mason is for you. Or if you want to try an ďall mountainĒ 29er the Mason can do that too. Not saying this is THE one bike for all riders, this bike can do it all and do it all well. This is my go to bike for fun trail riding and would be great in an enduro race.
    Enjoy the ride.
    Let us Ride!
    Sep 2012
    Awesome review. I'm a 29er HT lover, this bike compared to the Yelli/Honzo, etc seems to get very little attention, even just browsing reviews online.
    I'm surprised you got it down that light, that's impressive. Have you ridden any of the other bikes in this segment?
    MTB B'dos
    Reputation: LyNx's Avatar
    Great review, I'm sure loads will appreciate it. Also think the Mason is a sleeper bike, but some might stay away because of the 66.5* HTA. I'd like to demo one at some point, but there's no way I'd plonk down cash without demoing, not with that geo, just don't have the type of trails to justify something that slack, all the time, like the 67.5-68.5* HTA on my Prime, find it slack enough and also liked the Paradox with 69* HTA, but did find I would like it a bit slacker - they slacked it out to 68* for the V2. Curious what the BB height is when you set the fork to 110mm and 140mm? Paradox was 12.5" with a 120mm Minute, which made for definitely needing to time pedal strokes in the chunk.
    Got Twins?
    Hey Alberto,
    I have not ridden to any great length other bikes. I was going by headtube angles and chainstay lengths. After demoing the Mason, it was the one to beat. I may do that this weekend at MBO. If so, I'll post up.
    Let us Ride!
    Got Twins?
    Hey LyNx,
    When I get back from MBO, I'll post up some numbers. As I ride the Mason, 67* maybe the sweet spot. My local trails don't justify the slack HT, but it makes me want to attack the trails no matter if its down or just traversing. It makes my ride that much more fun.
    Let us Ride!
    Jul 2013
    i84biking ,
    What did you hear about the 2014 Mason?
    Sep 2012
    By luck I had a chance to ride a Mason this past weekend. DB rep said a FS Mason is on the way.
    I loved the handling of it. All the talk of short chainstays and lofting the front are true. Its a super playful bike. BUT, climbing even with the fork at 110mm requires much more body English to keep that front end down compared to my 17.5" CS bike. On a bonzai run down a 30+mph very loose rocky hill with drop offs I was really disappointed. Front felt composed but the rear felt skiddish to me, like it never settled down, stability wasnt confidence inspiring on the fast stuff. Loved the handling, but not the right bike for my area IMO.
    Having said all that I'm going to demo it again for an entire day this time.
    Jun 2013
    Very nice ride. I really dig this HT. Enjoy it, that's what it's all about.
    Quote Originally Posted by _Alberto_ View Post
    What you write seems more critical of HT and less of the Mason in particular; of course any HT will be chattery down rocky/tech terrain. However, with good rubber the skittishness is diminished quite a bit. Regarding the CS, the difference between your bike and the Mason is 17.5 to 17.16. 3/8" is not a night and day difference.
    Sep 2012
    It in fact was a huge difference on the trail. My bike is around 68.6 HTA, 120mm, 17.5" CS, and the Mason turned without having to muscle it (and my wheels are lighter) and lofting the front end was much easier.
    By comparison my bike doesn't feel the way I described down this decent at all. I enjoy HT bikes more so than FS; but I couldn't help but 140mm of travel is past what I personally seem to enjoy on a HT.
    Feb 2007
    The production Mason has 433mm chainstays which is just a hair over 17". Just wanted to clear that up, I've seen at least 5 different measurements listed on this site and others.
    Got Twins?
    Lynx,
    Sorry for taking so long to respond.
    Just measured it:
    140mm travel = 335mm/13.189" bb height
    110mm travel = 325mm/12.7953" bb height
    Measured with a Maxxis Ardent 2.2 on the rear and a 2.3 Geax Gato on the front.
    Hayes,
    I did not hear much. Just changes were coming for 2014. I'll chat up the DB demo guys at the August MBO and see what I can find out. Let you know then.
    After 3 days of riding, actually 2.5 after a crash on Sunday took me out for the rest of the day, the Mason was awesome coming down the trails in Oregon. I my put on a 2x up front to see how it is with a lower gear for some of the steep climbs. Actually, I'm really thinking that the RF Narrow/wide 30t ring may give me a little lower gear for some of them.
    Let us Ride!
    Jul 2013
    I84biking,
    Thanks for the follow up. I spoke with a DB rep at their 800 number last week. He said the new HT models would be at the Press camp last week but I did not see any posts or photos. The big splash was the FS. Also, they said the new production models were available in September, no other details available.
    I saw another post on swaping the FR to a 30t with good results. Good luck and let me know any news on the 14 HT.
    MTB B'dos
    Thanks a lot for that. So BB is quite high even with a 110mm fork, good to know, was thinking IF I decided to give one of these a try I didn't want the 66.5* HTA so would use a 120mm and bring it up a notch to about 67.4* and seeing your BB measurements tells me this could work nicely. Paradox had a 12.5" BB with 120mm Minute, so was quite low, I prefer a taller BB and not so much concentration on avoiding pedal strikes.
    Quote Originally Posted by l84biking View Post
    Lynx, sorry for taking so long to respond.
    Just measured it:
    Reputation: Rev Bubba's Avatar
    Excellent review. Probably much more bike than I need but a very interesting concept.
    Reputation: D Bone's Avatar
    Jul 2014
    Hello, I'm new to the forum. I have had several back surgeries and being hunched over all day is no longer for me. I currently have a Specialized Expedition that I have been riding on rides that the designers never dreamed it could go (I am an X moto-X-er) and am currently looking at the 2014 Mason (hardtail version)............. My question is, would you consider the seated riding position of the Mason as being "upright" when compared to a traditional XC hardtail? Thanks!
    Re: DB Mason Review
    Quote Originally Posted by D Bone View Post
    I consider it very upright. When I had mine I went so far as to switch to 800mm bars as I felt the cockpit cramped and too upright.
    The wider bars pulled me forward a bit without having to go to a longer stem or changing the handling characteristics. If anything, the bike was better to ride with the wider bars as they fit better the mold of a slack, short chain stay hardtail
    Sent from my C6806 using Tapatalk
    Jul 2014
    Thank you! I found one about 2hrs away and will ride it on Tuesday. Thanks again.
  1. Mason HT
    By shredjekyll in forum Diamondback
    Last Post: 03-24-2015, 10:33 AM
  2. Diamondback Mason Frame....where to buy?
    By ihaveagibsonsg in forum 29er Bikes
    Last Post: 06-08-2013, 07:50 PM
  3. DiamondBack Mason HT sizing
    By Necrodomis in forum Diamondback
    Last Post: 05-25-2013, 11:15 AM
  4. DB Mason sizing
    By dfinn in forum 29er Bikes
    Last Post: 03-10-2013, 07:36 AM
  5. New Mason FS
    By Stonebreaker in forum Diamondback
    Last Post: 10-03-2012, 02:59 PM
