Results 1 to 10 of 10
    Reputation: JustinKreger's Avatar
    Nov 2013
    Compliant Carbon 29ers
    Its time for an upgrade...
    After racing on my aluminum superfly for the past 3 years, i think its time to get a new frame. The aluminum frame is brutal an rocks an fast descents. I have decent parts on it now so I am looking at a frame or frame set.
    I have looked at the Bmc Te01 frame because of the slacker geo and compliant rear triangle. Only problem is its a little expensive.
    Any other ideas on reasonably prices 29ers that i can do 12-24 hour races on comfortably and is light enough for XC.
    Life is like riding a bicycle. To keep your balance you must keep moving.
    ~ Albert Einstein
    Formerly of Kent
    Reputation: Le Duke's Avatar
    Are you running large volume tires, tubeless, at low pressures?
    Death from Below.
    Nov 2013
    I am currently running 2.4f and 2.2r with about 20 psi, so I would say yes.
    ~ Albert Einstein
    Try the new geo Superfly 9.6-9.8. Totally compliant and a complete change from last year's carbon SF which was stiff.
    But an added option with a 30mm inside dim wheelset the added volume will give you more cushion. On the 9.8 it makes the rear match the front and the front solo air fork finally have some small bump compliance. I got credit for the oem wheels, cockpit and drive components at purchase. The frameset is sold separately in Europe, so email Trek to get it added to US offerings.
    my church is the woods
    Reputation: moonraker's Avatar
    Pivot Les
    Reputation: clarkrw3's Avatar
    Hard Eddie
    I don't huck.
    Jun 2005
    Scott Scale (carbon)
    Blog Ramblings
    West Coast writer for twentynineinches.com
    Reputation: andyfloyd's Avatar
    Look at the XMI Play Chinese IP-106. It is UD carbon with compliance built into the rear stays very similar to the Focus Raven 1.0 frameset.
    2014 27.5" SC Blur TRa - 2014 IP-106 Chiner 29er - 2005 Fuji Team SL 16.2lbs -
    Nov 2013
    Any experience on how they ride? durability? price?
    ~ Albert Einstein
    Quote Originally Posted by JustinKreger View Post
    It rides really nicely. Its a hardtail so its still stiff but its a lot less stiff than an aluminum frame. Its the same bike as the IP-057 basically but with more compliance built into the rear stays. Lots of people have over 3-4k miles on them in the last couple of years with basically no failures. The Frame is 400 +80 Shipping to your door in about 2 weeks direct from China. XMI play, ask for Peter he speaks good english.
  1. How compliant is the El Mariachi?
    By bailout in forum Salsa
    Last Post: 10-28-2012, 08:35 AM
  2. Carbon HT, Most Compliant?
    By atekt in forum 29er Bikes
    Last Post: 08-23-2012, 07:44 PM
  3. For Mike - carbon 29ers?
    By TiGeo in forum Motobecane
    Last Post: 12-08-2011, 09:28 AM
  4. Carbon SS 29ers
    By bank5 in forum 29er Bikes
    Last Post: 09-05-2011, 08:04 AM
  5. Carbon Epic 29ers
    By carlhulit in forum Specialized
    Last Post: 04-01-2011, 05:25 PM
