Page 3 of 6 FirstFirst 123456 LastLast
Results 101 to 150 of 279
  1. #101
    Tweed Run
    I've been looking at pictures of the Tweed Run. Some of you know what I'm talking about. It seems Brits ride more upright than many of us. More upright means higher CG, and they all seem to be having a splendid good time.
  2. #102
    Quote Originally Posted by Ze_Zaskar View Post
    A simple way to explain this issue is with the following concepts:
    -High CG- greater range of stability (angular amplitude) but a stronger and slower input is required to correct it.
    -Low CG- smaller range of stability (angular amplitude) but weaker and faster inputs are required to correct it.
    From a mechanical engineer's point of view, this pretty much sums it
    I am fine with that definition apart from the concept of stronger or weaker inputs being required in order to correct losses of stability.
    Remember that the corrective input mechanism is the moving of the front wheel from one side of the COG to the other. Because a tall bike falls more slowly the bike will lean less in a given time and so less corrective wheel movement is required. A rider of a less tall bike, reacting in the same time will require more movement. The magnitude of correction required also varies with the speed of the bike and how far back the COG is from the front wheel.
    File:Bike weaving.gif - Wikipedia, the free encyclopedia
    The notion that it is an input force applied by the bike that corrects the lean is misleading as the force that corrects the bike is that of gravity pulling downwards. The front wheel moves sideways whilst the COG travels in a smooth line. There is a small force that moves the front wheel from side to side but this force does not directly re balance the bike.
    To summarize:
    -High CG- greater range of stability (angular amplitude), with a slower rate of lean that can be countered more slowly. If countered quickly less front wheel movement will be required.
    -Low CG- smaller range of stability (angular amplitude), with a faster rate of lean that needs to be countered more quickly. If countered slowly larger front wheel movement will be required.
  3. #103
    Quote Originally Posted by I'm suba View Post
    They do appear to have a good time. Some commentators say that Geoff was well ahead of the modern tweed wearing trend as this 1984 photo shows. Cleland: The original big wheeled off-road bicycle?-4321632293_01fcfb3fa1_b.jpg
    The tweed run is not typical of British cycling as most UK riders ride in a forward position. The main upright cyclists in Europe are the Dutch, Germans, Belgians and Danes. Though there bikes, unlike Clelands, have slack frame angles, longer wheelbases and low bottom brackets.
  4. #104
    Quote Originally Posted by smilinsteve View Post
    Funny, in the video Graham just posted the guy balances a golf club with head up and head down and says its easier with head down, (COG closer to fulcrum, ie. finger)
    Take another look.
    He actually says it's easier with the head upwards so that the center of gravity is higher.
  5. #105
    Sep 2012
    I don't look like I'm having much fun, but I'm concentrating I suppose, those rocks are slippy.
    Attached Thumbnails Attached Thumbnails Cleland: The original big wheeled off-road bicycle?-tweed001.jpg
  6. #106
    Quote Originally Posted by GrahamWallace View Post
    Take another look.
    I watched it again. He says the club head is more easily balanced when it is near your finger. It is shown at time 4:15 to 4:40 in the video.
    Edit: But I think he mis-spoke. And looking at the video, he seems to be having more trouble with the club head down.
  7. #107
    Perpetual n00b
    Reputation: dgw2jr's Avatar
    Quote Originally Posted by GeoffApps View Post
    Look like a BAMF to me. I really want to try out one of those bikes!
  8. #108
    You are right.
    He does in fact say "it seems to me that the club head is more easily balanced with the club head, near!"
    I had the sound turned down and thought he said "club head, here!
    I eventually find a video that explains the principle and but the demonstrator gets a key word wrong?
    But you can see from the other demonstrations that a mass further away from the center of rotation moves more slowly. i.e. it is harder to move.
  9. #109
    Here's a web page that explains it:
    Exhibit Cross Reference - Balancing Stick
  10. #110
    Sep 2012
    Bamf?
  11. #111
    Well done Steve!
    Perseverance is the key to understanding counter-intuitive concepts like this.
    Bit by bit they start to make sense!
    Here's another one to ponder?
    When riding up a steep slope you need to keep the weight over the rear wheel to maintain traction. But you also need to keep your weight over the front wheel in order to hold it down.
    But how can the weight be over both the front and back wheels at the same time?
    Theoretically it can if the weight is an infinite height above the bike.
    By the same logic a taller bike should be able to climb a steeper hill than a short one
    This also explains why bikes with shorter wheel-bases climb best.
  12. #112
    Bamf?
    Bad. Bottomed. Mother. Thingy?
  13. #113
    Sep 2012
    I remember a scene from the seminal film 'On Any Sunday' about the hillclimb called 'The Widowmaker'.
    Intuition told those attempting it, year after year, that a huge engine in a mega long wheelbase motorbike with a low low saddle was the way to get to the top.
    If I remember rightly, few, if any, succeeded.
    Then a chap on a small-engined short wheelbase trials bike, standing on the pegs, slowly tiggled his way up to the top, turned round and came back down.
  14. #114
    Sep 2012
    Cor, is that a compliment?
  15. #115
    Perpetual n00b
    The meaning of BAMF
    Yea, it's a compliment here in the colonies.
    Is this the hill climb you are talking about: Hill climb ride up (from movie - On Any Sunday) - YouTube
  16. #116
    Sep 2012
    Yes, that's the one.
    Clearly, my memory of the film is wrong.
    Mind you, the last time I saw the film was in 1970.
    Thanks for that link ~ I must get the DVD, it was a most influential film for me.
  17. #117
    Reputation: BacDoc's Avatar
    BAMF - yes big compliment.
    Geoff and Graham,
    Your attitude and responses to the posts in this thread display qualities of intelligent thinking by enthusiastic riders/innovators. Keep up the good work!
    As a chiropractor I find Geoff's take on spinal health to be on the money!
  18. #118
    Quote Originally Posted by BacDoc View Post
    It's the English thing. They're farther along on the evolutionary chain.
  19. #119
    Sep 2012
    Geoff and Graham,
    Thanks for that.
    I was talking to one of the chiropractors in a group practice which had a stand set up at a cycle show.
    He agreed with me that the common 'stretched' posture on a bicycle is bad bad news for most of the body, particularly the spine.
    However, if he were to say anyting along these lines to a conventional cyclist he had discovered through experience that, because he was not also a cyclst, he would alienate his clients; not good for them, not good for his income.
    So, traditional cycling wisdom rules.
    I assume you've looked at this
  20. #120
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    Apparently I need educating on this one, as I do not believe it is correct. Could you explain your logic?
    Weight distribution is independent of COG height.
    [QUOTE=GrahamWallace;9725280By the same logic a taller bike should be able to climb a steeper hill than a short one[/QUOTE]
    As the height of the COG increases, so does the rider's need to move his position relative to the axles to account for it. Thus, height will at some point limit the grade that can be climbed without the bike tipping.
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
  21. #121
    Quote Originally Posted by meltingfeather View Post
    In theory, you can draw a line from the COG to the front or the rear axle, and as you raise the COG that line becomes more vertical. At infinitity, the line is vertical.
    But if you want to distribute weight evenly between front and rear, there are easier ways than putting your seat up in the sky. You just center your weight.
    Climbing steep hills does require a careful balance between front and rear weight distribution, but 50/50 is not necessarily the best distribution. I think longer top tubes allow for more rider adjustment to move weight back for traction, or to the front for stability, as needed.
    Good point. As the grade gets steeper, the COG moves backwards to a greater degree the higher it is.
  22. #122
    Parallel lines do no get closer together (what would be required for even weight distribution) no matter how long you make them. Also, for weight distribution, the horizontal distance from COG to axle is relevant. Height of the COG is irrelevant, unless I'm missing something.
  23. #123
    Not parallel. Picture you draw a line from the COG to the rear axle, and from the COG to the front axle. So you have a triangle, with a line between the axles as the base. As you raise the COG (at the point of the triangle) the angle at the peak of the triangle gets smaller and smaller...
    You never get to parallel, but theoretically you can get that angle as close to zero as you want.
    Not that I think this exercise has any practical use. The difference in COG height is too minor in real bike design to be a player in the weight distribution problem. Like you said, its horizontal position that determines it in real life.
  24. #124
    To repeat my original assertion:
    By the same logic a taller bike should be able to climb a steeper hill than a short one"
    Here is my explanation:
    The force that causes the front wheel to lift is an equal and opposite reaction to the torque being applied by the rotation of the rear wheel.
    In this instance a bike can be considered to be a third class lever with its pivot at the center of the rear axle, the input effort is the torque reaction from the rotation of the rear wheel as applied at the outside of the axle, and the load being the riders weight levered is at the COG. Bear in mind that with a third class lever the input force is always larger than the force applied to its load. Therefore, the further away the COG from the rear axle the smaller the reaction force applied to the COG. And at an infinite distance the force applied at the COG would be zero. In order for the bicycle not to tip forwards or backwards the COG needs to remain within the wheelbase so the only place it can be located at infinity is above the bike.
    Of course in reality you can't locate the COG at infinity. Even if you could its inertia would cause the bike to tip backwards as the bike went forwards. However moving the COG as far away from the rear axle whilst keeping it within the wheel-base will reduce the magnitude of the torque reaction. The best place to put the COM is high above the front wheel. Remember that the front wheel is further up the hill than the rear wheel so the wheel-base will have shortened relative to the horizontal. Due to the inertia of the COG any acceleration force applied to the will increase rear wheel traction but can also cause the bike to tip backwards. So smooth pedaling is essential. This can be aided by the use of elliptical gears that also allow the cadence to be lowered whilst reducing the chances of rear wheel slip.
    Its never fails to amaze me just how complicated is the physics of the simple machine that we call the bicycle.
    To help with the key concepts here are two videos:
    In this one of unicyclists cycling uphill you can see how unicyclists have to lean forvard as they pedal in order to counter the combined effect of the torque reaction and the inertia of their COG.
    How Levers Work - YouTube
    And towards the end of this this one, the Third Class Lever is explained.
  25. #125
    Sep 2012
    With a longer top tube your upper body is stretched in order to reach the handlebar.
    Your upper body is what you use to transfer weight fore and aft.
    A stretched upper body has only limited capacity for moving forwards and backwards.
    Therefore, a shorter toptube and reach does allow the flexibility.
  26. #126
    So, drum brakes? What kind of drive train are you using?
  27. #127
    The horizontal positions available is limited as you cannot move the COG outside of the wheelbase. Therefore the only way you way you can reduce the leverage effects of rear wheel torque reaction is by moving the COG upwards.
    The practical effects of this are indeed small. However, if you wanted to win a hill climbing competition at best it could increase the incline your bike could climb by the same proportion as the reduction in mechanical advantage caused by increasing the length of the 3rd angle lever. The distance between the rear axle and the COG.
    44% hill climb.
    Cleland: The original big wheeled off-road bicycle?-44_percent_climb_a_911.jpg
  28. #128
    Sep 2012
    Quote Originally Posted by leeboh View Post
    Back in the early 1980s, Cleland bicycles were fitted with Leleu 'floating cam' drum brakes. Apart from those made by Dave Wrath-Sharman, as far as we are aware, the Leleu brakes were the only floating cam drum brakes on the world market. All other drum brakes were, and are, fixed cam. This makes them unsuitable for extreme weather conditions and off-road use.
    The Leleu company in Lyons, France, closed down several years ago.
    Modern Cleland style bicycles use roller brakes. These are also in the hub and function completely differently to drum brakes. Roller brakes provide better modulation than disc brakes, they are cheap as chips, require virtually no maintenance (the pair I currently use are six years old and have had no more than 12 minutes maintenance in that period, and required no replacement parts). Moreover, they require grease to function and are thus completely impervious to water, so river crossings present no issues at all. The downside is that they are relatively heavy; with all those plus points, I'm quite happy to carry a few extra pounds.
    Pictorial details of the drivetain can be seen earlier in this thread. Further information can be found on the Cleland website. The drivetrain is fairly unusual, so as a general topic it is very broad. Once you have done your research, should you have any questions about specific areas, I'd be happy to respond.
  29. #129
    Reputation: Velobike's Avatar
    Back in the early 1980s, Cleland bicycles were fitted with Leleu 'floating cam' drum brakes. Apart from those made by Dave Wrath-Sharman, as far as we are aware, the Leleu brakes were the only floating cam drum brakes on the world market. All other drum brakes were, and are, fixed cam. This makes them unsuitable for extreme weather conditions and off-road use....
    I've used drum brakes and roller brakes offroad. A properly greased Shimano roller brake is much better than most people realise. I'd agree about the comments on the advantages of floating cam drum brakes, but Sturmey-Archer are now producing a 90mm drum which has more than adequate power (still not as powerful as a good disk though). However we're talking brakes that function longterm in foul conditions, and my experience is that disks don't do that without consuming expensive pads and needing maintenance.
    I've done 24 hour races in foul conditions with S-A drum brakes. I used them not because they are great brakes but because they were adequate brakes. Their great advantage is that in conditions where some competitors were changing their pads several times (as I had in earlier races) I was losing no time in the pits. When it's pitch black and the temp is around -10C I can take over 15 minutes an end to do what is usually a quick job. I reckon that was worth 1 lap overall, better than I could pick up by being fitter.
    This year's race was done on the larger S-A 90mm drums, which were much nicer to use because they didn't need the death grip to work on fast downhills. When stripped down after the race, there was negligible wear on the brake shoes and the internals were clean.
    This was one section before the race. It turned into mud soup and a brake grinder within the first lap.
    [IMG]
    Like this
    After the race. (The mudguards were to reduce the chance of hypothermia from being soaked more than to keep the mud off)
    [IMG]
    [IMG]
    Internal pics
    [IMG]
    Oh, btw, before I get pilloried for my unfashionable red bar ends in the wrong position, I'd better point out that they are so if I have to turn my bike upside down for trail repairs they will keep the bar off the ground and thus I don't have to remove my lights etc from the bars.
    Latitude: 5736' Highlands, Scotland
  30. #130
    I am not seeing this at all.
    Third class lever? that would mean the force is in between the load and fulcrum. If the load is the COG and the fulcrum is the axle, what is the force and where is it applied? You say:
    Well, the axle is attached to the bike by freely rotating ball bearings so there is no torque transfered from the wheel to the axle or the axle to the frame.
    The ground force creates a force reaction, not a torque, at the rear axle pushing the bike forward.
    So the force is at the fulcrum, and if the force is at the fulcrum it creates no rotation around the fulcrum.
    So what makes the front wheel lift?
    In a climb, like in that 44% grade picture, the only contact points of the rider to the bike are at the handlebar and at the pedals. If the bike and rider are at equilibrium with both tires on the ground, then you can raise that COG to infinity (along the force vector) without effecting that equilibrium.
    Now, suddenly the front wheel comes up, so one of these things must have happened.
    1. An upward force from the ground (bump).
    2. A rearward weightshift such as caused by acceleration from a pedal stroke.
    3. Pulling up on the handlebars.
    That's all I can think of. And height of the COG doesn't effect any of them unless changing the height also changes the for/aft weight distribution.
  31. #131
    Your above statement is true if the COG is being accelerated by drive forces emanating from the rear wheel. It would not be true if the COG is moving at a constant velocity.
    Of course with a low frequency pulsed drive of a bicycle some acceleration and deceleration of the COG is inevitable. So keeping the drive smooth as possible is essential. Hence the use of elliptical gear rings. It is only the reaction forces to any acceleration that can cause the front wheel to lift. The question is where to best position the COG in order that its weight can best counter these reaction forces.
    Remember that to move it forwards will reduce the traction of the rear wheel.
    And to move it backwards will of itself, will reduce the leverage that the COG has over the reaction forces.
    To move the COG upwards along the diagonal axis between the rear axle and the COG will increase the leverage that the COG has over the rear wheel torque reaction. Whilst the reaction force due to COG inertia, remains unchanged.
  32. #132
    ...Of course with a low frequency pulsed drive of a bicycle some acceleration and deceleration of the COG is inevitable. So keeping the drive smooth as possible is essential. Hence the use of elliptical gear rings. It is only the reaction forces to any acceleration that can cause the front wheel to lift. The question is where to best position the COG in order that its weight can best counter these reaction forces...
    I hadn't thought of that advantage of using elliptical rings. On really rocky steep hills, I've usually found the inability to keep the front wheel down stops me more often than the loss of puff or traction. I'll have to give it a try and see if it works for me.
    Edit: just been to HIghpath site, not currently available. Anywhere you recommend for these?
  33. #133
    It is true even if moving at constant velocity. The comment is specifically in regard to a bike on grade. At some point the bike will tip due to the grade moving the COG rearward of the rear axle, even if standing still. Increasing the grade as well as raising the COG make tipping due to acceleration easier.
    Well put, and exactly my point. Without the forward movement, raising the COG is counter productive to weight distribution on a bike on a grade.
  34. #134
    A bike brought me here!
    Reputation: Poikaa's Avatar
    Jun 2010
    Quote Originally Posted by NEPMTBA View Post
    And why not Horses?
    They graze as they go, water at any stream, can carry more gear, and are faster...LOL
    An Army commander was very influential for the start-up of bicycle mounted soldiers, had lots of pull! Not only that, bicycle mounted troops were popular all over Europe and Africa for many years. The Swiss were very much involved and still are to a degree.
    poikaa
    "I don't ride a bike, I'm the pilot!"
  35. #135
    I have rethought what I wrote earlier, and agree that the height of the COG is irrelevant to the weight distribution.
    And I would appreciate it, Melting Feather, if you would slap my silly as$ back into place when I say stupid crap
    The COG can be represented by a point and it creates a force vector directed from that point to the center of the earth. That vector is on a line that goes up into space and no matter where you move the COG up that line, the force vector to the ground does not change, so the weight distribution doesn't change.
  36. #136
    I have a really short top-tube, short wheelbase bike with an oval chainring. I agree with Geoff and Graham re climbing balance. Also on the trails-style handling benefit of a higher COG, a taller front end and more upright position puts me higher on teh bike when stood up and it has real benefits on slow, technical terrain comaperd to conventional bike design. Personally I prefer the way a low-BB bike can corner at speed and the planted feel it gives on a steep descent, but bikes are all about trade-offs and compromises - often the bikes that don't need to be too compromised are the best for some riders. Depends on how / what you ride.
    BTW, I've ridden that slope pictured earlier as I live + ride in the same area. It's steep, but not at-the-limit crazy-steep imo. It's long, uneven and traction is low though, so as a test of control it's a good one!
    Always interesting to read about these bikes, so thanks to Geoff and Graham for sharing your take on bike design. I think it's only the fact that common MTB culture has taken the direction it has that has made this style of bike marginal in its appeal, since the theory and 'riding ideal' that it's based on is excellent.
  37. #137
    Sep 2012
    Maybe see you at the Birthday Ride this December?
  38. #138
    New question here.
    Here is the problem in diagrammatic form.
    Cleland: The original big wheeled off-road bicycle?-torque-reaction.jpg
    The vertical broken line represents the center of the wheelbase.
    The red arrow represents the rear wheel torque but is not shown to scale. (If shown to scale is would be more than twice the size of longest reaction force shown).
    I have used black dots to represent three differently placed COGs, Attached an arrow to each black dot that shows the direction and relative magnitude of the torque reaction acting at each COG. (The top COG though not achievable on a standard bicycle is nonetheless, theoretically interesting).
    Each dotted line connecting the rear wheel to a COG represents the central axis of a virtual third class lever that transmits the anti clockwise torque reaction forces. In reality these forces would be transmitted through the bike and the body of the rider. (Remember that with a third class lever, the longer the lever, the less force is transmitted to the COG).
    Not shown is:
    * the large gravitational force acting vertically downwards on each COG.
    * the drive forces that act upwards and forwards from the rear axle to each COG.( These forces act as an equal and opposite reaction to the rear wheel torque They push the COG both onwards and upwards).
    * the reaction forces that would be generated by sudden accelerations of the COG caused by pedaling that is not smooth, (these will act at the GOG in equal and opposite direction and magnitude to any acceleration or deceleration).
    But what COG position will allow you to climb the steepest hill?
    If your not confused by now you're not trying hard enough
    Missing info: is the mass of the bike and rider and the coefficient of friction of the rear tire.
  39. #139
    The Wendover ride? Would love to, thanks.
    edit to add, Graham doesn't do a lecture in the pub after does he..? Just kidding. Keep at it and I'll keep reading.
  40. #140
    That's a nice drawing Graham.
    I still don't think we are on the same page.
    I do appreciate discussing it with you.
    What I'm thinking.
    - The red line is not a torque, it is the force vector caused by the tire pushing on the ground, and the equal and opposite vector is acting at the rear axle pushing the bike forward.
    - There is no "torque reaction" at each COG. The only forces on this system are red arrow, the forward force reaction at the rear axle, the downward force from the weight of the bike and rider, and the normal force up from the ground on the tires that is countering the weight.
    - When the bike accelerates from the red arrow force, if the bike and rider act as 1 rigid body, the position of the COG doesn't effect the motion. The only thing that matters is that the COG is in a place to provide sufficient force on the tires for traction in the rear and for stability of the front.
    -Normally, the bike and rider do not act as one rigid body. Acceleration will cause the bike to squirt out from under the rider, causing a relative weight shift backwards (the inertia of the rider is greater than that of the bike). A higher COG potentially makes this worse because the there is a longer lever arm from the COG to where the force is applied to the rider (his feet and hands if he is standing on the pedals).
    - In your picture, the answer to your question "which COG position will allow you to climb the steepest hill?" the answer is the most forward one if front wheel lift is the limiting factor, but in general it is the one that gives you the right balance of rear traction and front stability. This is detemined by the for-aft position of the COG only. I don't see how the height makes any difference at all.
    - I still see nothing analagous to a class 3 lever, since I disagree that there is a force (or "torque reaction") at the COG that you have drawn.
  41. #141
    Remember that with a third class lever, the longer the lever, the less force is transmitted to the COG.
    This argument has a converse that equally and oppositely counters it.
    As you move the COG away from the axle you also decrease the force/inertia effect required to impart torque/rotation about the axle by increasing the lever arm (the same mechanism by which the torque reaction is being reduced).
    In your own example of COG at infinity, when the "force transmitted to the COG," as you like to put it, is zero, the bike tips upon first input, which is not an equalization of weight distribution as you claimed, but the opposite extreme. The basic 3rd class lever example falls short in that, on a bicycle, the pivot point is free to move, and so, with a COG at infinity, no motion or force input at the COG is required for the relative rotation of the COG about the axle, which occurs due to movement of the pivot point, and the net effect is movement of the COG behind the rear axle (and tipping).
    Heightening the COG exacerbates the weight distribution effects of acceleration and grade.
    As you move the COG forward you balance and counter the effects of both forward acceleration and grade.
    I think that the raising of COG, which you are making as an argument for effective hill climbing, is nothing but a side-effect of moving forward, which on a bicycle requires standing.
    Interesting dialogue, to be sure.
    You Brits certainly are masters of adverse conditions riding. The terrain around here gets destroyed if ridden in those conditions and if I posted a photo of riding local terrain in that condition I'd get tarred and feathered by any local mtb'ers that came across it.
    Not to mention our climate can be described as long periods of drought punctuated by brief interludes of flash flooding.
  42. #142
    We may not be "on the same page" but are both seekers of the same truth.
    Steve you make some valid and interesting points there. However, before I reply in detail I would like to clarify whether you believe that torque reaction forces are involved at all?
    Here's a video of a Segway driving up and down a steep slope. Note the Segway is moving at a constant velocity and is not accelerating. However the rider can be seen to lean forwards markedly. Why does she need to do this and why does she not fall forward. Does it make sense that a faster rider or a shorter rider of the same weight would need to lean forwards even more?
    Steep segway climb - YouTube
    There is clearly some leverage involved in stopping the rider from falling forwards.. Could this leverage be categorized as the class three? And could the leverage result from the torque reaction to the motor/gearbox?
    Why doesn't the rider need to lean when going downwards?
    Ideally we need some good footage of a unicyclist riding up a steep slope, but so far, I haven't found a good example.
  43. #143
    The end game here is to arrive at some kind of consensus that we can agree on.
    There is no value in me having a theory if it won't stand up to scrutiny.
    We are treading new ground here, I don't know of any discussion of this topic in the "bicycle science" textbooks or Wikipedia.
    Take a look at the Segway clip that I have posted, what do you think?.
    My I ideas are based on testing various bike designs on my local 44% hill and then coming up with a rational of my own for what I have found. I have also built radio controlled models to test out ideas. I am hoping that what I learn from this conversation may feed into future bike designs.
    I will carefully consider your and Steve's thoughts and then report back in detail.
  44. #144
    I'm reminded of a purported quote from a former Australian Prime Minister:
    "That may work in practise, but it doesn't fit my theory" or words to that effect.
    The theories here all make sense in themselves, but the QED here is that Graham is climbing these hills when most can't. Finding out whether that is because he has monster legs and an incredibly smooth technique, or because of the bike design is the fun part.
  45. #145
    Graham you are really making me do my homework! I don't know anything about Segways, but now you give me something else to figure out.
    That's ok. I've been involved in these physics discussions in this forum for a couple of years (and have bumped into Melting Feather in a few of them), and I think I have learned more about physics at MTBR then I ever did in college (or close anyway).
    I will get back to you on this. I hope however, that I have enough fun, and a good ride, this weekend, that will keep me from spending too much time on the computer.
  46. #146
    Jun 2010
Name:	Torque Reaction.jpg
    > SNIP <
    > When the tyres loose contact! When this happens you will also be in a controlled or uncontrolled crash! <
    Some sort of "zero-sum-game" one plays with gravity.... the bike becomes a tool to win and the better you know your "tool", the greater your "edge"!
    poikaa
  47. #147
    Here's an explanation of Segway technology from Wikipedia:
    "The dynamics of the Segway PT are similar to a classic control problem, the inverted pendulum. The Segway PT (PT is an initialism for personal transporter while the old suffix HT was an initialism for human transporter) has electric motors powered by Valence Technology phosphate-based lithium-ion batteries which can be charged from household current. It balances with the help of dual computers running proprietary software, two tilt sensors, and five gyroscopic sensors developed by BAE Systems' Advanced Technology Centre[5]. The servo drive motors rotate the wheels forwards or backwards as needed for balance or propulsion. The rider controls forward and backward movement by leaning the Segway relative to the combined center of mass of the rider and Segway, by holding the control bar closer to or farther from their body. The Segway detects the change in the balance point, and adjusts the speed at which it is balancing the rider accordingly. On older models, steering is controlled by a twist grip on the left handlebar, which simply varies the speeds between the two motors, rotating the Segway PT (a decrease in the speed of the left wheel would turn the Segway PT to the left). Newer models enable the use of tilting the handle bar to steer"
    Segway PT - Wikipedia, the free encyclopedia
    The best example a "torque reaction"/third class lever machine, that I know of, is the classic dragster design. The long front end being one big reaction arm to the rear wheel torque..
Size:  23.7 KB .
    The COG of the dragsters engine is directly ahead of the rear axle so as to eliminate the chance of the engines inertia lifting up the nose and then flipping the dragster backwards. But in order to gain the maximum rear wheel traction the COG of the dragster needs to be as close to the rear axle as possible. The problem is that the torque reaction is powerful enough on its own, to lift the engine and flip the dragster backwards. To solve this problem by adding a large extra forward weight, would only serve to slow down the dragster. And moving the engine further forward, away from the axle, would reduce rear wheel traction.
    So instead they add a long and lightweight third class lever reaction arm onto the front. By placing a small weight at the nose end of this arm will then create enough down-force to counter the torque reaction. This works in the same way that a weight in an outstretched arm feels heavier than the same weight when your arm is bent.
    One thing to note regarding the video of the hill climbing Segway is that no bicycle under its own power, could ever ride up a slope that steep. The rear wheel torque of a bicycle would be nowhere near smooth enough. To make big inroads into the maximum incline that can be ridden on a bicycle, the problem of the pulsed nature of rear wheel torque would need to be addressed.
  48. #148
    Quote Originally Posted by Poikaa View Post
    poikaa
    For me, riding up challenging hills is inexplicably compulsive.
    Though I have never been interested in racing on mountain bikes I love to take on and hopefully defeat hills. It's part of my psyche, Like riding in bad weather. I seem to be more interested in defeating nature than other people. It's a form of insanity' It's very hard work and these hills would be easier and quicker to conquer on foot. And most of my climbs are attempted when no one is watching to see me either succeed or fail. I guess it's good exorcise and less dangerous than most other things that people do on mountain bikes.
    I do however recommend that people who try this practice ways of getting off quickly when things go wrong. As not knowing how to react when the rear wheel suddenly spins out on a 44% slope could result in you returning down the hill head first, with the bike landing on top of you. I am now equally as good at bailing out, as I am as getting into trouble in the first place.
  49. #149
    Quote Originally Posted by Velobike View Post
    I know which of my bikes can climb my 44% test slope and I know those that can't. I even keep information of the relative success rates of the good climbers. The problem is that all my 5 bikes are different.In order to identify exactly what made then climb better I would have to change one parameter at a time and then test the slightly altered bikes in identical conditions. I would also need to repeat the rides many times and record and average out the runs to take account of variations in the exact path taken.
    Though I am mad enough to do all this, in reality I neither have the time or the money.
    In mountain biking like many other sports the main driver for innovation is racing. The fact that we don't have a category of 'Uphill Racing' means that very little effort has gone into improving the climbing characteristics of mountain bikes.
  50. #150
    This is an interesting discussion, and certainly something I need to think more about; I will.
    The Segway context is something i need to digest a bit.
    The dragster example has a couple of key differences: weight as a critical design driver being primary.
