Results 1 to 8 of 8
    Swimming thru the Smog
    Chinese FM056 bottom bracket/F derailleur?
    I have my FM056 almost fully built but my multi clamp Shimano XT FD does not fit, and i do not have the correct bottom bracket. What XT part numbers do i need?
    What i have:
    Cranks: FC-M785 38/26t 175mm
    Front Derail: FD-M785
    Reputation: Epic_Dude's Avatar
    May 2010
    What bottom bracket style is your frame?
    Predator bb30 it said on the website
    Sorry press fit. Need input from other fm056 owners.
    Reputation: brmeyer135's Avatar
    Mar 2013
    Just looking around, I found this: Praxis Works | Conversion Kit
    You are going to need something like that to convert the Shimano to BB30
    Yea I think that is what I need. I think I need a traditional bottom swing fd as well.
    Reputation: karmax's Avatar
    Posed a similar question yesterday to the helpful folks at Praxis.
    My question was based in purchasing a FR219 from Flyxxi. The frame has a 68mm BB30 alloy shell. I was hoping to use some stripped down SLX cracks that have a 24mm spindle.
    the answer from praxis was:
    We do not make a Conversion BB for 68mm MTB frames.
    Our 68mm is made for the 68mm Shimano Road cranks.
    Our 73mm is made for the 73mm Shimano MTB cranks.
    You can't put the Shimano MTB crank on our 68mm as our BB is not designed to be spaced.
    In the NOTES tab we have a bullet point on this
    • 68mm can only be used with road cranks. Cannot be spaced.
    Sorry, at this time we cannot help you out.
    instead i went with the Race Face Bottom Bracket BB30 for X-Type. appears to work with shimano cranks. purchased part from bikediscount.de
    Hope this info helps. you may want to send praxis an email. they were very timely in a response.
    Wheels Manufacturing BB30-SHIM
    I think thiss will work.
  1. Replaced Shimano Bottom Bracket, now front derailleur won't shift to largest gear.
    By unsavory in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-18-2013, 01:15 PM
  2. Replies: 51
    Last Post: 10-08-2012, 08:56 PM
  3. Hollowtech bottom bracket with E-Type front derailleur
    By pcmark in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-12-2012, 09:34 AM
  4. Bottom Bracket help
    By redmosquito1983 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-19-2011, 05:17 PM
  5. Do I need a new Bottom Bracket
    By Lope in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-25-2011, 04:44 PM
