    Cateye Astrale 8 on my Giant XTC
    I swapped over my Cateye Astrale 8 to my Giant XTC1. It worked flawlessly on my Trek 26". I've gotten the crank indicator to work for cadence but I can't get the speed to work. They are lined up but no reading. I looked the instructions up online but it says the distance should be under 5 mm between the sensor and the pickup. Not sure if it should have been 5 cm as there is no way that could be that close. Don't know what it wrong. Any suggestions?
    I'd go with 5mm.
    Half our life is spent trying to find something to do with the time we have rushed through life trying to save
    It might be pretty tough to get it down to 5 mm. I have the stock wheelset and the spokes are centered for the most part and the disc brake keeps you from getting close to the hub.
    I got it to work. Had to make some shims out of some rubber to push it closer.
