Results 1 to 27 of 27
    @adelorenzo
    Reputation: anthony.delorenzo's Avatar
    Carbon fork crash carnage calamity
    Just thought I'd post some pics of my crash last year.
    To be crystal clear: this was from a CRASH. It is no fault of the equipment and, in fact, it saved my ass.
    No, but seriously, I CRASHED.
    With that being said, here's the story:
    This happened in October last year. We were out getting in one last ride on snowy and icy trails. My rear brake was totally gone -- it had been going for a while but I was planning to deal with it in the off-season.
    Came into a section of trail with a right hander into a steep downhill into a hard left-hander. Well, the downhill was glare ice. Only a front brake which was doing nothing, so basically I had to ride it out. Went into the woods and hit a tree straight on with a lot of momentum. I was braced for impact so stayed on the bike while the front end soaked it all up.
    End result, as you can see, is that the alloy fork crown bent. I was impressed that the carbon was unaffected. I haven't looked too closely at the wheel but it seems fine and the frame is good.
    Given 250 lbs. of bike and rider piling into a tree at speed I'm pretty damn pleased with the end result. Chalk one up for the Pro carbon fork. It inspired enough confidence that I plan to buy an identical fork to replace this one. The old fork is going to get built into a truing stand.
    I just pulled the bike down to start getting it ready for this season, so I figured I'd post some pics.
    Attached Thumbnails Attached Thumbnails Carbon fork crash carnage calamity-p3210001.jpg
    Full Tilt Boogie
    May 2005
    That is pretty impressive. Not where you'd expect it to fail first.
    I sell bikes here. Check out the Blog here. Facebook.
    Stayin' Puft
    Reputation: canyonrat's Avatar
    I don't know what is funnier, the pictures or the fact that you did that to your bike and just left it for 6 months.
    No story about you so glad you must be ok.
    Reputation: kosayno's Avatar
    You knew the brake was already failing and still rode the bike in the worst conditions possible? Looks like the fork hasn't completely failed. If you were to turn it 180 it would have a nice offset and good trail figures. Could probably squeeze another 6 months out of it too.
    Slow But Still Pedaling
    Reputation: JimInSF's Avatar
    Oct 2010
    Wonder what would have happened if you'd had a carbon crown...
    is buachail foighneach me
    Reputation: sean salach's Avatar
    Damn. That's a pretty good endorsement for that fork. Glad you came out of it unscathed.
    Reputation: hootsmon's Avatar
    Glad you're OK...
    but that fork's gonna ride all wonky now.
    Brisbane, AU
    M_S
    M_S is offline
    Nov 2007
    "carbon cracks on impact"
    "aluminum snaps it doesn't bend"
    This one might throw the mtbr materials "experts" through a loop.
    - Simon
    Probably wouldn't have crashed if you were riding with a seat anyway.
    M_S
    M_S is offline
    Nov 2007
    Also just flip it around for that high rake, G2+ handling.
    - Simon
    nothing to see here
    Reputation: Stevob's Avatar
    Lesson learned. Brakes are good things to maintain properly.
    I see hills.
    I want to climb them.
    ride more
    Holy crap ! I can't believe your wheel is still round, that looks like a big impact.
    Reputation: Midgetman's Avatar
    Riding without a working rear brake and without a saddle - that's what I call tough.
    Thumbs Up!
    Reputation: J Ro's Avatar
    Crazy, please tell me what rim? That's pretty impressive it did not ovalize on impact.
    "Everyone has a plan 'till they get punched in the mouth"
    Mike Tyson
    Moderator Moderator
    Reputation: driver bob's Avatar
    That will buff right out with a little effort
    Reputation: ianick's Avatar
    Story not accepted. Looks like a JRA incident to me.
    Juvenile Rheumatoid Arthritis?
    Delirious Tuck
    Reputation: thefriar's Avatar
    Wow! Impressive result, not what I was expecting when I opened thread.
    Professional Crastinator
    Reputation: Fleas's Avatar
    So not even so much as a smooch of tree bark? Catch your seat in a bad spot? (I almost got stabbed in the femoral artery when mine broke off the rails) Glad you came out OK.
    I guess if you do some kind of armchair crash analysis the failing fork probably resulted in the least potential of injury to the rider. If the wheel had folded, he'd have likely gone head/collarbone-first down into the tree with his center of mass lined up with the point of impact. If the frame (headtube junction/downtube) had failed, he would have been out one bike AND the fork would have probably been tweaked. Plus, forks are easy to replace, and not crazy expensive. I'd say you got your $$$'s worth out of that one. Where do I get one?
    I know a few 4x4 guys who have their drive lines and axles all beefed up, but use standard locking hubs. The hubs are the most likely part to fail - intentionally, like an electrical fuse. They are also the easiest to replace and you can still roll even when broken. A broken axle, driveshaft, or gear usually renders you immobile (at least less-mobile), and might break something else when it goes.
    -F
    PS - order some brakes
    get down!
    Reputation: appleSSeed's Avatar
    That's cool, thanks for sharing..pretty scary when you hit a part, going fast, and can't stop. I remember preriding a race somewhere and hit some slick rock(from water/mud) going downhill and couldn't stop and flew off the bike a good couple hundred feet. I think I broke my collarbone, but never got it fixed.
    Rudy Projects look ridiculous
    visit my blog, BEATS, BIKES & LIFE
    Its got what plants crave
    Reputation: Jim311's Avatar
    Feb 2006
    Just bend it back and ride on man. ****'ll buff out.
    Ocala Mountain Bike Association - www.omba.org
    Powered by ice cream.
    Reputation: Enel's Avatar
    Awesome. Check your frame carefully.
    saddlemeat
    Reputation: bsieb's Avatar
    Aug 2003
    That crown must be pretty soft if nothing else broke or bent.
    I ride with the best dogs.
    Glad you're ok!
    Definitely check the headtube for ovalisation, as it appears the steer tube bent as well. Hopefully it just messed up the headset cups and/or bearings. I'd get the headtube refaced and reamed just to be sure.
    Freelance Whatever
    Reputation: chowdownca's Avatar
    I guess "braced for impact" means a$$-puckered so tight that it ripped the seat off when impact was achieved.
    What I do for a living doesn't define me....
    Trail Junkie
    Reputation: dubdryver's Avatar
    Mar 2006
    Hmm...and people still worry about carbon. Seems like Carbon 1, Aluminum 0 in that battle.
    I don't think I would have rode w/ a back brake that was failing..front maybe, but highly unlikely. Just glad you weren't seriously injured!
    Ibis Ripley LS
    Intense Spider 29 C
    Cervelo S2
    Trek Boone 5 Disc
    Spech Tricross Expert
    Raleigh RX 1.0
    @adelorenzo
    The reason I haven't touched the bike is that I've been riding my Pugsley since that crash. It's still snow-biking here until mid-April. The only thing I did do was steal the Chromag seat to ride on this winter, planning to put a new one on that bike.
    Yeah, riding without a brake is dumb but one of those things. It was going, going, but still a little bit left and I kept telling myself it was the "last ride." Well, the "last ride" kept being one more ride, until it really was the last ride.
    The rim is an Equalizer. I loved those rims, but they aren't the best for tubeless riding so I have a new set of Stan's rims sitting in my garage waiting to be laced up.
    I'll definitely check the frame and headset closely when I take it apart but my initial inspection it looks good.
    As for me, I saw the hit coming so I had my weight shifted back with my feet braced on the pedals. I hit my arm on a tree but nothing major.
