Results 1 to 6 of 6
    Jan 2018
    Canyon Neuron AL 9.0 SL vs Scott Spark 930
    Hi guys,
    I consider buying a new bike.
    Considering both are the same price, which one would you choose ?
    I must say that the spark would be equipped exactly like the CANYON regarding the cranks (cranks Sram Eagle GX 12v)
    Same price same cranks.
    Here are the specs:
    SCOTT SPARK 930:
    • FRAME
      Spark 3 Alloy SL 6011
    • custom butted Hydroformed tubes
    • tapered Headtube / BB92 / Boost 12x148mm
    • FORK
      FOX 34 Float Performance Air
    • Grip 3 / 3-Modes / 15x110mm QR axle / tapered steerer
    • Reb. Adj. / Lockout / 120mm travel
    • REAR SHOCK
      FOX NUDE EVOL Trunnion
    • SCOTT custom w. travel / geo adj.
    • 3 modes: Lockout - Traction Control -Descend
    • DPS / Reb. Adj. / Travel 120 - 85 - Lockout / 165X45mm
    • REMOTE SYSTEM
      SCOTT TwinLoc Remote Technology
    • 3 modes front and rear / integ. Grip clamp
    • HEADSET
      Syncros Pro Press Fit / Tapered 1.5" - 1 1/8"
    • OD 50/61mm / ID 44/55mm
    • REAR DERAILLEUR
      Shimano XT RD-M8000 SGS
    • DM / Shadow Plus / 22 Speed
    • FRONT DERAILLEUR
      Shimano XT FD-M8020-D / side swing
    • SHIFTERS
      Shimano XT SL-M8000-B-I / Rapidfire Plus
    • 2 way releaseIspec 2 clamp
    • BRAKES
      Shimano SLX M7000 Disc
    • 180/F and 160/R mm SM-RT64 CL Rotor
    • CRANKSET
      Shimano XT FC-M8000-B2 / Hollowtech 2
    • 34x24 T
    • BB-SET
      Shimano BB-MT500-PA / shell 41x92mm
    • HANDLEBAR
      Syncros FL2.0 T-Bar / Alloy 6061
    • T shape Flat / 9 / 740mm
    • Syncros Pro lock-on grips
    • H'STEM
      Syncros FL2.0 / 6061 Alloy
    • 6 / integrated Top Cup / 31.8mm / 1 1/8"
    • SEATPOST
      FOX Transfer Dropper Remote
    • 31.6mm / S size 100mm / M, L & XL 125mm
    • SEAT
      Syncros XR2.0 / CROM rails
    • WHEELSET
      Syncros XR2.5 CL
    • F: 15x110mm, R: 12 x 148mm Boost
    • 25mm Tubless ready rim 28H
    • CHAIN
      Shimano CN-HG601
    • CASSETTE
      Shimano SLX CS-M7000 / 11-42 T
    • TIRES
      Maxxis Forekaster / 2.35 / 120TPI Kevlar Bead
    • TR Tubeless Ready / EXO / 3C maxx Speed
    • APPROX WEIGHTS IN KG
      13.80
    CANYON 9.0 AL
    • FRAME CANYON NEURON AL
    • REAR SHOCK FOX FACTORY KASHIMA FLOAT DPS LV
    • FORK FOX FACTORY 34 FLOAT KASHIMA
    • HEADSET CANYON | ACROS
    • REAR DERAILLEUR SRAM X01 EAGLE, 12S
    • DERAILLEUR HANGER DERAILLEUR HANGER NO. 26
    • SHIFTERS SRAM X01 EAGLE TRIGGER, 12S
    • BRAKES SRAM GUIDE R
    • CASSETTE SRAM XG-1295 EAGLE, 12S
    • WHEELSET MAVIC XA ELITE
    • TYRES SCHWALBE NOBBY NIC ADDIX SPEEDGRIP
    • CRANKS SRAM X1 EAGLE CARBON, 12S
    • CHAINRINGS 30
    • CHAIN SRAM XO1 EAGLE
    • BOTTOM BRACKET SRAM GXP PRESSFIT
    • STEM CANYON V14
    • HANDLEBAR CANYON H21 FLAT CF
    • GRIPS ERGON GA30
    • SADDLE FIZIK TUNDRA 2 MG
    • SEAT POST ROCKSHOX REVERB STEALTH B1
    • SADDLE CLAMP CANYON CLAMP SL
    • FRAME SIZES XS (27,5"), S (27,5"), M, L, XL
    • COLOUR STEALTH | FLASH BLUE
    • WEIGHT 12,5 KG (SIZE M )
    Apr 2018
    I think that you just confused Scott's model, it's a Spark 940.
    I'm in exactly the same dilemma, between a Spark or Neuron. The only detail that draws me closer to Scott is the head tube angle 67.2 vs 69.3, because on the equipment(suspension, seat, weels, transmission), the Canyon wins easily.
    Jan 2018
    I double checked and I'm pretty sure I did not make any mistake. The description is for the 930, not the 940.
    Anyways, I went for the Spark 930 (the wait for the Canyon was way too long for the XL size !). As you said, regarding the equipment, Canyon handily wins the contest !
    So far so good.
    I switched the group set from a 2x11 shimano xt to a Sram EAGLE GX 12 speed group with a sunrace cassette.
    Attached Thumbnails Attached Thumbnails Canyon Neuron AL 9.0 SL vs Scott Spark 930-img_2080.jpg
    Apr 2018
    You're absolutely right, it's really the Spark 930. My mistake. Beautiful bike, congratulations.
    As I can wait, I am still very doubtful of which to choose. Spark's geometry is indecent, and attracts me too much. But in my case I will buy it in Portugal, and the difference between Scott and Canyon is literally 1000 euros.
    If time was not a problem, would you choose Canyon?
    Apr 2018
    1000 euros if you compare the same components, like Canyon 8 vs Spark 940.
    Quote Originally Posted by cleitondomazak View Post
    Jan 2018
    I faced the same deal here in Europe. If you are a bit of a handy-man, I would go for the Canyon. The difference between the price and the equipment is pretty huge... No regret with the Scott, but the look and the components of the Canyon Neuron 8/9 makes it a beautiful bike also !
    Tough choice to make. But anyhow, both are very nice for middle range bikes.
  1. Need help rear hub scott spark 930!
    By chippedgti in forum Scott Sports
    Last Post: 07-28-2015, 08:52 AM
  2. Replies: 4
    Last Post: 10-28-2014, 08:17 PM
  3. Scott spark 950 vs Scott spark 29 elite
    By Davidg531 in forum 29er Bikes
    Last Post: 09-17-2014, 08:24 PM
  4. Would you buy the Scott Spark 930 or Genius 930
    By lacofdfireman in forum 29er Bikes
    Last Post: 03-21-2014, 01:31 PM
  5. Scott Spark 930 2013 - L or XL ?
    By z3n0mal4 in forum Scott Sports
    Last Post: 01-06-2014, 07:22 PM
Members who have read this thread: 38
