Results 1 to 8 of 8
    Cannondale Flash Carbon 29er 1 vs 29er 2
    I do not know much about the ballistic high mod carbon in the 1 vs ballistic carbon in the 2.
    The 1 is spec'd with XO, where the 2 is spec'd with x9.
    The 1 has the hollowgram, the 2 has the FSA SLK cranks
    The 1 has better spokes, hubs.
    The 1 is over $1000 more than the 2.
    Price aside, can you compare these for me, so I can make a good decision.
    What are opinions on resale value, after 1 year of riding on each?
    Any Idea on the weights of each?
    Older & Slower
    From what I understand...that $1,000 will get u some really nice stuff. But, the weight difference may not be that much at those levels. I think the hi mod is under 100 grams lighter. If u have the money, go for it. If money is tight, you'd be happy with the cheaper one. Part of the $ u save can go to an upgrade.
    Jan 2009
    The 1 has the most perfect of builds...
    XO, SI, Arch/ 240/ Aerolite....perfect build. No reason to upgrade anything on the 1.
    Reputation: brentos's Avatar
    @ $1,650 less than the HiMod 1. The 2 is by far the better value. It likely comes within 1 lb of the Flash 1.
    The best value overall though was last years Carbon 1.
    Moderator Moderator
    Reputation: driver bob's Avatar
    Quote Originally Posted by brentos
    x2. It's a lot of extra $$$ for not a lot of weight saving. I looked at both before ordering the 2.
    If there had been a Flash 29er Ultimate with full XX they might have suckered me into spending the extra.
    Jun 2010
    I just ordered the 2. I had the same debate between the 2 and 3.
    Anyone have any knowledge on the Hi modulus carbon of the 1, vs the "regular" carbon of the two?
    I have read that high modulus may be more fragile. True?
    Let's get some weights up! anyone with a 1, or a 2, let's compare!
    It's an odd scenario... I am in a position where I have never ridden a 29er, but will be riding/racing a Flash carbon 29er for 2011.
    I am a gear junky for sure, and like having the best models, but am nervous about a hardtail 29er after racing for years on a 4 and 4.
    Do I get the carbon 29er 1... or do I spend more, and get the carbon 29er 2, and a RZ120 2, to have a "fun bike"
    I am do not huck, or do any major drops, but I do like to ride hard.
    Feb 2010
    Number one all the way.
    Better,
    Cranks
    wheels
    brakes
    Lefty fork
    It's a no brainer.
