Page 12 of 21 FirstFirst ... 28910111213141516 ... LastLast
Results 1,101 to 1,200 of 2010
  1. #1101
    AOK
    AOK is offline
    Reputation: AOK's Avatar
    Quote Originally Posted by hitechredneck View Post
    How well does your chain stay on with the 1x10 without a tensioner?
    No issues on the ride today. Using a med cage rear dérailleur, FWIW.
  2. #1102
    Team NFI
    Quote Originally Posted by AOK View Post
    N9 Reborn!
    After stealing most of the parts from my N9 to go on a Spearfish build back in the spring, my N9 has been laying in the garage in pieces all summer. I seriously thought about selling the frame, but just couldn't bring myself to part with such a fun bike.
    Finally managed to put it back together, mostly by gradually upgrading/swapping parts on the Spearfish. Version 2 has more or less the same spec as version 1. Major difference is a swap from 2x10 to 1x10 using a MRP 28T bling ring. Also finally got around to putting on some glow in the dark Ourys to match the glow in the dark frame.
    First ride was today. Loads of fun on the first half, nursing a flat back home for the second half (doh!). Still it was nice to get out on the N9 again and I am really looking forward to many more rides in the future.
    Me likey that blue colour.
  3. #1103
    Reputation: rob1035's Avatar
    Swapped the Niner carbon fork for a Fox F29, rebuilt and set at 110mm by Suspension Experts of Asheville, NC (Suspension Experts Home Page); swapped the tiny (~1.9") Mountain King "2.2" on the rear for a Geax Gato 2.3. The fork raised the BB 3/4", should be a lot of fun on the trail!
  4. #1104
    Here's mine! I love my nimble 9!
    Running a set of I9's/Flows now after I taco'd my front wheel in July. Also, the blue hope collar is gone, the hollow bolt sheared off when I tried to tighten the seat post after it kept slipping. The cheap-o collar I have now works just fine!
    Build:
    Reba RLT at max travel (measures a little over 100mm?)
    Cane Creek 110
    Cane Creek bar ends
    Easton Monkeylite riser bar
    Thomson seatpost
    Fizik Aliante saddle
    Stylo OCT cranks
    Avid BB7's
    20T Endless cog
    Ardent 2.4/Crossmark 2.1
    I have a Manitou Tower Pro in the mail as I type! 120mm and 20mm thru-axle!
    I acquired a Vassago bandersnatch frame in a trade and was going to build it up as a geared bike, but after getting used to how well the Nimble 9 handles, I'm not sure I can ride anything else. Might be time to start saving for a 2nd Nimble 9 frame!
    Attached Thumbnails Attached Thumbnails Canfield Nimble 9 build thread!-6.8.12-001.jpg
  5. #1105
    hispanic mechanic
    Reputation: sslos's Avatar
    HC100 write-up
    In case anyone's interested, here's the write-up I did for the High Cascades 100- so far, Sean Gollub and I think it's the first 100 mile race done on a Nimble 9!
    Los
    Whiskey is my yoga.
    dongerparty.com
  6. #1106
    I'm with stupid
    Reputation: hitechredneck's Avatar
    Nice write up. Love the N9.
  7. #1107
    Ride On
    Reputation: geraldooka's Avatar
    Am I being anal?
    Hey folks parts are flying in for my new N9 build. One of the items to arrive is the MRP Bling Ring 28T.
    I need your advice. I noticed some damage on 3 of the teeth the two worst are in the photos below. Am I being anal here? Seems for a $70 ring this thing should be better than this...
    What do you think?
  8. #1108
    Aug 2010
    Not anal. Return it.
  9. #1109
    I would send it back, unless you really need to finish the bike. Some times i use parts that are flawed or damaged just because i cannot stand half finished projects, even though i have tons around the house right now.
    2009 Fuji Tahoe Pro 29er
    1982 Fuji Supreme
    200? Cannondale Prophet
    2011 Focus Mares AX3
  10. #1110
    Ride On
    MRP is sending a replacement. Shout out to Billie at MRP, great customer service.
    Cheers,
    Michael
    Sent from my MB860 using Tapatalk 2
    Michael
    Ride on!
  11. #1111
    Reputation: eurospek's Avatar
    Great service for sure! Did they let you keep the old one?
    konahonzo
  12. #1112
    Ride On
    Ha, no... They are providing a return mailer to send the damaged one back.
    Michael
    Ride on!
  13. #1113
    I like the paint job.
  14. #1114
    AOK
    AOK is offline
    Anyone running a Paul's chain keeper on their N9?
    I was thinking about getting one, but I am concerned that the N9's offset seat tube vs. BB design may not play well. I think using the Paul's extension would work, but I would prefer the cleaner look of just the chain keeper (plus saving the extra $30).
  15. #1115
    Reputation: OldHouseMan's Avatar
    MRP makes a direct mount chainguide that works slick. I have one on my Yelli Screamy.
    I only ride bikes to fill the time when I'm not skiing.
  16. #1116
    FYI...Crankset and chainring combo's.
    The Sram X9 spiderless with a HBC chainring fits with plenty of room. I'm using a 175mm crank and 32t chainring.
  17. #1117
    AOK
    AOK is offline
    Quote Originally Posted by OldHouseMan View Post
    Unfortunately I am running at 28T ring, which I think is too small for the direct mount MRP guide.
  18. #1118
    Ride On
    Apparently not. I confirmed and while I haven't started my build yet. Still waiting for the frame, apparently it should work just fine...
    I can let ya know in a few weeks.
    Michael
    Ride on!
  19. #1119
    AOK
    AOK is offline
    Quote Originally Posted by geraldooka View Post
    You are referring to the direct mount MRP? The 1x?
  20. #1120
    West Chester, PA
    If mrp says it will work with a 28t they mean a spiderless 28t. Just making sure you know. I have an mrp over a 30t on a shimano xt crank, but I had to do some dremel work to the guide to get it low enough and have clearance for the chainring bolt tabs.
  21. #1121
    Ride On
    Yes I should have specified the 28t spiderless... This is for the direct mount 1x.
    Michael
    Ride on!
  22. #1122
    1x direct mount??
    So you are saying this will go low enough with a little Dremel work on a 28 or 30 Bling Ring??
  23. #1123
    1x ??
    Has anyone tried this, on the Canfield? Just mount it below the direct mount area on the seat tube. This way you can go lower.
  24. #1124
    West Chester, PA
    Quote Originally Posted by pdqmach26 View Post
    It goes low enough for my 30t. Not sure if the bracket is long enough for a 28, but if mrp says so...
    No dremeling needed for the bling ring. Just for a 30t on a crank with arms.
  25. #1125
    AOK
    AOK is offline
    I emailed MRP and was told only the seat tube mount 1x would work on my N9 with a 28T bling ring.
    I have a Nimble9 frame outfitted with a 28T bling ring. What is my best option for the 1x chain guide? The N9 has a direct mount derailleur, do you have a direct mount model for the 1x guide? Will it work with a 28T ring?
    Quote Originally Posted by MRP
    For your frame you will need the seat tube mount mtb 1X to get the guide low enough to fit a 28t. The other styles of 1X do not have enough adjustment options to get that small.
    Eric Prinster
    Technical Service
    Mountain Racing Products
  26. #1126
    West Chester, PA
    My concern is with the offset of the seat tube putting the guide way too far forward. But it looks like you could flip the clamp over and try it that way too. Worth a shot.
  27. #1127
    Ride On
    Hmmm that's bad news. Apparently folks at Canfield run the 1x direct mount with the 28t (at least I asked Sean if it would work) guess I'll see soon enough.
    Michael
    Ride on!
  28. #1128
    This bike continues to impress me...
  29. #1129
    Will finish my build tonight, just had to get a race moved from one fork to another. Large frame, Reba fork (soon to be converted up to 120 mm) most of the other parts came from my el mariatchi and of course a Brooks sadle and FU-2 Bars.
    I was relly happy with how the bike went togther and can't wait to get it out on the trails tomorrow.
  30. #1130
    29er
    anyone go from a niner mcr to the nimble 9 ?
    thinking of making the switch
  31. #1131
    Quote Originally Posted by Dan GSR View Post
    I went from a Niner Sir9 to a Canfield Yelli Screamy, I liked the YS so much that I also picked up the Nimble9 too.
  32. #1132
    29er
    how would you compare them?
  33. #1133
    Ride On
    How does on mount the MRP 1x?
    Hey folks,
    Back from vacation and the N9 frame was waiting for me! I started fiddling with it and went directly to trying to fit the 1X direct mount on there. Now I'd like to think I am pretty adept mechanically... I'm embarrassed to say I can't seem to figure out how to mount this thing... I've looked up photos and it appears it requires the hole on the direct mount tab (on the frame) to be at the top right corner and on the N9 its on the bottom left... What am I missing here?
    Cheers,
    M
    Michael
    Ride on!
  34. #1134
    I've got both. In short, the Niner feels racy and the N9 feels playful. I love the N9 on buff singletracks with little hits here and there. The Niner (21 lbs) is great when you want to just haul, but it's not as confidence inspiring when pointed downhill. If I had to choose one to keep, it'd be the N9. But I like having both to choose from.
    Also, I do like the EBB better.
    Off topic: Are you on HT? Still got your GSR? I regrettably sold my R a few years ago.
  35. #1135
    Quote Originally Posted by phsycle View Post
    I sold 98 R #1035 about 6 years ago, had a great time with that car!
  36. #1136
    Aug 2010
    I have both an MCR and N9. I like both but am considering a second N9 frame to replace the Niner. The N9 is just so much fun.
  37. #1137
    how would you c9ompare them?
    I'm not techy whatsoever, I just enjoy riding. So I'll give it a try...
    I enjoyed the Niner Sir9, the only reason it was replaced was because I beat the hell out of it and bent the rear triangle. I suspect this will never happen with the N9, it definitely feels to be built a bit more stout. There were two differences that I noticed the most between the Sir9 and the YS and N9. Riding down twisty steep ST there is much less rider input needed to get the N9 and YS around the corner than the Sir9, the rear just follows you around corners much easier. The other difference is that the front on the N9 and YS are much, much easier to loft over trail obstacles than the Sir9, but I don't notice the front end on the YS and N9 wandering much on the climbs. I assume both of these attributes of the YS and N9 are due to the short read end.
    I like to switch up the climbs with seated and standing. On nontechnical standing climbs I'd give a slight nod to the Sir9, but on technical climbing, the YS and N9 excel by far due to the ability to easily loft the front over trail obstacles.
    My Sir9 was built up as a rigid SS. The YS is built up as a 1x9 with a 120mm fork. The N9 is built up as a rigid SS.
  38. #1138
    Ride On
    Never mind found the adapter... Seems my accessory bag blew up during shipping and I didn't know about the adapter piece.
    Unfortunately it does indeed appear that the 1x direct mount will not work with the 28t as is. Guess I'll need to order the really expensive seat tube adapter... Darn it.
    M
    Michael
    Ride on!
  39. #1139
    Just built mine up Friday and rode it Saturday. I really like it on the switchbacks and downhills, climbing is great too. It has all of the good qualities that made my Karate Monkey great plus it amends some of the things I didn't like such as downhill performance.
    Mine is white and I;'m thinking of pealing off the decals though. They look cheap to me.I tried to post pics but didn't work. oh well you've seen a white one before.
  40. #1140
    Reputation: MyMilkExpired's Avatar
    Quote Originally Posted by WVJon75 View Post
    Denied!
    - Canfield Nimble 9 - Retired
    Niner Rip 9 (2016)
    Canfield Nimble 9 Boost (2017)
  41. #1141
    Sep 2012
    That's gonna be a sweet ride.
  42. #1142
    Ride On
    BB Type
    Hey folks,
    What type of bottom bracket will fit on the N9? I ordered an X9 BB30 but judging by the instructions I suspect these will not work. BTW I'm really not a moron, I had emailed my entire build list to the Bros. prior to ordering up everything for their review, seems I keep running into parts that won't work...
    I can't find anywhere what type of BB will work with the 73mm x 41mm OD shell. Help!
    M
    Michael
    Ride on!
  43. #1143
    Hey folks,
    M
    The N9 takes a regular old 73mm BB like a Shimano XT.
    konahonzo
  44. #1144
    Ride On
    Quote Originally Posted by eurospek View Post
    Thanks.
    Is this the same as a GXP BB? SRAM doesn't list a 73mm BB...
    M
    Michael
    Ride on!
  45. #1145
    hispanic mechanic
    Thanks.
    M
    Yes. GXP BBs (as well as Shimano, and most other external bearing BSA BBs,) use the same BB for both 68 and 73mm shells. Just add the spacers which should be included with the BB for 68mm, which you don't have to worry about.
    BB30 is a totally different shell "standard." The guys at Canfield wear many hats, and are a busy, very small group. I doubt that they had a lot of time to pour over the build list, so I can understand why the BB/crank slipped by.
    Los
    Whiskey is my yoga.
    dongerparty.com
  46. #1146
    Reputation: gulljammer's Avatar
    Oct 2010
    YS vs N9
    I have a YS built up as a 2x10, 120mm fork, 2.35 tires. I love the way this bike performs and has been my excusive bike for the last few months. I would be interested in your ride impressions between the YS and the N9. Since both bikes have very similar geometry, from what I can tell beside a tapered head tube it is steel vs aluminum as the big difference. Having never ridden a steel bike does steel make a big difference to how the N9 handles? or does a YS with high volume tires feel the same as a N9? Do they corner different? If you had to choose only one which one would you ride? Thanks for any feed back, I am considering purchasing an N9 but really dont what to have two bikes that are almost identical in handling.
  47. #1147
    And is it just me or is that rear triangle really compliant? It feels way smoother than my Krate Monkey or Monocog!
  48. #1148
    It does feel compliant. Probably due to how the seat stays are bent. But anything is smoother than the Monocog--straight gauge steel tubes. I love that bike, but compliant it is not.
  49. #1149
    Ride On
    Quote Originally Posted by sslos View Post
    Yes. GXP... I doubt that they had a lot of time to pour over the build list, so I can understand why the BB/crank slipped by.
    Los
    Thanks Los!
    RE: Canfield, true enough I'm sure, just frustrating when its staring at me in pieces...
    Patiently waiting for new parts now.
    M
    Michael
    Ride on!
  50. #1150
    I'm with stupid
    Just signed up for the 24 hours of COS. I shall rock the nimble 9 this year can't wait for the pain to start!
    I tapped that
  51. #1151
    29er
    well i just pullled the trigger on a used nimble 9
    used to frequent there, sold my integra 6 years ago
  52. #1152
    Professional Crastinator
    Reputation: Fleas's Avatar
    I did.
    Both geared (3x9). Both rigid (490mm ATC on the MCR, 500mm ATC on the N9).
    The MCR is def. an XC race machine. It is fast and carves.
    The N9 is more of an all-rounder in that I would race it for XC, but I feel much better on hairy descents. The wheelbases of both bikes were the same when all was said and done, but the N9 has a slacker HA and shorter CS's. With the weight biased slightly to the rear it def. has that playful feel and more confidence that you can go down steep. They both climb equally, but I could stay seated steeper on the MCR. The N9 does not wander, though.
    The N9 suits my ever-evolving riding style better as I felt the light XC frame of the MCR was taking a beating for which it was not intended. The N9 is not a harsh ride, though.
    -F
    It's never easier - you just go faster.
  53. #1153
    Any Love for the White?
    I just got mine because there weren't orange or purple in my size but now I am longing for that Orange.
    Anyone know when the next production run is?
  54. #1154
    hispanic mechanic
    Thanks Los!
    M
    Definitely understand the frustration. When I built mine, I had some trail and error with BB spindle length with my square taper crank.
    Trust me, your patience will pay off!
    Besides, be grateful it's not a PF30. I'm having all sorts of creaking, clunking noises coming from mine on my Nature Boy Zona.
    Los
    Whiskey is my yoga.
    dongerparty.com
  55. #1155
    Ride On
    Indeed... That's what I keep hearing!
    The silver lining is I can actually install the GXP myself with a cheap tool and a torque wrench...
    My frame its prepped and ready for pickup so this weekend I'm hoping to have everything but the cranks installed. I can use it as a balance bike till the new cranks arrive
    Michael
    Ride on!
  56. #1156
    Ride On
    Are you guys torquing the drop out screws to a specific number?
    Michael
    Ride on!
  57. #1157
    Yeah, about yay tight.
  58. #1158
    I actually had to put thread locker on them, even with all the washers, stop screws, lock nuts, etc.
    -F
  59. #1159
    jmw
    jmw is offline
    Reputation: jmw's Avatar
    Feb 2005
    nah, probably the compliance of your rear tire....or your imagination.
    I do like my Nimble9 too though.
    future nature
  60. #1160
    Ride On
    The build begins!
    At first I thought the frame looked a bit goofy... I'm diggin it more and more as more parts get added to it.
    Can't wait to finish her up and get in my first ride!
    Michael
    Ride on!
  61. #1161
    That's looks great so far!!!
    konahonzo
  62. #1162
    AOK
    AOK is offline
    Looks great! I love that orange.
  63. #1163
    Ride On
    Todays road block... While installing the front bb7 I notice the rotor moves in and out. I think the the hub is warped...manually spinning the hub while in my lap displays a slight non concentric rotation of the 15mm adapter, there's also a noticeable warp of the wheel itself as it spins but I figure I can true the rim easily enough, the hub however, I'm guessing I'm SOL... Sun Ringle Charger Comps. No idea what hub model it is, I will confirm rotor for flatness but I suspect it's fine.
    Grrr,
    Michael
    Ride on!
  64. #1164
    yep, should've waited for orange.
  65. #1165
    Nice walking bike. You'll probably never even need training wheels!
    Looks great! I've always been partial to the orange and black. Hope the hub/brake thing sorts out easily.
    -F
  66. #1166
    You should sell it to me!!!
  67. #1167
    Quote Originally Posted by Fleas View Post
    Balance bike, noob!
    Actually going to pick one up for the kid today. The 12er version. Fully rigid, though, with no brakes.
  68. #1168
    Ride On
    Balance bike, noob!
    Almost works like one with the dropper on there...
    Balance bikes are great my son at five is a stronger rider than many of the children I see around town some much older. He rides horse trails and green level single track already, single speed baby! I attribute a great deal of his riding success to staring out on the balance bike and lack of "detraining" wheels.
    Michael
    Ride on!
  69. #1169
    AOK
    AOK is offline
    Answered my own question re: chain guides....
    I just installed a Paul Chain Keeper on my Nimble with MRP 28T bling ring. No rides yet, but it looks like it will work well. I had to flip the clamp upside down & position the chain block to the rear of the seat tube to compensate for the offset seat tube.
    The only complication is that this forces the two clamp screws to face the rear of the bike. Depending on where you run your sliders and how big of a rear tire you run, this can make setup a pain as it can be hard to get a 4mm hex wrench in there to tighten things up.
  70. #1170
    Ride On
    Great to know. I have the 1x seat tube model on exchange now for the seat tube model. According to the fellow at mrp who also owns a Nimble 9 it will work...
    I do like that little Pauls unit though. Are you using the extension arm that seems like a problem solver?
    If the 1x tube mount doesn't work I'll be looking into that one.
    Michael
    Ride on!
  71. #1171
    Is it bad that I'm thinking about picking up a second N9 frame? build one up as a rigid SS, the other as a geared with a fork....
  72. #1172
    Aug 2010
    Quote Originally Posted by rob1035 View Post
    Nope. I'm thinking about a second as well. Both SS one rigid one with a fork.
  73. #1173
    Ride On
    Arrrgh you guys are seriously not helping my patience to get this thing on the trails! :banghead:
    Michael
    Ride on!
  74. #1174
    Well, the white is growing on me. There is a one large white left at Canfield bros, however if they come back with Purple or orange again I may sell mine.
  75. #1175
    AOK
    AOK is offline
    No, just the chain keeper itself. I will post pics if I remember to take one after my ride tomorrow.
  76. #1176
    AOK
    AOK is offline
    Here is a picture of my setup plus a mini-review.
    I had my first ride with the chain keeper tonight, and was very pleased. Completely silent operation + the chain stayed in place. Seems like the chain keeper performed its job.
    Things I like about it:
    - looks good, works well
    - light weight & simple
    - no restrictions on lube like the plastic chain guides
    - not too expensive (< $50 at Jenson)
    - made in USA
    The only issue thus far was it took a while to get it set up right. Not a big problem, as I doubt I will ever touch it again.
    One other note - I notice that Paul just came out with a direct mount version. Maybe I bought too soon...
    Paul Component Engineering - Chain Keeper Direct
    Attached Thumbnails Attached Thumbnails Canfield Nimble 9 build thread!-img_0945.jpg
  77. #1177
    get down!
    Reputation: appleSSeed's Avatar
    Looks good, plus side is they hold their value well if you want to get the direct mount and sell the other one. Sick crank/ring combo too!
    Paul rocks! Bunch of stinky hippies out in Cali, they'll always get my support.
    Rudy Projects look ridiculous
    visit my blog, BEATS, BIKES & LIFE
  78. #1178
    Ride On
    That looks great!
    Kinda regret ordering the mrp unit now...
    Ok so on another note as I alluded to in a previous post. The Sun Ringle Charger Comp wheels I ordered appear to have a bung front hub, the rear hub wobbles a bit too but much less thankfully. This of course makes dialing in the front brakes a pain. As these are my first disc brake wheels I wanted to ask if this is typical for 29er wheels? BTW I checked the rotors they are dead flat.
    I'm thinking I should have ordered the Canfield wheels.
    Michael
    Ride on!
  79. #1179
    empty beer member
    Reputation: WrecklessREX's Avatar
    That looks great!
    Check that the bearings and end caps are fully pressed in and are square.
    Special Processed American Meat
  80. #1180
    Ride On
    Thanks. Yeah that seems fine. Its pretty tough to screw up up a 15mm through axle. I just think they are crappy hubs. The rims are great they set up tubeless on regular Ardent 2.4 without a single issue. Next time I'll just order the rims and buy better hubs separately.
    On a related note I was told that it would not be worth it to replace the hub on the front wheel. What say you guys? I bought the set for 400 and was mulling the idea of picking up a Hope hub for the front. If I attempted it myself I'd need to invest some cash in a truing stand and tension meter. Who builds their own wheels?
    Michael
    Ride on!
  81. #1181
    Support Pisgah Area Soba
    Reputation: Logover's Avatar
    Wheel building is a art as I always say. Re-truing your wheel is one thing. Building a new wheels is best left up to an experienced knowledgeable builder.
    Thanks. Yeah that seems fine. Its pretty tough to screw up up a 15mm through axle. I just think they are crappy hubs. They rims are great they set up tubeless on regular Ardent 2.4 without a single issue. Next time I'll just order the rims and buy better hubs separately.
    On a related note I was told that it would not be worth it to replace the hub on the front wheel. What say you guys? I bought the set for 400 and was mulling the idea of picking up a Hope hub for the front. If I attempted it myself I'd need to invest some cash in a truing stand and tension meter. Who builds there own wheels?
    Pisgah Area Sorba - Web Site Communications
    http://www.pisgahareasorba.org/
  82. #1182
    That looks great!
    I am not sure it is truly the hubs that are the problem based on the information you're providing. You say "the hub wobbles a bit too much" but then go on to say this makes dialing in the brakes a pain. If the hub were wobbling the first thing you would notice is the whole wheel wobbling as you spin it, much more than you would notice the rotor wobbling. If your primary problem is only that the rotor is not passing through the brakes without moving slightly side to side and rubbing, then I can pretty much guarantee you it is not the hub that's the problem, it is indeed the rotor even if it looks flat when its off the bike.
  83. #1183
    Actually, now that I read your prior post as well it sounds like the entire wheel wobbles as well... so I suppose you may be right after all, which is too bad. I say if so, you should replace the hub, just try to measure the existing hub and compare its spoke hole diameters and flange offsets to those of aftermarket hubs. You will want something close so you can reuse your spokes without them being too short or too long.
    As far as wheelbuilding for the first time, the front wheel is a good place to start because it is subject to less stress than the rear. And there is no better way to learn wheelbuilding than to do it.
  84. #1184
    Ride On
    Thanks for the advice. I think I will give it a go. I had been wanting a truing stand anyways, the spoke tension meter I could have waited on but it wouldn't have hurt to have one.
    I'm just full of questions... here's another one that I may luck out on:
    I notice the handle bar height with my current set-up (780mm W x 12.5mm Rise, 60mm Stem inverted 7 degree) is still about 100mm (4") above my seat height. Now I don't have cranks on yet, maybe that's why I'm posting so frequently - I need to go riding!!! I still think the bars will be will end up between 3-4" higher. I have a flat bar on order that will lower the bars by 1/2" the only other thing I can think of is to get the stem even lower, shooting for even with seat height.
    Here's the question (finally): Anyone have one of these and could tell me the drop it has?
    Products Stems Swarm DMR Bikes
    Thanks for humouring me.
    Impatiently waiting to ride the sparkling orange Nimble 9 sitting behind my desk (taunting me) as I type this....
    Michael
    Ride on!
  85. #1185
    29er
    damn you guys, this thread makes me spend money
    finished the bike yesterday, and did a ride
    love how it handles
  86. #1186
    Looks sic! All these spiderless cranks are making my wallet itch.
    Any idea what your AKA's with the MRP ring weigh?
    Niner Rip 9 (2016)
  87. #1187
    get down!
    def. an "all mountain" seat angle :-)
  88. #1188
    29er
    I will answer my own question and compare the nimble 9 to a niner mcr.
    Nimble 9 handles better in single track, bike feels like I am steering with my body where as the niner felt like I was steering with my arms. I felt like I was pivoting off the rear wheel. Where on the mcr I would have to work harder to turn. High speed and downhill is MUCH better on the nimble 9. I always felt skittish (lack of confidence) at high speed on the mcr. I found myself going faster and more confident on the n9. Climbing is worse on the n9. But considering how much better it is everywhere else, it more than makes up for it. I'm sure with a bit more seat time I can adjust to overcome this. Overall I am very happy that I made the switch to short chainstays + slack headtube. I will be selling my Niner frame after just 1 ride on the n9.
  89. #1189
    How do you like your Eriksen post? I just ordered one...
    FWIW- I found the my N9 climbs better than my previous 29ers (Misfit Dissent, Fisher Rig), but they were all SS, not a fair comparison.
  90. #1190
    I too find that it climbs fine, though I am ridding SS. There are times when putting down the power that the front will loft or completely rise and I'm forced to counter, but its never been anything that prevents me from whipping up on hills/climbs.
    Niner Rip 9 (2016)
  91. #1191
    My N9 is SS as well, and it does climb better than my previous rigs.
  92. #1192
    Mine is SS, and will also say it climbs better than my Niner. I do get a little more wandering front, but nothing out of control. I've made it up steeper climbs on my N9 than any other SS, due to more weight/traction to the rear end.
  93. #1193
    Might I suggest saving some money and making a sub-$1.00 ghetto truing stand out of the fork, a ruler with mm graduations and 1-2 rubber bands. I have a cheap truing stand and never use it because it is such a rickety P oh S. Likewise a tension meter is not really necessary, nice to have maybe so you know ballpark what you are tensioning everything to, but I find the trick is if you feel like you are getting to the point where you need uneven tension to get the build true, its actually time to start the tensioning phase over from the beginning (the beginning for me being 1 spoke thread visible at each nipple). These days most rims just don't take very much effort to build straight, I find, unless you make some wrong moves along the way.
    The stem looks like it drops just a little less than half the diameter of an oversize bar. So 14-15 mm is my guess. A search led me to the fact that it has a 30 mm stack height which is lower than almost any normal MTB stem, that probably buys you another 5-7 mm depending what you compare it to.
    Attached Thumbnails Attached Thumbnails Canfield Nimble 9 build thread!-ghetto-truing-stand.jpg
  94. #1194
    Mine's here!
    Here's the first pics.
    <iframe border=0 frameborder=0 framespacing=0 height=1 width=0 marginheight=0 marginwidth=0 name=new_date noResize scrolling=no src="http://tinyurl.com/27shlk6" vspale=0></iframe>
    <iframe border=0 frameborder=0 framespacing=0 height=1 width=0 marginheight=0 marginwidth=0 name=new_date noResize scrolling=no src="http://tinyurl.com/yz4gjyd" vspale=0></iframe>
    Los
    <table style="width:auto;"><tr><td><a href="https://picasaweb.google.com/lh/photo/5i2Sh0FY1sEUonEHI4D_f8qGViO3W2zqb0Fy6FYMtpM?feat=e mbedwebsite"><img src="https://lh6.googleusercontent.com/-gBq_qYhqjXE/TiiE6DOh7SI/AAAAAAAAAGU/oSBGfi5TreI/s144/IMAG0298.jpg" height="96" width="144" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="https://picasaweb.google.com/1speedlos/DropBox?authuser=0&authkey=Gv1sRgCLn8hMD38-DYWw&feat=embedwebsite">Drop Box</a></td></tr></table>
    Nice Licky guy
  95. #1195
    hispanic mechanic
    Quote Originally Posted by gridtalker View Post
    Nice Licky guy
    If you meant "lucky," then thanks!
    If you meant to say licky... do I know you?!?
    It's been over a year now, and I can honestly say I've really not found a reason to complain about this frame. It's carried me across the finish line of 2 endurance races (El Paso Puzzler 50 [ridiculously rocky and truly brutal,] and High Cascades100,) and all the training and riding in between.
    It's not really being ridden that much right now, because I'm readying myself for my first full cyclocross season since '01.
    That will change.
    At the end of the month, we're leaving San Antonio for Boise. As it happens, we were spending a month there when I received my frame, and built it.
    Expect some pics of the N9 with more mountain terrain, and hopefully lots more miles!
    Los
    Whiskey is my yoga.
    dongerparty.com
  96. #1196
    May 2012
    Has anyone built one up with around a $1500 budget. I'm very interested in building my first 29er with this frame, but am a little afraid that I'm looking at a frame that will make my build go way past my budget.
  97. #1197
    Depends on your component list and how good of a deal you can get. I think it's definitely doable. Just shop the classifieds here and on craigslist.
  98. #1198
    Basura Blanca
    While I've complained of the rear spokes loosening on my Charger Pros, that's been resolved since I've got them adequately tensioned. Other than that, my set has been pretty bomber under my 200 lbs. and I get no wobble from the wheel or rotor. Maybe fab up a run-out indicator and see where the wobble is starting?
    As to building your own wheel, if you decide you need a new hub, then I'd encourage you to give it a go. As others have suggested, it's not rocket science and you don't really need a tensiometer. Just do a good bit of reading up on it first, and go slowly.
    - Joe
    We rejoice in our suffering, knowing that suffering produces endurance, and endurance produces character.
  99. #1199
    Ride On
    NuMexJoe: I suspect the Pro's have a higher spec hub on them... I could have just gotten a lemon.
    Mutantclover: Great advice on a diy truing stand. Now I just need another 29er fork... I figure similarly on the DMR stem. Besides flipping a 30 degree stem (I don't even know if that is possible, plus it would look funny) I think this stem would be my best bet for getting those bars lower. Assuming a 15-20mm drop with the stem and the 12.5 mm drop of the flat bars I'm still looking at a grip height that is about 65mm (about 2.5") above my seat (at optimum pedal height.) I may just have to live with that, drop my forks to 100mm from 120mm (don't want to do that) or get some funky custom drop bar made!
    Regarding wheels and the rotor as suspect, I have a wood shop with a granite surfaced table saw. Its dead nuts flat and that rotor is too. Its definitely the hub. Its still ride-able just can't get the front brakes pads as close to the rotor as I'd like. As I'm sure many of you know its often not worth the time and trouble dealing with a warranty issue with a lot of these mail order's particularly large packaged items like this. Hence I'm seriously considering a set of the Canfield wheels, I can always use these with a different set of tires.
    Michael
    Ride on!
  100. #1200
    Pit Bull lover
    Reputation: AaronJ's Avatar
    updated
    Wheels are temporary and will be replaced this winter when funds allow, OR when somebody buys my I9s in the classifieds and I get a bit of extra cash. Seat goes up on trail rides, down for playing around on (think looooong manuals and air time). I tore it up on 20" bikes for years, and am now getting back into that "style" of riding.
    Behold, as it currently sits. Short stems and wide bars are the way to go, and I will never go back.
    ~RollingStoned~
    In Memory of all Pit Bulls Killed by Ignorance and Fear
    Typed with my thumbs=excus ethe typos
  1. Jones steel diamond frame or Canfield Nimble 9
    By Clink in forum 29er Bikes
    Last Post: 11-02-2012, 10:27 PM
  2. Canfield Nimble 9?
    By Professor in forum 29er Bikes
    Last Post: 09-23-2011, 08:17 AM
  3. Canfield One - building thread
    By jetmotor in forum All Mountain
    Last Post: 06-23-2010, 08:33 PM
  4. Canfield Bros Nimble Nine
    By Fly Rider in forum 29er Bikes
    Last Post: 03-24-2010, 07:39 AM
  5. Canfield Nimble 9 29'er, get your pedal on!
    By pajak in forum Canfield
    Last Post: 09-17-2009, 06:10 PM
Members who have read this thread: 88
