Results 1 to 13 of 13
    May 2018
    Bought Cube acid 2018 but 27.5 is it bad ?(feel so regret)
    Hi , i just bought brand new 27.5 18 frame cube acid 2018 but i see now 27.5 not good for hardtail.i feel so regret. I dont open the box, yet so i am thinking about sale or open box and ride and just fun. Is it optimistic or just sale 27.5 and buy 29er?Whats your opinion.Is 27.5 very bad compare to the 29er on the same bike how many percent difference is there between 27.5 and 29.
    Also I am 178cm(5'10) and inseam 78-80cm(31.5inch) cube acid is medium frame(18) , is it small for me
    Talk to the seller about getting a 29 in exchange now while the bike is unopened. Also get the correct size in whatever you end up with.
    27.5+/29 hardtails give you more tire width options going into the future than a straight 27.5.
    I wouldn't buy new without Boost sizing in the frame(12x148) and fork(15x110) to be able to use 2.5 and wider tires when I wanted to try them.
    May 2018
    Thanks for reply.
    I bought the bike while traveling abroad 1-2 month ago now and my own country so i cant not return the product or exchange
    i dont open the box because I planned to ride the bike in the summer and summer almost came.i just checked size from bike-discount site before buying it say
    Crotch height: 78-80
    Frame height: 18 inch corresponds 46 cm
    27.5 wheel dramaticly bad compare to 29er or there is a difference of 10-15% between them.I wacthed almost all 27.5 vs 29er compare videos and forum posts No one buy 27.5 hardtail unless short but i did experience... i do not buy never any 27.5 650b wheel.
    Sell it.
    You may as well assemble it a test ride it.
    Sizing depends on your inseam measurement in shoes plus your height with added consideration for your arm length if it's abnormal. Use a book against a wall to help you measure inseam distance. That model has a short cockpit reach measurement so a Large is likely your size unless you have long legs for your height.
    Feb 2016
    Ride the bike, itís in the ballpark for sizing, I do believe. 29ers are ok, but Iíd ride a 27.5 anyday. 29 is not the holy grail. Thereís tons of folks that love the 27.5.
    The smaller wheels accelerate faster, and they are more maneuverable. If you are riding technical terrain the 27.5 wheels will give you an advantage in terms of line picking and quick changes of direction.
    If you are dead set on bigger wheels, you might try a 29" wheel up front with a short fork. I'd go with a rigid fork if you went that route, but a suspension fork would work as well. The shorter the axle-to-crown distance on the fork, the less the geometry will be changed and you will benefit from some of advantages of a 29 inch front wheel.
    The steering will slow down a bit if you go with a smaller back wheel/bigger front wheel, but you get used it, and the increased rollover is nice.
    May 2018
    Thanks for all reply.All comments are valuable
    I will decide what to do.I just found cude acid 27.5 frame and 29 frame size chart.Cube frame 14-16-18(xs,s,m) coming 27.5, 17-19-21-23(m,l,xl,xxl) coming with 29er
    The Reach numbers are showing as low. That can give you a tight cockpit. Or require a long stem.
    An example is a Kona Honzo. S M L XL. Reach is 425mm 450 475 and 510mm.
    KONA BIKES | MTB | HONZO | Honzo AL
    You'd be a M in the Honzo.
    Reputation: vikb's Avatar
    The bike is in a box. Sell it. Get what you can for it and make a better choice going forward.
    My buddy bought a Chromag 275er hardtail and he loves it. I don't think you have to have a 29er for a hardtail.
    Safe riding,
    Vik
    www.vikapproved.com
    Dec 2014
    Meh, just go ride it. People are still having the time of their lives riding 26ers and that bike is a perfectly good MTB as far as hardtails on that price category go. Besides I don't think you will get significantly more money selling it as new in box vs. slightly used.
    May 2018
    Thanks for ideas, I contacted the seller and cube customer service,
    I gave all my body measurements and the result 18 frame is good for me.I will ride it maybe next bike 29er
    RAKC Industries
    Jan 2017
    Who cares about wheels size, it's pointless to worry about unless your an experienced rider that knows what they need for their specific riding.
    But ordering a bike not knowing what your proper fit is was a very big mistake. Never buy a bike online under you have a solid understanding of how geometry will fit you and what size you should be riding.
    Sent from my SM-G950U using Tapatalk
    Life on a bike doesn't begin till the sun goes down.
    US partner for Ravemen:
    www.rakclighting.com
    May 2018
    That's the point, i totally agree
  1. Replies: 2
    Last Post: 11-15-2015, 10:15 AM
  2. Cube LTD pro 2012 frame on Cube LTD 2010 bike
    By phoenix2012 in forum All Mountain
    Last Post: 07-22-2013, 12:30 PM
  3. Cube Acid 2011 crankset problem
    By njanos in forum Beginner's Corner
    Last Post: 07-27-2011, 01:01 PM
  4. Cube Attention and Acid
    By Mr C 77 in forum Bike and Frame discussion
    Last Post: 06-24-2011, 01:41 AM
  5. Trek 6300 v Cube acid?
    By daveleebrown in forum Vacations & Destinations
    Last Post: 05-25-2011, 05:14 AM
Members who have read this thread: 88
