Page 11 of 12 FirstFirst ... 789101112 LastLast
Results 251 to 275 of 278
  1. #251
    Mtn Biker Machinist
    Reputation: 1 cog frog's Avatar
    Dec 2004
    Quote Originally Posted by fab4 View Post
    Here's my Chinese 29er carbon with drop bars and set up as a rigid 1 x 10.
    This may be the curmudgeon in me talking, but that bike is gaudy to the point of being offensive to my eyes!
    I'm glad you like it, rock on! And before you get offended and neg rep me, remember: Opinions are like @$$holes, everyone has one, and they all stink!
    This is only MY opinion.
    frog
  2. #252
    Reputation: MMcG's Avatar
    Jul 2003
    16" Unit 29er with Pugsley fork up front:
  3. #253
    Reputation: Saul Lumikko's Avatar
    Oct 2012
    Here's my Titus Fireline Ti swoops downtube prototype by Van Nicholas from On-One. I made singlespeed forkends from 6 mm aluminum plate mostly by hand.
    Other parts include Pro carbon fork, On-One Midge bar, Avid BB7 + CC Drop-V, Fixie Inc. hubs, Notubes Crest 29er hoops, Nobby Nics at 2.35 wide run tubeless and a few Ritchey parts here and there. I have a carbon seatpost but I want to change the clamp to a wider one before making the switch. Also I feel that the fork is a bit short at 465 mm a-c (80 mm equiv.), so I ordered a Soul Cycles steel fork with 485 mm a-c, so the geometry will be like the frame was designed.
  4. #254
    Self-defeatist
    Reputation: CLONG's Avatar
    Nov 2006
    Quote Originally Posted by MMcG View Post
    Looks great MMcG!
    You're just a couple of changes away from hitting every niche in the book. Pop in a Pug wheel and throw on a fixed gear and we can start a Fatfrontfixxiedropbar29er thread!
    I'm covered in beer.
  5. #255
    Looking for a little technical help. Looking to convert my Singular Gryphon from SS to gears, while making use of parts I have lying around. Want to set it up 3 x 9, raceface mtb crank, shimano derailleurs, bb7 brakes. Can I set it up with brifters? I read some place that Shimano 10 speed brifters would work - this true? Any experience out there? All help appreciated.
  6. #256
    Mtn Biker Machinist
    Dec 2004
    Quote Originally Posted by chunkylover53 View Post
    If your BB7's are the road version, then road brifters will work. If they are the mountain version, the cable pull is different (think cantilever vs. v-brake levers), and they will not work well. Shifting should be ok as long and the deraileurs are Shimano.
    Pics of the current setup and the parts you want to use may help, of nothing else so we can see another cool Gryphon setup!
    frog
  7. #257
    Jul 2003
    Even more changes still:
    Reba up front and a Luxy Bar with Tektro brake lever set up.
  8. #258
    My buddy runs 3 speed shimano on his, but with a bar-end shifter on the left.
    Jeff's Bike Blog: Singular Gryphon Review
    I use 10 speed shimano on my Karate Monkey with Durace shifters.
    Jeff's Bike Blog: Durace 10 speed Karate Monkey
    A cx70 front derailler was a great addition. You dont really need 3 rings up front : )
    Jeff's Bike Blog: Drop bar set-up and STI on Karate Monkey
  9. #259
    1cogfrog, cousinmosquito - thanks for the info. I do have the road BB7s, so that should be good. I didn't realize the pull issue on the front, so something like the cx 70 might be workable. Actually building this up to be a bit of a gravel grinder - and while I am looking for some high gears (to keep up with folks on cross bikes), would also like some lower ones to get up some steep hills when things turn to single track. It's fat bike time here in Canada - so will look for needed parts over the winter.
  10. #260
    Nov 2012
    javascript:void(0);
  11. #261
    Nov 2012
    I really
  12. #262
    Nov 2012
    Like
  13. #263
    Nov 2012
    To post
  14. #264
    Nov 2012
    Some
  15. #265
    Nov 2012
    Pictures
  16. #266
    Nov 2012
    Of my
  17. #267
    Nov 2012
    Bike !!!
  18. #268
    Nov 2012
    Kona Unit MX Monstercross
    My Kona Unit, with Salsa Woodchipper bar wich I trimmed 1.5" each side and Schwalbe 1.35" Sammy Slick.
    I changed the 18 teeth rear cog for a 14 teeth one to make more speed and I changed the original stem for a shorter one for better positions with the drop bar.
    More upgrades will follow.
    Greetings Bas.
    Last edited by Bas Vermond; 11-15-2012 at 12:37 AM. Reason: Pictures were not visible
  19. #269
    ... Om ...
    Reputation: wv_bob's Avatar
    I should've cleaned it up and took better photos before cannibalizing it last week ...
    Attached Thumbnails Attached Thumbnails Bored? Post your Drop-Bar 29er!-img_6691.jpg
    Don't worry, don't hurry, never volunteer
    Canfield Nimble 9 * WTB Phoenix * Salsa Big Mama
  20. #270
    I Ride for Donuts
    Oct 2007
    My Ogre in winter mode...
    Attached Thumbnails Attached Thumbnails Bored? Post your Drop-Bar 29er!-picture1.jpg
    (no excuse for that either)
  21. #271
    Jul 2003
    Just some stem changes. Could still use about a 70x35 degree or 80x35 degree stem for this particular set up.
  22. #272
  23. #273
    Jul 2003
    Now a fork change
  24. #274
    Nov 2012
    I changed the saddle for a Brooks 232 professional " Alpe D' Huez.
  25. #275
    Soma Juice
    Here's mine:
    Attached Thumbnails Attached Thumbnails Bored? Post your Drop-Bar 29er!-image008.jpg
Hot Deals
Contests
Latest Mountain Bike Articles
