Results 1 to 26 of 26
    Bontrager Jones ACX TLR tire
    Can these tires be run on a Stans rim without sealant? I would be using the yellow tape. I think I heard that Shiggy was running some TLR tires dry. Not sure what tires or rim setup he was using for that though.
    Also, is the tire profile better suited for the Arch or the wider Flow?
    Powered by ice cream.
    Reputation: Enel's Avatar
    I have had an FR3 TLR tire mounted up dry on a Flow for a few weeks with no leakage. It was just a test mount, and I have not ridden the wheel at all, but it holds air fine.
    Quote Originally Posted by Enel
    Well, that's sounds encouraging at least. I just checked out the FR3 - wow, that's quite a tire! Looks like a good chunky freeride/AM tire. I'm currently running full on DH tires on my 26" trail bike and love em, but I'm trying to wean myself off of chunky tires. These 29's would be for a single speed, so totally the wrong application. Got ... to ... resist ...
    Vaginatarian
    I didnt try it dry but on flow rims with yellow tape and stans
    worked fine excellent grip soft sidewalls
    Sort of.
    I have been able to get them to seal up dry on both Stan's Arch w/ yel tape and Bontrager Rhythm w/strips.
    But they do leak down slowly( like a latex tube...1-2 lbs a day)
    I do run sealant in them....and always have a few little beads of white on the sidewalls and tread.
    Bottom line: pour in a little juice.If you're trying to save a few grams..just pull out your finger nails.
    My ACX TLRs had small pin holes in the sidewall that needed sealant. My XDX's seemed to hold air without sealant, but I never tried riding them that way.
    Full Tilt Boogie
    May 2005
    No tubeless set up is designed to be run without sealant. It's not recommended, won't gain you anything, and will nullify one of the main reasons people run tubeless in the first place, puncture protection.
    I sell bikes here. Check out the Blog here. Facebook.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by benwitt11
    Ummm...no. The original UST spec does not use sealants. Many tire makers recommend NOT using sealant. A good UST tubeless tire will loose pressure slowly when punctured by thorns (been there). I have never needed to fix a flat of a dry tubeless tire on the trail because of a puncture.
    Tubeless READY tires are designed to be used with sealants, but the puncture protection is still secondary to just sealing the casing to hold pressure.
    The main reason I use tubeless is the ease of swapping tires without needing to worry with inner tubes or mess with sealants.
    Bonty TLR tires are designed to be used with sealant, though I have found the Abrasion Resistance Casing versions to be good without in most cases. They are also designed to be used tubeless only on TLR or UST-spec rims, which the Stans rims are not.
    mtbtires.com
    Quote Originally Posted by shiggy
    Are there any aftermarket 29 rims that are TLR or UST? I'm pretty sure the UST is a no - pre-built wheelsets only. I don't know that I've ever seen TLR rims. Are they Bonty house-brand stuff only?
    Vaginatarian
    Quote Originally Posted by steiny
    I would consider Stans Flows and arches TLR and very good ones at that
    Dec 1998
    Bonty Duster and Race Lite TLR rims are available
    mtbtires.com
    Reputation: flat_chipmunk's Avatar
    Jun 2005
    acx
    Does it really matter if ACXs seal dry if they are crappy tires?
    IMHO they are.good for mud only as knobs fold/squirm on anything else
    Vaginatarian
    Quote Originally Posted by flat_chipmunk
    I dont know what version you tried but didnt have any issues like that on the 29" version. in fact they were one of the better gripping and rolling tires Ive used
    MTB B'dos
    Reputation: LyNx's Avatar
    OK, first to answer the OPs question.....yup, although not with the ACX, but had sucess with the MudX TLR, holds air fine without sealant on my Flows with yellow tape, better than tubes IMHO.
    As to the actual ACX tyre, not sure if there's a difference, but definitely can't say the 26" version impressed me any, very slow rolling although pretty good for mud. I prefer the MudX, it rolls fast and works really well in mud of all consistancies.
    Quote Originally Posted by dan0
    Nov 2006
    I love this tire = I run it tubless on a Arch rim
    Mudder
    Reputation: slalomnorth65's Avatar
    TLR ACX AR Casing?
    Does the 29 x 2.2" TLR Jones ACX have a pretty strong sidewall? (What bontrager calls the AR casing)
    Quote Originally Posted by slalomnorth65
    Yes, I have been trying to kill one for a year. Love it.
    JustRide44
    Reputation: rooster44's Avatar
    Jan 2009
    Really? Why is "ease of swapping tires" more important than puncture protection, or ability to run lower pressure?
    Vaginatarian
    Dude , it does NOT have the wear layer
    http://bontrager.com/model/02495
    Vaginatarian
    No it doesnt,
    http://bontrager.com/model/07573
    is the only 29" I can find that does
    My bad, my tire is the XR TLR. I can't find it on the website, but it looks like this.
    http://bontrager.com/model/02864
    JustRide44
    Jan 2009
    Aren't those the tires that came on the 1st generation Supefly? My buddy loves them for loose, ground up granite & pretty light eh?
    Dec 2008
    I just mounted a rear on a new set of bonti rythym pro and the seal really well. The rythym pros are TLR and i opted for the 20mm version.
    The 29-3 is a much better all rounder than the ACX better on the front in mud resists over steering much better, bigger volume for munching rocks and a better compound for sticking to wet rocks. Faster rolling to!!
    I'll be ordering a FR3 soon for full on Rock duties and Try trails soon to.
    Reputation: toddre's Avatar
    Slight Hi-Jack here, but can some one just tell me the story with 29/3 tires?
    Let's see if I get this right
    There are two, a front and rear. "Rear" being smaller with the "paddle" knob patern and the
    "front" having more of a center ""ridge" (for lack of a better word).
    Now the other thing is, are people using the "front" on both ends?
    How does it work on the rear?
    The FR3 is the 1 with the central ridge but you've got the rest right.
    The 29-3's long knob's basically give loads of turning bite more so than a ACX or WTB Stout out riding both on mud hugely.
    I have a 69er so I can only test on the front, don't think it would in Front 2.25 size make a good rear tyre for putting the power down. And wouldn't ride a tyre that small on the rear.
