• 08-18-2011
    subspd
    They just restocked all the FS 29ers. Just a heads up.
    I ordered the "base" XT/recon model to see what all the fuss is about. I'll post up my review once I get some rides in on it.
  • 08-30-2011
    subspd
    Wife likes it a lot. Very nice spec for the price. Noticed that it is heavy though. Especially in the rear where the rear linkage while beefy is heavy. My guess as I haven't got it on a scale yet is this is definitely a 30lb+ bike. Good thing she has a strong motor. I felt that the top tube is short for my tastes but I do have monkey arms, she how says she feels like it fits her great and gives her more control as she is not as extended out allowing her more use of her core and not just her arms if that makes any sense... I also couldn't stand how narrow the bars are 650mm, but they fit her narrow shoulders great. I like my 720mm Carbon Niner bar ;)
    Oh yeah and no heavy bob either! :thumbsup:
    I will get some more up to date pics as I have already converted it from a 3x10 to a 2x10 with a BBG bash guard.
  • 08-30-2011
    subspd
    Here it is with the bash guard.
  • 08-31-2011
    sport7
    cool
  • 08-31-2011
    AZ
    What is the weight?
  • 08-31-2011
    subspd
    Originally Posted by AZ.MTNS View Post
    What is the weight?
    Heavy... :thumbsup:
    Don't have a bike scale at home next time I'm at the LBS with it I'll throw it on a scale. But it is over 30lbs which is not good considering how light the rest of the spec is, this has to be a heavy frame. The wheel set is a crappy WTB as well and I am sure a couple pounds will be lost in the future with a wheel set and tubeless upgrade. Thinking the x9/Arch combo will work nicely for this budget build. I am also going to swap the front tire for something more aggressive I think I have a Kenda Nevegal 2.2 that would work well, except that it is also heavy. :madman:
  • 08-31-2011
    psunuc
    I just put together mine. I got the X0 setup and it looks like a great bike. I will weigh it and post up some pictures later on. I kept it how it came pretty much aside from Thomson seatpost/stem and carbon FSA bar. First (real) ride will be Friday.
    I did notice that some of the paintjobs looked shiny. Mine is matte black.
  • 08-31-2011
    psunuc
    I snapped a couple quick (not good) shots. I also weighed it, 28.4 on the button.
    Im not a weight weenie or racer, so if it would have said 35 it wouldnt have mattered. I think 28.4 is respectable though. I saw somewhere that the BikeDirect guy built one and weighed it; I think it was 28 something so my weight seems consistent. I think its a nice bike and I anticipate getting years of service from it. :thumbsup:
  • 08-31-2011
    subspd
    Just so I can give the right answer. Is it true there is no lockout on the rear RockShok monarch shock? I only see a three position switch none of which lock it out like a Fox.
  • 09-01-2011
    vizsladog
    the shock is a rt3 wich has 3 platforms like the fox. no platform,medium platform and max platform
  • 09-01-2011
    Slee_Stack
    For the cheap cost, a few extra pounds ain't a bad trade-off. Interestingly, I've added weight to my own bike with almost every component change I've made thus far. Weight be darned. I want comfort, traction, and good performance (drivetrain-wise) above all else. Well a good-looking bike too...
  • 09-01-2011
    avn06us
    Hello,
    Have a quick question about sizing on this bike.
    I am 5'8" and inseam is about 30 inches. I have tried other 29 niner bikes in Cannondale and specialized and medium size fits well.
    Would you recommend a Medium or Small in the Motobecane FS 29?
    Would you recommend the SRAM or Shimano setup?
    Thanks for your recommendation,
  • 09-02-2011
    psunuc
    Originally Posted by avn06us View Post
    Hello,
    Sizing a bicycle for someone over a forum is tough. This link helped me out when I was in your situation:
    Mountain Bike Size Calculator
  • 09-02-2011
    SLCBKR22
    Does anybody have an opinion about the brands on BikesDirect.com? I want to get a full suspension as a back up to my hartail 29'r and I can't justify dropping alot at an LBS. I've heard bad & good things about bikes direct brands/bikes but not sure if I should save for a name brand or just pull the trigger with BD. Any suggestions?
  • 09-02-2011
    CYCLEJCE
    They are most likely built by the same factory building the "name brand" frames. The rest is just components.
  • 09-02-2011
    floydlippencott
    Some people love them, others not so much love. My best advice is to test ride, there is nothing like a test ride.
  • 09-02-2011
    finny1999
    My opinion is the frame quality is at par with most big name bikes. The components are generally better for the money. While the service and warranty is good when/if needed it doesn't compare to what a lbs and big name manufacturer can offer. What you get really depends on expectations. If you can maintain your bike and understand that bikes and their parts may break when you use them there is good value. If you expect any problems you have to be covered by warranty and taken care of immediately shop at your lbs.
    If they offer this bike in an xl I'll more than likely buy one. Only reason I haven't yet is because the tt on the large is smaller than i would like. Nothing against the bike or brand itself.
  • 09-02-2011
    Natedogz
    Originally Posted by subspd View Post
    KHS got the cable routing right.
    Yes, yes they did. Motobecane looks nice except for the hideous cable routing on top of top tube!
  • 09-02-2011
    subspd
    Agreed but still it is a great deal of a bike. I agree about the top tube length I think I would ride a large just because of that. My wife likes her medium though and she is 5'10" we normally ride the same size but I just felt too cramped.
  • 09-04-2011
    cfgray
    Bikesdirect 29fs
    I am going to post this in the correct spot but wanted throw it out here. I just got my medium frame fs 29er from bikes direct and lost my job. So wife freaked out and i have to sell it. Brand new, had it built but have not ridden it yet. I would like to get the $1399 I paid for it. I am in NY.
  • 09-04-2011
    Ace5high
    Not sure why they do that either... I dont like the top routing.
    I cant help but think these look a lot like early Canzo's ...
  • 09-04-2011
    ShawnA
    Sorry to hear that, good luck with the sale.
  • 09-04-2011
    yungster
    Why don't you return it? I think you have some time after purchase.. just need to pay for shipping back
  • 09-05-2011
    cfgray
    Thats a good idea, I will contact them.
    I also questioned the sizing? I am 6' and inseam 31" , Chris put me on a medium?
  • 09-05-2011
    Motocrosser86
    ride reports??
  • 09-05-2011
    hefeweizan
    how's it riding now?
  • 09-05-2011
    Ace5high
    Originally Posted by Motocrosser86 View Post
    ride reports??
    Yes Yes report please!
  • 09-06-2011
    cfgray
    I went to the local shop that built for me and they crushed the box. So i will check with bikesdirect but i would understand if i cant return it. So here it is sitting in garage waiting for new owner.
  • 09-06-2011
    subspd
    I think many have been afraid to post ride reports because even in the Moto thread people blast anyone who says anything good about the bike.... :0
  • 09-07-2011
    psunuc
    I took the bike for one ride. It was on some difficult terrain and the bike performed well. (Insert normal praises). In time I will find things that I dont like as well as things that I really like; that is how it is for every bike I ride. I will post some updates as I get more miles on it.
    If you have 2k to spend on a bike, I suggest picking up the X0 or XTR package. You can't beat it bike for the money. :thumbsup:
  • 09-07-2011
    Ace5high
    Yeah, its prob the "die hard-on 26er's" on their red and white speshy's with matching jerseys ;)
    I should know I pass enough of these guys on the trails :lol:
    P.S. Sorry if you ride an S, long as your not a hard-on about it :p
  • 09-09-2011
    trojanfisherman
    Yeah. It is a good bike for the price. I rode for few weeks by now and it performed well. I changed my wheelset to stan crest and went tubeless with racing ralph (2.3)on the front and aspen(2.1) on the back and weighs around 27lb now. But chain broke twice already. I had to replace with another KMC 112 L but it turned out it was short!!! I had to take few links out of old chain and add them to new one. I know shimano make 116 L and sram makes 114l and 120l. I guess big frame requires longer chain. I compared with old chain, new KMC 112 l is two links short. Maybe I should have asked Bikesdirect to send me a new chain. It should not have been broken like that. It is a brand new bike.
  • 09-09-2011
    psunuc
    Congrats on your first post and welcome to the forum!
    Which 29er do you have (components, size, etc.)? Thanks for the help. :D
  • 09-09-2011
    trojanfisherman
    It's Motobecane Fantom FS 29er with sram x0.
  • 09-09-2011
    Ace5high
    Those KMC chains are crap IMO, Id just get a Shimano on there If I were you ;)
  • 09-10-2011
    subspd
    If you get a chance to get an exact weight that would be great as I am sure many will be considering a wheel upgrade to what you have.
  • 09-10-2011
    Delirious
    If I hadn't just bought a new bike this summer I would have jumped all over this. :( Does Moto have a trade in program :)
  • 09-10-2011
    STT GUY
    Originally Posted by bikesdirect View Post
    Yes
    framesets on the way with rear shock and Reba with thru axle
    price will be $1099 - so if someone has a fork they can ebay the Reba and be into the frame with rear shock at a very low cost
    Framesets will go on bikeisland in about 6 weeks or so
    BTW - we are super happy with these bikes and I know customers are going to be shocked with quality, ride, and value
    I will take a "surplus" Reba off anyone who buys a frame and fork wants to sell just the fork.
  • 09-12-2011
    mojoman
    does anyone have any experiance with the suspension design on the Fantom 29 FS. I am considering this for my next bike and don't want to make a big mistake on what I buy
  • 10-12-2011
    beungood
    Thank you
    however, some may like to know that soon we will have a $599 single pivot FS29er and a 4-bar link at about $699
    I feel it is important to get cyclists who are on a budget started and as you say "bring more people to the fold."
    When are these coming out? Any date? Are you considering 650B Fs Mountain bikes also?
    Jack
  • 10-12-2011
    beungood
    What size riders
    Originally Posted by JimmyD442 View Post
    My girlfriend purchased a small size. Packed well, tapered steerer, platform fork with lockout/ blowoff that works and platform rear shock. Good breaks and excellent mix of xt slx finishing kit. For $1400 shiped!? How can you find fault with that ? The frame is beautiful . Only drawbacks, hubs are cheap and bar could be wider .... But for $1400 !? Good job bikes direct way to challenge the big names on value !:D
    What size riders will the small size fit? I noticed th medium has a pretty high standover..
    Jack
  • 12-18-2011
    iamjolly123
    Hey, what size is that and how tall is your wife? i'm deciding between the medium and large.:)
  • 12-19-2011
    CLMcLovin
    I have the 29er Fantom FS and I'm 6' with 32" inseam. I went with a size medium and it fits me very well. The bike felt huge when I first got it but I was coming from a 26" that was a little on the small side for me. Now I sometimes wish I had a large so I could run a shorter stem. Mainly because I like the looks of the short stems. Like I said the medium fits great and is very comfortable to me. I did change the handlebars to the high riser Monkeylite carbon bars (680mm wide) and that made the bike feel more stable and more comfortable.
  • 12-19-2011
    CLMcLovin
    Heavy... :thumbsup:
    I went this route the first time and X.9/Arch combo is inexpensive and light but the rear X.9 hub is not a very good design in my opinion. The bearing on the brake side gave out just after a month of owning it. It's just a really small bearing on that side with no other bearings to support it. Luckily, Jenson refunded my money, no hassle. The front X.9 hub is fine though. I would go X.9/Arch on the front and Hope Pro II/Arch on the back. That's what I have for a spare set now. I ended up finding a deal on a set of Industry 9/Arch's that I run most of the time on our local trails with Racing Ralph 2.4 on front and Rocket Ron 2.25 on the back (both tubeless).
  • 03-11-2012
    sldpulr
    Any one know where to get just the frame?
  • 03-11-2012
    bryan_d
    If they ever get stock, it can be found at bikesdirect.com and bikeisland.com.
  • 11-25-2012
    stencil
    Interesting. I'm 5'10" with a 31" inseam. I'm coming from a 17" HT that I like to throw around, but I'm thinking the Medium 29er FS (which looks to measure out at a 18.5" seat tube length) would be the right move for me. Do you think I'd be better off with a Small instead of Medium?
    Also, they're offering the $1599 model with XT/SLX or X9. Leaning toward Shimano as that's what I've always used, but would I get more out of the X9?
  • 11-25-2012
    SonnyP
    I am 5'11 with a 31" inseam, slightly longer arms, and I have the 47cm Fantom 29er FS XT/SLX. The fit for me is perfect. I had to cut a couple inches off the seatpost, but once the seat was placed, everything fit perfect. The shifting is smooth and I have experienced no problems. The shifters allow you to shift with your thumb or fingers. I push myself on this bike and all it seems to do is want more. The confidence it gives can be dangerous.
  • 11-25-2012
    stencil
    Thanks - I heard back from them already (impressive on a Sunday) and they recommend the medium for me.
    Now... Is the xtr spec worth the extra $600? :)
  • 11-26-2012
    mojoman
    If you can afford the XTR, get it. The build on that bike is worth it, you just about get the frame for free for what they are charging.
  • 11-26-2012
    stencil
    So I made a bit of a left turn and ended up getting the Santa Cruz Superlight 29 R XC. My brother-in-law has one and I took it for a spin on his street and fell in love immediately. I love the low stand over position, the elevated chain stays, and it looks darn cool. Found a great deal on it so I didn't go too far over budget.
  • 11-27-2012
    29er Craze
    I have been looking at this brand. Nice selection of bikes. Does anyone have any feedback for this bike??
    2013 Motobecane FLY Team 29 Titanium
  • 11-27-2012
    AZ
    In the Motobecane forum, scroll way, way down.
    Motobecane - Mtbr Forums
  • 11-27-2012
    everything motorcycl
    Yeah if only it came frame and fork only. Maybe? All it says is that it has a Reba fork. Wonder if it is an RL or RLT?
    Otherwise it 'looks' really nice. Happy to see the tapered head tube and 20mm front axle.
    Contact them, they are real fast at getting back with emails!!! Seem like good folks, interesting business model. Most frames are made in Tawain or china with about a handful of mfg plants. I would GUESS motobecane basically spec orders their frames, then put stickers, then put components. Seems like they are about similar quality at about 15-20% less.
    bikenerds has some sick closeouts too. Big fan of the closeout stuff!
