Results 1 to 14 of 14
    Best Seatpost Clamps?
    By the end of my rides, my seatpost on my Stumpjumper always seems to have sunk just a bit. It's annoying. Do bolt clamps provide a better grip? Either way, what are best clamps available? I'm thinking of getting the Command Post remote adjust seatpost, so I'm thinking I might as well get a bolt clamp instead of a QR clamp. Right?
    Jan 2009
    thomson makes a super nice bolt-on and DK's are nice as well. The only reason to get a quick release would be if you didn't like the adjustable seatpost and went back to standard. In that case Syntace is probably the best or Salsa is another good option.
    I've got a Salsa quick release and it works great.
    1*14*29*2.1 & 1*1*29*2.4
    my salsa clamp works well...looks strong as and looks good too.
    Thanks for the tips on good brands. Any particular models from those you recommend?
    Missouri sucks...
    Reputation: Soupboy's Avatar
    OP - what size do you need? Generally speaking, bolt-on vs. QR clamps will serve more gooderer. Also, there are no 29er specific clamps, unless you're half Welsh half burro.
    Professional Amateur
    Quote Originally Posted by finch2
    Just like what everyone else is saying, Salsa FTW. Also you might want to check to make sure you have the right diameter seatpost clamp.
    Never Satisfied...
    Jan 2009
    No issues with my Thompson
    May 2010
    I propose HOPE...
    Great looks and perfect operation.
    turtles make me hot
    Reputation: NYrr496's Avatar
    I have the Syntace on my Stumpjumper. It doesn't slip and it has a plastic scraper type seal that keeps crud from getting down your seat tube. I like it.
    I like turtles
    Reputation: timjr21's Avatar
    hope
    I second the hope suggestion. Hope makes great stuff. Looks great, works even better..
    Feb 2006
    If you want to use a QR clamp, I think Salsa makes a nice one. Otherwise, if you just want to use a binder clamp... buy the cheapest one you can find. They all do the same thing.
    Nov 2008
    +1 Salsa
Members who have read this thread: 10
