Page 26 of 27 FirstFirst ... 16 22 23 24 25 26 27 LastLast
Results 626 to 650 of 665
  1. #626
    Anyone seen a Civilian Luddite 29er?
    Quote Originally Posted by newdee View Post
    Pulled the trigger and made the mistake of riding it home. Now i want it!
    You'll need to get a new one when or if they have come out.
  2. #627
    Nice!
  3. #628
    Reputation: newdee's Avatar
    Apr 2014
    Quote Originally Posted by SS Hack View Post
    I know. Its a small, and i'm roughly 5'10" and i didn't have an allen key to put the seat back up, so it was like riding a giant bmx, with a giant grin the whole way home.
  4. #629
    Apr 2014
    Whats the consensus on weight with this bike? Bone stock with pedals it weighed 26.8 lbs. Seems high as i think i saw some people quoting 26.X lbs for large sizes? Tires and wheels gotta go. Im hoping we can get it down to under 23.
    This bike has a pretty high front end. Has anyone swapped out the risers to a big sweep bar or alt bar? Photos?
  5. #630
    Mine weighs 25 with almost everything stock except Charger wheels and 690/790 gram tires tubeless. I can make it almost 23 even when I throw on Crests with lighter tires. The frame is 6+ pounds, so it'll never be that light. I happen to love the high front and the low risers feel perfect to me.
  6. #631
    Reputation: borbntm's Avatar
    I have had mine down to high 23/low 24 lb range but currently at 25.2 lbs with fatty 2.4 Conti. Mountain Kings rolling tubless on Stan's Arch EX wheelset. I am running a Niner Carbon flat top bar and an Easton carbon post at this weight (size large). I love the high front end with the 100mm rigid fork. Super comfortable and lots of fun to toss around.
  7. #632
    Mine is 23 even and I run tubes. Everything except frame, fork, and headset have been replaced. 1500g wheelset onboard. I could get to 22.3ish if I went tubeless. But I don't ride enough to make that worth it. To get to a solid 22 pound bike you will need to buy nice stuff. XO cranks and the like. No middle of the road stuff.
  8. #633
  9. #634
    Quote Originally Posted by alefak View Post
    My quick take:
    - The deal on Competitive Cyclist was smoking while it lasted consdiering a lot of folks nabbed the whole bike for the same price as just the bare frame.
    - The new frameset looks like a better rear dropout design (looks like less potential for slipping)
    - Not buying the "up to a pound" lighter statement.... the thing is a tank then, it still is in the new design
    - I wonder about the paint durability based on the fact they are using the same factory
    - I doubt I would spend $600 for the frame,... I think my price point would be closer to $475-525 for the bare frame (no HS, seat clamp, fork)
    - New colors don't do anything for me... then again.... I like white bikes....
    - I like the abilty to run a belt as its always interested me...and not that there is anything in a name... but the Luddite now has a full tapered carbon fork, machined head tube, BB30 shell, carbon drive drivetrain... about the only thing not current tech is the tubeset. Not complaining, its just funny.
    Stellar bike. I am not sure I will ever have a reason to sell mine.... but price point jumped up a bit too high at which point I wouild probabliy just get a Niner SIR.
  10. #635
    It's interesting how far up market they're trying to go. I love mine, but this is a stiffer and heavier type frame and I don't think the special "founder's blend" steel will change that much. The frame still looks burly. My $150 On One is smother and lighter.
  11. #636
    Apr 2014
    I agree. I also have an Inbred and there seems to be a pretty big contrast between the tubing. Although, its pretty hard to complain since we bought the Luddite for $400 and it was ridden about twice judging by the wear(or lack thereof) on the tires.
  12. #637
  13. #638
    Just converted mine to 1x10
    Attached Thumbnails Attached Thumbnails Anyone seen a Civilian Luddite 29er?-image.jpg
  14. #639
    Apr 2014
    Has anyone put a drop bar on one of these? The high front end seems like it would work well for that like a Fargo.
  15. #640
    If anyone still has the original truvativ GXP crank and bottom bracket, can you take a pic and post it of the drive side space between the chainring and the bottom bracket? I had mine apart and need to see what it should look like. For some reason I have about a 1/4" gap between the chainring and the BB now when I put it back together. Just want to make sure something is not messed up.
  16. #641
    Is there any play in the cransket? I can check mine tonight but i have removed reinstalled the crank multiple times and dont remember a space that that looks like that. I think if you installed wrong you would have play unless you did something like put wave washer on wrong side.
    I am still really enjoying this bike and while almost sold at one point I am glad I kept and am looking to turn it into more a bikepacking rig. iahve had it setup SS, 1x9, 3x9, and should have some leftover 1x10 parts to throw on soon.
    XC, Road, XXC, Endurance, Mtn, All-Mtn, Cross, Gravel, just go have fun on 2 wheels!
  17. #642
    No, with the gap its got zero play. Which is why I took it apart to remove play. The pic would be helpful. Thanks!
  18. #643
    Here are some pics:
    Anyone seen a Civilian Luddite 29er?-image.jpgAnyone seen a Civilian Luddite 29er?-image.jpg
  19. #644
    thanks that helps!
  20. #645
    thanks that helps!
    Glad to help....Crappy I pad pics best I can do right now, tight schedule today.
    Anyone out there waiting for the new updated bike to ship??
  21. #646
    Quote Originally Posted by borbntm View Post
    I don't mean to dig up an old thead, but I'm looking at buying a young turk 29. It is basically this luditte with the 1X10. I've never ridden a bike with these type of dropouts. Do they ever loosen while riding?
    I ride in Moab and really rocky terrain a lot and in my head I picture all the little screws and things for the dropouts coming loose over all the rocks and square edges.. I've read a lot on the Trek Rig where they have issues with the dropouts all the time
    Has this been a problem with anyone? Should I be worried or am I just being paranoid?
    What are your thoughts?
    Check out my riding blog:
    http://onetrailatatime.blogspot.com
  22. #647
    You know what, I hate to say it, because I L O V E my Luddite, but I have had a few issues with the axle slipping. I contacted Civilian and they offered some ideas for reducing the problem and it seemed to help, but it makes me nervous to this day.
    That said, however, this is one of the most fun bikes I've ever had. I love riding it and find it comfortable, predictable and it just leaves me with a great big smile every time.
    2004 Specialized FSR Pro
    2011 Specialized Stumpjumper Comp 29er
    Civilian Luddite 29er SS
  23. #648
    Quote Originally Posted by SpringsRubicon View Post
    Thanks for the Honest feedback. It looks like such an awesome bike, I'm just worried a little with all the rocks I ride on and the slippage I've been reading about on this thread.
  24. #649
    Still love mine too!! It is a fun bike! With the paint removed on the bolt side and the slider side.....No slippage and no worries! I'm running mine 1x10 and haven't touched the sliders in over a year. Just get the Allen bolt as tight as you can.
  25. #650
    Mine is rock solid. What cage detailer is that? No guide right?
