Results 1 to 14 of 14
    Anyone put an FSA DH Pig Pro headset in their Redline 29'er?
    Did ya have any prob getting the flange in the lower casing to seat fully? I'm wanting to put one in my D440 when the stock Cane Creek goes south (only a matter of time). This is one beefy headset! The prob I can see is, the flange is taller than the expanded area on the lower part of the headtube. I sure don't want to crack that headtube, trying to get that rascal to fully seat....
    Expert Crasher
    Reputation: GreenLightGo's Avatar
    I'd stick with a normal style headset - Cane Creek S3 would be ideal.
    Happiness depends more on the inward disposition of mind than on outward circumstances. Benjamin Franklin
    I have an S2 I could throw in there. LOL!....looks like a tinker toy, next to the DH Pro. But it'd probably do OK.
    TLL
    TLL is offline
    Reputation: TLL's Avatar
    By "expanded part" do you mean external butting? Should be fine.
    Best low cost HS on the market, period.
    Hadley rear hub service here and here.
    Reputation: bobbotron's Avatar
    Nov 2007
    Quote Originally Posted by TLL
    I really like the one I installed on my dambala a while ago.
    bhc
    bhc is offline
    I have one on an 05' Monocog, 26" wheels. Been on for over 3 years, no problems. Nice and tough with a rigid fork.
    I'm using a FSA Orbit XL II. Love it... smooth and rock solid. Cheap too. Might be a good FSA alternative.
    TLL
    TLL is offline
    Quote Originally Posted by racerdave
    Decent headset (I have used a few) but the Pig DH is so much nicer for around $10 more.
    TLL... Hmm, might have to give that one a shot if/when I need another. Thanks.
    My friend Daniel had one on his monocog, but it was an 06 or 07 29er. Those are bomber headsets.
    I'm talking about the part that gets pressed up into the headtube. You look at the D440 headtube, the little expanded area at the bottom of the headtube is 10mm high as far as I can measure. The part on the DH Pig, that gets pressed up into that expanded area, I measure as 14mm. It's that extra 4mm that has me concerned. Is that extra 4mm being hidden by the current headset?
    I have a Pig DH Pro on my 2008 D460. No issues, fits great.
    The consensus appears to be that I am overworking this, then. Thanks to all who responded
    Reputation: Reporterkyle's Avatar
    I have one on my Monocog 29er. Fits and works fine. Bomber headset.
