Results 1 to 6 of 6
    Anybody have problems with the wheels on their Tallboy LT?
    I went on my first ride on my new Tallboy LT today and had a fall that resulted in my front wheel potato chipping. I was thinking it was all my fault for failing on the nasty little climb I was on. When I got home I pulled the wheel off, removed the tire and tube and started to look to see if I might be able to true it back up. That was when I noticed that the joint in the rim partially separated. Now I am thinking that the rim may have bent because it was defective. I fell because I stalled out on the climb, so it's not a case of going fast and tweaking the wheel.
    Anybody else had an issue with the WTB i23 rims?
    Reputation: Simpledesign's Avatar
    Re: Anybody have problems with the wheels on their Tallboy LT?
    ST or Team Rim? The ST is not an I-beam wheel. It should still hold up to some normal trail abuse but just a thought.
    Sent from my Samsung Galaxy SIII using Tapatalk 2
    '12 Trek Marlin Signature Green
    '13 Santa Cruz Tallboy LT Gulf Blue/Orange
    Mine are fine with a few dings after almost a year of abuse. Still holding up with tubeless. Talk to your lbs first and foremost...
    ST rim. If the joint hadn't separated I would just chalk it up to bad luck. Th joint issue makes me think defective rim. I will go to my lbs and see what they say.
    EMBA Member
    Reputation: Ladmo's Avatar
    Jan 2013
    I have this setup on my tallboy. Lots of scrapes and other wear marks all over them and still running perfectly true as far as I can tell. Coming up on one year of use.
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    sounds like you just hit it right. you don't have to go fast to tweak a wheel.
    I don't follow the separated joint to a conclusion of defective wheel. Rim joints often dislodge or separate in a failed wheel.
    What's your thinking?
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
  1. Tallboy rear skewer problems...???
    By bowler1 in forum Santa Cruz
    Last Post: 02-07-2013, 10:13 AM
  2. Upgrade stock Tallboy wheels?
    By jabrabu in forum Wheels and Tires
    Last Post: 11-21-2011, 07:37 PM
  3. Opinions on stock Tallboy wheels
    By jabrabu in forum Santa Cruz
    Last Post: 08-07-2011, 02:11 PM
  4. Replies: 22
    Last Post: 07-01-2011, 01:08 PM
  5. Replies: 4
    Last Post: 05-17-2011, 07:39 PM
