Results 1 to 16 of 16
    Any way to add a rack onto a Access frame?
    Hi there, I have a Performance Access 9.7 2010, and I've been wanting to do some touring on it. It's a great bike, almost as fast as my carbon frame schwinn peloton on the road, so Im completely satisfied with it. I mostly use it with slick tires for commuting on the roads, and I sometimes go to the mountains for the trail riding and i just put on some treaded tires.
    But now that I'm considering doing some long distance backpack riding, I am thinking of getting a different bike for this just because the Access 2010 frame does not have the holes to put a rear rack on it. Is there any way I can drill some holes in it to put the rack in it or am I going to damage the integrity of the frame?
    I was considering buying this REI Novaro Matador:
    http://www.rei.com/product/807239
    What do you think about this? Do you think this would be better for long distance touring than my access 9.7, or are the parts a lot worse. Am I better off just buying the frame for the Matador and just moving all the parts from my Access 9.7 onto the matador frame?
    Also, separate topic but I just bought a book on a Lance Armstrong biking workout program that was on sale at Barnes and Noble and it said something that made me a bit sad, it said that aluminum frames are stiff and light but the disadvantage is that they will only last about 5 years before they break. Is this true, or is that only for road bikes? If I do get another bike, do I need to get a steel or titanium frame if I want something that will last much longer (20+ years?).
    Thank you all for the help.
    Mar 2011
    check out the Freeload racks, they are perfect for bikepacking adventures and will work on ANY MTB, front or rear
    http://www.freeload.co.nz/
    Thanks for the link, the only problem is it only supports 25 kg, that is only 12 pounds so that's not enough to hold enough gear for a long trek. The racks that bolt to the frame hold like 50 pounds i believe.
    Reputation: TwoHeadsBrewing's Avatar
    1. Seat clamp rack mounting: Here's one for $10
    2. DIY P-clamps and stainless bolts from the hardware store. Some of the p-clamps are rubberized so they'll grip the seat stays and not mar the paint. Like these
    Ah, these ones by Nitto look better than a hardware store cludge.
    3. Tubus makes a kit also: Seat stay mounting clamp bracket
    "Got everything you need?"
    So these parts attach to the bike and they work as the holes I can bolt the seat into?
    Mar 2011
    Quote Originally Posted by grossen
    The conversion is the other way, 12 kg is 55 libs
    Quote Originally Posted by edsterra
    Oh yes i forgot, thank you for correction.
    Reputation: seat_boy's Avatar
    I believe the Access already has upper and lower eyelets (at least, mine did). A pair on the wishbone seatstay, and another down in the dropout.
    Reputation: Minimalist's Avatar
    Quote Originally Posted by seat_boy
    Mine too.
    Bloated Cubs Fan
    Reputation: waterdude's Avatar
    Jun 2010
    Mine too.
    I said, "Do you speak-a my language?" He just smiled and gave me a vegemite sandwich...
    Okay I suppose there is eyelets in the dropouts, but I don't see any on the seatstay, are they hard to find?
    Bloated Cubs Fan
    Jun 2010
    Click on the thumbnail. I imagine yours is the same.
    Former Bike Wrench
    So did mine
    Reputation: OmaHaq's Avatar
    Jun 2010
    Old Man Mountain racks work on about everything...
    Nature Rider, Not MTBer
    Reputation: Plim's Avatar
    Dec 2004
    Quote Originally Posted by waterdude
    That's what my Access frame looks like. I've got a rack bolted to the frame right now, with panniers on the rack.
    This is no time for levity. - Oliver Hardy
    Trail Junkie
    Reputation: dubdryver's Avatar
    Mar 2006
    I actually built a bike rack for my Santa Cruz Blur a while back. I got everything from the hardware store with the exception of the actual bike rack. I used 1/8" aluminum strips that I drilled holes big enough for the skewers, and more that tied into the clam further up the seat stays that formed a "U" that the bike rack connected to. The rack was actually very strong, and I loaded close to 40lb onto with the panniers. I was concerned about the shock giving out because I tacked on an extra 60lb to my bike load but it took it. To top it off, my dad thought he would be clever and have a cool trailer. I ended up towing that as well for nearly all the climbing, but he just started mountain biking a few months before.
    If you are looking for a DIY for one, or for anything for that matter, check out www.instructables.com
    Ibis Ripley LS
    Intense Spider 29 C
    Cervelo S2
    Trek Boone 5 Disc
    Spech Tricross Expert
    Raleigh RX 1.0
