Results 1 to 48 of 48
    Reputation: simenf's Avatar
    Nov 2008
    Any plans for a 29er Maxxis Crossmark in 2.25?
    The 2.1 tire is great, but I really would like some more width and volume in the tire I use for most of my riding (marathons, trails, gravel, road and more). Bigger is better!
    Anyone knows of any plans to beef it up? A tubeless version too, maybe?
    Always Learning
    Reputation: BruceBrown's Avatar
    Quote Originally Posted by simenf
    Contact Maxxis and let them know your desire for a wider version of the Crossmark.
    Nov 2008
    I have done, and they just refer me to my local importer (which obviously has very little impact with Maxxis).
    Therefore, hoping that more people will show interest and someone from Maxxis will read this and do something about it...
    Come on - show yourselves :-)
    11 is one louder than 10
    Reputation: Green Giant's Avatar
    would love one... with a tubeless bead (like the bonty TR's)
    "The thing is, Bob, it's not that I'm lazy, it's that I just don't care."
    Reputation: blooper's Avatar
    I would also like to see a 2.2 or larger. Sometime Maxxis tires are not as wide as stated on the tire.
    Ride it like you stole it!
    Reputation: Davidcopperfield's Avatar
    Real 60mm Crossmark +1
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by blooper
    All the new models are pretty much as stated especially if you look at the (modified) ISO size.
    ie Ardent 29x2.25, 54/56 - 622 (casing/tread-bead seat diameter). Actual width: Casing, 54.5mm / 2.15"; Tread, 56.8mm / 2.24".
    mtbtires.com
    bog
    bog is offline
    I'd be all over that. I love the Crossmark for anything but slick trails but find the volume on the small side for sure. I think mine measures in under 2" wide.
    Tallboy3c : Stigmata2 : Hightower LT
    Always Learning
    I think they will certainly listen.
    I would think if enough riders believe that a Crossmark in a wider version would be an improvement and result in increased performance (and of course sales), they would entertain the concept. Again, I haven't ridden the Crossmark so cannot say.
    BB
    Expert Crasher
    Reputation: GreenLightGo's Avatar
    Try the Maxxis Ardent - it rolls surprisingly well. Having used both, I'd say you won't be disappointed.
    Happiness depends more on the inward disposition of mind than on outward circumstances. Benjamin Franklin
    veldrijder
    Reputation: jmoote's Avatar
    The Ardent has the volume, and rolls faster than it looks but it still rolls nowhere near as fast as a Crossmark, and more importantly the handling traits are entirely different as the Ardent really wants to be thrown into a corner rather than carving through the apex. I can appreciate the Ardent for what it is, but it didn't stay on my bike for more than a couple rides... I just can't get a feel for it in the corners.
    bog
    bog is offline
    I currently run an Ardent up front & a Xmark out back
    I love that combo because I can really jam the front end into corners and let the back end come around with it. When the trails get some more moisture I'll try an Ardent on the back but I'd love a bigger Xmark to provide a bit more balance front to rear when weighting the front end through corners. As it is right now I have to weight the back end a touch more than I'd like. I just really love how well the Xmark rolls AND hooks up so a bigger one would be great.
    Quote Originally Posted by GreenLightGo
    what a joke
    Reputation: ozlongboarder's Avatar
    I just put the 2.25 crossmarks on my 26er....its like a new bike, Roll fast and grip is phenomenal. Would love some 2.25s for my karate monkey.
    Is there a specific email address we should be sending the request to?
    blah blah blah
    Nov 2008
    How to contact Maxxis
    I had the same experience going up one size - it made the bike so much better.
    Cannot find an email address, but the contact form works.
    Everybody who wants a bigger Crossmark (2.25), please write to Maxxis! Together we can do it!
    I have yet to take off my 2.25s racing ralphs with the snake skin sides. I weigh in a hefty 190lbs run tubeless at 20 or below front and back and grip everything up or down. That would be my thought on that.
    May 2005
    I will take a 2.25 Crossmark and Larsen TT please!
    Nov 2008
    Reply from Maxxis today:
    "Simen, Have you checked out the Ardent 29 x 2.25 yet? It's a great, fast rolling tire and so far those that have ridden it have given us great feedback. I realize it's not the Crossmark but it's the best we got for now. We'll see what we can do about the 29er version. It can't hurt to hear that people are looking for it though! Best Regards, Maxxis-USA"
    Recovering
    Reputation: jbogner's Avatar
    The Ardent 2.25's are wicked fast rollers- as fast as Crossmarks but the more open side tread offers even more traction on dirt.
    I was running the Ardent 2.25 front / Crossmark 2.1 rear combo for a while...
    Former New Yorker, now in Fort Collins
    http://www.nycmtb.com
    Quote Originally Posted by jbogner
    Sorry but I can't agree to the Ardent being anywhere near as fast as the Crossmarks. Here is why: The crossmark has less volume which requires I run more air pressure... hence less RR. The Ardent has much more volume and is pressure sensitive if you try to get max performance. (Grip and ride quality) For me the magic pressure for the Ardent is 28-30 whereas I run the crossmark @ 36-38 lbs. From my driveway and trail tests there is no comparison between the RR of the 2 tires. With that being said I like both tires but each has it's own character with the Ardent edging out the crossmark for everything except RR.
    I would love to see a 2.25 Crossmark!
    What's "social pace?"
    Quote Originally Posted by flyag1
    Higher pressure doesn't mean less RR in off-road conditions.
    Recovering
    And a 2.25 Crossmark would have more volume and require lower pressure just like the 2.25 Ardent. That's the whole point in running a larger tire. Why would you want a larger volume tire only to run it rock hard?
    Reputation: BlueMountain's Avatar
    Nov 2006
    Let's not simply get a bigger LUST Crossmark. I used both 26er sizes. The small one was not that good and the 2.25 is better but not that good for loose conditions. Still, it is a fast roller that isn't a Racing Ralph fast but a bit tougher. The 2.25 is heavy for a XC tire with such a shallow tread depth.
    Keep it TLR and maybe offer it in two 29er sizes- 2.0 and 2.2. Keep the weight of the 2.0 around 700 and the 2.2 around 800 if possible.
    Map Maker
    Reputation: cbchess's Avatar
    +1 count me in!
    bigger Crossmark please!
    Richmond, VA
    Ra-MORE mtb club
    I think we can all agree that tread pattern has less impact on trail bite when we drop pressure. (e.i. low pressure = increased tire patch = increases traction) So a 2.25 crossmark should have enough volume to allow for lower pressure which will result in better traction and ride comfort.
    Therefore the extra rubber (weight) of the Ardent tread pattern over the crossmark is not necessary and only serves to increase weight and RR. Maybe we would give up some traction or trail bite, but I don't think the extra traction is proportionate to the additional weight. Look at the nbr of peeps rolling slick 29er tires and read their reviews.
    At 200 plus lbs there is just not enough volume in the 2.1 crossmarks to protect my rims unless I run higher pressure... whereas a true 2.25 would allow low pressure.
    Maybe the Aspens are my fix, but where are they?
    meh on the crossmark
    now a 2.25 monorail would be sweet
    Expert Crasher
    The 29x2.1 Aspens won't have any more volume than the 29x2.1 Crossmark. They'll be out after I-bike some time.
    Nov 2008
    I hope they will add some sidewall protection too. It's really exposed on the 2.1 and easy to tear..
    ol'guy who says hi &waves
    Reputation: fred-da-trog's Avatar
    Oct 2003
    Put me down as another vote for a larger Crossmark.
    I may not have the best of everything, but I have the best everything that matters.
    Put me on the list for Crossmark 2.25 as well.
    Nov 2008
    Any rumours about?
    Supersonic Garfield
    Reputation: Trond's Avatar
    Put me on the list for a pair of Crossmark 2.25
    Me too.
    Me too
    Reputation: ndbike's Avatar
    Jun 2005
    I'm in for a 2.25 Crossmark too. And while the folks at Maxxis are at it they could beef up the sidewalls just a little bit on the future 2.25 Crossmark and on the current 2.25 Ardent.
    Reputation: slip20's Avatar
    yes
    crossmark 2.25 for me, please.
    Full Tilt Boogie
    May 2005
    For any new tires to excite me they really need to have true tubeless beads. Ghetto really doesn't do it for me. I'd love a 2.25" Crossmark that has a TLR bead.
    I sell bikes here. Check out the Blog here. Facebook.
    Reputation: bholwell's Avatar
    Oct 2007
    On behalf of Maxxis I'd like to say that we really value our customer's feedback. While I cannot comment on what may or may not be in the works for 2010, please know that we truely listen to every contact submission form, and are completely behind the 29" wheel format.
    Stay tuned next year for some very exiting new tires!
    Tire Design & Development Engineer. The opinions expressed in this forum are solely my own.
    Expert Crasher
    Quote Originally Posted by bholwell
    Good news!
    never ender
    Reputation: fat_weasel's Avatar
    Jan 2005
    Big fan of the 2.1 Xmark. A 2.25 with 60a rubber would be even better.
    I want a 2.25 Larsen TT
    Reputation: murtaghstyle's Avatar
    2.25 crossmark could be quite cool in the front.
    I was just looking at the Maxxis E-store and noticed this:
    https://www.shopmaxxis.com/b2c/
    TB96699000
    29x2.25 CrossMark Foldable 70a 620g
    47.00
    47.00 USD
    In Stock
    Gross Amount 47.00 USD
    Is this just a typo or did they release this without anyone (me) knowing?
    I bet it's a misprint. But if you want to order one and let us know if in fact it is 2.25, please do.
    RIDE MF RIDE,
    Scotto
    Oct 2007
    Quote Originally Posted by joncmack
    Sorry, it's a typo. If you google the part number, you'll see that it's the 29x2.1 model.
    Well, since Maxxis seems to be listening, here is another vote for a 2.25 Crossmark with a TLR bead. And a 2.25 Aspen, same bead.
    Thank you, Santa!
    Whining is not a strategy.
    Only interested if they have a Tubeless-Ready bead. IF TLR, I'll take six in 2.25 to start with. I liked the 26er version in 2.25.
    Reputation: PuddleDuck's Avatar
    2.25 xmark for me.
    sticky tread compound option too
    wider + TLR = really happy dedicated Maxxis customer
